[SOLVED] sfc /scannow problem!
JimTrek
London
Hi there,
I recently posted this query (sfc /scannow problem) on Microsoft Technet, but I feel a bit stuck with the advice I'm recieving!
Can anybody here help?
Sorry if this is in the wrong category!...
I was going to edit my initial post (no edit button!) to include, I ran sfc & dism/restorehealth, then tried to run SFCFix but it just keeps crashing out!?
SFCFix Has Crashed
Something has gone horribly wrong and SFCFix has crashed. Would you like SFCFix
to submit a crash report to the developer so that this problem can be fixed?
Type "y" for yes or "n" for no and press enter to continue:
Any ideas? Here is my CBS.log file:
Rann sfc /scannow again today, always stops at 59% with error: Windows Resource Protection could not perform the requested operation.
I tried running SFCFix (with admin rights!) straight after, but it's still crashing! Any help would be much appreciated, thanks!
Sorry for all the replies, I didn't realise you only had 15min's before you couldn't edit your post anymore! Here's the SFCFix.txt & CrashDump.dmp zip file:
OMG! :r1:, the file was too large so I ran out of time trying to upload! :banghead:
Here's the link for the SFCFixCrashDump.zip:==>> WeTransfer
Hello and welcome!
Please do not multiple post but post only once and wait for an analyst to reply.
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload to a file sharing service and just provide the link here.
Hello and welcome!
Hi softwaremaniac, again yes, I apologise for the multople posts!
Here's a Screenshot of what happened when I tried to copy the COMPONENTS file to my desktop, I'll reboot & try again!
I anticipated you'd might ask that, so I ran sfc /scannow straight after, but it returns the same result as always, it stops at 59% with the same error: Windows Resource Protection could not perform the requested operation.
Just in case you need it, here's the latest CBS log file:++>>
2. Try running SFC just like you have in the past.
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
SFC Scan
Here you go:
GSmartControl
  • Execute gsmartcontrol.exe; Let the install complete and launch the programme.
Here is the Extended Self-Test results from GSmartContol:==>>
smartctl 6.5 2016-05-07 r4318 [i686-w64-mingw32-win10(64)] (sf-6.5-1)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     ST1000LM035-1RK172
Serial Number:    WDEHA5JY
LU WWN Device Id: 5 000c50 0aae57ae0
Firmware Version: RSM7
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Feb 08 23:30:38 2019 GMTST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (    0) seconds.
capabilities:              (0x51) SMART execute Offline immediate.
                    No Auto Offline data collection support.
                    Suspend Offline collection upon new
                    command.
                    No Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 173) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   082   064   006    -    160307664
  3 Spin_Up_Time            PO---K   099   099   000    -    0
  4 Start_Stop_Count        -O--CK   098   098   000    -    2246
  5 Reallocated_Sector_Ct   PO--CK   100   100   036    -    0
  7 Seek_Error_Rate         POSR-K   080   060   045    -    99787995
  9 Power_On_Hours          -O--CK   099   099   000    -    1112 (177 103 0)
 10 Spin_Retry_Count        PO--CK   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    456
183 Runtime_Bad_Block       -O--CK   100   100   000    -    0
184 End-to-End_Error        PO--CK   100   100   097    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   065   052   040    -    35 (Min/Max 12/42)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    15
192 Power-Off_Retract_Count -O---K   100   100   000    -    16
193 Load_Cycle_Count        -O--CK   097   097   000    -    6206
194 Temperature_Celsius     -O---K   035   048   000    -    35 (0 9 0 0 0)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
254 Free_Fall_Sensor        -O--CK   100   100   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  SATA NCQ Queued Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    512  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS    8160  Device vendor specific log
