FOF
Contributor
Hello,
Have a bunch of legacy SCSI storage devices including Quantum Cartridge drives and Iomega Zip drives that I would like to connect to my current PC, which is a custom build based around the Asus P8Z77-V Pro. The board has seven PCI slots. I can make any slot from 3 through 6 available for a SCSI interface board.
The SCSI boards I have been looking at are the Adaptec 1822300 64-bit PCI SCSI Controller Card or the Intel SRCU42E PCI Express SCSI Controller Card. The problem is, I don't know if these boards will work or are compatible with my Asus motherboard. Will they work? Are there other, better, boards that will work?
I am using Windows 7 professional 64 bit. It's all tuned up and operating properly, thanks to PeterJ. I'd just like to remount some of my SCSI storage devices to try to recover about 10 years worth of photos, audio, and film from my older projects.
Any advice?
Regards,
Rod
Slot 1 | PCI Express 2.0 x1 |
Slot 2 | PCI Express 3.0 x16 |
Slot 3 | PCI Express 2.0 x1 |
Slot 4 | PCI |
Slot 5 | PCI Express 3.0 x16 |
Slot 6 | PCI |
Slot 7 | PCI Express 2.0 x4 in a x16 size |
Any advice?
Regards,
Rod
