[SOLVED] Help! DLL problem.
Davidhart711
Skype says Cannot load dnsapi.dll and when I go onto chrome it says DNS_PROBE_FINISHED_NXDOMAIN. I can't go on the Internet on this pc. The other forums helps me and tried everything nothing worked so they put me here please help.
Hi, Davidhart711.
In order to assist you, I need you to provide the logs requested in the Malware Removal Posting Instructions. You will need to transport the files to the affected PC and then transfer the logs back to the device you are using now to connect to the Internet.
Ok Here Are The Logs: FRST:Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version:18-10-2015
Ran by David's PC (administrator) on DESKTOP-9CHG1P7 (19-10-2015 14:43:54)
Running from C:\Users\David's PC\Desktop
Loaded Profiles: David's PC (Available Profiles: David's PC)
Platform: Windows 10 Home (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: Edge)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: FRST Tutorial - How to use Farbar Recovery Scan Tool - Geeks to Go Forum
(AMD) C:\Windows\System32\atiesrxx.exe
(AMD) C:\Windows\System32\atieclxx.exe
(Advanced Micro Devices) C:\Program Files\AMD\{920DEC42-4CA5-4d1d-9487-67BE645CDDFC}\amdacpusrsvc.exe
(Advanced Micro Devices, Inc.) C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(Adobe Systems, Incorporated) C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
(ThreatTrack Security Inc.) C:\Program Files (x86)\VIPRE\SBPIMSvc.exe
(VIA Technologies, Inc.) C:\Windows\System32\ViakaraokeSrv.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\MsMpEng.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\NisSrv.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\MpCmdRun.exe
(ThreatTrack Security Inc.) C:\Program Files (x86)\VIPRE\SBAMSvc.exe
(ThreatTrack Security Inc.) C:\Program Files (x86)\VIPRE\WebProxy.exe
(TortoiseSVN - Home) C:\Program Files\TortoiseSVN\bin\TSVNCache.exe
(Logitech Inc.) C:\Program Files\Logitech Gaming Software\LCore.exe
(Apple Inc.) C:\Program Files\iTunes\iTunesHelper.exe
(Valve Corporation) C:\Program Files (x86)\Steam\Steam.exe
(Oracle Corporation) C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
(ThreatTrack Security Inc.) C:\Program Files (x86)\VIPRE\SBAMTray.exe
(Apple Inc.) C:\Program Files\iPod\bin\iPodService.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
(Advanced Micro Devices Inc.) C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\MOM.exe
(Advanced Micro Devices Inc.) C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
(Microsoft Corporation) C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.10240.16464_none_116100d161f6ab1d\TiWorker.exe
(Valve Corporation) C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
(Valve Corporation) C:\Program Files (x86)\Common Files\Steam\SteamService.exe
(Microsoft Corporation) C:\Windows\System32\InstallAgent.exe
(Adobe Systems Incorporated) C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
() C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\CoreSync.exe
(Microsoft Corporation) C:\Windows\System32\wbem\WMIADAP.exe
==================== Registry (Whitelisted) ===========================
HKLM\...\Run: [SynTPEnh] => %ProgramFiles%\Synaptics\SynTP\SynTPEnh.exe
HKLM\...\Run: [Launch LCore] => C:\Program Files\Logitech Gaming Software\LCore.exe [14601160 2015-07-01] (Logitech Inc.)
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [170256 2015-09-15] (Apple Inc.)
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [508104 2015-09-04] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [334896 2015-06-08] (Oracle Corporation)
HKLM-x32\...\Run: [SBAMTray] => C:\Program Files (x86)\VIPRE\SBAMTray.exe [3000800 2015-09-29] (ThreatTrack Security Inc.)
HKLM-x32\...\Run: [StartCCC] => C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\amd64\CLIStart.exe [767176 2015-08-21] (Advanced Micro Devices, Inc.)
HKLM-x32\...\Run: [Adobe Creative Cloud] => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe [2292912 2015-09-17] (Adobe Systems Incorporated)
HKU\S-1-5-21-3319179057-3537631228-1508127923-1002\...\Run: [Steam] => C:\Program Files (x86)\Steam\steam.exe [2900560 2015-10-08] (Valve Corporation)
HKU\S-1-5-21-3319179057-3537631228-1508127923-1002\...\Run: [Skype] => C:\Program Files (x86)\Skype\Phone\Skype.exe [55357464 2015-09-04] (Skype Technologies S.A.)
HKU\S-1-5-21-3319179057-3537631228-1508127923-1002\...\RunOnce: [Uninstall C:\Users\David's PC\AppData\Local\Microsoft\OneDrive\17.3.5907.0716\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\David's PC\AppData\Local\Microsoft\OneDrive\17.3.5907.0716\amd64"
HKU\S-1-5-21-3319179057-3537631228-1508127923-1002\...\RunOnce: [Uninstall C:\Users\David's PC\AppData\Local\Microsoft\OneDrive\17.3.5930.0814\amd64] => C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\David's PC\AppData\Local\Microsoft\OneDrive\17.3.5930.0814\amd64"
ShellIconOverlayIdentifiers: [ Tortoise1Normal] -> {C5994560-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise2Modified] -> {C5994561-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise3Conflict] -> {C5994562-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise4Locked] -> {C5994563-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise5ReadOnly] -> {C5994564-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise6Deleted] -> {C5994565-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise7Added] -> {C5994566-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise8Ignored] -> {C5994567-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ Tortoise9Unversioned] -> {C5994568-53D9-4125-87C9-F193FC689CB2} => C:\Program Files\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers: [ AccExtIco1] -> {AB9CF9F8-8A96-4F9D-BF21-CE85714C3A47} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2015-09-11] ()
ShellIconOverlayIdentifiers: [ AccExtIco2] -> {853B7E05-C47D-4985-909A-D0DC5C6D7303} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2015-09-11] ()
ShellIconOverlayIdentifiers: [ AccExtIco3] -> {42D38F2E-98E9-4382-B546-E24E4D6D04BB} => C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSyncExtension\CoreSync_x64.dll [2015-09-11] ()
ShellIconOverlayIdentifiers-x32: [ Tortoise1Normal] -> {C5994560-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise2Modified] -> {C5994561-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise3Conflict] -> {C5994562-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise4Locked] -> {C5994563-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise5ReadOnly] -> {C5994564-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise6Deleted] -> {C5994565-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise7Added] -> {C5994566-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise8Ignored] -> {C5994567-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
ShellIconOverlayIdentifiers-x32: [ Tortoise9Unversioned] -> {C5994568-53D9-4125-87C9-F193FC689CB2} => C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll [2015-08-25] (TortoiseSVN - Home)
Tcpip\Parameters: [DhcpNameServer] 192.168.1.1
Tcpip\..\Interfaces\{1b6feee2-fd5c-4dbc-820d-3de22d63eabb}: [DhcpNameServer] 192.168.1.1
Internet Explorer:
BHO: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files\Java\jre1.8.0_51\bin\ssv.dll [2015-08-04] (Oracle Corporation)
BHO: VIPRE Search Guard Helper -> {963C8283-AE7F-4AA6-9B3B-847A8FC62C5E} -> C:\Program Files (x86)\VIPRE\x64\VSGx64.dll [2015-09-29] ()
BHO: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files\Java\jre1.8.0_51\bin\jp2ssv.dll [2015-08-04] (Oracle Corporation)
BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_51\bin\ssv.dll [2015-08-04] (Oracle Corporation)
BHO-x32: VIPRE Search Guard Helper -> {963C8283-AE7F-4AA6-9B3B-847A8FC62C5E} -> C:\Program Files (x86)\VIPRE\VSG.dll [2015-09-29] ()
BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_51\bin\jp2ssv.dll [2015-08-04] (Oracle Corporation)
Toolbar: HKLM - VIPRE Search Guard Toolbar - {A924C17A-5E94-4E02-BED5-49720BA6F7FA} - C:\Program Files (x86)\VIPRE\x64\VSGx64.dll [2015-09-29] ()
Toolbar: HKLM-x32 - VIPRE Search Guard Toolbar - {A924C17A-5E94-4E02-BED5-49720BA6F7FA} - C:\Program Files (x86)\VIPRE\VSG.dll [2015-09-29] ()
Handler: vipresg - {47BE2E5B-703B-444F-ABD3-05717D2191C6} - C:\Program Files (x86)\VIPRE\x64\VSGx64.dll [2015-09-29] ()
Handler-x32: vipresg - {47BE2E5B-703B-444F-ABD3-05717D2191C6} - C:\Program Files (x86)\VIPRE\VSG.dll [2015-09-29] ()
FireFox:
FF Plugin: @java.com/DTPlugin,version=11.51.2 -> C:\Program Files\Java\jre1.8.0_51\bin\dtplugin\npDeployJava1.dll [2015-08-04] (Oracle Corporation)
FF Plugin: @java.com/JavaPlugin,version=11.51.2 -> C:\Program Files\Java\jre1.8.0_51\bin\plugin2\npjp2.dll [2015-08-04] (Oracle Corporation)
FF Plugin: adobe.com/AdobeAAMDetect -> C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\npAdobeAAMDetect64.dll [2015-09-17] (Adobe Systems)
FF Plugin-x32: @Apple.com/iTunes,version=1.0 -> C:\Program Files (x86)\iTunes\Mozilla Plugins\npitunes.dll [2014-10-30] ()
FF Plugin-x32: @java.com/DTPlugin,version=11.51.2 -> C:\Program Files (x86)\Java\jre1.8.0_51\bin\dtplugin\npDeployJava1.dll [2015-08-04] (Oracle Corporation)
FF Plugin-x32: @java.com/JavaPlugin,version=11.51.2 -> C:\Program Files (x86)\Java\jre1.8.0_51\bin\plugin2\npjp2.dll [2015-08-04] (Oracle Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.28.15\npGoogleUpdate3.dll [2015-09-17] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.28.15\npGoogleUpdate3.dll [2015-09-17] (Google Inc.)
