update and shutting down problem
Commander
Hi all!
I have Windows 7(x64) Ultimate on my computer,and it worked fine until i tried to update it.
Some updates didn't want to install,and after that the computer cant shut down properly,just stuck on the shutting down.
I tried to uninstall some updates,to solve the problem,but i can't uninstall one update(KB4054518).
Some updates have caused a problem,and the computer can't shut down properly,so am asking you for help.
I did SURT and SFC and I will post them here.
Thanks for your reply.
Hello,i did as you told me.
Start time: 2021-01-17 01:29:35.836
Using .zip script file at C:\Users\User\Desktop\SFCFix.zip [0]
Not using an additional text script file.
ERROR: File Placement Mode failed to identify destinations for all files and folders.
SFCFixScript.txt
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_b85a4f21afbb528a\spwizimg.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
Successfully copied file C:\Users\User\AppData\Local\niemiro\Archive\x86_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_b85a4f21afbb528a\spwizimg.dll to C:\Windows\winsxs\x86_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_b85a4f21afbb528a\spwizimg.dll.
Successfully copied file C:\Users\User\AppData\Local\niemiro\Archive\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll to C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_b85a4f21afbb528a\spwizimg.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_b85a4f21afbb528a\spwizimg.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
AutoAnalysis:: directive failed to complete successfully.
Finish time: 2021-01-17 01:29:41.264
Script hash: oi8OMNE2IFOQPAbvyR/wAud6veEjQeNxkvOkxklkrX0=
Well done.
Perform a new scan with SFCFix.
  1. Double-click SFCFix.exe to run the tool. A dialog may come up asking for approval. If it does go ahead and allow.
  2. On completion a log file (SFCFix.txt) will be opened. Copy and Paste its content into your next reply.
New scan with SFCFix.
Start time: 2021-01-17 12:13:56.186
WARNING: File C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp was not backed up as that would replace the current backup.
FIXED: Corruption at C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp has been successfully repaired from C:\Windows\System32\oobe\background.bmp.
SUMMARY: All detected corruptions were successfully repaired.
Finish time: 2021-01-17 12:14:35.014
ChkDsk Scan
  • Click on Start - All programs - Accessories.
  • Rightclick on Command-prompt and select Run as administrator.
  • When command prompt opens, typ chkdsk into it, then press enter.
  • Wait for this to complete.
  • Download ListChkdskResult.exe by SleepyDude and save it on your desktop.
  • Rightclick
    ListChkdskResult.exe and select Run as administrator. Notepad will open the file ListChkdskResult.txt on completion. (The file ListChkdskResult.txt can be found on your desktop.)
  • Copy and paste its content in your next reply.
Start time: 2021-01-17 15:17:46.053
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp
Successfully copied file C:\Users\User\AppData\Local\niemiro\Archive\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp to C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp.
Successfully restored ownership for C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp
Successfully restored permissions on C:\Windows\winsxs\amd64_setup-uxwizard-clientimages_31bf3856ad364e35_6.1.7600.16385_none_a4cc3ba14850df9e\background.bmp
Finish time: 2021-01-17 15:17:46.630
Script hash: OMs+5HB3/yPcDw133pjzxKobGHfUZhgT+YOxswNJfIo=
------< Log generate on 1/17/2021 15:20:37 >------
Category: 0
Computer Name: User-PC
Event Code: 26212
Record Number: 31793
Source Name: Chkdsk
Time Written: 01-17-2021 @ 14:20:10
Event Type: Information
User:
Message: Chkdsk was executed in read-only mode on a volume snapshot.
Checking file system on C:
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
289024 file records processed.
File verification completed.
1531 large file records processed.
0 bad file records processed.
2 EA records processed.
94 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
386606 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
289024 file SDs/SIDs processed.
Cleaning up 303 unused index entries from index $SII of file 0x9.
Cleaning up 303 unused index entries from index $SDH of file 0x9.
Cleaning up 303 unused security descriptors.
48792 data files processed.
37032904 USN bytes processed.
Windows has checked the file system and found no problems.
104806399 KB total disk space.
80521488 KB in 196605 files.
168716 KB in 48793 indexes.
0 KB in bad sectors.
396195 KB in use by the system.
23720000 KB available on disk.
26201599 total allocation units on disk.
5930000 allocation units available on disk.
Category: 0
Event Code: 1001
Record Number: 27525
Time Written: 12-08-2020 @ 18:54:22
User:
Message:
that you continue.
Attribute record of type 0x80 and instance tag 0x4 is cross linked
starting at 0x16c468 for possibly 0x18 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x4
in file 0x180c6 is already in use.
