[SOLVED] Problem with update
kubaaa216
Hello, I have problem with Windows 10 update, 0x800f0922. When I'm trying to restart/turn off my pc i need to wait because of is this ******** and i need to wait too when im trying to turn on my pc after installing this update, everytime it says "We couldn't complete updates, undoing changes" then i need to wait around 5 minutes until i will be able to see my desktop :banghead:
AMD Phenom II X4 840
GTX 550Ti
Gigabyte GA-970A-DS3
2x4 GoodRam DDR3 1333MHz CL9
Windows 10 Pro x64
I was trying to manually install this update, it isn't working, the same problem.
sorry for my english :v
Screens, logs: https://1drv.ms/f/s!AmUkmwnGX9qbZ19zxR8Ddv-q_lw
Open CMD as administrator, and type in these commands one by one pressing Enter after each.
SC config wuauserv start= auto
SC config bits start= auto
SC config cryptsvc start= auto
SC config trustedinstaller start= auto
Reboot.
Okay, now I have to disable Startup apps and I have something named "rundll32" located in C:\Windows\System32. Disable that too?