FF Plugin-x32: adobe.com/AdobeAAMDetect -> C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\npAdobeAAMDetect32.dll [2015-09-17] (Adobe Systems)
Chrome:
CHR DefaultSearchKeyword: Default -> t
CHR Profile: C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default
CHR Extension: (Google Slides) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2015-08-04]
CHR Extension: (Google Docs) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2015-08-04]
CHR Extension: (Google Drive) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2015-08-04]
CHR Extension: (YouTube) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2015-08-04]
CHR Extension: (Google Search) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljniedjpjpf [2015-08-04]
CHR Extension: (Google Sheets) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2015-08-04]
CHR Extension: (LoungeDestroyer) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghahcnmfjfckcedfajbhekgknjdplfcl [2015-08-12]
CHR Extension: (Google Docs Offline) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2015-09-04]
CHR Extension: (Chrome Hotword Shared Module) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\lccekmodgklaepjeofjdjpbminllajkg [2015-08-04]
CHR Extension: (Refresh Monkey) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\ljngnafhejmefmijjoedbclkadhacebd [2015-08-05]
CHR Extension: (Chrome Web Store Payments) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2015-08-04]
CHR Extension: (Gmail) - C:\Users\David's PC\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2015-08-04]
==================== Services (Whitelisted) ========================
R2 AdobeUpdateService; C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe [669872 2015-10-11] (Adobe Systems Incorporated)
R2 AGSService; C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe [2015936 2015-10-11] (Adobe Systems, Incorporated)
R2 AMD FUEL Service; C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe [344064 2015-08-21] (Advanced Micro Devices, Inc.) [File not signed]
R2 amdacpusrsvc; C:\Program Files\AMD\{920DEC42-4CA5-4d1d-9487-67BE645CDDFC}\amdacpusrsvc.exe [121856 2015-07-27] (Advanced Micro Devices) [File not signed]
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [77104 2015-09-02] (Apple Inc.)
S3 Origin Client Service; C:\Program Files (x86)\Origin\OriginClientService.exe [2078216 2015-10-08] (Electronic Arts)
R2 SBAMSvc; C:\Program Files (x86)\VIPRE\SBAMSvc.exe [4337696 2015-09-29] (ThreatTrack Security Inc.)
R2 SBPIMSvc; C:\Program Files (x86)\VIPRE\SBPIMSvc.exe [212448 2015-09-29] (ThreatTrack Security Inc.)
R2 VIAKaraokeService; C:\Windows\system32\viakaraokesrv.exe [36504 2015-06-22] (VIA Technologies, Inc.)
R3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [362928 2015-07-10] (Microsoft Corporation)
R3 WebProxy; C:\Program Files (x86)\VIPRE\WebProxy.exe [6339552 2015-09-29] (ThreatTrack Security Inc.)
R2 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [24864 2015-07-10] (Microsoft Corporation)
===================== Drivers (Whitelisted) ==========================
R2 amdacpksd; C:\WINDOWS\system32\drivers\amdacpksd.sys [297672 2015-07-15] (Advanced Micro Devices)
S0 amdkmafd; C:\Windows\System32\drivers\amdkmafd.sys [31992 2015-06-03] (Advanced Micro Devices, Inc.)
R2 AODDriver4.3; C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys [59616 2014-02-11] (Advanced Micro Devices)
R3 AtiHDAudioService; C:\Windows\system32\drivers\AtihdWT6.sys [102912 2015-07-21] (Advanced Micro Devices)
S3 CM_VENDER_CMD; C:\Program Files\Common Files\Logitech\G430Install\CMVC64.sys [17104 2014-07-30] (Windows (R) Win 7 DDK provider)
S3 gfiark; C:\Windows\System32\drivers\gfiark.sys [41032 2013-05-23] (ThreatTrack Security)
S3 gfiutil; C:\Windows\System32\drivers\gfiutil.sys [31264 2013-09-04] (ThreatTrack Security)
R2 LGCoreTemp; C:\Program Files\Logitech Gaming Software\Drivers\LgCoreTemp\lgcoretemp.sys [14184 2015-06-21] (Logitech)
R3 LGJoyXlCore; C:\Windows\system32\drivers\LGJoyXlCore.sys [68384 2015-06-10] (Logitech Inc.)
R3 MTsensor; C:\Windows\System32\drivers\ASACPI.sys [17280 2013-05-17] ()
R3 rt640x64; C:\Windows\System32\drivers\rt640x64.sys [587264 2015-07-10] (Realtek )
S3 rzbtendpt; C:\Windows\System32\drivers\rzbtendpt.sys [49880 2015-07-21] (Razer Inc)
S3 rzdaendpt; C:\Windows\System32\drivers\rzdaendpt.sys [42200 2015-07-21] (Razer Inc)
S3 rzendpt; C:\Windows\System32\drivers\rzendpt.sys [49880 2015-07-21] (Razer Inc)
S3 rzhnet; C:\Windows\System32\Drivers\rzhnet.sys [29912 2015-07-21] (Razer Inc)
S3 rzjstk; C:\Windows\System32\drivers\rzjstk.sys [36568 2015-07-21] (Razer Inc)
S3 rzkeypadendpt; C:\Windows\System32\drivers\rzkeypadendpt.sys [43736 2015-07-21] (Razer Inc)
S3 rzmpos; C:\Windows\System32\drivers\rzmpos.sys [46808 2015-07-21] (Razer Inc)
S3 rzp1endpt; C:\Windows\System32\drivers\rzp1endpt.sys [50392 2015-07-21] (Razer Inc)
S3 rzvkeyboard; C:\Windows\System32\drivers\rzvkeyboard.sys [42200 2015-07-21] (Razer Inc)
S3 rzvmouse; C:\Windows\System32\drivers\rzvmouse.sys [42200 2015-07-21] (Razer Inc)
R2 sbapifs; C:\Windows\System32\DRIVERS\sbapifs.sys [90464 2015-09-29] (ThreatTrack Security Inc.)
R3 sbwtis; C:\Windows\system32\DRIVERS\sbwtis.sys [95608 2015-09-29] (ThreatTrack Security)
S3 UdeCx; C:\Windows\System32\drivers\udecx.sys [44032 2015-07-10] ()
S0 WdBoot; C:\Windows\System32\drivers\WdBoot.sys [44568 2015-07-10] (Microsoft Corporation)
R0 WdFilter; C:\Windows\System32\drivers\WdFilter.sys [291680 2015-07-10] (Microsoft Corporation)
R2 WdNisDrv; C:\Windows\System32\Drivers\WdNisDrv.sys [119648 2015-07-10] (Microsoft Corporation)
R2 WebExaminer; C:\WINDOWS\system32\Drivers\WebExaminer64.sys [44680 2015-09-29] (ThreatTrack Security Inc.)