0xa8       GPL,SL  VS     136  Device vendor specific log
0xa9       GPL,SL  VS       1  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    8920  Device vendor specific log
0xb6       GPL     VS    1920  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL,SL  VS      16  Device vendor specific log
0xc2       GPL,SL  VS     240  Device vendor specific log
0xc3       GPL,SL  VS       8  Device vendor specific log
0xc4       GPL,SL  VS      24  Device vendor specific log
0xc9       GPL,SL  VS       1  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%      1112         -
# 2  Short offline       Completed without error       00%       787         -
# 3  Short offline       Completed without error       00%       720         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    35 Celsius
Power Cycle Min/Max Temperature:     12/42 Celsius
Lifetime    Min/Max Temperature:      9/51 Celsius
Under/Over Temperature Limit Count:   0/24
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        30 minutes
Min/Max recommended Temperature:      0/ 0 Celsius
Min/Max Temperature Limit:            0/ 0 Celsius
Temperature History Size (Index):    128 (116)
Index    Estimated Time   Temperature Celsius
 117    2019-02-06 08:00    37  ******************
 118    2019-02-06 08:30    37  ******************
 119    2019-02-06 09:00    39  ********************
 120    2019-02-06 09:30    38  *******************
 121    2019-02-06 10:00    37  ******************
 122    2019-02-06 10:30    26  *******
 123    2019-02-06 11:00    33  **************
 124    2019-02-06 11:30     ?  -
 125    2019-02-06 12:00    10  -
 126    2019-02-06 12:30    25  ******
 127    2019-02-06 13:00     ?  -
   0    2019-02-06 13:30    12  -
   1    2019-02-06 14:00    31  ************
   2    2019-02-06 14:30    31  ************
   3    2019-02-06 15:00    32  *************
 ...    ..(  2 skipped).    ..  *************
   6    2019-02-06 16:30    32  *************
   7    2019-02-06 17:00     ?  -
   8    2019-02-06 17:30    18  -
   9    2019-02-06 18:00    32  *************
  10    2019-02-06 18:30    33  **************
  11    2019-02-06 19:00    34  ***************
  12    2019-02-06 19:30    35  ****************
  13    2019-02-06 20:00    36  *****************
  14    2019-02-06 20:30    36  *****************
  15    2019-02-06 21:00    36  *****************
  16    2019-02-06 21:30    33  **************
  17    2019-02-06 22:00    34  ***************
  18    2019-02-06 22:30     ?  -
  19    2019-02-06 23:00    12  -
  20    2019-02-06 23:30    32  *************
  21    2019-02-07 00:00    35  ****************
  22    2019-02-07 00:30    38  *******************
  23    2019-02-07 01:00    30  ***********
  24    2019-02-07 01:30     ?  -
  25    2019-02-07 02:00    12  -
  26    2019-02-07 02:30    30  ***********
  27    2019-02-07 03:00    32  *************
  28    2019-02-07 03:30    34  ***************
  29    2019-02-07 04:00    28  *********
  30    2019-02-07 04:30    27  ********
  31    2019-02-07 05:00    32  *************
  32    2019-02-07 05:30    36  *****************
  33    2019-02-07 06:00    34  ***************
  34    2019-02-07 06:30    35  ****************
  35    2019-02-07 07:00    38  *******************
  36    2019-02-07 07:30    29  **********
  37    2019-02-07 08:00    32  *************
  38    2019-02-07 08:30    34  ***************
  39    2019-02-07 09:00    33  **************
  40    2019-02-07 09:30     ?  -
  41    2019-02-07 10:00    16  -
  42    2019-02-07 10:30    31  ************
  43    2019-02-07 11:00    32  *************
  44    2019-02-07 11:30    29  **********
  45    2019-02-07 12:00    32  *************
  46    2019-02-07 12:30    27  ********
  47    2019-02-07 13:00    25  ******
  48    2019-02-07 13:30    26  *******
  49    2019-02-07 14:00    28  *********
  50    2019-02-07 14:30    26  *******
  51    2019-02-07 15:00    28  *********
  52    2019-02-07 15:30     ?  -
  53    2019-02-07 16:00    11  -
  54    2019-02-07 16:30    29  **********
  55    2019-02-07 17:00    28  *********
  56    2019-02-07 17:30    26  *******
  57    2019-02-07 18:00    24  *****
  58    2019-02-07 18:30    25  ******
