Hi
Recently built a new Ryzen system using the X370 Gaming K4 board and R1700
Installed a fresh Win10 and the stuttering / cracking sound when playing music is really annoying me
I checked using Latency Mon and here's the report:
CONCLUSION
LatencyMon has been analyzing your system for 0:08:15 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: BRIAN-PC
OS version: Windows 10 , 10.0, build: 14393 (x64)
Hardware: ASRock, X370 Gaming K4
CPU: AuthenticAMD AMD Ryzen 7 1700 Eight-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 16336 MB total
CPU SPEED
Reported CPU speed: 3394 MHz
Highest measured interrupt to process latency (µs): 12152.382496
Average measured interrupt to process latency (µs): 38.471915
Highest measured interrupt to DPC latency (µs): 12146.515828
Average measured interrupt to DPC latency (µs): 30.723641
REPORTED ISRs
Highest ISR routine execution time (µs): 17.921626
Driver with highest ISR routine execution time: Wdf01000.sys - 核心模式驅動程式架構執行階段, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001438
Driver with highest ISR total time: Wdf01000.sys - 核心模式驅動程式架構執行階段, Microsoft Corporation
Total time spent in ISRs (%) 0.001438
ISR count (execution time <250 µs): 138246
REPORTED DPCs
Highest DPC routine execution time (µs): 12173.662935
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.251734
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.434728
DPC count (execution time <250 µs): 1753924
DPC count (execution time 500-999 µs): 41
DPC count (execution time 2000-3999 µs): 39
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 251
Hard pagefault count of hardest hit process: 121
Highest hard pagefault resolution time (µs): 50018.117266
Total time spent in hard pagefaults (%): 0.020753
Number of processes hit: 13
PER CPU DATA
CPU 0 Interrupt cycle time (s): 46.961074
CPU 0 ISR highest execution time (µs): 17.921626
CPU 0 ISR total execution time (s): 0.061983
CPU 0 ISR count: 67031
CPU 0 DPC highest execution time (µs): 12173.662935
CPU 0 DPC total execution time (s): 33.348608
CPU 0 DPC count: 1642104
CPU 1 Interrupt cycle time (s): 3.766499
CPU 1 ISR highest execution time (µs): 14.175015
CPU 1 ISR total execution time (s): 0.0020
CPU 1 ISR count: 2087
CPU 1 DPC highest execution time (µs): 11357.833235
CPU 1 DPC total execution time (s): 0.206622
CPU 1 DPC count: 7791
CPU 2 Interrupt cycle time (s): 2.761188
CPU 2 ISR highest execution time (µs): 3.906895
CPU 2 ISR total execution time (s): 0.000133
CPU 2 ISR count: 131
CPU 2 DPC highest execution time (µs): 11292.908662
CPU 2 DPC total execution time (s): 0.209265
CPU 2 DPC count: 30656
CPU 3 Interrupt cycle time (s): 3.759926
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 310.788450
CPU 3 DPC total execution time (s): 0.072468
CPU 3 DPC count: 8314
CPU 4 Interrupt cycle time (s): 2.773566
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 291.334119
CPU 4 DPC total execution time (s): 0.108738
CPU 4 DPC count: 15576
CPU 5 Interrupt cycle time (s): 3.249754
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 339.529169
CPU 5 DPC total execution time (s): 0.033539
CPU 5 DPC count: 3037
CPU 6 Interrupt cycle time (s): 2.89540
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 238.520919
CPU 6 DPC total execution time (s): 0.067425
CPU 6 DPC count: 8469
CPU 7 Interrupt cycle time (s): 3.240207
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 271.969947
CPU 7 DPC total execution time (s): 0.033655
CPU 7 DPC count: 3636
CPU 8 Interrupt cycle time (s): 3.259255
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 292.045374
CPU 8 DPC total execution time (s): 0.065253
CPU 8 DPC count: 5853
CPU 9 Interrupt cycle time (s): 3.159596
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 138.334119
CPU 9 DPC total execution time (s): 0.020233
CPU 9 DPC count: 2269
CPU 10 Interrupt cycle time (s): 3.420218
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 254.158515
CPU 10 DPC total execution time (s): 0.032723
CPU 10 DPC count: 3346
CPU 11 Interrupt cycle time (s): 3.409911
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 177.433117
CPU 11 DPC total execution time (s): 0.027613
CPU 11 DPC count: 3164
CPU 12 Interrupt cycle time (s): 3.120072
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 309.225692
CPU 12 DPC total execution time (s): 0.095789
CPU 12 DPC count: 8591
CPU 13 Interrupt cycle time (s): 2.986699
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 289.560990
CPU 13 DPC total execution time (s): 0.025777
CPU 13 DPC count: 2772
CPU 14 Interrupt cycle time (s): 3.180997
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 307.382440
CPU 14 DPC total execution time (s): 0.060916
CPU 14 DPC count: 6382
CPU 15 Interrupt cycle time (s): 3.360835
CPU 15 ISR highest execution time (µs): 15.427225
CPU 15 ISR total execution time (s): 0.049780
CPU 15 ISR count: 68997
CPU 15 DPC highest execution time (µs): 314.374779
CPU 15 DPC total execution time (s): 0.022947
CPU 15 DPC count: 2491
This is very frustrating. BIOS is currently the latest version and all the chipset / GPU drivers are the latest. I am using an external DAC as the audio device.
Anybody got any idea? Thanks.
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16336 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
CPU 8 ISR count: 0
CPU 9 ISR count: 0
CPU 10 ISR count: 0
CPU 11 ISR count: 0
CPU 12 ISR count: 0
CPU 13 ISR count: 0
CPU 14 ISR count: 0
