[SOLVED] [W7SP1 x64] Many problems
earias
I am fighting during th whole day cleaning my systems of malware &, later, with Windows Update (which I do not think it is resolved sine I cannot chose to update for other MS products), and now with SFC problems.
I managed, thanks to your guide, to fix most of my SFC problems, but I cannot get rid of a couple of them.
It seems that the moves deteted in SC and stored in FileMaps folder are not being applied ad are detected continuously. Also SFC reports error when sending samples. And seems that some packages are corrupted (Expecting attribute name [HRESULT = 0x800f080d - CBS_E_MANIFEST_INVALID_ITEM]) and (Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE])...
I would be very grateful if you could hint me on how to fix them.
All the log files can be found here.
Thanks a lot for your time,
Hello and welcome!
Dropbox - SFCFix.zip
SFC Scan
