P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 6, 2021 #41 Attach the file C:\Windows\Logs\CBS\CbsPersist_20210405002405.cab to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 6, 2021 #42 Changed to .rar Attachments CbsPersist_20210405002405.rar 4.1 MB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 6, 2021 #43 Boot your computer into a Clean Boot state following these instructions: How to perform a clean boot in Windows. After that, check Windows Update again. Post a screenshot of the available important updates.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 16, 2021 #45 Try to install Internet Explorer 11 x64 for Windows 7
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 16, 2021 #46 I've just tried. After installing and restarting the system had to cancel all the changes.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 16, 2021 #47 Attach the zipped cbs.log to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 16, 2021 #48 Done. Attachments CBS.log 7.7 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #49 Try to install this update: Download Update for Windows 7 for x64-based Systems (KB2990214) from Official Microsoft Download Center
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #50 As often in such a case, most of .exes are not running after installing that. I've had to recover my Windows.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #51 As often in such a case, most of .exes are not running after installing that. Click to expand... I don't see why that would happen. Try to install KB890830 and report the result.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #52 Error code: 80070241 P.S. It was successfully installed at the second attempt. Last edited: Apr 17, 2021
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #53 As you currently have IE10, try to install KB3124275
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #54 It has been installed successfully.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #55 Great. Try to install KB3071756 only and report the result. If it fails copy the file c:\Windows\Logs\CBS\cbs.log to your desktop, zip and attach it to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #56 Failed. Had to recover. Attachments CBS.rar 920.9 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #57 Remove Update Manually Click on the Start button and in the search box, type Command Prompt. When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following command into it, then press enter. wusa /uninstall /KB:4040980 Let me know if it says it was successful or if there are any errors.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,614 Apr 17, 2021 #59 FRST Registry Search Click the Start button and choose Control Panel. In the upper right corner ensure the View by: is set to Category. Select the Programs group. Click the Turn Windows features on or off link. This will bring up the Server Manager dialog. Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps. You can minimize it if you wish but keep it open. Right-click on the file FRST64.exe and choose Run as administrator. Copy and paste KB4040980 into the Search box and click the Search Registry button. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply. You may close any remaining open windows now.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 17, 2021 #60 Should I delete all these items in the registry? Attachments SearchReg.txt 1.9 KB · Views: 1
