It seems there's something wrong with your EFI partition, your SSD as well the HDD contain an EFI partition. I would suggest the following.
Drive c: (System) (Fixed) (Total:131.4 GB) (Free:24.17 GB) (Model: Ramsta SSD S800 512GB) NTFS
Drive d: () (Fixed) (Total:344.95 GB) (Free:139.7 GB) (Model: Ramsta SSD S800 512GB) NTFS
1. Free up some more space on your system partition (
C), or resize the partitions on this SSD.
2. Make a full system image of your current SSD were Windows is installed on.
3. Disconnect the 1TB hard drive of Seagate (ST1000DM010-2EP102).
4. Rebuild the EFI partition using the following instructions into the Windows Recovery Environment.
1. Boot the computer into the
Recovery Environment - open the command prompt and run the following commands.
2. Replace
0 with the actual number of the HDD/SSD where Windows is installed.
diskpart
list disk
select disk 0
list partition
3. Then run the following command and replace
1 with the actual number of the Windows OS partition.
4. The following commands will resize the Windows OS partition and create the new
EFI System Partition. (Note: the driveletter W should be free!)
shrink desired=100
create partition efi size=100
format quick fs=fat32
assign letter=w
5. Run the following commands to list the partitions and volumes.
list partition
list volume
6. Note the drive letter where the Windows OS is installed, which is displayed after running
list volume.
7. Close diskpart.
8. Run the following command: Replace
X with the volume letter of the Windows OS partition.
9. Now the BCDBoot command copies the boot files from the Windows partition into the EFI System Partition and re-create the BCD store.
