Windows PINTLGB.IMD corrupt can not repair-- I have SAME problem
Badger
Hiya Go the Power (ex sth aussie and port supporter here btw) :lol:
anyway i seem to have the exact same problem as poto, i resisted the temptation to apply the fix shown later in this thread but have run sfcfix and here are the results.
[CODE]
Start time: 2014-09-14 13:53:47.407
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD
CORRUPT: C:\Windows\winsxs\wow64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_808c0da292f3ca46\PINTLGB.IMD
Finish time: 2014-09-14 14:12:29.728
[/CODE]
Its happening on a laptop too (asus) causing the sys to freeze, have run malwarebytes, jrt and avast and all came up clean, as did chkdsk and mem test
Rgds
Badger
Hi Badger and welcome to Sysnative forums :)
Ex port supporter? Not to sure if I can help you if you don't still barrack for Port :p.
Lets get that file fixed up.
SFC /SCANNOW
  1. Right click on the
    button
Convert CBS.log to CBS.txt
    button
  2. Click on Run => Inside the run box copy and paste the following command:
  3. Press Enter
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or ge.tt