S3 wfpcapture; \SystemRoot\System32\drivers\wfpcapture.sys [X]
==================== One Month Created files and folders ========
2015-10-19 14:43 - 2015-10-19 14:44 - 00000000 ____D C:\FRST
2015-10-19 14:43 - 2015-10-19 14:43 - 00020350 _____ C:\Users\David's PC\Desktop\FRST.txt
2015-10-19 14:43 - 2015-10-19 11:40 - 00852744 _____ C:\Users\David's PC\Desktop\SecurityCheck.exe
2015-10-19 14:42 - 2015-10-19 11:40 - 02196992 _____ (Farbar) C:\Users\David's PC\Desktop\FRST64.exe
2015-10-19 14:41 - 2015-10-19 14:41 - 00016148 _____ C:\WINDOWS\system32\DESKTOP-9CHG1P7_David's PC_HistoryPrediction.bin
2015-10-18 16:38 - 2015-10-18 16:38 - 00000000 ____D C:\ReplacementFiles
2015-10-18 13:49 - 2015-10-18 13:49 - 00000000 ____D C:\Users\David's PC\AppData\Local\niemiro
2015-10-18 12:57 - 2015-10-18 13:41 - 00000000 ____D C:\SFCFix
2015-10-17 16:15 - 2015-10-17 16:15 - 00000214 _____ C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job
2015-10-17 16:11 - 2015-10-17 16:11 - 00000000 ____D C:\WINDOWS\pss
2015-10-15 17:53 - 2015-10-15 17:53 - 00000000 ____D C:\Logitech
2015-10-13 14:52 - 2015-10-10 02:40 - 21875712 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2015-10-13 14:52 - 2015-10-05 23:03 - 16708608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2015-10-13 14:52 - 2015-09-24 23:17 - 24595456 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2015-10-13 14:51 - 2015-10-10 02:07 - 18806272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2015-10-13 14:51 - 2015-10-05 22:46 - 13027840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2015-10-13 14:51 - 2015-10-01 00:00 - 08020320 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2015-10-13 14:51 - 2015-09-25 00:01 - 02573768 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml6.dll
2015-10-13 14:51 - 2015-09-24 23:56 - 22322624 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2015-10-13 14:51 - 2015-09-24 23:26 - 20858360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2015-10-13 14:51 - 2015-09-24 23:09 - 12504064 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2015-10-13 14:51 - 2015-09-24 23:02 - 07523840 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2015-10-13 14:51 - 2015-09-24 23:01 - 04792320 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2015-10-13 14:51 - 2015-09-24 22:48 - 19325952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2015-10-13 14:51 - 2015-09-24 22:38 - 03580416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2015-10-13 14:51 - 2015-09-24 22:36 - 11262976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2015-10-13 14:51 - 2015-09-24 22:36 - 05454848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2015-10-13 14:50 - 2015-10-10 03:12 - 00078528 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2015-10-13 14:50 - 2015-10-01 00:01 - 01294352 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2015-10-13 14:50 - 2015-10-01 00:01 - 01123400 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2015-10-13 14:50 - 2015-10-01 00:01 - 01018568 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2015-10-13 14:50 - 2015-10-01 00:01 - 00858408 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2015-10-13 14:50 - 2015-09-30 23:03 - 00757760 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapi.dll
2015-10-13 14:50 - 2015-09-25 00:01 - 00498016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\usbhub.sys
2015-10-13 14:50 - 2015-09-24 23:52 - 00980832 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecConfig.efi
2015-10-13 14:50 - 2015-09-24 23:33 - 01997336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml6.dll
2015-10-13 14:50 - 2015-09-24 23:11 - 00257024 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataAccountApis.dll
2015-10-13 14:50 - 2015-09-24 23:11 - 00223232 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneCallHistoryApis.dll
2015-10-13 14:50 - 2015-09-24 23:07 - 01276416 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifinetworkmanager.dll
2015-10-13 14:50 - 2015-09-24 23:04 - 02178560 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2015-10-13 14:50 - 2015-09-24 23:04 - 00826880 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript.dll
2015-10-13 14:50 - 2015-09-24 23:04 - 00771072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2015-10-13 14:50 - 2015-09-24 23:03 - 00796160 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
2015-10-13 14:50 - 2015-09-24 23:03 - 00576000 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
2015-10-13 14:50 - 2015-09-24 23:02 - 00949248 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
2015-10-13 14:50 - 2015-09-24 23:02 - 00689152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authentication.Web.Core.dll
2015-10-13 14:50 - 2015-09-24 23:02 - 00579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
2015-10-13 14:50 - 2015-09-24 23:01 - 03586560 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2015-10-13 14:50 - 2015-09-24 23:00 - 01423872 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataService.dll
2015-10-13 14:50 - 2015-09-24 23:00 - 01382400 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2015-10-13 14:50 - 2015-09-24 23:00 - 00856576 _____ (Microsoft Corporation) C:\WINDOWS\system32\ContactApis.dll
2015-10-13 14:50 - 2015-09-24 23:00 - 00752640 _____ (Microsoft Corporation) C:\WINDOWS\system32\ChatApis.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 01795072 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 01205248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Unistore.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 00720896 _____ (Microsoft Corporation) C:\WINDOWS\system32\EmailApis.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 00685568 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppointmentApis.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 00590336 _____ (Microsoft Corporation) C:\WINDOWS\system32\MessagingDataModel2.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 00288256 _____ (Microsoft Corporation) C:\WINDOWS\system32\PimIndexMaintenance.dll
2015-10-13 14:50 - 2015-09-24 22:59 - 00163840 _____ (Microsoft Corporation) C:\WINDOWS\system32\CallHistoryClient.dll
2015-10-13 14:50 - 2015-09-24 22:58 - 01871360 _____ (Microsoft Corporation) C:\WINDOWS\system32\msxml3.dll
2015-10-13 14:50 - 2015-09-24 22:47 - 00195584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDataAccountApis.dll
2015-10-13 14:50 - 2015-09-24 22:47 - 00172032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PhoneCallHistoryApis.dll
2015-10-13 14:50 - 2015-09-24 22:38 - 00650240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript.dll
2015-10-13 14:50 - 2015-09-24 22:38 - 00574464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2015-10-13 14:50 - 2015-09-24 22:38 - 00504320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
2015-10-13 14:50 - 2015-09-24 22:37 - 00766976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
2015-10-13 14:50 - 2015-09-24 22:37 - 00613376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
2015-10-13 14:50 - 2015-09-24 22:37 - 00480256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authentication.Web.Core.dll
2015-10-13 14:50 - 2015-09-24 22:34 - 00928256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Unistore.dll
2015-10-13 14:50 - 2015-09-24 22:34 - 00625152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ContactApis.dll
2015-10-13 14:50 - 2015-09-24 22:34 - 00579584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppointmentApis.dll
2015-10-13 14:50 - 2015-09-24 22:34 - 00557568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ChatApis.dll
2015-10-13 14:50 - 2015-09-24 22:34 - 00525312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EmailApis.dll
2015-10-13 14:50 - 2015-09-24 22:33 - 00131072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CallHistoryClient.dll
2015-10-13 14:50 - 2015-09-24 22:32 - 01594368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msxml3.dll
2015-10-13 14:50 - 2015-09-24 22:32 - 00466432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MessagingDataModel2.dll
2015-10-12 11:35 - 2015-10-12 11:35 - 00053034 _____ C:\Users\David's PC\Downloads\batman_forever.zip
2015-10-12 11:09 - 2015-10-12 11:09 - 00000000 ____D C:\Users\David's PC\AppData\LocalLow\Adobe
2015-10-12 11:07 - 2015-10-12 11:07 - 00003654 _____ C:\WINDOWS\System32\Tasks\AdobeAAMUpdater-1.0-DESKTOP-9CHG1P7-David's PC
2015-10-12 11:07 - 2015-10-12 11:07 - 00000000 ____D C:\ProgramData\regid.1986-12.com.adobe
2015-10-11 12:32 - 2015-10-11 12:32 - 00001085 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop CC 2015.lnk
2015-10-11 12:28 - 2015-10-12 11:00 - 00000000 ____D C:\Program Files\Adobe
2015-10-11 12:21 - 2015-10-13 14:47 - 00000000 ___RD C:\Users\David's PC\Creative Cloud Files
2015-10-11 12:20 - 2015-10-11 12:20 - 00001302 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Creative Cloud.lnk
2015-10-11 12:20 - 2015-10-11 12:20 - 00001290 _____ C:\Users\Public\Desktop\Adobe Creative Cloud.lnk
2015-10-11 12:17 - 2015-10-11 12:17 - 00686768 _____ (Adobe Systems Incorporated) C:\Users\David's PC\Downloads\CreativeCloudSet-Up (1).exe
2015-10-11 10:58 - 2015-10-11 10:58 - 00003552 _____ C:\WINDOWS\System32\Tasks\{E4BE0B84-287E-46F0-AD0D-FA345291B916}
2015-10-11 10:36 - 2015-10-11 12:32 - 00000000 ____D C:\Users\David's PC\Documents\Adobe
2015-10-11 10:32 - 2015-10-12 11:06 - 00000000 ____D C:\Program Files\Common Files\Adobe
2015-10-11 10:26 - 2015-10-19 14:43 - 00000000 ____D C:\ProgramData\boost_interprocess
2015-10-11 10:26 - 2015-10-11 12:21 - 00000000 ___RD C:\Users\David's PC\Creative Cloud Files (1)
2015-10-11 10:24 - 2015-10-11 12:27 - 00000000 ____D C:\ProgramData\Adobe
2015-10-11 10:23 - 2015-10-12 11:03 - 00000000 ____D C:\Program Files (x86)\Adobe
2015-10-11 10:21 - 2015-10-19 14:43 - 00000000 ____D C:\Users\David's PC\AppData\Local\Adobe
2015-10-11 10:21 - 2015-10-11 10:21 - 00686768 _____ (Adobe Systems Incorporated) C:\Users\David's PC\Downloads\CreativeCloudSet-Up.exe
2015-10-10 11:40 - 2015-10-16 21:11 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\TS3Client
2015-10-10 11:40 - 2015-10-10 11:40 - 00001008 _____ C:\Users\Public\Desktop\TeamSpeak 3 Client.lnk
2015-10-10 11:40 - 2015-10-10 11:40 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamSpeak 3 Client
2015-10-10 11:40 - 2015-10-10 11:40 - 00000000 ____D C:\Program Files\TeamSpeak 3 Client
