Windwos 8.1 Pro SFC has in-between-state / WU works but CBS needs repair
MrG
Contributor
Hey,
Windows 8.1 Pro (6.3.9600.17031). I ran into ntfs corruptions (probably bad sata cable or driver issue) and got my system files damaged.
Microsoft update is working fine though and the system seems to be stable now. Eventlogs are quite clean. SFCFix says: "AutoAnalysis:: SUMMARY: No corruptions were detected. AutoAnalysis:: directive completed successfully."
But in fact I now have a state that is in-between.
Running DISM /online /cleanup-image /checkhealth says: "can be repaired".
Running DISM /online /cleanup-image /scanhealth says: "can be repaired".
Running DISM /online /cleanup-image /restorehealth says: Error: 0x800f081f - no action taken. :huh:
CBS Log excerpt:
Operation: Detect and Repair​
Operation result: 0x0​
Last Successful Step: Entire operation completes.​
Total Detected Corruption: 114​
CBS Manifest Corruption: 29​
CBS Metadata Corruption: 10​
CSI Manifest Corruption: 28​
CSI Metadata Corruption: 0​
CSI Payload Corruption: 47​
Total Repaired Corruption: 0​
CBS Manifest Repaired: 0​
CSI Manifest Repaired: 0​
CSI Payload Repaired: 0​
CSI Store Metadata refreshed: True​
Total Operation Time: 668 seconds.​
Eventlog says: 0 of 114 systemstore errors have been repaired.
If required I might be able to pull a WinSxS folder from a backup.
I attached DISM and CBS logs. SFCFix.txt containts no additional info.
I'd like to have a better understanding why DISM is unable to pull required files from WU or the install DVD.
Thanks for your support,:thumbsup2:
MrG
[EDIT]: I just re-ran SFCFix and it gave a different result:
Attempting repair . . .
Stage 1
Stage 2
Stage 3
[SFCFix starting SFC /scannow externally]
-> no errors:huh:
Hello and welcome to the forum :)
SFC /SCANNOW
  1. Right click on the
    button
Convert CBS.log to CBS.txt
    button
  2. Click on Run => Inside the run box copy and paste the following command:
  3. Press Enter
  4. Once this has completed please go to your Desktop and you will find CBS.txt, please rename this file to CBS_{Insert forum username here}_{insert todays Date here}.txt For example "CBS_Go The Power_1803.txt"
  5. Please upload CBS_{Username}_{Date}.txt to this thread.
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or One Drive
Hey Go The Power,
thanks for taking on my case. :thumbsup2: I attached the requested log. It contains more than one SFC run as you will see. I kept the extra runs before. Maybe they provide additional information.
Regards,
MrG
Here's the log as plain text file with the latest results only.
Previous post with big ZIP file might contain more information, though.
Regards,
MrG
Hello again,
This might be a little more tough than I imagined, i should be able to repair it fine, it might just take a couple of rounds.
SFCFix script
  2. Go to your desktop and right click on the background -> Select New -> Text Document -> Name this file SFCFixScript.txt.
  3. Open up SFCFixScript.txt and copy all of the following text inside the code box below and paste it into SFCFixScript.txt.
    Trace::
    wow64_microsoft.windows.powershell.common_31bf3856ad364e35_6.3.9600.17401_none_2c45c4552352d08a
    x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e
    FileScan::
    Pending.GRL
  4. Click on File -> Save. Close out of SFCFixScript.txt.
  5. Save any open documents and close all open windows.
  6. On your Desktop, you should see two files: SFCFix.exe and SFCFixScript.txt.
  7. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
  8. SFCFix will now process the script.
  9. Upon completion, a file should be created on your Desktop: SFCFix.txt.
  10. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
Can you please go the following location C:\Windows\System32\config and look for the following files:
-COMPONENTS
-Any other files that start with the word COMPONENTS
-Or any files that have a similar name to COMPONENTS (it could be spelt different, have a number, a symbol etc)
If you find any please create a folder on your desktop and copy and paste all these files into this folder.
Next can you please zip this folder -> Please name this zip file to COMPONENTS_{Insert forum username here}_{insert todays Date here}.zip For example "COMPONENTS_Go The Power_1803.Zip"
Once done, upload them for me to analyze. The file may be too big to attach to this post, please use either Dropbox or One Drive.
Hey Go The Power,
wow, it really seems to be a hard one. :eek: I did as you said and SFCFix crahed with an unhandled exception.
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-05-05 21:16:10.707
Using .txt script file at C:\Users\Georg\Desktop\SFCFixScript.txt [0]
Trace::
Successfully traced component wow64_microsoft.windows.powershell.common_31bf3856ad364e35_6.3.9600.17401_none_2c45c4552352d08a.
    Package_1548_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-4486_neutral_GDR4
Successfully traced component x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e.
    Package_3_for_KB2934520~31bf3856ad364e35~amd64~~6.3.1.1.2934520-423_neutral_LDR3
SFCFix version 2.4.3.0 by niemiro has encountered an unhandled exception.
Finish time: 2015-05-05 21:16:22.167
Script hash: 2DRf+iFMlaHJCTQ4PDTDTnVfBGAJoEvpgE8ScLtv6f8=
I zipped the COMPONENTS files. COMPONENTS.LOG* has not been written since 2013! .blf an regtrans-ms have been updated some days ago. I'll send you the ondrive link as PM.
I also zipped the only folder in WinSxS containing "PENDING.GRL". I'll send you the ondrive link as PM as well.
BTW: What db format is COMPONENTS. Some kind of SQL express?
[EDIT]: I noticed that I have a very "impressive" WinSxS/Temp/InFlight folder containing 12.078 sub folders. Is that normal?
