Sound starts to crackle and the mous movement lags when the pc has run for like 30-100 minutes.
This is happening on a clean install.
I ran LatencyMon and it showed me that ntoskrnl.exe and ndis.sys is spiking at like 1,3 ms and 0,95 ms each.
I tried to update my GPU driver and my mobo has no bios updates avaliable, also I tried to update my chipset drivers, ethernet drivers, usb host controller driver and the audio driver.
I will attach my LatencyMon log file.
CONCLUSION
LatencyMon has been analyzing your system for 0:27:33 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: KGB
OS version: Windows 10, 10.0, version 1903, build: 18362 (x64)
Hardware: To be filled by O.E.M., Gigabyte Technology Co., Ltd.
CPU: AuthenticAMD AMD FX-8370 Eight-Core Processor
Logical processors: 8
Processor groups: 1
RAM: 10214 MB total
CPU SPEED
Reported CPU speed: 4019 MHz
Highest measured interrupt to process latency (µs): 4693,30
Average measured interrupt to process latency (µs): 9,510618
Highest measured interrupt to DPC latency (µs): 4686,20
Average measured interrupt to DPC latency (µs): 4,015414
REPORTED ISRs
Highest ISR routine execution time (µs): 226,455088
Highest reported total ISR routine time (%): 0,082551
Total time spent in ISRs (%) 0,088348
ISR count (execution time <250 µs): 430683
REPORTED DPCs
Highest DPC routine execution time (µs): 1291,963175
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0,044555
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 460.79 , NVIDIA Corporation
Total time spent in DPCs (%) 0,174993
DPC count (execution time <250 µs): 4844998
DPC count (execution time 500-10000 µs): 495
DPC count (execution time 1000-2000 µs): 14
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: avastsvc.exe
Total number of hard pagefaults 12282
Hard pagefault count of hardest hit process: 4865
Number of processes hit: 47
PER CPU DATA
CPU 0 Interrupt cycle time (s): 85,614357
CPU 0 ISR highest execution time (µs): 226,455088
CPU 0 ISR total execution time (s): 11,604036
CPU 0 ISR count: 411913
CPU 0 DPC highest execution time (µs): 1291,963175
CPU 0 DPC total execution time (s): 21,282976
CPU 0 DPC count: 4729808
CPU 1 Interrupt cycle time (s): 19,196833
CPU 1 ISR highest execution time (µs): 120,538194
CPU 1 ISR total execution time (s): 0,065530
CPU 1 ISR count: 10614
CPU 1 DPC highest execution time (µs): 220,728042
CPU 1 DPC total execution time (s): 0,244516
CPU 1 DPC count: 19684
CPU 2 Interrupt cycle time (s): 18,841709
CPU 2 ISR highest execution time (µs): 32,034835
CPU 2 ISR total execution time (s): 0,00540
CPU 2 ISR count: 2129
CPU 2 DPC highest execution time (µs): 952,901966
CPU 2 DPC total execution time (s): 0,784862
CPU 2 DPC count: 45062
CPU 3 Interrupt cycle time (s): 18,621585
CPU 3 ISR highest execution time (µs): 7,697686
CPU 3 ISR total execution time (s): 0,002310
CPU 3 ISR count: 1141
CPU 3 DPC highest execution time (µs): 201,893755
CPU 3 DPC total execution time (s): 0,141921
CPU 3 DPC count: 17553
CPU 4 Interrupt cycle time (s): 17,209911
CPU 4 ISR highest execution time (µs): 7,329435
CPU 4 ISR total execution time (s): 0,001511
CPU 4 ISR count: 784
CPU 4 DPC highest execution time (µs): 814,604130
CPU 4 DPC total execution time (s): 0,349565
CPU 4 DPC count: 14478
CPU 5 Interrupt cycle time (s): 16,821612
CPU 5 ISR highest execution time (µs): 7,272953
CPU 5 ISR total execution time (s): 0,00110
CPU 5 ISR count: 589
CPU 5 DPC highest execution time (µs): 204,982085
CPU 5 DPC total execution time (s): 0,067347
CPU 5 DPC count: 8006
CPU 6 Interrupt cycle time (s): 13,202977
CPU 6 ISR highest execution time (µs): 19,829062
CPU 6 ISR total execution time (s): 0,001337
CPU 6 ISR count: 740
CPU 6 DPC highest execution time (µs): 530,018164
CPU 6 DPC total execution time (s): 0,234510
CPU 6 DPC count: 6978
CPU 7 Interrupt cycle time (s): 12,786521
CPU 7 ISR highest execution time (µs): 22,560587
CPU 7 ISR total execution time (s): 0,004561
CPU 7 ISR count: 2773
CPU 7 DPC highest execution time (µs): 231,740732
CPU 7 DPC total execution time (s): 0,040634
CPU 7 DPC count: 3938
CONCLUSION
SYSTEM INFORMATION
Computer name: KGB
Processor groups: 1
RAM: 10214 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
