P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 24, 2021 #61 The following method is easier: Right-click Start and select Run. Typ MSCONFIG in the search field and click OK. Open the tab Boot. Put a checkmark at Safe boot and select the option Minimal. (To start Windows in Normal mode again, remove this checkmark.) Click OK, next click Restart. Windows will now start in Safe mode. This may take a bit longer as usual.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 24, 2021 #62 Here it is. Attachments Fixlog.txt 1 KB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #63 Still no luck. Step 1: Click on Start - All programs - Accessories. Rightclick on Command-prompt and select Run as administrator. When command prompt opens, typ diskpart into it, then press enter. Wait for this to complete. Typ list volume and press enter. Wait for this to complete. Take a screenshot of the commandprompt window. Read this on how to take a screenshot. Upload the image file to a file-sharing site such as Filedropper.com or imgur.com and post the downloadlink. Step 2: Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment fixlist.txt and save it to your desktop. Right-click on FRST64.exe and select "Run as administrator". Press the Fix button. The tool will now process fixlist.txt. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from. Post the logfile Fixlog.txt as attachment in your next reply. Attachments fixlist.txt 207 bytes · Views: 3
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #64 https://imgur.com/a/nnWSXTt Attachments Fixlog.txt 1.5 KB · Views: 6
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #65 Are you willing to remove the hard drive from this machine and connect it to another computer as a slave drive ?
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #66 That's not really something I'm comfortable doing. Could I create a recovery image on a separate hard drive and use that? Have you been able to diagnose the problem?
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #67 Could I create a recovery image on a separate hard drive and use that? Click to expand... Not sure if the issue remains. Have you been able to diagnose the problem? Click to expand... There is a problem with a folder that we cannot remove for some reason. Probably because the integrity flag is set on that folder which is highly unusual on an NTFS system. ChkDsk reports no problem so that is a bit weird also. I'll need to dig in further.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #68 Thanks. When I go to the C_G18030.DLL folder on my computer I see that it is there but it is empty. Do you think trying to install the 3 most recent Windows updates would be of any help?
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #69 No, but you can try.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #70 Well I was able to install the updates. So far, the issues with sfc and dism seem to be the only ones I'm experiencing.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #71 Are you able to see the bolded folder "c:\windows\winsxs\amd64_microsoft-windows-i..onal-codepage-54936_31bf3856ad364e35_6.3.9600.17415_none_cc06413d136cdc9b in the explorer ?
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #72 Yes. The folder is there but is 0 bytes in size and when I double click on it it tells me access is denied.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #73 Good, post a screenshot of the property tabs General and Security.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #74 https://imgur.com/a/F2Z4JVh https://imgur.com/a/tBafE9w
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 25, 2021 #75 Click Advanced on the second screenshot. Post a screenshot of the window that appears.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #76 The folder immediately above c:\windows\winsxs\amd64_microsoft-windows-i..onal-codepage-54936_31bf3856ad364e35_6.3.9600.17415_none_cc06413d136cdc9b is amd64_microsoft-windows-i..onal-codepage-54936_31bf3856ad364e35_6.3.9600.16384_none_cbb9a66113a67013 but it contains the DLL file C_G18030.DLL that's supposed to be in the folder below it too.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #78 Also, all the other amd64_microsoft-windows-i..onal-codepage folders were last modified on 8/22/2013 while the two I mentioned above were last modified on 3/14/2015 and 3/11/2015 respectively.
D drencrom Well-known member Joined May 10, 2017 Posts 95 Jan 25, 2021 #79 Also the name of the folder we are looking at is blue in color, while all the other folders' names are black.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,663 Jan 26, 2021 #80 The folder immediately above c:\windows\winsxs\amd64_microsoft-windows-i..onal-codepage-54936_31bf3856ad364e35_6.3.9600.17415_none_cc06413d136cdc9b is amd64_microsoft-windows-i..onal-codepage-54936_31bf3856ad364e35_6.3.9600.16384_none_cbb9a66113a67013 but it contains the DLL file C_G18030.DLL that's supposed to be in the folder below it too. Click to expand... The filenames are the same but the sizes are not. In the screenshot, click Configure. Post a screenshot of the window that appears.
