[Win7SP1 x64] DPC latency issue (crackling audio) dxgkrnl.sys
explorers
I have notebook Dell vostro 3700 with Windows 7 x64 SP1.
While using sound card which is located in motherboard there were no clicks. But when the connecting cables to the sound card broke, I bought an external sound card (E-MU Tracker Pre) with a connection to a computer by usb. And started the nightmare with clicks in any applications.
Download applications DPC Latency Checker and latency monitor and found USBPORT.SYS and dxgkrnl.sys 14778,15788 us
Also disabled system drives I do not use (Lan, ricoh memory stick host controller).
Hi TemplarBlood. :welcome:
Would you try these steps?
Preamble
In case you don't know how to open an elevated command prompt in windows 7, you can use one of these three methods:
  • click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear
  • click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear
  • click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear
  • Left-click on Start, type directly msconfig, press enter.
    Is the radio button on normal startup?
  • Advanced disk cleanup with cleanmgr:
    • Open an elevated command prompt
    • Type cleanmgr /sageset:1 and press enter.
    • Select all the options, or leave unticked the ones you prefer.
    • Type cleanmgr /sagerun:1 and press enter
    • Let it work until it finishes.
  • Launch this command from an elevated command prompt:
    If you get the following message:
    Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
    Read Windows Update Forum Posting Instructions (click) and provide the necessary (and missing) informations to the experts. I.e., you should:
    • export and zip/compress the entire CBS folder on your desktop
    • open a new topic in the windows update sub-forum (in sysnative.com)
    • attach that zipped file to that new topic
    If the CBS compressed folder will be too large, you can check the second post on that thread (to use the sfcfix tool with a script) or you can use a (possibly fast) web service like MS OneDrive, Google Drive, DropBox, Box, Mega, Apple iCloud, Amazon Cloud Drive, and so forth...
    Instead if you get the following messages, go to the next step:
    Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log
  • Defragment your system drive (using windows default defragmenter). Steps:
    • Type defrag c: /h and press enter
    • Wait until it finishes
  • Check your system partition, then post the result here. Steps:
    • Open an elevated command prompt.
    • Type chkdsk c: /b and press enter.
    • You'll get:
      Cannot lock current drive.
    • Type Y and press enter.
    • Then restart/reboot and wait until it finishes this check.
    • To find chkdsk result:
      • Copy/paste this command and press enter:
        wevtutil qe application /c:1 /rd:true  /f:text /q:"*[System[Provider[(@Name='Microsoft-Windows-Wininit')]]]" > "%userprofile%\desktop\ChkDskLOG.txt" & notepad "%userprofile%\desktop\ChkDskLOG.txt"
      • It should create chkdsklog.txt on your desktop and open it: paste its content here.
      • If the command won't work, type eventvwr, press enter, in the event viewer window double-left-click Windows Logs to expand it, left-click Application, double-left-click the information event with source wininit, copy its content and post it here.
If the problem persists:
    • System Manufacturer?
    • Laptop or Desktop?
    • x86 (32bit) or x64 (64bit)?
    • Service pack?
    • Age of system? (hardware)
    • Age of OS installation?
    • CPU
    • RAM (brand, model, which slots are you using?)
    • Video Card
    1. Download Speccy portable - actual version 1.30.730 (click), unzip/decompress it and put it on your desktop.
      (Or generate a log in your pc, if you prefer to not publish the snapshot for some reason)
      (Or upload here the generated log, in case you didn't publish the snapshot)
  • Facultative System information log (if previous point fails for some obscure reason)
    The following command should be run from an elevated command prompt.
    It should generate a log, named MsInfo.nfo, on your desktop, after some time (few seconds or minutes).
    msinfo32 /nfo msinfo32 /nfo "%userprofile%\desktop\MsInfo.nfo"
    (Then upload it here)
  • Download and install the Windows Performance Toolkit - Windows Assessment and Deployment Kit (Windows ADK) for Windows 8.1 Update - adksetup.exe 1.36MB (click):
    Then open an elevated command prompt (right-click on the windows start button on bottom-left corner, left-click Command Prompt (Admin)) and launch these commands:
    You can also read the original tutorial/guide and its following posts for more informations:
    How to Diagnose and Fix High DPC Latency Issues with WPA (Windows Vista/7/8) (click) (by Niemiro)
