[SOLVED] WS2016 DISM error 1734 the array bounds are invalid and other problems
ankar84
Russia
Hello!
I have a server with issue look like described in this thread [SOLVED] - WS2016 DISM error 1734 the array bounds are invalid
c:\Windows\System32>%WINDIR%\SysNative\dism.exe /Online /Cleanup-image /Restorehealth
Version: 10.0.14393.4169
Image Version: 10.0.14393.4169
Error: 1734
The array bounds are invalid.
So I'm asking forum help to fix that issue and attach cbs logs according to instruction
  1. Open Windows Explorer and browse to the C:\Windows\Logs folder.
  2. Right-click on the CBS folder and choose Send to > Compressed (zipped) folder.
  3. Now the message will appear, "Windows cannot create the Compressed (zipped) Folder here. Do you want it to be placed on the desktop instead?"
  4. Click on the Yes button here. A file called CBS.zip will be created on your desktop
Another few issues with that server
c:\Windows\System32>sfc /scannow
Windows Resource Protection could not start the repair service.
c:\Windows\System32>DISM.exe /Online /Cleanup-image /Restorehealth
Error: 11
You cannot service a running 64-bit operating system with a 32-bit version of DISM.
Please use the version of DISM that corresponds to your computer's architecture.
c:\Windows\System32>vssadmin list shadows
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2013 Microsoft Corp.
Error: Unexpected failure: Class not registered
Step 1. Download
Hello, Maxstar!
Thank a lot for your help!
Looks like it helped!
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Windows\system32>DISM /online /cleanup-image /RestoreHealth
Error: 11
C:\Windows\system32>%WINDIR%\SysNative\dism.exe /Online /Cleanup-image /Restorehealth
[==========================100.0%==========================] The restore operation completed successfully.
Great, but there's still a redirection issue and could be related to some modified environment variables.
Please run the following command and attach Set.txt to your next post.
set > "%userprofile%\Desktop\set.txt"
It seems some third party tool has changed some environment variables?
We have a few specific software on that server. But that same software do not affect other servers where it installed too. So, I'm no so sure it is a third party software fault.
Can you advice what else to check.
Problems that it see now:
1. dism.exe on works with specified path like %WINDIR%\SysNative\dism.exe
2. sfc /scannow doesn't start with error Windows Resource Protection could not start the repair service.
3. Shadow Copies system shows error Error: Unexpected failure: Class not registered
Could you please run the Set command on another server to compare the result?
Here is a pretty same server because it is a second server in failover cluster. And that server don't have all described issues
S-NSK15-FS00001
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_ARCHITEW6432=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=3e04
S-NSK15-FS00002
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_LEVEL=6
I would suggest to remove the x86 architecture entry first.
Remove the following Environment Vairable.
  • Click the Start button and in the search box, type sysdm.cpl
  • When you see sysdm.cpl > Control Panel Item on the list, right-click on it and select Run as administrator.
  • Open the tab Advanced and click on Environment Variables.
  • Select in the System variables section > PROCESSOR_ARCHITECTURE=x86 and click on the Delete button.
  • Click on Ok and close the System Properties window.
Hmm that's odd, I've never seen this before on systems? There is also another difference between both systems.
FS00001
ProgramData=C:\ProgramData
ProgramFiles=C:\Program Files (x86)
ProgramFiles(x86)=C:\Program Files (x86)
ProgramW6432=C:\Program Files
FS00002