Deleting corrupt attribute record (128, "")
from file record segment 98502.
starting at 0x270203 for possibly 0x1 clusters.
in file 0x2965a is already in use.
from file record segment 169562.
Attribute record of type 0x80 and instance tag 0x3 is cross linked
starting at 0x1899bf for possibly 0x85 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x3
in file 0x298eb is already in use.
from file record segment 170219.
starting at 0x12205c for possibly 0x6 clusters.
in file 0x29e54 is already in use.
from file record segment 171604.
starting at 0x34f6e6 for possibly 0x3c clusters.
in file 0x2a804 is already in use.
from file record segment 174084.
starting at 0x17ad12 for possibly 0x3 clusters.
in file 0x2a9df is already in use.
from file record segment 174559.
starting at 0x5bf8d9 for possibly 0x13 clusters.
in file 0x2aa0d is already in use.
from file record segment 174605.
starting at 0x251b3d for possibly 0x33 clusters.
in file 0x2aa2c is already in use.
from file record segment 174636.
starting at 0x64df67 for possibly 0x10 clusters.
in file 0x2adad is already in use.
from file record segment 175533.
starting at 0x342ff3 for possibly 0x50 clusters.
in file 0x2bb2d is already in use.
from file record segment 178989.
starting at 0x19ad46 for possibly 0x5 clusters.
in file 0x2bf16 is already in use.
from file record segment 179990.
starting at 0x2c6a39 for possibly 0x4 clusters.
in file 0x2c344 is already in use.
from file record segment 181060.
Attribute record of type 0xa0 and instance tag 0x3 is cross linked
starting at 0xfc731 for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0xa0 and instance tag 0x3
in file 0x2ca04 is already in use.
Deleting corrupt attribute record (160, $I30)
from file record segment 182788.
starting at 0x19ad36 for possibly 0x10 clusters.
in file 0x2ca42 is already in use.
from file record segment 182850.
starting at 0xfc730 for possibly 0x1 clusters.
in file 0x2cac8 is already in use.
from file record segment 182984.
starting at 0xfdf47 for possibly 0x6 clusters.
in file 0x2cb90 is already in use.
from file record segment 183184.
starting at 0x2d2194 for possibly 0x3 clusters.
in file 0x2cb93 is already in use.
from file record segment 183187.
starting at 0x18dbe4 for possibly 0x3 clusters.
in file 0x2cd20 is already in use.
from file record segment 183584.
starting at 0x59661b for possibly 0x7b clusters.
in file 0x2d00a is already in use.
from file record segment 184330.
Attribute record of type 0xa0 and instance tag 0x4 is cross linked
starting at 0x2937a0 for possibly 0x13 clusters.
Some clusters occupied by attribute of type 0xa0 and instance tag 0x4
in file 0x2d02e is already in use.
from file record segment 184366.
starting at 0x6543b8 for possibly 0x6d clusters.
in file 0x2d292 is already in use.
from file record segment 184978.
starting at 0x2ca5b7 for possibly 0x1 clusters.
in file 0x2d2c6 is already in use.
from file record segment 185030.
Attribute record of type 0x80 and instance tag 0x1 is cross linked
starting at 0x60edea for possibly 0x7b clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x1
in file 0x2d40d is already in use.
from file record segment 185357.
starting at 0x60b4fb for possibly 0x185 clusters.
in file 0x2d4e1 is already in use.
from file record segment 185569.
starting at 0x60a91a for possibly 0x145 clusters.
in file 0x2d6c8 is already in use.
from file record segment 186056.
starting at 0x2c1b5c for possibly 0x5 clusters.
in file 0x2da3f is already in use.
from file record segment 186943.
starting at 0x560807 for possibly 0xb clusters.
in file 0x2dd24 is already in use.
from file record segment 187684.
starting at 0x251b09 for possibly 0x1 clusters.
in file 0x2dd82 is already in use.
from file record segment 187778.
starting at 0x1e8b40 for possibly 0x1 clusters.
in file 0x2de11 is already in use.
from file record segment 187921.
starting at 0x5b99b3 for possibly 0x6 clusters.
in file 0x2e260 is already in use.
from file record segment 189024.
starting at 0x361384 for possibly 0x5 clusters.
in file 0x2e27a is already in use.
from file record segment 189050.
starting at 0x34f8ad for possibly 0x10 clusters.
in file 0x2e602 is already in use.
from file record segment 189954.
starting at 0x189291 for possibly 0x2 clusters.
in file 0x2e801 is already in use.
from file record segment 190465.
starting at 0x36d03d for possibly 0x7 clusters.
in file 0x2e9fd is already in use.
