[SOLVED] [W10ProV1607b14393 x64] OS freeze when WU starts, SFC not working, DISM not working
RomanD
Good day!
I meet OS freezes for 10-15 minutes every time when WU starts. Three month ago it was freeze for 1 minute. The time for freeze is grow up for that period.
I have a russian version of Windows 10, so I think error screen don't tell you anything. I will try to translate it as possible with my poor knowledge of english language.
What I have tried:
1. Ran "sfc /scannow", but without success. Process is terminated with message "Requested operation could not be performed"
2. Ran DISM twice. Attempting restore with online service and with OS distributive without success. Two times got error "Component store is corrupted"
3. Ran sfcfix twice. First it works for 40 minutes and fix something. Second time I got message "No corruptions were detected". Two times sfcfix can't make ZIP files for upload.
4. Renamed %systemroot%\System32\catroot2 and %systemroot%\SoftwareDistribution. Run DISM after that again without success.
Logs for DISM and SFC is attached.
View attachment logs.zip
Re: [WIN10 Pro x64] OS freeze when WU starts, SFC not working, DISM not working
Still patiently wait and hope for lucky feature :)
Hi and welcome to Sysnative. Sorry for the delay. Please start with the following.
Retrieve Components Hive
Hi, Brian!
Components hive located here: Yandex.Disk
Looks like you have some corruption within the identity value data within the following key. I think the hex 6C highlighted below should be 2C since the character should be a comma.
HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-fatchkdsk_31bf3856ad364e35_10.0.14393.0_none_2f3ecb61e0cfbdce
Let's try the following fix.
Step#1 - SFCFix Script
Unbelievable. How did You do that? Now SFC worked for 100%, but still not able to repair all. New cbs.log attached. Yandex.Disk
SFCFix.log here
----------------------BOF-----------------------
Start time: 2017-11-05 19:45:25.089
Microsoft Windows 10 Build 14393 (Updates Deferred) - amd64
Using .txt script file at SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-fatchkdsk_31bf3856ad364e35_10.0.14393.0_none_2f3ecb61e0cfbdce.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-fatchkdsk_31bf3856ad364e35_10.0.14393.0_none_2f3ecb61e0cfbdce.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-fatchkdsk_31bf3856ad364e35_10.0.14393.0_none_2f3ecb61e0cfbdce.
Finish time: 2017-11-05 19:45:25.697
Script hash: GyzjnKsLe+RG+374dsBnRTVJTJMATOzkn4XypmMADCc=
I tried to run DISM for restore with online download and SFC reports 143 errors that cannot be repaired. SFC can't download 142 broken packages. Now downloading ISO with Win 10. After that will run DISM trying to take files from local storage. Will report about progress.
Lots and lots of practice and experience. :smile9:
To fix the rest of them I need you to do the following and provide resulting log.
Could not find 6 files and 1 metadata corruption. CBS log here Yandex.Disk
Here you go.
SFC Fix reports that can't unpack zip file. May be some dll missing: zlib.dll or something like that.
So I unpack script and manually parse it. Removed HKLM key and paste absent folders and files into WinSxs and restored permissions/ownership.
Now it's ok and SFC reports no errors.
Thanks a lot! You all making a very big job. And I even can't imagine what resource You are using for that. Much GB's of many windows installation and many knowledge. Respect.
