Win 8.1 SFC finds 2 corruptions and audio not working
Nashnir
Currently the audio doesn't work in my Win 8.1 system.
I am not sure if it happened after a particular update or not.
I have tried almost everything short of a fresh re-install or refresh.
I have also disabled AVG and Komodo and added exceptions and ignore rules to make sure they are not responsible.
The BIOS firmware test confirms that the hardware is working as the sound test works fine,
SFC finds two corruptions and fixes one one is still un-repaired.
The SFCfIX log is below and the CBS folder is in the attachment.
Thanks in advance.
Start time: 2014-10-06 00:59:04.591
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.16384.
CBS & SFC total fixed corruption count: 1
Finish time: 2014-10-06 01:47:46.232
Hello Nashnir and welcome to Sysnative forums.
Sorry for the delay in getting back to you. There are two corruptions that stand out inside your log.
\SystemRoot\WinSxS\amd64_microsoft-windows-wof-tasks.resources_31bf3856ad364e35_6.3.9600.17034_en-us_5e6a2af5a7fbe715\WofTasks.dll.mui
  Found: {l:32 b:jOi6jnJu6JJeZWDYasNb4Ql2kdHPrIiOa9IOgE6p6xU=} Expected: {l:32 b:JhyVcO5V2lwMlbP4ISwpl97+rCSlHecR/5vPczZoX1s=}
\SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
 Found: {l:32 b:fthsN2DyXfFtag35R/GvwlBKHvHOzp2cyrtn+Y3OvrQ=} Expected: {l:32 b:n520k714Uu3utHa5JGQ6HQYbZphKhlMWq5pEmfnCDuw=}
SFC /SCANNOW
  1. Right click on the
    button
Convert CBS.log to CBS.txt
    button
  2. Click on Run => Inside the run box copy and paste the following command:
  3. Press Enter
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or ge.tt