PendingDeletes contains two files:
$$DeleteMe.malgunmc.ttf.01d007013e3aaa87.0000 --- 03.10.2014
$$DeleteMe.WTVGOTHIC-S.ttc.01d007013e8ebf20.0003 --- 003.10.2014
Pending Renames contains 14.046 elements!
Well, might I just have this problem for a looong time without really noticing it?
Regards,
MrG
One small addition: File change times in PendingRenames match the first time I used SFCFix.exe or later.
Hello again MrG
It is a registry hive :), prety much everything you see inside the registry is linked to a physical file. The registry or regedit is like a viewer for these file, the same way word is a viewer for .doc files.
We will need to address this as well.
DISM Scan
    button
  3. Inside the Command Prompt windows copy and paste the following command DISM /Online /Cleanup-Image /RestoreHealth
    button
  3. Press Enter
Hey Go The Power,
here's the requested log. The command was
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth /source:C:\disk_N\Windows\winsxs
(Source is the winsxs backup I had.)
When I look at the contents it seems there's a lot of work done. However, there is no result. Log contains 3+ dism runs including a service autorun last night.
I wonder what causes
  1. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE] many times
  2. SQM: Warning: Failed to get machine name. The data won't be available. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
  3. Corrupted Payloads
  4. Missing Packages
... and especially the inability to replace the missing or corrupted files from WU or the install DVD. Can you shed some light?
Regards,
MrG
One more thing ;-)
I ran dism /online /cleanup-image /analyzecomponentstore and it said Error: 0x800f0900
The CBS.log reads
2015-05-09 18:23:27, Info                  CBS    TI: --- Initializing Trusted Installer ---
2015-05-09 18:23:27, Info                  CBS    TI: Last boot time: 2015-05-09 05:02:39.490
2015-05-09 18:23:27, Info                  CBS    Starting TrustedInstaller initialization.
2015-05-09 18:23:27, Info                  CBS    Ending TrustedInstaller initialization.
2015-05-09 18:23:27, Info                  CBS    Starting the TrustedInstaller main loop.
2015-05-09 18:23:27, Info                  CBS    TrustedInstaller service starts successfully.
2015-05-09 18:23:27, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart
2015-05-09 18:23:27, Info                  CBS    Startup processing thread terminated normally
2015-05-09 18:23:28, Info                  CBS    Starting TiWorker initialization.
2015-05-09 18:23:28, Info                  CBS    Ending TiWorker initialization.
2015-05-09 18:23:28, Info                  CBS    Starting the TiWorker main loop.
2015-05-09 18:23:28, Info                  CBS    TiWorker starts successfully.
2015-05-09 18:23:28, Info                  CBS    Universal Time is: 2015-05-09 16:23:28.337
2015-05-09 18:23:28, Info                  CBS    Loaded Servicing Stack v6.3.9600.17709 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.17709_none_fa7932f59afc2e40\cbscore.dll
2015-05-09 18:23:28, Info                  CSI    00000001@2015/5/9:16:23:28.340 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff8ee7d7f19 @0x7ff8eeab4984 @0x7ff8eeab41bb @0x7ff7f19ad69a @0x7ff7f19adf4f @0x7ff8fae32053)
2015-05-09 18:23:28, Info                  CBS    SQM: Initializing online with Windows opt-in: True
2015-05-09 18:23:28, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2015-05-09 18:23:28, Info                  CBS    SQM: Requesting upload of all unsent reports.
2015-05-09 18:23:28, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_std.sqm, flags: 0x2
2015-05-09 18:23:28, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_all.sqm, flags: 0x6
2015-05-09 18:23:28, Info                  CBS    NonStart: Set pending store consistency check.
2015-05-09 18:23:28, Info                  CBS    Session: 30444148_2068907324 initialized by client DISM Package Manager Provider.
2015-05-09 18:23:28, Info                  CBS    No call is made on InitiateChanges, Synchronous analysis only.
2015-05-09 18:23:28, Info                  CBS    Analyze: processing started.  Client: DISM Package Manager Provider, Session: 30444148_2068907324
2015-05-09 18:23:28, Info                  CBS    Reboot mark set
2015-05-09 18:23:28, Info                  CBS    Winlogon: Registering for CreateSession notifications
2015-05-09 18:23:28, Info                  CBS    Analyze: begin WinSxS tree walk
2015-05-09 18:23:39, Info                  CBS    Analyze: end WinSxS tree walk
2015-05-09 18:23:39, Info                  CBS    Read out cached package applicability for package: Microsoft-Windows-CameraCodec-Package~31bf3856ad364e35~amd64~~6.3.9600.16453, ApplicableState: 112, CurrentState:112
2015-05-09 18:23:40, Info                  CBS    Skipping package [Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.3.9600.16384] since it has a release-type [Language Pack] that makes it not superseded
2015-05-09 18:23:40, Info                  [B]CBS    Failed to peek next token (status=0xc0000161) [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE][/B]
2015-05-09 18:23:40, Info                  CBS    Failed to get next Token [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Wrong XML DECL [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Invalid xml format [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Manifest parsing error at line: 1, context:
2015-05-09 18:23:40, Info                  CBS    Failed to parse the manifest from the buffer. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed to parse cbs package. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed to load package: Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed to con [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed to read manifest content. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed checking if package is deeply superseded:  [Microsoft-Windows-ProfessionalWMCEdition~31bf3856ad364e35~amd64~~6.3.9600.16384] [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Analyze: Failed to collect packages from package store [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Analyze: Failed getting superseded package count [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Reboot mark cleared
2015-05-09 18:23:40, Info                  CBS    Winlogon: Deregistering for CreateSession notifications
2015-05-09 18:23:40, Info                  CBS    Winlogon: Stopping notify server
2015-05-09 18:23:40, Info                  CBS    Winlogon: Unloading SysNotify DLL
2015-05-09 18:23:40, Info                  CBS    Analyze: processing complete.  Session: 30444148_2068907324 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Error                 CBS    Session: 30444148_2068907324 failed to perform store analysis operation [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Received notification that the operation is complete.