from file record segment 190973.
starting at 0x33f348 for possibly 0x102 clusters.
in file 0x2eb56 is already in use.
from file record segment 191318.
starting at 0x2c14d3 for possibly 0x2 clusters.
in file 0x2ebf1 is already in use.
from file record segment 191473.
starting at 0x347b2c for possibly 0x2 clusters.
in file 0x2ec09 is already in use.
from file record segment 191497.
starting at 0x217bc8 for possibly 0x1 clusters.
in file 0x2ec81 is already in use.
from file record segment 191617.
starting at 0x371cdb for possibly 0x2 clusters.
in file 0x2ec87 is already in use.
from file record segment 191623.
starting at 0x381fe6 for possibly 0x2 clusters.
in file 0x2ec88 is already in use.
from file record segment 191624.
starting at 0x5c2a7d for possibly 0x2 clusters.
in file 0x2ecb7 is already in use.
from file record segment 191671.
starting at 0x5c8bb4 for possibly 0x2 clusters.
in file 0x2ecbb is already in use.
from file record segment 191675.
starting at 0x5cc818 for possibly 0x2 clusters.
in file 0x2ecbe is already in use.
from file record segment 191678.
starting at 0x5cbf6d for possibly 0x2 clusters.
in file 0x2ecbf is already in use.
from file record segment 191679.
starting at 0x5cd4af for possibly 0x2 clusters.
in file 0x2ecc1 is already in use.
from file record segment 191681.
starting at 0x5cdb33 for possibly 0x2 clusters.
in file 0x2ecc5 is already in use.
from file record segment 191685.
starting at 0x5d3ad4 for possibly 0x2 clusters.
in file 0x2ecc9 is already in use.
from file record segment 191689.
starting at 0x5d4c1b for possibly 0x2 clusters.
in file 0x2ecce is already in use.
from file record segment 191694.
starting at 0x5d47c8 for possibly 0x2 clusters.
in file 0x2eccf is already in use.
from file record segment 191695.
starting at 0x5ece96 for possibly 0x2 clusters.
in file 0x2ecd2 is already in use.
from file record segment 191698.
starting at 0x5f0e1f for possibly 0x2 clusters.
in file 0x2ecd7 is already in use.
from file record segment 191703.
starting at 0x5f119e for possibly 0x2 clusters.
in file 0x2ecd8 is already in use.
from file record segment 191704.
starting at 0x5f715c for possibly 0x2 clusters.
in file 0x2ecd9 is already in use.
from file record
Category: 0
Event Code: 1001
Record Number: 20564
Time Written: 08-30-2020 @ 10:26:57
User:
Message:
that you continue.
198144 file records processed.
596 large file records processed.
90 reparse records processed.
285000 index entries processed.
198144 file SDs/SIDs processed.
Cleaning up 626 unused index entries from index $SII of file 0x9.
Cleaning up 626 unused index entries from index $SDH of file 0x9.
Cleaning up 626 unused security descriptors.
43429 data files processed.
37356848 USN bytes processed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
38339320 KB in 151543 files.
121036 KB in 43430 indexes.
304327 KB in use by the system.
66041716 KB available on disk.
16510429 allocation units available on disk.
Internal Info:
00 06 03 00 a8 f9 02 00 69 26 06 00 00 00 00 00 ........i&......
46 01 00 00 5a 00 00 00 00 00 00 00 00 00 00 00 F...Z...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Step 1: SFCFix Scan
Restart the computer.
If it fails, attach the zipped cbs.log to your next reply.
Start time: 2021-01-17 15:41:57.515
Finish time: 2021-01-17 15:42:28.559
I restarted computer,but it got stuck on shutting down again,so i force shut down.
Than I checked for windows updates,and i send you a picture of updates.
Should I try to install them all?
Try to install KB3042058 only. If it succeeds install the other "Security update for Windows 7...." first. Select 1 or 2 updates at a time.
Please report the result.
I first installed (KB3042058) successfully,as you told me. (when i did the restart,it got stuck again on shutting down)
After that,i installed other updates successfully. (again stuck on shutting down)
I checked the updates,and I'm sending you a picture.
Install KB3074543, KB3097989, KB3122648, KB3127220 in the given order.
I installed all 4 updates as you told me,everything went smoothly.(except stuck on shutting down).
I checked the updates again.
Install KB3138612, KB915597, KB4041083 in the given order.
I installed all three successfully.
Great, install KB4474419 only.
Restart the machine, check for Windows Updates and post a screenshot of the result.
I restarted the computer,but stuck on shutting down as always.
I checked for updates.
Install KB4516065 only. If it succeeds install the remaining one.
