Naz
- Feb 28, 2022
- 3
Hello everyone,
I have a problem with my audio I tried so many things I updated my bios, my drivers that didn't help at all. I hope that you can help me.
CONCLUSION
LatencyMon has been analyzing your system for 0:22:05 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: NAZ
OS version: Windows 11, 10.0, version 2009, build: 22000 (x64)
Hardware: System Product Name, System manufacturer
BIOS: 2501
CPU: GenuineIntel Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
Logical processors: 8
Processor groups: 1
Processor group size: 8
RAM: 24492 MB total
CPU SPEED
Reported CPU speed (WMI): 360 MHz
Reported CPU speed (registry): 360 MHz
Highest measured interrupt to process latency (µs): 3072.30
Average measured interrupt to process latency (µs): 4.331054
Highest measured interrupt to DPC latency (µs): 3067.10
Average measured interrupt to DPC latency (µs): 2.153548
REPORTED ISRs
Highest ISR routine execution time (µs): 192.4650
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001553
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001553
ISR count (execution time <250 µs): 160226
REPORTED DPCs
Highest DPC routine execution time (µs): 3179.027222
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0.047813
Total time spent in DPCs (%) 0.110462
DPC count (execution time <250 µs): 1987113
DPC count (execution time 500-10000 µs): 2309
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 8
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 45227
Hard pagefault count of hardest hit process: 34326
Number of processes hit: 49
PER CPU DATA
CPU 0 Interrupt cycle time (s): 41.079056
CPU 0 ISR highest execution time (µs): 192.4650
CPU 0 ISR total execution time (s): 0.164648
CPU 0 ISR count: 160226
CPU 0 DPC highest execution time (µs): 3179.027222
CPU 0 DPC total execution time (s): 9.630070
CPU 0 DPC count: 1071559
CPU 1 Interrupt cycle time (s): 17.423359
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 337.930556
CPU 1 DPC total execution time (s): 0.405403
CPU 1 DPC count: 189315
CPU 2 Interrupt cycle time (s): 16.470599
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 260.830
CPU 2 DPC total execution time (s): 0.202770
CPU 2 DPC count: 82251
CPU 3 Interrupt cycle time (s): 14.121233
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 257.176111
CPU 3 DPC total execution time (s): 0.147442
CPU 3 DPC count: 61176
CPU 4 Interrupt cycle time (s): 13.255960
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 345.761111
CPU 4 DPC total execution time (s): 0.199325
CPU 4 DPC count: 86274
CPU 5 Interrupt cycle time (s): 12.459002
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 199.106111
CPU 5 DPC total execution time (s): 0.163805
CPU 5 DPC count: 71537
CPU 6 Interrupt cycle time (s): 13.762708
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 378.089444
CPU 6 DPC total execution time (s): 0.170004
CPU 6 DPC count: 75358
CPU 7 Interrupt cycle time (s): 16.896408
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 428.709444
CPU 7 DPC total execution time (s): 0.791904
CPU 7 DPC count: 351961
CONCLUSION
SYSTEM INFORMATION
Computer name: NAZ
BIOS: 2501
Processor groups: 1
RAM: 24492 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 1 ISR count: 0
CPU 2 ISR count: 0
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