2015-05-09 18:23:40, Info                  CBS    Session: 30444148_2068907324 finalized. Reboot required: no [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-09 18:23:40, Info                  CBS    Failed to FinalizeEx using worker session [HRESULT = 0x800f0900]
2015-05-09 18:23:40, Info                  CBS    progress thread terminated normally
So here's the XML parser error. But can you tell, what actually produces that error?
Regards,
MrG
Hey Go The Power,
can I supply anything else to get this miserable issue resolved or understand what in detail keeps the component store from getting (self-)repaired? :huh:
Regards,
MrG
Hello again,
Sorry for the delay.
There are two files with a XML format, .mum files and .manifest files. This error means either a mum/manifest file is corrupt. DISM has confirmed that there are few mum files corrupt.
These are the errors detected by DISM (this will take a few rounds)
(p)	CBS MUM Corrupt			Package_116_for_KB3008923~31bf3856ad364e35~amd64~~6.3.1.3
(p)	CBS Catalog Corrupt			Package_117_for_KB3008923~31bf3856ad364e35~amd64~~6.3.1.3
(p)	CBS MUM Corrupt			Package_140_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS MUM Corrupt			Package_141_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS Catalog Corrupt			Package_14_for_KB2928680~31bf3856ad364e35~amd64~~6.3.1.2
(p)	CBS MUM Corrupt			Package_187_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_189_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-uiautomationcore_31bf3856ad364e35_6.3.9600.16410_none_ab734e2e4a3e8133
Repair failed: Missing replacement manifest.
(p)	CBS MUM Corrupt			Package_191_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_204_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS Catalog Corrupt			Package_207_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS MUM Corrupt			Package_256_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_259_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS MUM Corrupt			Package_270_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS MUM Corrupt			Package_274_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_2_for_KB2894029~31bf3856ad364e35~amd64~~6.3.1.0
(p)	CBS MUM Corrupt			Package_333_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS MUM Corrupt			Package_371_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_373_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-a..on-authui-component_31bf3856ad364e35_6.3.9600.16412_none_cddf5bb6e397c75f
(p)	CBS MUM Corrupt			Package_3_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CBS MUM Corrupt			Package_41_for_KB2901101~31bf3856ad364e35~amd64~~6.3.1.0
(p)	CBS MUM Corrupt			Package_446_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-directcomposition_31bf3856ad364e35_6.3.9600.16408_none_98e22e8649d66fcf
(p)	CBS MUM Corrupt			Package_452_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-d..ssociationframework_31bf3856ad364e35_6.3.9600.16410_none_1505864a0257d576
(p)	CBS MUM Corrupt			Package_532_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-ui-search_31bf3856ad364e35_6.3.9600.16408_none_f07ec5fe2b15424b
(p)	CBS MUM Corrupt			Package_53_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CBS Catalog Corrupt			Package_57_for_KB2887595~31bf3856ad364e35~amd64~~6.3.2.0
(p)	CSI Manifest Corrupt			amd64_microsoft-hyper-v-vstack-vmwp_31bf3856ad364e35_6.3.9600.16421_none_263ccee13391b861
(p)	CBS MUM Corrupt			Package_622_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16408_none_39c57062f960b936\AppxManifest.xml
Repair failed: Missing replacement payload.
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16408_none_39c57062f960b936\AppxBlockMap.xml
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\SkyDriveTinyLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\SkyDriveWideLogo.scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\SkyDriveSmallLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosLargeLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosLargeLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosLargeLogo.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosSmallLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\SkyDriveSmallLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosSplashScreen.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16408_none_e2c998faf9a70378\PhotosApp.lnk
(p)	CBS MUM Corrupt			Package_709_for_KB2883200~31bf3856ad364e35~amd64~~6.3.1.18
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-m..aviewer-mediashared_31bf3856ad364e35_6.3.9600.16408_none_4caf8ac0829de10b
(p)	CBS MUM Corrupt			Package_99_for_KB3008923~31bf3856ad364e35~amd64~~6.3.1.3
(p)	CBS MUM Corrupt			Package_for_KB2911106_RTM~31bf3856ad364e35~amd64~~6.3.1.3
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-store-client-ui_31bf3856ad364e35_6.3.9600.16442_none_a944a3303753c3fd
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-appx-deployment-client_31bf3856ad364e35_6.3.9600.16452_none_b1134adfe297aef8
(p)	CSI Manifest Corrupt			x86_microsoft-windows-a..on-authui-component_31bf3856ad364e35_6.3.9600.16412_none_71c0c0332b3a5629
(p)	CSI Manifest Corrupt			msil_windowsformsintegration_31bf3856ad364e35_4.0.9600.16404_none_70194aa68565455f
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-a..on-authui-component_31bf3856ad364e35_6.3.9600.16441_none_cdbdeba8e3b101db
(p)	CSI Manifest Corrupt			x86_microsoft-windows-a..on-authui-component_31bf3856ad364e35_6.3.9600.16441_none_719f50252b5390a5
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-appx-deployment-client_31bf3856ad364e35_6.3.9600.16407_none_b14e5bede26aa1f6
(p)	CSI Manifest Corrupt			amd64_6eeda35f1896913d0b4ca0661847cebc_b03f5f7f11d50a3a_6.3.9600.17239_none_35c724178fc8375c