2015-10-10 11:38 - 2015-10-10 11:40 - 31011848 _____ (TeamSpeak Systems GmbH) C:\Users\David's PC\Downloads\TeamSpeak3-Client-win64-3.0.18.exe
2015-10-09 12:56 - 2015-10-09 12:56 - 00000000 ____D C:\Users\David's PC\Documents\STAR WARS Battlefront Beta
2015-10-08 22:18 - 2015-10-08 22:18 - 00001424 _____ C:\Users\Public\Desktop\STAR WARS Battlefront Beta.lnk
2015-10-08 22:18 - 2015-10-08 22:18 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\STAR WARS Battlefront Beta
2015-10-08 21:50 - 2015-10-08 21:50 - 00000000 ____D C:\Program Files (x86)\Origin Games
2015-10-08 21:49 - 2015-10-09 12:55 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\Origin
2015-10-08 21:49 - 2015-10-08 21:50 - 00000000 ____D C:\Users\David's PC\AppData\Local\Origin
2015-10-08 21:48 - 2015-10-14 20:13 - 00000000 ____D C:\ProgramData\Origin
2015-10-08 21:48 - 2015-10-09 12:56 - 00000000 ____D C:\ProgramData\Electronic Arts
2015-10-08 21:48 - 2015-10-08 21:49 - 00000000 ____D C:\Program Files (x86)\Origin
2015-10-08 21:48 - 2015-10-08 21:48 - 00001052 _____ C:\Users\Public\Desktop\Origin.lnk
2015-10-08 21:48 - 2015-10-08 21:48 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Origin
2015-10-08 21:47 - 2015-10-08 21:48 - 17113896 _____ (Electronic Arts, Inc.) C:\Users\David's PC\Downloads\OriginThinSetup.exe
2015-10-08 14:34 - 2015-10-08 14:34 - 00000000 ____D C:\ProgramData\ATI
2015-10-07 18:29 - 2015-10-07 18:29 - 00061917 _____ C:\WINDOWS\SysWOW64\CCCInstall_201510071829298143.log
2015-10-07 18:29 - 2015-10-07 18:29 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AMD Catalyst Control Center
2015-10-07 18:29 - 2015-10-07 18:29 - 00000000 ____D C:\Program Files\ATI Technologies
2015-10-07 18:28 - 2015-10-07 18:28 - 00061155 _____ C:\WINDOWS\SysWOW64\CCCInstall_201510071828071208.log
2015-10-07 18:25 - 2015-10-07 18:25 - 47794160 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\system32\amdocl64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 39721456 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\SysWOW64\amdocl.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 30776304 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\atio6axx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 27544560 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\system32\amdocl12cl64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 25320432 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\SysWOW64\atioglxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 22327280 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\SysWOW64\amdocl12cl.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 15725552 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\system32\aticaldd64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 14310896 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\SysWOW64\aticaldd.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 09355016 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\amdxc64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 07683096 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\amdxc32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 06686192 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\amdmantle64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 05216240 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\amdmantle32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 03471376 _____ C:\WINDOWS\SysWOW64\atiumdva.cap
2015-10-07 18:25 - 2015-10-07 18:25 - 03437632 _____ C:\WINDOWS\system32\atiumd6a.cap
2015-10-07 18:25 - 2015-10-07 18:25 - 01196032 _____ C:\WINDOWS\system32\amdocl_as64.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 01070592 _____ C:\WINDOWS\system32\amdocl_ld64.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 01004032 _____ C:\WINDOWS\SysWOW64\amdocl_as32.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00935408 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\SysWOW64\atiadlxy.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00935408 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\SysWOW64\atiadlxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00833800 _____ C:\WINDOWS\system32\amdicdxx.dat
2015-10-07 18:25 - 2015-10-07 18:25 - 00807424 _____ C:\WINDOWS\SysWOW64\amdocl_ld32.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00662392 _____ C:\WINDOWS\SysWOW64\atiapfxx.blb
2015-10-07 18:25 - 2015-10-07 18:25 - 00662392 _____ C:\WINDOWS\system32\atiapfxx.blb
2015-10-07 18:25 - 2015-10-07 18:25 - 00631280 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\amdlvr64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00524272 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\SysWOW64\amdlvr32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00471320 _____ C:\WINDOWS\system32\amdmiracast.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00375792 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\atiapfxx.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00341488 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\ATIODE.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00243696 _____ C:\WINDOWS\system32\clinfo.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00213488 _____ C:\WINDOWS\system32\amdgfxinfo64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00199664 _____ (AMD) C:\WINDOWS\system32\atitmm64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00198640 _____ C:\WINDOWS\SysWOW64\amdgfxinfo32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00177344 _____ C:\WINDOWS\system32\ativce03.dat
2015-10-07 18:25 - 2015-10-07 18:25 - 00175648 _____ C:\WINDOWS\system32\amde31a.dat
2015-10-07 18:25 - 2015-10-07 18:25 - 00168944 _____ C:\WINDOWS\system32\atieah64.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00165360 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atig6txx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00152560 _____ C:\WINDOWS\SysWOW64\atieah32.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00151936 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\amdhcp64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00150512 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atigktxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00143344 _____ C:\WINDOWS\system32\amdhdl64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00138384 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\SysWOW64\amdhcp32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00136176 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\mantle64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00132080 _____ C:\WINDOWS\SysWOW64\amdhdl32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00122352 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\mantle32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00117608 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\amdave64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00111600 _____ C:\WINDOWS\system32\hsa-thunk64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00111088 _____ C:\WINDOWS\SysWOW64\hsa-thunk.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00110320 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\amdave32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00103408 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\mantleaxl64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00100816 _____ C:\WINDOWS\system32\ativce02.dat
2015-10-07 18:25 - 2015-10-07 18:25 - 00097776 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atisamu64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00096752 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\mantleaxl32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00089584 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atisamu32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00088000 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atimpc64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00088000 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\amdpcom64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00083952 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atig6pxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00081168 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atimpc32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00081160 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\amdpcom32.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00078320 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atiglpxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00078320 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atiglpxx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00073712 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00071152 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\system32\aticalrt64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00068080 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00064496 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\system32\aticalcl64.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00060912 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\SysWOW64\aticalrt.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00059888 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\ATIODCLI.exe
2015-10-07 18:25 - 2015-10-07 18:25 - 00059376 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\amdmmcl6.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00057840 _____ (Advanced Micro Devices Inc.) C:\WINDOWS\SysWOW64\aticalcl.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00052208 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\Drivers\ati2erec.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00048112 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\amdmmcl.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00047664 _____ C:\WINDOWS\system32\kapp_ci.sbin
2015-10-07 18:25 - 2015-10-07 18:25 - 00043536 _____ C:\WINDOWS\system32\kapp_si.sbin
2015-10-07 18:25 - 2015-10-07 18:25 - 00038384 _____ (AMD) C:\WINDOWS\system32\atimuixx.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00012784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\detoured.dll
2015-10-07 18:25 - 2015-10-07 18:25 - 00012784 _____ (Microsoft Corporation) C:\WINDOWS\system32\detoured.dll
