S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #61 Yes, and if it fails again, attach all these listed logs. NET Framework can be a real pain to fix as you can see.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #62 PC rebooted, I tried to install .NET Framework 3.5 and same error. Attach all logs which .NET Framework Repair Tool showed me?
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #64 I see it's really hard to fix, of course I can say "f.ck this" and reinstall Windows but installing again all games and programs don't sound good https://1drv.ms/f/s!Aqj_Rn2gVmn7gkYhoMYKkCSrOp2h
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #65 Can you try installing the latest NET 4.7.2. and let me know if it returns the same error? Download .NET Framework 4.7.2
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #66 I didn't know that - .NET Framework 4.7.2 is actually installed on my PC
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #67 Please take a screenshot of all the features enabled and all of the NET Framework versions installed.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #68 These in Control Panel --> Turn Windows Features on or off?
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #70 https://1drv.ms/u/s!Aqj_Rn2gVmn7glPK5evxqWka5VFG
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #71 Step#1 - DISM /RestoreHealth Scan Warning:this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Right-click on the Start button and select Command Prompt (Admin) When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter Dism /Online /Cleanup-Image /RestoreHealth Once it finishes, copy and paste the following into the command-prompt window and press Enter. If prompted to overwrite the existing file go ahead. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" Once this has completed please go to your Desktop and you will find CBS.txt => Please zip/upload to this thread. Please Note:: if the file is too big (over 7MB) to upload to your next post, please upload via a service and just provide the link.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #72 https://1drv.ms/t/s!Aqj_Rn2gVmn7glS7ewA4j6o-STyL
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #73 SFC Scan Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each sfc /scannow Wait for this to finish before you continue copy %windir%\logs\cbs\cbs.log %userprofile%\Desktop\cbs.txt This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #74 https://1drv.ms/t/s!Aqj_Rn2gVmn7glV8bZ154MKb7sVN
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #75 OK, everything is clean. Please open Command Prompt as Administrator and try the following: Code: DISM /Online /Enable-Feature /FeatureName:NetFx3 /All If it fails, attach CBS.log.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #76 softwaremaniac said: OK, everything is clean. If it fails, attach CBS.log. Click to expand... Yup, it failed. https://1drv.ms/u/s!Aqj_Rn2gVmn7glYQorgiUCG4nmt- code error: 0x800f0922
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #77 Can you temporarily uninstall your antivirus product while we troubleshoot?
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #78 I think I can just turn off Windows Defender. It's only antivirus I've got
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 3, 2018 #79 Aha, it's Windows Defender. Then disregard. Please provide the following logs, so I can review Step#1 - FRST Scan 1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one. 2. Right click to run as administrator. When the tool opens click Yes to disclaimer. 3. Please ensure you place a check mark in the Addition.txt check box at the bottom of the form before running (if not already). 4. Press Scan button. 5. It will produce a log called FRST.txt in the same directory the tool is run from (which should now be the desktop) 6. Please attach the log back here. 7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also attach that along with the FRST.txt in your reply.
K kubaaa216 Well-known member Joined Aug 1, 2018 Posts 75 Aug 3, 2018 #80 https://1drv.ms/f/s!Aqj_Rn2gVmn7glfp_O9SIC53pT-V