(p)	CSI Manifest Corrupt			amd64_d11a33b45b975e2923addbcf75cba95a_b03f5f7f11d50a3a_6.3.9600.20721_none_cd2e56bf60d67504
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-d..umaninterfacedevice_31bf3856ad364e35_6.3.9600.16403_none_1bd96661addc0af9
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-scripting-jscript9_31bf3856ad364e35_11.0.9600.16412_none_5231f4acd51503ec
(p)	CSI Manifest Corrupt			msil_windowsformsintegration.resources_31bf3856ad364e35_4.0.9600.16404_de-de_833b9a85b1c634a9
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-scripting-jscript9_31bf3856ad364e35_11.0.9600.16438_none_52336c90d513d060
(p)	CSI Manifest Corrupt			amd64_microsoft-hyper-v-vstack-vmwp_31bf3856ad364e35_6.3.9600.16402_none_26536f03338099d6
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_6.3.9600.16441_none_d04c4ed354f3e090
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-kernelstreaming_31bf3856ad364e35_6.3.9600.16395_none_483552c069e25709
(p)	CSI Manifest Corrupt			amd64_microsoft-windows-store-client-ui_31bf3856ad364e35_6.3.9600.16408_none_a975e49c372dec43
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_6.3.9600.16407_none_d07d903f54ce08d6
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-sharedaccess_31bf3856ad364e35_6.3.9600.16404_none_0036ea4951632e75
(p)	CSI Manifest Corrupt			wow64_microsoft-windows-web-app-host_31bf3856ad364e35_6.3.9600.16431_none_2dd5e1d8d73cb439
(p)	CSI Manifest Corrupt			wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16456_none_26d560a171cd383a
(p)	CSI Payload Corrupt			msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf\System.Web.Mobile.resources.dll
(p)	CSI Payload Corrupt			wow64_microsoft-windows-twinui_31bf3856ad364e35_6.3.9600.16500_none_6f0d0411c17ba77b\@TileEmpty1x1Image.png
(p)	CSI Payload Corrupt			wow64_microsoft-windows-twinui_31bf3856ad364e35_6.3.9600.16456_none_6edcf44bc19ece13\@TileEmpty1x1Image.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf
(p)	CSI Payload Corrupt			x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf
(p)	CSI Payload Corrupt			wow64_microsoft-windows-twinui_31bf3856ad364e35_6.3.9600.16457_none_6eddf495c19de76a\@TileEmpty1x1Image.png
(p)	CSI Payload Corrupt			amd64_netfx4clientcorecomp.resources_31bf3856ad364e35_6.3.9600.17187_de-de_9dd6d99e15044673\Microsoft.Windows.ApplicationServer.Applications.dll.mui
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\SkyDriveTinyLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\SkyDriveWideLogo.scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\SkyDriveSmallLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosLargeLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosLargeLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosLargeLogo.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosSmallLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\SkyDriveSmallLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosSplashScreen.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16457_none_e2928914f9d075d6\PhotosApp.lnk
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16457_none_398e607cf98a2b94\AppxManifest.xml
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16457_none_398e607cf98a2b94\AppxBlockMap.xml
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxManifest.xml
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxBlockMap.xml
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveTinyLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveWideLogo.scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-180.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSmallLogo.contrast-black_scale-80.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-140.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSplashScreen.contrast-black_scale-100.png
(p)	CSI Payload Corrupt			amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosApp.lnk
(p)	CSI Payload Corrupt			x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp
(p)	CSI Payload Corrupt			x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386\PJLMON.DLL
(p)	CSI Payload Corrupt			x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386\PJLMON.DLL
(p)	CSI Payload Corrupt			x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386\PJLMON.DLL
(w)	CBS Package Index Package Missing	0x80070490	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-NetFx3-Server-OC-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-NetFx4-OC-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-NetFx4-ServerCore-OC-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Watchlist Package Missing	0x80070490	Microsoft-Windows-ServerCore-Package~31bf3856ad364e35~amd64~~0.0.0.0	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Update Watchlist Package Missing	0x80070490	NetFx3	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
(w)	CBS Update Watchlist Package Missing	0x80070490	NetFx4Extended-ASPNET45	Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384
Summary:
SFC /SCANNOW
  1. Click on the
  4. Please wait for this to Finish before continuing with the rest of the steps.
  1. Click on the
    button => Inside the search box copy and paste the following command:
  2. Press Enter
  3. Once this has completed please go to your Desktop and you will find CBS.txt, please rename this file to CBS_{Insert forum username here}_{insert todays Date here}.txt For example "CBS_Go The Power_1803.txt"
  4. Please upload CBS_{Username}_{Date}.txt to this thread.
Hey Go The Power,
looks to me like it is getting better according to the CBS.log down below, right?
I look forward to the next round. :thumbsup2:
BTW: Why do CBS log files report a HTTp 403 error, when trying to upload sqm file?
