finalzephyr
- Aug 9, 2020
- 24
I have been having so many issues with this audio crackling and it's driving me nuts. I have tested both Realtek and Windows audio drivers, and crackling occurs on both, although slightly less on the Windows one. I have run tests through LatencyMon to make sure that it is an internal issue with my system. I can't find any fixes online so I created this thread. I'll provide information here:
I have attached a link below to the zip file of DxDiag, msinfo32, and the trace file.
39.71 MB file on MEGA
I have also attached screenshots of LatencyMon.
Here below is the link to the speccy snapshot:
http://speccy.piriform.com/results/NnmU42YHUL02rDbL7YmxbPB
- System Manufacturer? ASUSTeK
- Laptop or Desktop? Laptop
- Exact model number (if laptop, check label on bottom) G501JW
- OS ? (Windows 10, 8.1, 8, 7, Vista) Windows 10
- x86 (32bit) or x64 (64bit)? 64 bit
- Service pack? Not sure
- What was original installed OS on system? When I received it last year, it had Windows 10. I reset the laptop while it had Windows 10 installed when I first received it
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? OEM, I think
- Age of system? (hardware) Laptop was made in 2015. I received it last year from someone else, so I do not know when they purchased it
- Age of OS installation? I don't know.
- Have you re-installed the OS? I have only reset the laptop when I received it, so I did not reinstall the operating system
- CPU Intel Core i7 4750HQ
- RAM (brand, EXACT model, what slots are you using?) 8GB DDR3 Dual Channel, Samsung, M471B5173DB0-YK0. More info in the Speccy link I provided
- Video Card NVIDIA GeForce GTX 960M
- MotherBoard - (if NOT a laptop) N/A
- Power Supply - brand & wattage (if laptop, skip this one) N/A
- Is driver verifier enabled or disabled? Disabled
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Windows Defender
- Are you using proxy, vpn, ipfilters or similar software? No
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) No
- Are you currently under/overclocking? Are there overclocking software installed on your system? No
