Hola !
I just wanna start off with some short backstory; I have been playing Diablo 3 since release and ive always had "stutterlags", but i just wrote it off as old hardware (mostly the graphic card).
A week ago i got really tired of it and bought a GeForce GTX 980 Ti. But the stutterlags remained!
So i started looking in to it. With LatencyMon i saw that i had alot of DPC spikes, with over a week now doing whatever solutions ive found on google i still havent figured out the problem.
Hardware:
P8Z77-V PRO
Intel i7-3770K (Ivybridge)
Gigabyte NVIDIA GeForce GTX 980 Ti 6GB G1 Gaming
16GB DDR3 (Corsair Vengeance LP CML 16GX3M4A1600C9)
Corsair Force 3 SSD (and two regular western digital harddrives)
Corsair TX650W Power supply
And i use Windows 10 64-bit.
Things ive tried so far:
Changing from Windows 7 to Windows 10
Updating BIOS
Disabled EPU Powersaving mode, Sidestep, Turbomode & C1E in Bios
Disabled/Enabled HPET
Disabled/Enabled NIC & Soundcard
Set all power options to max
Updating every driver imaginable
Switching PCIe ports for the graphic card
I let LatencyMon run idle for 10 hours.
Stats here:
I also had high ISR count on: dxgkrnl.sys , storport.sys , HDAudBus.sys & USBPORT.SYS
Im pulling my hair out on this one, i would really appreciate some help :)
Hardware:
P8Z77-V PRO
Updating BIOS
Stats here:
_________________________________________________________________________________________________________CONCLUSION
LatencyMon has been analyzing your system for 10:08:59 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-0PS28RR
Hardware: ASUSTeK COMPUTER INC., P8Z77-V PRO
CPU: GenuineIntel Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Logical processors: 8
Processor groups: 1
RAM: 16327 MB total
CPU SPEED
Reported CPU speed: 3518 MHz
Highest measured interrupt to process latency (µs): 609,738706
Average measured interrupt to process latency (µs): 1,843041
Highest measured interrupt to DPC latency (µs): 607,992437
Average measured interrupt to DPC latency (µs): 0,492309
REPORTED ISRs
Highest ISR routine execution time (µs): 76,985787
Highest reported total ISR routine time (%): 0,008884
Total time spent in ISRs (%) 0,013920
ISR count (execution time <250 µs): 3469321
REPORTED DPCs
Highest DPC routine execution time (µs): 2356,073906
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 353.82 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,014268
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0,034391
DPC count (execution time <250 µs): 113253661
DPC count (execution time 500-999 µs): 6
DPC count (execution time 1000-1999 µs): 3
DPC count (execution time 2000-3999 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: skype.exe
Total number of hard pagefaults 59083
Hard pagefault count of hardest hit process: 23467
Highest hard pagefault resolution time (µs): 7110150,600341
Total time spent in hard pagefaults (%): 0,039383
Number of processes hit: 43
PER CPU DATA
CPU 0 Interrupt cycle time (s): 237,316368
CPU 0 ISR highest execution time (µs): 76,985787
CPU 0 ISR total execution time (s): 40,662992
CPU 0 ISR count: 3467301
CPU 0 DPC highest execution time (µs): 2356,073906
CPU 0 DPC total execution time (s): 73,073450
CPU 0 DPC count: 101761775
CPU 1 Interrupt cycle time (s): 88,829760
CPU 1 ISR highest execution time (µs): 53,100625
CPU 1 ISR total execution time (s): 0,026301
CPU 1 ISR count: 1928
CPU 1 DPC highest execution time (µs): 1006,805003
CPU 1 DPC total execution time (s): 1,415555
CPU 1 DPC count: 632365
CPU 2 Interrupt cycle time (s): 84,650342
CPU 2 ISR highest execution time (µs): 15,298465
CPU 2 ISR total execution time (s): 0,000390
CPU 2 ISR count: 71
CPU 2 DPC highest execution time (µs): 161,574758
CPU 2 DPC total execution time (s): 7,012822
CPU 2 DPC count: 4294524
CPU 3 Interrupt cycle time (s): 61,359220
CPU 3 ISR highest execution time (µs): 4,78340
CPU 3 ISR total execution time (s): 0,000083
CPU 3 ISR count: 21
CPU 3 DPC highest execution time (µs): 112,709494
CPU 3 DPC total execution time (s): 0,576662
CPU 3 DPC count: 209427
CPU 4 Interrupt cycle time (s): 80,281554
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 149,942013
CPU 4 DPC total execution time (s): 5,903757
CPU 4 DPC count: 1988858
CPU 5 Interrupt cycle time (s): 70,116398
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 131,971575
CPU 5 DPC total execution time (s): 3,745135
CPU 5 DPC count: 1448037
CPU 6 Interrupt cycle time (s): 82,126276
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 219,723707
CPU 6 DPC total execution time (s): 6,765384
CPU 6 DPC count: 2430952
CPU 7 Interrupt cycle time (s): 60,685432
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 114,044343
CPU 7 DPC total execution time (s): 2,037529
CPU 7 DPC count: 487733
SYSTEM INFORMATION
Processor groups: 1
RAM: 16327 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 71
CPU 3 ISR count: 21
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