2015-05-15 20:32:02, Info                  CBS    SQM: Upload callback called with file path: C:\WINDOWS\servicing\sqm\CBSScavengeSession_0_std.sqm, status: 0x0, HTTP response: 403
Result of the SFCFix script run:
Start time: 2015-05-18 22:40:02.867
Using .zip script file at C:\Users\Georg\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf
Successfully took permissions for file or folder C:\WINDOWS\winsxs\msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386\PJLMON.DLL to C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386\PJLMON.DLL.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386\PJLMON.DLL to C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386\PJLMON.DLL.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386\PJLMON.DLL to C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386\PJLMON.DLL.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp to C:\WINDOWS\winsxs\x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf to C:\WINDOWS\winsxs\x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf\System.Web.Mobile.resources.dll to C:\WINDOWS\winsxs\msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf\System.Web.Mobile.resources.dll.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf to C:\WINDOWS\winsxs\amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxBlockMap.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxBlockMap.xml.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxManifest.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376\AppxManifest.xml.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosApp.lnk to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosApp.lnk.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-100.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-100.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-140.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-140.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-180.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosLargeLogo.contrast-black_scale-180.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSmallLogo.contrast-black_scale-80.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSmallLogo.contrast-black_scale-80.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSplashScreen.contrast-black_scale-100.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\PhotosSplashScreen.contrast-black_scale-100.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-140.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-140.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-180.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveSmallLogo.contrast-black_scale-180.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveTinyLogo.contrast-black_scale-80.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveTinyLogo.contrast-black_scale-80.png.
Successfully copied file C:\Users\Georg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveWideLogo.scale-140.png to C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8\SkyDriveWideLogo.scale-140.png.
Successfully restored ownership for C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386
Successfully restored permissions on C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17328_none_cfe52b70d6184dcd\I386
Successfully restored ownership for C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386
Successfully restored permissions on C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17278_none_cfaf19eed640dc5b\I386
Successfully restored ownership for C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386
Successfully restored permissions on C:\WINDOWS\winsxs\x86_ntprint.inf_31bf3856ad364e35_6.3.9600.17111_none_cfe8f58ad616862d\I386
Successfully restored ownership for C:\WINDOWS\winsxs\x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp
Successfully restored permissions on C:\WINDOWS\winsxs\x86_mscorlib_b77a5c561934e089_4.0.9600.17187_none_8d60d4a1676c663e\normnfc.nlp
Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf
Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_feba3c9dfb652379\license.rtf
Successfully restored ownership for C:\WINDOWS\winsxs\msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf
Successfully restored permissions on C:\WINDOWS\winsxs\msil_system.web.mobile.resources_b03f5f7f11d50a3a_4.0.9600.17219_de-de_594d625d3d914caf
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-l..ult-professionalwmc_31bf3856ad364e35_6.3.9600.16475_none_5ad8d821b3c294af\license.rtf
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxsetup_31bf3856ad364e35_6.3.9600.16477_none_3978c0a4f99a6376
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-filemanager.appxmain_31bf3856ad364e35_6.3.9600.16477_none_e27ce93cf9e0adb8
SFCFix version 2.4.3.0 by niemiro has completed.
Currently storing 9 datablocks.
Finish time: 2015-05-18 22:41:19.450
Script hash: Dpi0j/w3PLf9PTnZKpSxVwIDq00sDRUTu41kcYuVSxk=
And as requested the latest CBS.log attached.
Hey again,
thanks for the fix.zip!
I recovered one additional manifest from a backup and in total the corruption count is down to 97.
Here's in addition the CBS.log created by the last DISM run.
And thanks for the extra clarification you gave. I know know how to access a registry hive and where the XML parser error originates.
Can you also give some insight why this is:
2015-05-19 22:57:36, Info                  CBS    SQM: CheckSur: hrStatus: 0x800f0906 [CBS_E_DOWNLOAD_FAILURE], download Result: 0x800f0941 [CBS_E_WU_MAPPING_UNAVAILABLE]
Is the "windows update mapping" broken or is the file just not included in WU?
Regards,
MrG
And (as it might help?) here's also the result of
dism /online /Cleanup-Image /AnalyzeComponentStore
which fails with
Error: 0x800f0900
2015-05-21 00:56:09, Info                  CBS    TI: --- Initializing Trusted Installer ---
2015-05-21 00:56:09, Info                  CBS    TI: Last boot time: 2015-05-21 00:01:40.492
2015-05-21 00:56:09, Info                  CBS    Starting TrustedInstaller initialization.
2015-05-21 00:56:09, Info                  CBS    Ending TrustedInstaller initialization.
2015-05-21 00:56:09, Info                  CBS    Starting the TrustedInstaller main loop.
2015-05-21 00:56:09, Info                  CBS    TrustedInstaller service starts successfully.
2015-05-21 00:56:09, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart
2015-05-21 00:56:09, Info                  CBS    Startup processing thread terminated normally
2015-05-21 00:56:09, Info                  CBS    Idle scavenging initiated
2015-05-21 00:56:10, Info                  CBS    Starting TiWorker initialization.
2015-05-21 00:56:10, Info                  CBS    Ending TiWorker initialization.
2015-05-21 00:56:10, Info                  CBS    Starting the TiWorker main loop.
2015-05-21 00:56:10, Info                  CBS    TiWorker starts successfully.
2015-05-21 00:56:10, Info                  CBS    Universal Time is: 2015-05-20 22:56:10.567
2015-05-21 00:56:10, Info                  CBS    Loaded Servicing Stack v6.3.9600.17709 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.17709_none_fa7932f59afc2e40\cbscore.dll
2015-05-21 00:56:10, Info                  CSI    00000001@2015/5/20:22:56:10.567 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff9ff1c7f19 @0x7ffa00d74984 @0x7ffa00d741bb @0x7ff7b264d69a @0x7ff7b264e88b @0x7ffa10a02053)
2015-05-21 00:56:10, Info                  CBS    SQM: Initializing online with Windows opt-in: True
2015-05-21 00:56:10, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2015-05-21 00:56:10, Info                  CBS    SQM: Requesting upload of all unsent reports.
