[SOLVED] W2016 Standard - Issue with cumulative updates starting with KB5027219 6/13/2023
slash
I think this might be some odd issue with language packs? ..
(p) CBS Catalog Missing Microsoft-Windows-LanguageFeatures-Basic-gu-in-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-LanguageFeatures-Basic-he-il-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-LanguageFeatures-Basic-hi-in-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-Spelling-Dictionaries-gu-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-Spelling-Dictionaries-he-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-TextPrediction-Dictionaries-he-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-WordBreaking-Dictionaries-gu-Package~31bf3856ad364e35~amd64~~10.0.14393.0
(p) CBS Catalog Missing Microsoft-Windows-WordBreaking-Dictionaries-he-Package~31bf3856ad364e35~amd64~~10.0.14393.0
I've tried most everything.. DISM, SFCSCAN, remove .NET and re-add, etc.. but, I'm stuck!
Step 1. Download
Please do the following
  • Open the start menu and type Task Scheduler and hit enter.
  • Navigate to Task Scheduler Library > Microsoft > Windows > PI
  • Take a screenshot of this window and attach it to your next post.
It seems the SecureBootEncodeUEFI task is corrupted!
Export registry key as hive file.
  • Open the Start menu of Windows and type CMD.
  • When you see Command Prompt on the list, select the option Run as administrator.
  • Copy and paste the following command into the command prompt and press enter.
reg save "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Schedule\Taskcache" "%userprofile%\Desktop\TaskList.hiv"
  • Once done, a file will appear on your desktop, called TaskList.hiv.
  • ZIP this file and attach it to your next reply.
Download the
  • Press the Fix button.
Possibly due to permissions the fix failed, but you were able to remove them manually I would suggest to update again.