2015-10-07 16:07 - 2015-10-02 13:36 - 00810488 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2015-10-07 16:07 - 2015-10-02 13:36 - 00176632 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2015-10-07 16:05 - 2015-10-07 16:05 - 00001240 _____ C:\WINDOWS\SysWOW64\ServiceConfig.xml
2015-10-07 16:00 - 2013-09-04 14:57 - 00031264 _____ (ThreatTrack Security) C:\WINDOWS\system32\Drivers\gfiutil.sys
2015-10-07 16:00 - 2013-05-23 08:39 - 00041032 _____ (ThreatTrack Security) C:\WINDOWS\system32\Drivers\gfiark.sys
2015-10-07 15:59 - 2015-10-07 15:59 - 00001960 _____ C:\Users\Public\Desktop\VIPRE.lnk
2015-10-07 15:59 - 2015-10-07 15:59 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VIPRE
2015-10-07 15:59 - 2015-09-29 13:10 - 00044680 _____ (ThreatTrack Security Inc.) C:\WINDOWS\system32\Drivers\WebExaminer64.sys
2015-10-07 15:59 - 2015-09-29 13:08 - 00047584 _____ (ThreatTrack Security Inc.) C:\WINDOWS\system32\sbbd.exe
2015-10-07 15:58 - 2015-10-10 10:13 - 00000000 ____D C:\ProgramData\VIPRE
2015-10-07 15:58 - 2015-10-07 16:14 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\VIPRE
2015-10-07 15:58 - 2015-10-07 16:00 - 00000000 ____D C:\Program Files (x86)\VIPRE
2015-10-07 15:57 - 2015-10-07 15:58 - 06556128 _____ (ThreatTrack Security, Inc) C:\Users\David's PC\Downloads\setup-vipre-antivirus-en-us-trial.exe
2015-09-30 20:13 - 2015-09-17 02:50 - 02464216 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2015-09-30 20:13 - 2015-09-17 02:50 - 01563392 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmde.dll
2015-09-30 20:13 - 2015-09-17 02:49 - 06487248 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2015-09-30 20:13 - 2015-09-17 02:49 - 01563472 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmpmde.dll
2015-09-30 20:13 - 2015-09-17 02:49 - 00894256 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Wdf01000.sys
2015-09-30 20:13 - 2015-09-17 02:49 - 00553808 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncHost.exe
2015-09-30 20:13 - 2015-09-17 02:48 - 02824248 _____ (Microsoft Corporation) C:\WINDOWS\system32\msmpeg2vdec.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 02494712 _____ C:\WINDOWS\system32\CoreUIComponents.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 02432336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2015-09-30 20:13 - 2015-09-17 02:48 - 02156400 _____ (Microsoft Corporation) C:\WINDOWS\system32\hevcdecoder.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 01983824 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2015-09-30 20:13 - 2015-09-17 02:48 - 00809352 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 00784136 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 00555768 _____ (Microsoft Corporation) C:\WINDOWS\system32\directmanipulation.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 00537080 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWanAPI.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 00505696 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2015-09-30 20:13 - 2015-09-17 02:48 - 00476760 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFCaptureEngine.dll
2015-09-30 20:13 - 2015-09-17 02:48 - 00332624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fastfat.sys
2015-09-30 20:13 - 2015-09-17 02:47 - 01397088 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManager.dll
2015-09-30 20:13 - 2015-09-17 02:44 - 00781976 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfds.dll
2015-09-30 20:13 - 2015-09-17 02:43 - 00966416 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.appcore.dll
2015-09-30 20:13 - 2015-09-17 02:37 - 01295712 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpx.dll
2015-09-30 20:13 - 2015-09-17 02:28 - 05120056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2015-09-30 20:13 - 2015-09-17 02:28 - 02154808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2015-09-30 20:13 - 2015-09-17 02:28 - 01357888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmde.dll
2015-09-30 20:13 - 2015-09-17 02:28 - 00441168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncHost.exe
2015-09-30 20:13 - 2015-09-17 02:27 - 01766952 _____ C:\WINDOWS\SysWOW64\CoreUIComponents.dll
2015-09-30 20:13 - 2015-09-17 02:27 - 00454512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\directmanipulation.dll
2015-09-30 20:13 - 2015-09-17 02:26 - 02446648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msmpeg2vdec.dll
2015-09-30 20:13 - 2015-09-17 02:26 - 00646672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2015-09-30 20:13 - 2015-09-17 02:26 - 00434376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFCaptureEngine.dll
2015-09-30 20:13 - 2015-09-17 02:26 - 00428128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWanAPI.dll
2015-09-30 20:13 - 2015-09-17 02:25 - 00962400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicenseManager.dll
2015-09-30 20:13 - 2015-09-17 02:21 - 00658528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfds.dll
2015-09-30 20:13 - 2015-09-17 02:20 - 00764416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.appcore.dll
2015-09-30 20:13 - 2015-09-17 02:06 - 00467968 _____ (Microsoft Corporation) C:\WINDOWS\system32\MBMediaManager.dll
2015-09-30 20:13 - 2015-09-17 02:05 - 02226688 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
2015-09-30 20:13 - 2015-09-17 02:04 - 07569408 _____ (Microsoft Corporation) C:\WINDOWS\system32\mos.dll
2015-09-30 20:13 - 2015-09-17 02:04 - 00910848 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedStartModel.dll
2015-09-30 20:13 - 2015-09-17 02:00 - 03248640 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2015-09-30 20:13 - 2015-09-17 02:00 - 02417664 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2015-09-30 20:13 - 2015-09-17 01:58 - 00503808 _____ (Microsoft Corporation) C:\WINDOWS\system32\tileobjserver.dll
2015-09-30 20:13 - 2015-09-17 01:57 - 02228736 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvc.dll
2015-09-30 20:13 - 2015-09-17 01:57 - 00281600 _____ (Microsoft Corporation) C:\WINDOWS\system32\VEEventDispatcher.dll
2015-09-30 20:13 - 2015-09-17 01:56 - 00859136 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2015-09-30 20:13 - 2015-09-17 01:56 - 00521728 _____ (Microsoft Corporation) C:\WINDOWS\system32\PsmServiceExtHost.dll
2015-09-30 20:13 - 2015-09-17 01:55 - 02236416 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2015-09-30 20:13 - 2015-09-17 01:55 - 01601536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Speech.dll
2015-09-30 20:13 - 2015-09-17 01:54 - 03781120 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2015-09-30 20:13 - 2015-09-17 01:54 - 00780288 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.dll
2015-09-30 20:13 - 2015-09-17 01:53 - 07055872 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
2015-09-30 20:13 - 2015-09-17 01:52 - 01181696 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
2015-09-30 20:13 - 2015-09-17 01:52 - 00591360 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmsvc.dll
2015-09-30 20:13 - 2015-09-17 01:52 - 00570880 _____ (Microsoft Corporation) C:\WINDOWS\system32\MbaeApi.dll
2015-09-30 20:13 - 2015-09-17 01:51 - 02660864 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Logon.dll
2015-09-30 20:13 - 2015-09-17 01:51 - 01203712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Devices.Bluetooth.dll
2015-09-30 20:13 - 2015-09-17 01:51 - 01067520 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2015-09-30 20:13 - 2015-09-17 01:51 - 00359936 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncsi.dll
2015-09-30 20:13 - 2015-09-17 01:50 - 00312832 _____ (Microsoft Corporation) C:\WINDOWS\system32\SensorsApi.dll
2015-09-30 20:13 - 2015-09-17 01:49 - 02740224 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2015-09-30 20:13 - 2015-09-17 01:49 - 01290240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Shell.dll
2015-09-30 20:13 - 2015-09-17 01:49 - 01010176 _____ (Microsoft Corporation) C:\WINDOWS\system32\RDXService.dll
2015-09-30 20:13 - 2015-09-17 01:48 - 02093056 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
2015-09-30 20:13 - 2015-09-17 01:48 - 00517632 _____ (Microsoft Corporation) C:\WINDOWS\system32\NotificationController.dll
2015-09-30 20:13 - 2015-09-17 01:48 - 00408064 _____ (Microsoft Corporation) C:\WINDOWS\system32\CredProvDataModel.dll
2015-09-30 20:13 - 2015-09-17 01:48 - 00387584 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
2015-09-30 20:13 - 2015-09-17 01:47 - 00513536 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngcsvc.dll
2015-09-30 20:13 - 2015-09-17 01:45 - 01331200 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIAutomationCore.dll
2015-09-30 20:13 - 2015-09-17 01:45 - 00869376 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapControlCore.dll
2015-09-30 20:13 - 2015-09-17 01:45 - 00627712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.dll
2015-09-30 20:13 - 2015-09-17 01:44 - 00526336 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
2015-09-30 20:13 - 2015-09-17 01:43 - 01213440 _____ (Microsoft Corporation) C:\WINDOWS\system32\RemoteNaturalLanguage.dll
2015-09-30 20:13 - 2015-09-17 01:43 - 00378368 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemEventsBrokerServer.dll
2015-09-30 20:13 - 2015-09-17 01:42 - 02646528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2015-09-30 20:13 - 2015-09-17 01:41 - 00217088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\VEEventDispatcher.dll
2015-09-30 20:13 - 2015-09-17 01:40 - 06101504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mos.dll
2015-09-30 20:13 - 2015-09-17 01:40 - 01918464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2015-09-30 20:13 - 2015-09-17 01:40 - 01162240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Speech.dll
2015-09-30 20:13 - 2015-09-17 01:39 - 00587264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.dll
2015-09-30 20:13 - 2015-09-17 01:38 - 00058368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usoapi.dll
2015-09-30 20:13 - 2015-09-17 01:37 - 00454656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MbaeApi.dll
2015-09-30 20:13 - 2015-09-17 01:35 - 05079552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
2015-09-30 20:13 - 2015-09-17 01:35 - 02207232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2015-09-30 20:13 - 2015-09-17 01:35 - 01820160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll
2015-09-30 20:13 - 2015-09-17 01:35 - 00828928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Devices.Bluetooth.dll
2015-09-30 20:13 - 2015-09-17 01:34 - 00253440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SensorsApi.dll
2015-09-30 20:13 - 2015-09-17 01:32 - 00336384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CredProvDataModel.dll
2015-09-30 20:13 - 2015-09-17 01:32 - 00313856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
2015-09-30 20:13 - 2015-09-17 01:29 - 01104384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIAutomationCore.dll
2015-09-30 20:13 - 2015-09-17 01:29 - 00701952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\JpMapControl.dll
2015-09-30 20:13 - 2015-09-17 01:29 - 00677888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapControlCore.dll
2015-09-30 20:13 - 2015-09-17 01:29 - 00464896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.dll
2015-09-30 20:13 - 2015-09-17 01:26 - 00899584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RemoteNaturalLanguage.dll
2015-09-30 20:13 - 2015-09-17 01:16 - 00512000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2015-09-30 20:13 - 2015-09-12 22:05 - 02987520 _____ (Microsoft Corporation) C:\WINDOWS\system32\esent.dll
2015-09-30 20:13 - 2015-09-12 21:41 - 02639872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\esent.dll
2015-09-30 20:12 - 2015-09-19 01:14 - 00102304 _____ (Microsoft Corporation) C:\WINDOWS\system32\omadmapi.dll
2015-09-30 20:12 - 2015-09-17 02:50 - 00099664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pdc.sys
2015-09-30 20:12 - 2015-09-17 02:50 - 00088384 _____ (Microsoft Corporation) C:\WINDOWS\system32\remoteaudioendpoint.dll
2015-09-30 20:12 - 2015-09-17 02:49 - 00501008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2015-09-30 20:12 - 2015-09-17 02:48 - 00584656 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2015-09-30 20:12 - 2015-09-17 02:48 - 00516448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBHUB3.SYS
2015-09-30 20:12 - 2015-09-17 02:48 - 00406864 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\FWPKCLNT.SYS
2015-09-30 20:12 - 2015-09-17 02:48 - 00395088 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2015-09-30 20:12 - 2015-09-17 02:48 - 00278352 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
2015-09-30 20:12 - 2015-09-17 02:48 - 00243760 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2015-09-30 20:12 - 2015-09-17 02:37 - 01168736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
2015-09-30 20:12 - 2015-09-17 02:28 - 00407608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2015-09-30 20:12 - 2015-09-17 02:28 - 00074880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll
2015-09-30 20:12 - 2015-09-17 02:26 - 01895568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hevcdecoder.dll
2015-09-30 20:12 - 2015-09-17 02:26 - 00508248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2015-09-30 20:12 - 2015-09-17 02:11 - 00160256 _____ (Microsoft Corporation) C:\WINDOWS\system32\enrollmentapi.dll
2015-09-30 20:12 - 2015-09-17 02:10 - 00169984 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmregistration.dll
2015-09-30 20:12 - 2015-09-17 02:09 - 00269312 _____ (Microsoft Corporation) C:\WINDOWS\system32\provengine.dll
2015-09-30 20:12 - 2015-09-17 02:09 - 00143360 _____ (Microsoft Corporation) C:\WINDOWS\system32\provops.dll
2015-09-30 20:12 - 2015-09-17 02:08 - 00494592 _____ (Microsoft Corporation) C:\WINDOWS\system32\StoreAgent.dll
2015-09-30 20:12 - 2015-09-17 02:08 - 00053760 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Speech.Pal.dll
2015-09-30 20:12 - 2015-09-17 02:08 - 00026624 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManagerShellext.exe
2015-09-30 20:12 - 2015-09-17 02:06 - 00690688 _____ (Microsoft Corporation) C:\WINDOWS\system32\CellularAPI.dll
2015-09-30 20:12 - 2015-09-17 02:06 - 00149504 _____ (Microsoft Corporation) C:\WINDOWS\system32\tetheringservice.dll
2015-09-30 20:12 - 2015-09-17 02:05 - 00483328 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneDriveSettingSyncProvider.dll
2015-09-30 20:12 - 2015-09-17 02:04 - 00504320 _____ (Microsoft Corporation) C:\WINDOWS\system32\DataSenseHandlers.dll
2015-09-30 20:12 - 2015-09-17 02:03 - 00267776 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dll
2015-09-30 20:12 - 2015-09-17 02:03 - 00187904 _____ (Microsoft Corporation) C:\WINDOWS\system32\provisioningcsp.dll
2015-09-30 20:12 - 2015-09-17 02:03 - 00154624 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcertinst.exe
2015-09-30 20:12 - 2015-09-17 02:03 - 00088064 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngckeyenum.dll
2015-09-30 20:12 - 2015-09-17 02:03 - 00083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceEnroller.exe
2015-09-30 20:12 - 2015-09-17 02:02 - 00168960 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmmigrator.dll
2015-09-30 20:12 - 2015-09-17 02:02 - 00068096 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseDesktopAppMgmtCSP.dll
2015-09-30 20:12 - 2015-09-17 02:00 - 00446976 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapConfiguration.dll
2015-09-30 20:12 - 2015-09-17 02:00 - 00106496 _____ (Microsoft Corporation) C:\WINDOWS\system32\KeywordDetectorMsftSidAdapter.dll
2015-09-30 20:12 - 2015-09-17 01:57 - 00403456 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
2015-09-30 20:12 - 2015-09-17 01:57 - 00137728 _____ (Microsoft Corporation) C:\WINDOWS\system32\VEStoreEventHandlers.dll
2015-09-30 20:12 - 2015-09-17 01:56 - 00317440 _____ (Microsoft Corporation) C:\WINDOWS\system32\configmanager2.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00671232 _____ (Microsoft Corporation) C:\WINDOWS\system32\WUDFx02000.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00366592 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00346112 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00202240 _____ (Microsoft Corporation) C:\WINDOWS\system32\accountaccessor.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00121856 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcsps.dll
2015-09-30 20:12 - 2015-09-17 01:55 - 00120832 _____ (Microsoft Corporation) C:\WINDOWS\system32\omadmclient.exe
2015-09-30 20:12 - 2015-09-17 01:55 - 00073728 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwancfg.dll
2015-09-30 20:12 - 2015-09-17 01:54 - 00324096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.TestingFramework.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 06572032 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwanmm.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 01216512 _____ (Microsoft Corporation) C:\WINDOWS\system32\netcenter.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 00856576 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 00465920 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwanconn.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 00371712 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlasvc.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 00204800 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcmcsp.dll
2015-09-30 20:12 - 2015-09-17 01:52 - 00162304 _____ (Microsoft Corporation) C:\WINDOWS\system32\SubscriptionMgr.dll
2015-09-30 20:12 - 2015-09-17 01:51 - 01812480 _____ (Microsoft Corporation) C:\WINDOWS\system32\pnidui.dll
2015-09-30 20:12 - 2015-09-17 01:51 - 00145920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mdmregistration.dll
2015-09-30 20:12 - 2015-09-17 01:50 - 00421888 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll
2015-09-30 20:12 - 2015-09-17 01:50 - 00320000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\portcls.sys
2015-09-30 20:12 - 2015-09-17 01:50 - 00221184 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationPeWiFi.dll
2015-09-30 20:12 - 2015-09-17 01:50 - 00204288 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationPeCell.dll
2015-09-30 20:12 - 2015-09-17 01:50 - 00036352 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\buttonconverter.sys
2015-09-30 20:12 - 2015-09-17 01:49 - 00439296 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationWebproxy.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00342016 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationGeofences.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00268800 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationFramework.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00215552 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationCrowdsource.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00176640 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationPeIP.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00095744 _____ (Microsoft Corporation) C:\WINDOWS\system32\LocationWiFiAdapter.dll
2015-09-30 20:12 - 2015-09-17 01:49 - 00041472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Speech.Pal.dll
2015-09-30 20:12 - 2015-09-17 01:48 - 00347136 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncryptprov.dll
2015-09-30 20:12 - 2015-09-17 01:48 - 00273920 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.LockScreen.dll
2015-09-30 20:12 - 2015-09-17 01:47 - 00371712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneDriveSettingSyncProvider.dll
2015-09-30 20:12 - 2015-09-17 01:47 - 00186880 _____ (Microsoft Corporation) C:\WINDOWS\system32\cloudAP.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00928256 _____ (Microsoft Corporation) C:\WINDOWS\system32\JpMapControl.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00621056 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00414208 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00224256 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCore.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00118272 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCsp.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00084480 _____ (Microsoft Corporation) C:\WINDOWS\system32\MDMAppInstaller.exe
2015-09-30 20:12 - 2015-09-17 01:46 - 00079872 _____ (Microsoft Corporation) C:\WINDOWS\system32\HttpsDataSource.dll
2015-09-30 20:12 - 2015-09-17 01:46 - 00030208 _____ (Microsoft Corporation) C:\WINDOWS\system32\syncmlhook.dll
2015-09-30 20:12 - 2015-09-17 01:45 - 00832512 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsStore.dll
2015-09-30 20:12 - 2015-09-17 01:45 - 00193024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Management.dll