2015-05-21 00:56:10, Info                  CBS    SQM: Queued 1 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2
2015-05-21 00:56:10, Info                  CBS    SQM: Upload callback called with file path: C:\Windows\servicing\sqm\PackageChangeBegin_Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~~6.3.9600.16384_0_std.sqm, status: 0x0, HTTP response: 403
2015-05-21 00:56:10, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2015-05-21 00:56:10, Info                  CBS    NonStart: Set pending store consistency check.
2015-05-21 00:56:10, Info                  CBS    Maint: starting/resuming idle maintenance
2015-05-21 00:56:10, Info                  CBS    Session: 30446416_705420339 initialized by client CbsTask.
2015-05-21 00:56:10, Info                  CBS    Maint: processing started.  Client: CbsTask, Session: 30446416_705420339
2015-05-21 00:56:10, Info                  CBS    Maint: launch type: ScheduledTask
2015-05-21 00:56:10, Info                  CBS    Reboot mark set
2015-05-21 00:56:10, Info                  CBS    Winlogon: Registering for CreateSession notifications
2015-05-21 00:56:10, Info                  CBS    Maint: begin deep clean
2015-05-21 00:56:10, Info                  CBS    Read out cached package applicability for package: Microsoft-Windows-CameraCodec-Package~31bf3856ad364e35~amd64~~6.3.9600.16453, ApplicableState: 112, CurrentState:112
2015-05-21 00:56:11, Info                  CBS    Skipping package [Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.3.9600.16384] since it has a release-type [Language Pack] that makes it not superseded
2015-05-21 00:56:12, Info                  CBS    Failed to peek next token (status=0xc0000161) [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed to get next Token [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Wrong XML DECL [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Invalid xml format [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Manifest parsing error at line: 1, context:
2015-05-21 00:56:12, Info                  CBS    Failed to parse the manifest from the buffer. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed to parse cbs package. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed to load package: Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed to con [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed to read manifest content. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed checking if package is deeply superseded: Microsoft-Windows-ProfessionalWMCEdition~31bf3856ad364e35~amd64~~6.3.9600.16384 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Failed automatic deepclean, scenario: 0 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 00:56:12, Info                  CBS    Maint: end deep clean, deep clean time so far: 1 seconds
2015-05-21 00:56:12, Info                  CBS    Maint: begin drain catalogs
2015-05-21 00:56:22, Info                  CBS    Maint: end drain catalogs, drain time so far: 9 seconds
2015-05-21 00:56:22, Info                  CBS    Maint: begin archive logs
2015-05-21 06:37:55, Info                  CBS    Archived backup log: C:\Windows\Logs\CBS\CbsPersist_20150520220209.cab.
2015-05-21 06:37:55, Info                  CBS    CAB compressed log file: C:\Windows\Logs\CBS\CbsPersist_20150520220209.log
2015-05-21 06:38:25, Info                  CBS    Archived backup log: C:\Windows\Logs\CBS\CbsPersist_20150520225609.cab.
2015-05-21 06:38:25, Info                  CBS    CAB compressed log file: C:\Windows\Logs\CBS\CbsPersist_20150520225609.log
2015-05-21 06:38:25, Info                  CBS    Maint: end archive logs, archive time so far: 20529 seconds
2015-05-21 06:38:25, Info                  CBS    Maint: begin scavenge
2015-05-21 06:38:25, Info                  CBS    Scavenge: Start CSI
2015-05-21 06:38:28, Info                  CSI    00000002 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xe005e0f920
2015-05-21 06:38:28, Info                  CSI    00000003 Creating NT transaction (seq 1), objectname [6]"(null)"
2015-05-21 06:38:28, Info                  CSI    00000004 Created NT transaction (seq 1) result 0x00000000, handle @0x2e8
2015-05-21 06:38:28, Info                  CSI    00000005 Poqexec successfully registered in [ml:26{13},l:24{12}]"SetupExecute"
2015-05-21 06:38:28, Info                  CSI    00000006@2015/5/21:04:38:28.450 Beginning NT transaction commit...
2015-05-21 06:38:28, Info                  CSI    00000007@2015/5/21:04:38:28.465 CSI perf trace:
CSIPERF:TXCOMMIT;997
2015-05-21 06:38:28, Info                  CSI    00000008 CSI Store 962193718416 (0x000000e00736fc90) initialized
2015-05-21 06:38:28, Info                  CSI    00000009@2015/5/21:04:38:28.481 CSI Transaction @0xe004ebcdd0 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2015-05-21 06:38:28, Info                  CBS    Scavenge: Begin CSI Store
2015-05-21 06:38:39, Info                  CSI    0000000a Performing 1 operations; 1 are not lock/unlock and follow:
  (0)  Scavenge (8): flags: 00000037
2015-05-21 06:38:39, Info                  CSI    0000000b Scavenge: Begin processing lists
2015-05-21 06:38:39, Info                  CSI    0000000c Scavenge: Begin planning
2015-05-21 06:38:43, Info                  CSI    0000000d Scavenge: Planning Complete.
The following actions will be performed:
    Regeneration Candidates: 0
    Removal Candidates: 6
    Superseded/LDR (Delta Compression) Candidates: 3
    NTFS Compression Candidates: 0
    Null-Delta Compression Candidates:
        Mutable file Candidates: 0
        Boot-Recovery Candidates: 0
    Deletion Candidates (Non Driver): 0
    Driver Deletion Candidates: 0
2015-05-21 06:38:43, Info                  CSI    0000000e Creating NT transaction (seq 2), objectname [6]"(null)"
2015-05-21 06:38:43, Info                  CSI    0000000f Created NT transaction (seq 2) result 0x00000000, handle @0x634
2015-05-21 06:38:43, Info                  CSI    00000010@2015/5/21:04:38:43.594 Beginning NT transaction commit...