  59    2019-02-07 19:00    27  ********
  60    2019-02-07 19:30    26  *******
  61    2019-02-07 20:00    26  *******
  62    2019-02-07 20:30    31  ************
  63    2019-02-07 21:00    34  ***************
  64    2019-02-07 21:30     ?  -
  65    2019-02-07 22:00    16  -
  66    2019-02-07 22:30    31  ************
  67    2019-02-07 23:00    33  **************
  68    2019-02-07 23:30    34  ***************
  69    2019-02-08 00:00    32  *************
  70    2019-02-08 00:30    31  ************
  71    2019-02-08 01:00    30  ***********
  72    2019-02-08 01:30    32  *************
  73    2019-02-08 02:00    33  **************
  74    2019-02-08 02:30     ?  -
  75    2019-02-08 03:00    33  **************
  76    2019-02-08 03:30     ?  -
  77    2019-02-08 04:00    17  -
  78    2019-02-08 04:30     ?  -
  79    2019-02-08 05:00    15  -
  80    2019-02-08 05:30    28  *********
  81    2019-02-08 06:00    30  ***********
  82    2019-02-08 06:30    30  ***********
  83    2019-02-08 07:00    32  *************
  84    2019-02-08 07:30    32  *************
  85    2019-02-08 08:00     ?  -
  86    2019-02-08 08:30    17  -
  87    2019-02-08 09:00    30  ***********
  88    2019-02-08 09:30    33  **************
  89    2019-02-08 10:00    33  **************
  90    2019-02-08 10:30    31  ************
  91    2019-02-08 11:00    29  **********
  92    2019-02-08 11:30     ?  -
  93    2019-02-08 12:00    12  -
  94    2019-02-08 12:30    25  ******
  95    2019-02-08 13:00    36  *****************
  96    2019-02-08 13:30    41  **********************
  97    2019-02-08 14:00    39  ********************
  98    2019-02-08 14:30    39  ********************
  99    2019-02-08 15:00    37  ******************
 100    2019-02-08 15:30    28  *********
 101    2019-02-08 16:00    36  *****************
 102    2019-02-08 16:30    40  *********************
 103    2019-02-08 17:00    38  *******************
 104    2019-02-08 17:30    39  ********************
 105    2019-02-08 18:00    37  ******************
 106    2019-02-08 18:30    35  ****************
 107    2019-02-08 19:00    33  **************
 108    2019-02-08 19:30    35  ****************
 109    2019-02-08 20:00    31  ************
 110    2019-02-08 20:30    39  ********************
 111    2019-02-08 21:00    38  *******************
 112    2019-02-08 21:30    36  *****************
 113    2019-02-08 22:00    36  *****************
 114    2019-02-08 22:30    35  ****************
 115    2019-02-08 23:00    35  ****************
 116    2019-02-08 23:30    34  ***************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             456  ---  Lifetime Power-On Resets
0x01  0x010  4            1112  ---  Power-on Hours
0x01  0x018  6      5988141801  ---  Logical Sectors Written
0x01  0x020  6       118640893  ---  Number of Write Commands
0x01  0x028  6      9102974945  ---  Logical Sectors Read
0x01  0x030  6       123246888  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             348  ---  Spindle Motor Power-on Hours
0x03  0x010  4              80  ---  Head Flying Hours
0x03  0x018  4            6206  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               1  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              35  ---  Current Temperature
0x05  0x010  1              32  ---  Average Short Term Temperature
0x05  0x018  1              31  ---  Average Long Term Temperature
0x05  0x020  1              48  ---  Highest Temperature
0x05  0x028  1              13  ---  Lowest Temperature
0x05  0x030  1              37  ---  Highest Average Short Term Temperature
0x05  0x038  1              29  ---  Lowest Average Short Term Temperature
0x05  0x040  1              34  ---  Highest Average Long Term Temperature
0x05  0x048  1              31  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              55  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1              13  ---  Specified Minimum Operating Temperature
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2           22  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Test result: Completed without error. ([FONT=&quot]No errors or pink attributes!)[/FONT]