2015-09-30 20:12 - 2015-09-17 01:44 - 01844736 _____ (Microsoft Corporation) C:\WINDOWS\system32\workfolderssvc.dll
2015-09-30 20:12 - 2015-09-17 01:44 - 00599552 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnapps.dll
2015-09-30 20:12 - 2015-09-17 01:44 - 00274944 _____ (Microsoft Corporation) C:\WINDOWS\system32\syncutil.dll
2015-09-30 20:12 - 2015-09-17 01:43 - 00328704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapConfiguration.dll
2015-09-30 20:12 - 2015-09-17 01:43 - 00185344 _____ (Microsoft Corporation) C:\WINDOWS\system32\psmsrv.dll
2015-09-30 20:12 - 2015-09-17 01:39 - 00247808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.TestingFramework.dll
2015-09-30 20:12 - 2015-09-17 01:36 - 01171456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netcenter.dll
2015-09-30 20:12 - 2015-09-17 01:32 - 00195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.LockScreen.dll
2015-09-30 20:12 - 2015-09-17 01:31 - 00268800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ncryptprov.dll
2015-09-30 20:12 - 2015-09-17 01:30 - 00311808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
2015-09-30 20:12 - 2015-09-17 01:28 - 00473088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wpnapps.dll
2015-09-29 18:40 - 2015-09-29 18:40 - 00001822 _____ C:\Users\Public\Desktop\iTunes.lnk
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\Program Files\iTunes
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\Program Files\iPod
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\Program Files\Bonjour
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\Program Files (x86)\iTunes
2015-09-29 18:40 - 2015-09-29 18:40 - 00000000 ____D C:\Program Files (x86)\Bonjour
2015-09-29 13:10 - 2015-09-29 13:10 - 00634560 _____ (Xceed Software Inc (450) 442-2626 support@xceedsoft.com www.xceedsoft.com) C:\WINDOWS\SysWOW64\XceedZip.dll
2015-09-29 13:09 - 2015-09-29 13:09 - 00095608 _____ (ThreatTrack Security) C:\WINDOWS\system32\Drivers\sbwtis.sys
2015-09-29 13:08 - 2015-09-29 13:08 - 00090464 _____ (ThreatTrack Security Inc.) C:\WINDOWS\system32\Drivers\sbapifs.sys
2015-09-29 13:08 - 2015-09-29 13:08 - 00047584 _____ (ThreatTrack Security Inc.) C:\WINDOWS\SysWOW64\sbbd.exe
==================== One Month Modified files and folders ========
2015-10-19 14:43 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\AppReadiness
2015-10-19 14:42 - 2015-08-04 00:57 - 00000275 _____ C:\WINDOWS\WindowsUpdate.log
2015-10-19 14:41 - 2015-09-17 19:52 - 00000000 ____D C:\Users\David's PC\AppData\Local\TSVNCache
2015-10-19 14:41 - 2015-08-04 15:46 - 00000000 ____D C:\Program Files (x86)\Steam
2015-10-19 14:41 - 2015-08-04 15:08 - 00000934 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job
2015-10-19 14:40 - 2015-08-04 00:59 - 00005388 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2015-10-19 14:38 - 2015-08-04 15:16 - 00003280 _____ C:\WINDOWS\SysWOW64\WebProxyOff.ini
2015-10-19 14:38 - 2015-08-04 15:16 - 00003280 _____ C:\WINDOWS\system32\WebProxyOff.ini
2015-10-19 14:35 - 2015-08-04 00:54 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
2015-10-18 20:42 - 2015-08-04 15:04 - 00000000 ____D C:\Users\David's PC
2015-10-18 20:42 - 2015-08-04 00:51 - 00065536 _____ C:\WINDOWS\system32\spu_storage.bin
2015-10-18 20:42 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\sru
2015-10-18 20:42 - 2015-08-03 22:51 - 00262144 ___SH C:\WINDOWS\system32\config\BBI
2015-10-18 20:24 - 2015-08-04 15:08 - 00000938 _____ C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job
2015-10-18 13:58 - 2015-08-03 22:54 - 00000000 ____D C:\WINDOWS\CbsTemp
2015-10-18 11:55 - 2015-08-05 08:57 - 02177264 _____ C:\Users\David's PC\Desktop\dism.log
2015-10-18 09:38 - 2015-08-04 00:49 - 00009586 _____ C:\WINDOWS\setupact.log
2015-10-15 18:34 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\NDF
2015-10-15 18:26 - 2015-08-04 15:47 - 00000000 ____D C:\Users\David's PC\AppData\Local\Steam
2015-10-15 17:56 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\WinBioDatabase
2015-10-14 20:13 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\appraiser
2015-10-14 20:08 - 2015-08-04 15:41 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\Skype
2015-10-14 14:49 - 2015-08-13 14:59 - 00000000 ____D C:\WINDOWS\system32\MRT
2015-10-14 14:42 - 2015-08-13 14:59 - 143481208 _____ (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2015-10-12 12:58 - 2015-08-04 21:41 - 00078204 _____ C:\WINDOWS\PFRO.log
2015-10-12 12:58 - 2015-08-04 00:48 - 00202264 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2015-10-12 11:07 - 2015-08-04 15:04 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\Adobe
2015-10-11 10:25 - 2015-08-04 00:51 - 00000000 ____D C:\ProgramData\Package Cache
2015-10-10 09:51 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\rescache
2015-10-09 12:54 - 2015-08-09 12:42 - 00000000 ____D C:\Users\David's PC\AppData\Roaming\Apple Computer
2015-10-08 21:49 - 2015-08-04 15:07 - 00000000 ____D C:\Users\David's PC\AppData\Local\AMD
2015-10-07 18:29 - 2015-08-22 19:08 - 00000000 ____D C:\Program Files (x86)\ATI Technologies
2015-10-07 18:29 - 2015-08-04 00:52 - 00000000 ____D C:\ProgramData\AMD
2015-10-07 18:27 - 2015-08-04 00:51 - 00000000 ____D C:\AMD
2015-10-07 18:25 - 2015-07-16 05:12 - 00162240 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atiuxp64.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 12088008 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atidxx64.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 10211016 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atidxx32.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 08982440 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atiumd6a.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 08864928 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atiumd64.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 08009360 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atiumdva.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 07482560 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atiumdag.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 01479808 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\aticfx64.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 01223552 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\aticfx32.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 00143056 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atiuxpag.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 00130072 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\system32\atiu9p64.dll
2015-10-07 18:25 - 2015-07-16 05:11 - 00112368 _____ (Advanced Micro Devices, Inc. ) C:\WINDOWS\SysWOW64\atiu9pag.dll
2015-10-07 18:25 - 2015-07-16 05:06 - 21648880 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\Drivers\atikmdag.sys
2015-10-07 18:25 - 2015-07-16 04:17 - 00683504 _____ (AMD) C:\WINDOWS\system32\atieclxx.exe
2015-10-07 18:25 - 2015-07-16 04:17 - 00451056 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\atidemgy.dll
2015-10-07 18:25 - 2015-07-16 04:17 - 00255472 _____ (AMD) C:\WINDOWS\system32\atiesrxx.exe
2015-10-07 18:25 - 2015-07-16 04:13 - 01256432 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\atiadlxx.dll
2015-10-07 18:25 - 2015-07-16 04:13 - 00674288 _____ (Advanced Micro Devices, Inc.) C:\WINDOWS\system32\Drivers\atikmpag.sys
2015-10-07 18:25 - 2015-07-16 04:12 - 00874480 _____ (AMD) C:\WINDOWS\system32\coinst_15.20.dll
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ___SD C:\WINDOWS\SysWOW64\F12
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ___SD C:\WINDOWS\system32\F12
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ___RD C:\WINDOWS\PurchaseDialog
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessibility
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\WinBioPlugIns
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\system32\SystemResetPlatform
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\Provisioning
2015-10-07 16:04 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\L2Schemas
2015-10-07 15:58 - 2015-08-04 15:13 - 00000000 ____D C:\ProgramData\Downloaded Installations
2015-10-03 13:15 - 2015-08-04 15:33 - 00000000 ____D C:\ProgramData\Skype
2015-09-29 18:40 - 2015-08-09 12:01 - 00000000 ____D C:\Program Files\Common Files\Apple
2015-09-29 18:24 - 2015-08-03 23:00 - 00000000 ____D C:\WINDOWS\LiveKernelReports
2015-09-29 18:15 - 2015-08-03 23:00 - 00000000 ____D C:\Program Files\Windows Journal
2015-09-26 15:28 - 2015-08-04 15:09 - 00002260 _____ C:\Users\Public\Desktop\Google Chrome.lnk
2015-09-20 17:51 - 2015-08-04 15:08 - 00002353 _____ C:\Users\David's PC\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2015-09-20 17:51 - 2015-08-04 15:08 - 00000000 ___RD C:\Users\David's PC\OneDrive
==================== Files in the root of some directories =======
2015-09-01 20:00 - 2015-09-01 20:00 - 0000906 _____ () C:\Users\David's PC\AppData\Local\_settings.ini
==================== Bamital & volsnap =================
C:\WINDOWS\system32\winlogon.exe => File is digitally signed
C:\WINDOWS\system32\wininit.exe => File is digitally signed
C:\WINDOWS\explorer.exe => File is digitally signed
C:\WINDOWS\SysWOW64\explorer.exe => File is digitally signed
C:\WINDOWS\system32\svchost.exe => File is digitally signed
C:\WINDOWS\SysWOW64\svchost.exe => File is digitally signed
C:\WINDOWS\system32\services.exe => File is digitally signed
C:\WINDOWS\system32\User32.dll => File is digitally signed
C:\WINDOWS\SysWOW64\User32.dll => File is digitally signed
C:\WINDOWS\system32\userinit.exe => File is digitally signed
C:\WINDOWS\SysWOW64\userinit.exe => File is digitally signed
C:\WINDOWS\system32\rpcss.dll => File is digitally signed
C:\WINDOWS\system32\dnsapi.dll
[2015-07-10 07:00] - [2015-08-03 21:19] - 0680256 ____A (Microsoft Corporation) 1DECD2DB5B4FE56FE3FD33910A85C4CB
C:\WINDOWS\SysWOW64\dnsapi.dll IS MISSING <==== ATTENTION
C:\WINDOWS\system32\Drivers\volsnap.sys => File is digitally signed
LastRegBack: 2015-10-17 12:21
==================== End of FRST.txt ============================
And Heres The Check UP:
Results of screen317's Security Check version 1.010 --- 10/01/15
x64 (UAC is enabled)
Internet Explorer 11
``````````````Antivirus/Firewall Check:``````````````
Windows Firewall Enabled!