2015-05-21 06:38:44, Info                  CSI    00000011@2015/5/21:04:38:44.507 CSI perf trace:
CSIPERF:TXCOMMIT;1334591
2015-05-21 06:38:47, Info                  CSI    00000012@2015/5/21:04:38:47.388 PopulateComponentFamiliesKey - Begin
2015-05-21 06:38:55, Info                  CSI    00000013@2015/5/21:04:38:55.165 PopulateComponentFamiliesKey - End
2015-05-21 06:38:55, Info                  CSI    00000014 Beginning Delta compression of LDR / Superseded Components
2015-05-21 06:38:57, Info                  CSI    00000015 Creating NT transaction (seq 3), objectname [6]"(null)"
2015-05-21 06:38:57, Info                  CSI    00000016 Created NT transaction (seq 3) result 0x00000000, handle @0x15448
2015-05-21 06:38:57, Info                  CSI    00000017@2015/5/21:04:38:57.945 Beginning NT transaction commit...
2015-05-21 06:38:58, Info                  CSI    00000018@2015/5/21:04:38:58.202 CSI perf trace:
CSIPERF:TXCOMMIT;376283
2015-05-21 06:38:59, Info                  CSI    00000019 Creating NT transaction (seq 4), objectname [6]"(null)"
2015-05-21 06:38:59, Info                  CSI    0000001a Created NT transaction (seq 4) result 0x00000000, handle @0x15704
2015-05-21 06:38:59, Info                  CSI    0000001b@2015/5/21:04:38:59.162 Beginning NT transaction commit...
2015-05-21 06:38:59, Info                  CSI    0000001c@2015/5/21:04:38:59.618 CSI perf trace:
CSIPERF:TXCOMMIT;667425
2015-05-21 06:38:59, Info                  CSI    0000001d Creating NT transaction (seq 5), objectname [6]"(null)"
2015-05-21 06:38:59, Info                  CSI    0000001e Created NT transaction (seq 5) result 0x00000000, handle @0x154cc
2015-05-21 06:38:59, Info                  CSI    0000001f@2015/5/21:04:38:59.882 Beginning NT transaction commit...
2015-05-21 06:39:00, Info                  CSI    00000020@2015/5/21:04:39:00.292 CSI perf trace:
CSIPERF:TXCOMMIT;598711
2015-05-21 06:39:00, Info                  CSI    00000021 Delta compression complete. Total number of components compressed: 3, Total file compressed: 6, Total files untouched: 5, Total file skipped due to backing: 0, Total file size compressed:2117632, Total delta file size: 188416, compression ratio: 91%
2015-05-21 06:39:00, Info                  CSI    00000022 Scavenge: List processing complete.
2015-05-21 06:43:08, Info                  CSI    00000023 Couldn't mark for pending delete: [ml:78{39},l:76{38}]"\SystemRoot\WinSxS\Temp\PendingDeletes"\[l:90{45}]"$$DeleteMe.malgunmc.ttf.01d007013e3aaa87.0000".  Reason: [13]"Cannot Delete"
2015-05-21 06:43:08, Info                  CSI    00000024 Couldn't mark for pending delete: [ml:78{39},l:76{38}]"\SystemRoot\WinSxS\Temp\PendingDeletes"\[l:96{48}]"$$DeleteMe.WTVGOTHIC-S.ttc.01d007013e8ebf20.0003".  Reason: [13]"Cannot Delete"
2015-05-21 06:43:33, Info                  CBS    Session: 30446464_2974735941 initialized by client DISM Package Manager Provider.
2015-05-21 06:43:33, Info                  CBS    No call is made on InitiateChanges, Synchronous analysis only.
2015-05-21 06:43:43, Info                  CSI    00000025 ICSITransaction::Commit calling IStorePendingTransaction::Apply - coldpatching=FALSE applyflags=7
2015-05-21 06:43:43, Info                  CSI    00000026 Creating NT transaction (seq 6), objectname [6]"(null)"
2015-05-21 06:43:43, Info                  CSI    00000027 Created NT transaction (seq 6) result 0x00000000, handle @0x34c
2015-05-21 06:43:43, Info                  CSI    00000028 Poqexec successfully registered in [ml:26{13},l:24{12}]"SetupExecute"
2015-05-21 06:43:43, Info                  CSI    00000029@2015/5/21:04:43:43.309 Beginning NT transaction commit...
2015-05-21 06:43:43, Info                  CSI    0000002a@2015/5/21:04:43:43.637 CSI perf trace:
CSIPERF:TXCOMMIT;481223
2015-05-21 06:43:43, Info                  CBS    Scavenge: Completed, disposition: 0X1
2015-05-21 06:43:43, Info                  CSI    0000002b@2015/5/21:04:43:43.637 CSI Transaction @0xe004ebcdd0 destroyed
2015-05-21 06:43:43, Info                  CBS    Maint: end scavenge, scavenge time so far: 318 seconds
2015-05-21 06:43:43, Info                  CBS    Maint: TransientManifestCache disabled in config.
