Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,064 Location Upstate, NY Feb 16, 2013 #1 Some years ago, I got tired of the numerous security vulnerabilities in Adobe Reader. At the time, I also wanted a program with a smaller footprint and no added toolbars. My choice was, and still is, Sumatra PDF. One comment about SumatraPDF is that many people do not care for the bright yellow background. If you don't like the yellow background, it can be changed to the color of your choice. It is simple to change the yellow background to the color of your choice. See how in my blog post at Replacing Adobe Reader with Sumatra PDF.
Laxer Co-FounderSenior Administrator Staff member Joined Feb 20, 2012 Posts 4,002 Location Portland, OR Feb 16, 2013 #2 I just use google chrome and drag the PDF files in... Works like a charm! :thumbsup2:
AceInfinity Emeritus, Contributor Joined Feb 21, 2012 Posts 1,728 Location Canada Feb 16, 2013 #3 I haven't even installed anything, while using Windows 8 I don't mind the Microsoft PDF reader. If I didn't have this snap feature, then I probably would have installed a program, but there's no need now.
A Guy Righteous Dude Joined Jun 2, 2012 Posts 1,077 Location Bay Area Peninsula Feb 16, 2013 #4 Been using Sumatra for several years. I have Foxit portable should I need to anything more. Nitro is also highly rated. A Guy
jcgriff2 Co-Founder / AdminBSOD Instructor/ExpertMicrosoft MVP (Ret.) Staff member Joined Feb 19, 2012 Posts 21,541 Location New Jersey Shore Feb 17, 2013 #5 No problems with Adobe Reader here. I do get rid of the various garbage Adobe apps included with it.
Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,064 Location Upstate, NY Feb 17, 2013 #6 It isn't problems with Adobe Reader, rather it is that it is a target for malware writers. Although not a large a target as Java, the security vulnerabilities in Adobe products seem to be never ending and patching is poor.
Tekno Venus Senior Administrator, Developer Staff member Joined Jul 21, 2012 Posts 7,203 Location UK Feb 17, 2013 #7 I use Adobe Reader XI and Adobe Acrobat X Pro. It annoys me that Adobe don't update Acrobat the same as Reader and for me to upgrade from Acrobat X Pro to XI Pro would cost $200. No way am I paying that. I keep Reader as updated as possible, but Acrobat X is updated as it's gonna get, they've stop pushing security updates for it.
T Teaplease Contributor Joined Mar 19, 2013 Posts 57 Apr 21, 2013 #8 Yep,been using Sumatra Portable for some time & can't fault it.
Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,064 Location Upstate, NY Apr 21, 2013 #9 Same here, Teaplease, even when there is an indication that Adobe Reader is required. Sumatra PDF works just fine.
T Teaplease Contributor Joined Mar 19, 2013 Posts 57 Apr 21, 2013 #10 Corrine said: Same here, Teaplease, even when there is an indication that Adobe Reader is required. Sumatra PDF works just fine. Click to expand... I uninstalled Adobe from the outset & installed Foxit,but I seem to remember once when I updated it,it wanted to install some toolbar or something that put me off anyway.As I'd read good reviews of Sumatra I went with that. I always use portable versions of software too,if available.
Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,064 Location Upstate, NY Apr 21, 2013 #11 Foxit added the Ask Toolbar.
A Guy Righteous Dude Joined Jun 2, 2012 Posts 1,077 Location Bay Area Peninsula Apr 23, 2013 #13 Irony is...it didn't ask A Guy
T Teaplease Contributor Joined Mar 19, 2013 Posts 57 Apr 23, 2013 #14 ha...but it sure got an answer!
U usasma Retired Admin Joined Feb 20, 2012 Posts 2,126 Apr 26, 2013 #15 I've used Foxit for years - over time I've come to be disappointed by it. Too lazy to switch, but this topic is causing me to reconsider trying Sumatra Thanks all!
