[SOLVED] USBPORT.SYS and ndis.sys high latency when using Wi-Fi router. No latency spikes when connecting the ethernet directly to pc without a router
brokerZIP
Sep 13, 2022
2
CONCLUSION
LatencyMon has been analyzing your system for 0:01:57 (h:mm:ss) on processors 0,1,2,3,4 and 5.
SYSTEM INFORMATION
Computer name: WIN-4VLT3IF0IJS
OS version: Windows 10 , 10.0, version 1809, build: 17763 (x64)
Hardware: INTEL, X79
CPU: GenuineIntel Intel(R) Xeon(R) CPU E5-2420 0 @ 1.90GHz
Logical processors: 12
Processor groups: 1
RAM: 8114 MB total
CPU SPEED
Reported CPU speed: 1896 MHz
Highest measured interrupt to process latency (µs): 2663,40
Average measured interrupt to process latency (µs): 8,997331
Highest measured interrupt to DPC latency (µs): 1151,20
Average measured interrupt to DPC latency (µs): 1,934441
REPORTED ISRs
Highest ISR routine execution time (µs): 38,623945
Driver with highest ISR routine execution time: USBPORT.SYS - Драйвер порта USB 1.1 и 2.0, Microsoft Corporation
Highest reported total ISR routine time (%): 0,001372
Driver with highest ISR total time: USBPORT.SYS - Драйвер порта USB 1.1 и 2.0, Microsoft Corporation
Total time spent in ISRs (%) 0,001372
ISR count (execution time <250 µs): 3599
REPORTED DPCs
Highest DPC routine execution time (µs): 1401,314346
Driver with highest DPC routine execution time: ndis.sys - NDIS (Network Driver Interface Specification), Microsoft Corporation
Highest reported total DPC routine time (%): 0,044214
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0,090154
DPC count (execution time <250 µs): 311462
DPC count (execution time 500-999 µs): 253
DPC count (execution time 1000-1999 µs): 7
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: browser.exe
Total number of hard pagefaults 66
Hard pagefault count of hardest hit process: 62
Number of processes hit: 2
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2,729713
CPU 0 ISR highest execution time (µs): 38,623945
CPU 0 ISR total execution time (s): 0,018181
CPU 0 ISR count: 3405
CPU 0 DPC highest execution time (µs): 1401,314346
CPU 0 DPC total execution time (s): 1,218174
CPU 0 DPC count: 308972
CPU 1 Interrupt cycle time (s): 0,825495
CPU 1 ISR highest execution time (µs): 23,375527
CPU 1 ISR total execution time (s): 0,000620
CPU 1 ISR count: 112
CPU 1 DPC highest execution time (µs): 1017,569620
CPU 1 DPC total execution time (s): 0,015573
CPU 1 DPC count: 711
CPU 2 Interrupt cycle time (s): 1,001847
CPU 2 ISR highest execution time (µs): 13,685654
CPU 2 ISR total execution time (s): 0,000459
CPU 2 ISR count: 82
CPU 2 DPC highest execution time (µs): 184,679325
CPU 2 DPC total execution time (s): 0,017443
CPU 2 DPC count: 1261
CPU 3 Interrupt cycle time (s): 0,729554
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 36,544304
CPU 3 DPC total execution time (s): 0,000334
CPU 3 DPC count: 43
CPU 4 Interrupt cycle time (s): 0,894008
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 489,523207
CPU 4 DPC total execution time (s): 0,013744
CPU 4 DPC count: 694
CPU 5 Interrupt cycle time (s): 0,697654
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 156,143460
CPU 5 DPC total execution time (s): 0,000663
CPU 5 DPC count: 41
Write your reply...
