Provide the Components Hive
1. Navigate to
C:\Windows\System32\Config and locate the
COMPONENTS file.
Note: If you find that you need to reboot and are unable to because this is a server then try Option#2 below.
3.
Right-click on this file on your desktop and select
Send To...Compressed (zipped) folder. This will create a file named
COMPONENTS.ZIP on your desktop.
4. The file will likely be too large to upload here so please upload to
Gofile or
WeTransfer and just provide the link here.
- Please download the Freeware RegBak from here: Acelogix Software - Download products
- Go ahead and install this program and accept all the defaults. After the last install screen the program should open.
- Click the New Backup button. Accept the defaults and simply click Start.
- When it says Finished successfully, click the Close button.
- This will bring you back to the main screen of the program. You will see one entry in this list with the date that you did it. Right-click on this line-item and select Explore Backup...
- This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, one of which is named COMPONENTS.
- Copy the COMPONENTS file to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
- Now right-click on the COMPONENTS file that is on your desktop and select Send to > Compressed (zipped) folder.
- Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply.
- You can close any open windows you have as well as the RegBak program now.