2015-05-21 06:43:43, Info                  CBS    Maint: completed, interruptions: 0, (this pass: time: 20858 seconds, used space change: -1325652 KB, hr: 0x800f0900, source: PackageRemoval)
2015-05-21 06:43:43, Info                  CBS    SQM: Upload requested for report: CBSScavengeSession, session id: 101457977, sample type: Standard
2015-05-21 06:43:43, Info                  CBS    SQM: Warning: Failed to get machine name. The data won't be available. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2015-05-21 06:43:43, Info                  CBS    SQM: Warning: Failed to get domain name. The data won't be available. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2015-05-21 06:43:43, Info                  CBS    SQM: Queued 1 file(s) for upload with pattern: C:\Windows\servicing\sqm\CBSScavengeSession_*_std.sqm, flags: 0x2
2015-05-21 06:43:43, Info                  CBS    SQM: Upload callback called with file path: C:\Windows\servicing\sqm\CBSScavengeSession_0_std.sqm, status: 0x0, HTTP response: 403
2015-05-21 06:43:43, Info                  CBS    Reboot mark cleared
2015-05-21 06:43:43, Info                  CBS    Winlogon: Deregistering for CreateSession notifications
2015-05-21 06:43:43, Info                  CBS    Winlogon: Stopping notify server
2015-05-21 06:43:43, Info                  CBS    Winlogon: Unloading SysNotify DLL
2015-05-21 06:43:43, Info                  CBS    Maint: processing complete.  Session: 30446416_705420339. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:43:43, Info                  CBS    Failed performing maintenance task [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:43:43, Info                  CBS    Analyze: processing started.  Client: DISM Package Manager Provider, Session: 30446464_2974735941
2015-05-21 06:43:43, Info                  CBS    Reboot mark set
2015-05-21 06:43:43, Info                  CBS    Winlogon: Registering for CreateSession notifications
2015-05-21 06:43:43, Info                  CBS    Analyze: begin WinSxS tree walk
2015-05-21 06:43:43, Info                  CBS    Warning: Failed while executing service idle processing. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:43:43, Info                  CBS    Failed to run idle scavenge [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:43:43, Info                  CBS    Warning: Failed to execute idle scavenge start. Error code: 0X800f0900 [HRESULT = 0x800f0900]
2015-05-21 06:43:43, Info                  CBS    Signalling IdleScavenge Complete.
2015-05-21 06:44:25, Info                  CBS    Failed opening C:\Windows\WinSxS\ManifestCache\ce67db068093d0010400000040124404 [HRESULT = 0xd0000056 - NTSTATUS Error]
2015-05-21 06:44:25, Info                  CBS    Failed enumerating hardlinks for C:\Windows\WinSxS\ManifestCache\ce67db068093d0010400000040124404 [HRESULT = 0xd0000056 - NTSTATUS Error]
2015-05-21 06:45:41, Info                  CBS    Analyze: end WinSxS tree walk
2015-05-21 06:45:41, Info                  CBS    Read out cached package applicability for package: Microsoft-Windows-CameraCodec-Package~31bf3856ad364e35~amd64~~6.3.9600.16453, ApplicableState: 112, CurrentState:112
2015-05-21 06:45:44, Info                  CBS    Skipping package [Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.3.9600.16384] since it has a release-type [Language Pack] that makes it not superseded
2015-05-21 06:45:46, Info                  CBS    Failed to peek next token (status=0xc0000161) [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to get next Token [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Wrong XML DECL [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Invalid xml format [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Manifest parsing error at line: 1, context:
2015-05-21 06:45:46, Info                  CBS    Failed to parse the manifest from the buffer. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to parse cbs package. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to load package: Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.3.9600.16384 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to con [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to read manifest content. [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed checking if package is deeply superseded:  [Microsoft-Windows-ProfessionalWMCEdition~31bf3856ad364e35~amd64~~6.3.9600.16384] [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Analyze: Failed to collect packages from package store [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Analyze: Failed getting superseded package count [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Reboot mark cleared
2015-05-21 06:45:46, Info                  CBS    Winlogon: Deregistering for CreateSession notifications
2015-05-21 06:45:46, Info                  CBS    Winlogon: Stopping notify server
2015-05-21 06:45:46, Info                  CBS    Winlogon: Unloading SysNotify DLL
2015-05-21 06:45:46, Info                  CBS    Analyze: processing complete.  Session: 30446464_2974735941 [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Error                 CBS    Session: 30446464_2974735941 failed to perform store analysis operation [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Session: 30446464_2974735941 finalized. Reboot required: no [HRESULT = 0x800f0900 - CBS_E_XML_PARSER_FAILURE]
2015-05-21 06:45:46, Info                  CBS    Failed to FinalizeEx using worker session [HRESULT = 0x800f0900]
2015-05-21 06:45:46, Info                  CBS    Received notification that the operation is complete.
2015-05-21 06:45:46, Info                  CBS    progress thread terminated normally
2015-05-21 06:47:46, Info                  CBS    Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2015-05-21 06:47:46, Info                  CBS    TiWorker signaled for shutdown, going to exit.
2015-05-21 06:47:46, Info                  CBS    Ending the TrustedInstaller main loop.
2015-05-21 06:47:46, Info                  CBS    Starting TrustedInstaller finalization.
2015-05-21 06:47:46, Info                  CBS    Ending TrustedInstaller finalization.
2015-05-21 06:47:46, Info                  CBS    Ending the TiWorker main loop.
2015-05-21 06:47:46, Info                  CBS    Starting TiWorker finalization.
2015-05-21 06:47:46, Info                  CBS    Ending TiWorker finalization.
Meanwhile I ran /AnalyzeComponentStore dozens of times and one by one replaced corrupted mums in servicing with working ones from another Windows 8 system.
Finally AnalyzeComponentStore was able to complete successfully. I'll see how things are going now and post back later.
Hey Go The Power,
here is the status:
DISM /online /cleanup-image /analyzecomponentstore runs ok !
DISM /online /cleanup-image /analyzecomponentstore returns Error: 14098 !
DISM /online /cleanup-image /restorehealth gives: Error 0x800f081f Error when reparing. Either the reapir source was not found or the store is corrupt.
I attached both DISM.log and CBS.log.
Well, Go The Power, that's the point where you come in ... :thumbsup2:
Regards,
MrG
