neutrino Member Joined Apr 13, 2020 Posts 6 Apr 13, 2020 #1 Hello there, I've had an audio issue with my XPS since I bought it. I had abandoned finding a solution until I recently decided to look again and stumbled upon this forum. Everything I've been able to find so far points to a DPC latency issue but haven't found a solution. I hope we can find a solution together. Posting instruction questions: System Manufacturer: Dell Laptop or Desktop: Laptop Exact model number: XPS 9570 OS: Windows 10 Pro x64 (64bit) Service pack? What was original installed OS on system: Windows 10 Pro Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer): OEM version Age of system: 1 year and 6 months Age of OS installation: 1 year and 6 months Have you re-installed the OS: No CPU: i5-8300H RAM: Crucial 32GB kit (16GBx2) DDR4 2666MT/s (PC4-21300) DR x8 SODIMM – installed on two slots (0 slots remaining) Video Card: Intel Integrated UHD Graphics 630 MotherBoard – N/A Power Supply - brand & wattage N/A Is driver verifier enabled or disabled? Not sure What security software are you using? Kaspersky Free (running at startup, CCleaner (running at startup), Malwarebytes (installed and not running at startup – run every 6 months or so) Are you using proxy, vpn, ipfilters or similar software: Yes, NordVPN Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software): No Are you currently under/overclocking? Are there overclocking software installed on your system? No modification made to clock speeds and no overclocking software installed. Link to zipped trace.etl, msinfo32.nfo and DxDiag.txt: DPC Latency Help Files.zip System information from Speccy: http://speccy.piriform.com/results/6dABfdbFIWHBopV2274dqcr Edit: grammar
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Apr 13, 2020 #2 Hi! Please start by updating your BIOS to the latest version and temporarily uninstalling NordVPN. Support for XPS 15 9570 | Drivers & Downloads | Dell US
neutrino Member Joined Apr 13, 2020 Posts 6 Apr 13, 2020 #3 I just did that. It did not seem to improve the audio issue. Trace.etl, msinfo32.nfo and DxDiag Version 2: DPC Latency Help Files V.2.zip
V Vezovi Active member Joined Jan 17, 2020 Posts 39 Apr 14, 2020 #4 Have you tried MSI mode on realtek audio?
neutrino Member Joined Apr 13, 2020 Posts 6 Apr 14, 2020 #5 Vezovi said: Have you tried MSI mode on realtek audio? Click to expand... Could you be more specific? I wasn't able to find any MSI mode in the Realtek audio properties.
neutrino Member Joined Apr 13, 2020 Posts 6 Apr 14, 2020 #7 I just checked the MSI mode. It was already set to 1. Would you suggest to turn it off (value of 0)?
V Vezovi Active member Joined Jan 17, 2020 Posts 39 Apr 15, 2020 #8 You can try, but i don't think its gonna work. If it doesn't, switch back to 1.
neutrino Member Joined Apr 13, 2020 Posts 6 Apr 15, 2020 #9 Vezovi said: You can try, but i don't think its gonna work. If it doesn't, switch back to 1. Click to expand... I turned it off. It didn't yield any results. And then I turned it back on again. No changes in the situation.
neutrino Member Joined Apr 13, 2020 Posts 6 Apr 17, 2020 #10 I've tried uninstalling Kaspersky and Malwarebytes. That, however, didn't improve the situation.
xilolee Moderator Staff member Joined Dec 31, 2013 Posts 3,670 Location World, Europe, Italy Apr 25, 2020 #11 Hi. Try the following command from an elevated command prompt (also known as "command prompt ran as an administrator" or command prompt (admin)) and post its result here: Code: sfc /scannow (It could last from 10 to 50 minutes, usually)
