C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 2, 2021 #21 I've changed its extension into .rar because .cab is not allowed here. Attachments CbsPersist_20210323213426.rar 3.6 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 2, 2021 #22 Attach the file C:\Windows\Logs\CBS\CbsPersist_20210323183814.cab to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 3, 2021 #23 I've changed to .rar. Attachments CbsPersist_20210323183814.rar 4.2 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 3, 2021 #24 Remove Update Manually Click on the Start button and in the search box, type Command Prompt. When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following command into it, then press enter. wusa /uninstall /KB:2789645 Let me know if it says it was successful or if there are any errors.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 3, 2021 #25 It says: "KB2789645 update is not installed on this computer"
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 3, 2021 #26 FRST Registry Search Click the Start button and choose Control Panel. In the upper right corner ensure the View by: is set to Category. Select the Programs group. Click the Turn Windows features on or off link. This will bring up the Server Manager dialog. Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps. You can minimize it if you wish but keep it open. Right-click on the file FRST64.exe and choose Run as administrator. Copy and paste KB2789645 into the Search box and click the Search Registry button. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply. You may close any remaining open windows now.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 3, 2021 #27 Done. Attachments SearchReg.txt 116.2 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 4, 2021 #28 Step 1: Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment fixlist.txt and save it to your desktop. Right-click on FRST64.exe and select "Run as administrator". Press the Fix button. The tool will now process fixlist.txt. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from. Post the logfile Fixlog.txt as attachment in your next reply. Step 2: Restart the machine. Check Windows Update again. Post a screenshot of the important updates available. Attachments fixlist.txt 111 KB · Views: 2
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 4, 2021 #29 Here it is. Attachments Fixlog.txt 233.2 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 4, 2021 #31 Try to install KB2836942 only. If it fails attach the zipped cbs.log to your next reply.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 4, 2021 #32 I used to install it many times but it constantly became uninstalled. I'll try again. P.S. Installed successfully.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 4, 2021 #33 Next, try to install KB3060716.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 4, 2021 #34 I've had to restore my Windows after it.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 5, 2021 #35 Why, did you get an error or something like that ? Is KB3060716 successfully installed ? Check Windows Update and post a screenshot of the important updates available.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 5, 2021 #36 It requires re-boot during installing. And it can't re-boot without system restoring.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 5, 2021 #37 Try to install KB915597 only and report the result.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 5, 2021 #38 Unknown error: 8050800C code.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,643 Apr 5, 2021 #39 SFC Scan Click the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following commands into it, press enter after each. Code: sfc /scannow Wait for this to finish before you continue Code: copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" This will create a file, cbs.txt on your Desktop. Please attach this to your next post. Note: if the file is too big to upload to your next post please upload via a service such as Filedropper or One Drive or WeTransfer and just provide the download link.
C Chicho1973 Well-known member Joined Feb 23, 2021 Posts 54 Apr 5, 2021 #40 cbs.txt http://www.filedropper.com/cbs_6
