Hello,
For the past roughly five days or so, I've been experiencing horrendous audio quality when using USB headsets, which I can only describe as the sounds seeming to stutter, pop, and crackle. The issue seems to be particular to my PC and not the headsets, as they work fine on other PCs but experience trouble regardless of which port I use on mine. I have a pair of speakers which work fine, and plugging in devices via the audio in/out jacks also work without issue. I've exhausted a long list of potential fixes trying to solve this issue, and though I'm not 100% certain this is the culprit, my PC has been having issues with DPC latency, which may even be causing me performance issues abroad. According to LatencyMon, the problem processes are ndis.sys, and storport.sys.
I've generated a trace file using xperf that I hope someone will be able to use to help troubleshoot the issue: trace.etl - Google Drive
Thanks in advance for any help that anyone is able to provide.
