P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 17, 2021 #61 No. Reboot the machine. Perform the instructions in message #59 again.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #62 It seems to me it has not been changed. Attachments SearchReg.txt 1.9 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 17, 2021 #63 Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment fixlist.txt and save it to your desktop. Right-click on FRST64.exe and select "Run as administrator". Press the Fix button. The tool will now process fixlist.txt. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from. Post the logfile Fixlog.txt as attachment in your next reply. Attachments fixlist.txt 1.4 KB · Views: 2
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 18, 2021 #64 Done. Attachments Fixlog.txt 3.5 KB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 18, 2021 #65 Try to install KB3071756 only and report the result. If it fails copy the file c:\Windows\Logs\CBS\cbs.log to your desktop, zip and attach it to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 18, 2021 #66 As always. Attachments CBS.rar 872.5 KB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 18, 2021 #67 Install Update with DISM Download the update MSU here: https://download.microsoft.com/down...6F4-F4928818C9A4/Windows6.1-KB3050265-x64.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand Windows6.1-KB3050265-x64.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3050265-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Right-click on the Command Prompt window and click Select All, this will invert all of the colors by selecting the text, now press enter. All of this text is now copied. Paste (Ctrl+V) it into your next post. Zip and attach C:\Windows\Logs\CBS\CBS.log
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 18, 2021 #68 Thanks! The operation completed successfully. Attachments CBS.rar 10.1 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 18, 2021 #69 Try to install KB3071756 only and report the result. If it fails copy the file c:\Windows\Logs\CBS\cbs.log to your desktop, zip and attach it to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 18, 2021 #70 It is a spelled update. Attachments CBS.rar 12.7 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 19, 2021 #71 Install Update with DISM Download the update MSU here: http://download.windowsupdate.com/d..._b1aab0ef3752c52636409b50eb7853f645859e78.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand windows6.1-kb3071756-x64_b1aab0ef3752c52636409b50eb7853f645859e78.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb3071756-x64_b1aab0ef3752c52636409b50eb7853f645859e78.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Right-click on the Command Prompt window and click Select All, this will invert all of the colors by selecting the text, now press enter. All of this text is now copied. Paste (Ctrl+V) it into your next post. Zip and attach C:\Windows\Logs\CBS\CBS.log
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 19, 2021 #72 The operation was completed successfully but required restarting. After restarting the system had to be recovered. Attachments CBS.rar 311.8 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 19, 2021 #73 Check Windows Update and post a screenshot of all important updates.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 19, 2021 #75 Install Update with DISM Download the update MSU here: https://download.microsoft.com/down...-6388FF7968AD/Windows6.1-KB3065987-v2-x64.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand Windows6.1-KB3065987-v2-x64.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3065987-v2-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Right-click on the Command Prompt window and click Select All, this will invert all of the colors by selecting the text, now press enter. All of this text is now copied. Paste (Ctrl+V) it into your next post. Zip and attach C:\Windows\Logs\CBS\CBS.log
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 19, 2021 #76 The operation completed successfully.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 19, 2021 #77 Great. Install Update with DISM Download the update MSU here: https://download.microsoft.com/down...EA0-BEB0B90C2099/Windows6.1-KB3075851-x64.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand Windows6.1-KB3075851-x64.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB3075851-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Right-click on the Command Prompt window and click Select All, this will invert all of the colors by selecting the text, now press enter. All of this text is now copied. Paste (Ctrl+V) it into your next post. Zip and attach C:\Windows\Logs\CBS\CBS.log
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 19, 2021 #78 The operation completed successfully.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,650 Apr 20, 2021 #79 SFC Scan Click the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following commands into it, press enter after each. Code: sfc /scannow Wait for this to finish before you continue Code: copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" This will create a file, cbs.txt on your Desktop. Please attach this to your next post. Note: if the file is too big to upload to your next post please upload via a service such as Filedropper or One Drive or WeTransfer and just provide the download link.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 20, 2021 #80 Done. Attachments cbs.txt 907.2 KB · Views: 1
