A couple days ago, I removed a virus with Malwarebytes, However, when I restarted my PC to complete the removal, after logging in, I found myself in a black desktop with my cursor and a CMD, so I looked up for a fix and found a solution - to run explorer.exe from task manager, it works, but I have to do it every time I log in, which is a bit inconvenient.
sfc /scannow says everything's ok and my Shell value is explorer.exe, can anyone help me fix the issue? or is clean installing the only way?
Log:
-Log Details-
Scan Date: 9/20/17
Scan Time: 7:14 PM
Log File: b96bacb0-9e1e-11e7-96c3-9c5c8e901a96.json
Administrator: Yes
-Software Information-
Version: 3.2.2.2029
Components Version: 1.0.188
Update Package Version: 1.0.2850
License: Premium
-System Information-
OS: Windows 10 (Build 15063.608)
CPU: x64
File System: NTFS
User: DESKTOP-06VVNV0\Admin
-Scan Summary-
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 395091
Threats Detected: 1
Threats Quarantined: 1
Time Elapsed: 2 min, 20 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
(No malicious items detected)
Module: 0
Registry Key: 0
Registry Value: 1
Hijack.AutoRun, HKU\S-1-5-21-1516618583-4124683476-2910086463-1001\SOFTWARE\MICROSOFT\COMMAND PROCESSOR|AUTORUN, Quarantined, [14433], [245417],1.0.2850
Registry Data: 0
Data Stream: 0
Folder: 0
File: 0
Physical Sector: 0
(end)
Thanks for the help !
Log:
-Log Details-
Scan Date: 9/20/17
Scan Time: 7:14 PM
Administrator: Yes
Version: 3.2.2.2029
License: Premium
CPU: x64
File System: NTFS
-Scan Summary-
Result: Completed
Threats Detected: 1
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
Module: 0
Registry Key: 0
Registry Value: 1
Registry Data: 0
Data Stream: 0
Folder: 0
File: 0
Physical Sector: 0
(end)