ThreatTrack Security VIPRE
Windows Defender
Antivirus out of date! (On Access scanning disabled!)
`````````Anti-malware/Other Utilities Check:`````````
Java 8 Update 51
Java version 32-bit out of Date!
Google Chrome (45.0.2454.101)
Google Chrome (45.0.2454.99)
````````Process Check: objlist.exe by Laurent````````
Windows Defender MSMpEng.exe
Windows Defender MpCmdRun.exe
`````````````````System Health check`````````````````
Total Fragmentation on Drive C: %
````````````````````End of Log``````````````````````
I saw in your other topic that SFC was continuously getting stuck at 24%. The reason it was suggested you run SFC is that there has been success repairing the issue with the dnsapi.dll with SFC. So, let's give this a try. Again, you'll need to work between your phone and the computer.
Please do the following to run FRST:
Note: If the tool warns you about the version you're using being an outdated version please download and run the updated version.
NOTICE: This script was written specifically for this user. Running it on another machine may cause damage to your operating system
  • Open Notepad (Start =>All Programs => Accessories => Notepad).
  • Copy/Paste the entire contents of the code box below into Notepad.
start
CreateRestorePoint:
CloseProcesses:
cmd: sfc /scanfile=C:\Windows\system32\dnsapi.dll
cmd: sfc /scanfile=C:\Windows\SysWOW64\dnsapi.dll
EmptyTemp:
end
  • Click Format and ensure Wordwrap is unchecked.
  • Important: Save the code to the same folder/directory that FRST.exe is located in, naming it as fixlist.txt
  • Start FRST in a similar manner to when you ran a scan earlier, but this time when it opens ....
    • Press the Fix button once and wait.
    • FRST will process fixlist.txt
    • When finished, it will produce a log fixlog.txt in the same folder/directory as FRST64.exe
    • Please post the log in your next reply.
Fix result of Farbar Recovery Scan Tool (x64) Version:18-10-2015
Ran by David's PC (2015-10-19 20:00:26) Run:1
Running from C:\Users\David's PC\Desktop\New folder
Loaded Profiles: David's PC (Available Profiles: David's PC)
Boot Mode: Normal
fixlist content:
start
CreateRestorePoint:
CloseProcesses:
EmptyTemp:
end
========= sfc /scanfile=C:\Windows\system32\dnsapi.dll =========
W i n d o w s R e s o u r c e P r o t e c t i o n c o u l d n o t p e r f o r m t h e r e q u e s t e d o p e r a t i o n .
========= sfc /scanfile=C:\Windows\SysWOW64\dnsapi.dll =========
EmptyTemp: => 1.5 GB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 20:02:58 ====
It was worth a try. We'll need replace the corrupt dnsapi.dll. Please follow these instructions carefully. You will need to download a zip file and move it to the computer, unzipping it to the desktop there and then following the FRST instructions. So, take your time and follow the steps in order.
1. Please download the dnsapi_sysWOW64.zip from here and extract the file to your desktop: C:\Users\David's PC\Desktop.
2. Please do the following to run FRST:
start
CreateRestorePoint:
CloseProcesses:
Replace: C:\WinSxS\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a C:\Users\David's PC\Desktop\dnsapi.dll
end
3. Please perform a SFC (System File Checker) scan again.
  • Click Start, and then type cmd in the Start Search box.
  • Right-click cmd in the Programs list, and then right-click Run as administrator.
  • If you are prompted for an administrator password or confirmation, type your password or click Continue
  • At the command prompt, type the following line, and then press ENTER: sfc /scannow (note the space before the slash)
  • When the scan is complete, restart your computer and advise of the results
When I extract the winrar and dnsapi is on my desktop. Do I put the dll in the same folder as FRST is in or can I just keep on my desktop?
FixLog:
Ran by David's PC (2015-10-20 18:40:54) Run:2
Boot Mode: Normal
fixlist content:
start
CreateRestorePoint:
CloseProcesses:
end
"C:\WinSxS\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a" => not found
==== End of Fixlog 18:41:19 ====
Drat!
  • Start FRST with Administrator privileges.
  • Write the following text into the Search textbox: dnsapi.dll
  • Click on the Search Files button.
  • When finished, a log file Search.txt pops up and is saved to the same location the tool was run from.
  • Please copy and paste its contents in your next reply.
Search.txt
Ran by David's PC (2015-10-20 19:11:57)
Boot Mode: Normal
================== Search Files: "dnsapi.dll" =============
C:\Windows\WinSxS\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll
[2015-07-10 07:00][2015-10-17 20:39] 0534064 ____A () D41D8CD98F00B204E9800998ECF8427E [File not signed]
C:\Windows\WinSxS\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll
[2015-07-10 07:00][2015-08-03 21:19] 0680256 ____A (Microsoft Corporation) 1DECD2DB5B4FE56FE3FD33910A85C4CB [File not signed]
C:\Windows\System32\dnsapi.dll
[2015-10-20 18:39][2015-07-10 07:00] 0534064 ____A (Microsoft Corporation) BB5BBD0E4D04047585E4ED0F07AA51E7 [File is digitally signed]
C:\ReplacementFiles\dnsapi.dll
[2015-10-18 16:37][2015-07-10 07:00] 0680256 ____A (Microsoft Corporation) C287D0E32771E3222A444DC527A29477 [File is digitally signed]
====== End of Search ======
One question The dnsapi.dll in my system32 could i delete that one and place the new one you made me download to replace it????
My apology, I provided an incomplete file name. The revised instructions follow with the complete name.
1. Please do the following to run FRST:
start
CreateRestorePoint:
CloseProcesses:
Replace: C:\Windows\WinSxS\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll C:\Users\David's PC\Desktop\dnsapi.dll
end
2. Please perform a SFC (System File Checker) scan again.
Fingers crossed! If it doesn't, I have another member of the team here who I will ask to add a third pair of eyes.
Didnt Work :'(
Fix result of Farbar Recovery Scan Tool (x64) Version:21-10-2015 01
Ran by David's PC (2015-10-21 18:35:14) Run:3
Boot Mode: Normal
fixlist content:
start
CreateRestorePoint:
CloseProcesses:
end
C:\Users\David's PC\Desktop\dnsapi.dll => moved successfully
Could not replace C:\Users\David's PC\Desktop\dnsapi.dll
==== End of Fixlog 18:35:33 ====
I've asked BrianDrab, Windows Update Instructor and Security Analyst for assistance.
Stand by, David. Brian explained what wasn't working and why. I've asked him to provide you with the instructions to ensure we get it correct this time.
