C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 18, 2021 #21 I tried to install the update (KB4516065) twice,but both times it didnt work. Attachments updates7.png 143.4 KB · Views: 3 CBS.zip 662.5 KB · Views: 1
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 19, 2021 #22 I read somewhere on the forum,to try to install KB4490628 first,and then to install KB4516065. I installed KB4490628 successfully,and after that,I scan for updates,and there was no update KB4516065 anymore. I'm sending you a picture of the updates. What should I do next? Attachments updates8.png 133.7 KB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 19, 2021 #23 Try to install them, one at a time.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 19, 2021 #24 I first tried to install KB4534310,at first it was successfully,but when i go restart to finish update, at 13% it said failure to configure windows updates,and reverting changes.I'm sending you cbs log. Attachments CBS (2).zip 1.1 MB · Views: 0
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 19, 2021 #25 I successfully installed another update KB4535102,and after that I checked the updates again,and only appeared to me KB4534310 which could not be installed. After that i run sfc/scannow,and am sending you a file. I apologize if I'm boring. here is a link on google drive:CBS (3).zip
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 20, 2021 #26 The cbs.log isn't complete. Please zip and attach it again.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 20, 2021 #28 Boot your computer into a Clean Boot state following these instructions: How to perform a clean boot in Windows. After that, check Windows Update again and report the result.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 20, 2021 #29 I Boot my computer into a Clean Boot state,and after that I checked Windows Update. Attachments updates11.png 135.6 KB · Views: 4
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 21, 2021 #30 Install KB915597 first.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 21, 2021 #31 I installed successfully KB915597,after that i tried to install KB4534310 again,but at 13% I received message failure to configure windows update.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 21, 2021 #32 Attach the zipped cbs.log and the file C:\Windows\WindowsUpdate.log to your next reply.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 21, 2021 #33 Here is cbs log. I run sfc/scannow,and here is picture of that process. Attachments CBS (5).zip 160.9 KB · Views: 1 picture1.png 50.1 KB · Views: 4
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 21, 2021 #34 Please attach the file C:\Windows\WindowsUpdate.log also.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 21, 2021 #35 here is windowsupdate.log Attachments WindowsUpdate.log 1.2 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 22, 2021 #36 Step 1: Go to Control Panel - Windows Update - Change settings. Select Never check for updates (not recommended). Click OK. Select Download updates but let me choose whether to install them. Step 2: Try to install KB4534310 again and report the result.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 24, 2021 #37 I do everything as you said,but when i go restart to finish installation,at 13% said failure to configure windows update. here is cbs.log and windows update log. Attachments CBS (6).zip 1 MB · Views: 1 WindowsUpdate (2).log 1.3 MB · Views: 0
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 24, 2021 #38 Attach the file C:\Windows\INF\setupapi.dev.log to your next reply.
C Commander Well-known member Joined Jan 16, 2021 Posts 61 Jan 29, 2021 #39 here is setupapi.dev.log Attachments setupapi.dev.log 4.6 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 12,668 Jan 29, 2021 #40 Remove Update Manually Click on the Start button and in the search box, type Command Prompt. When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following command into it, then press enter. wusa /uninstall /KB:4054518 Let me know if it says it was successful or if there are any errors.
