[SOLVED] Updates KB4462927, KB2592687 and KB4457144 do not work / Win7 Home Prem. 64bit
Scrooge
Hamburg
I'm currently installing Win7 HP 64bit on an AMD machine (MSI KA790GX, chipset: AMD 790GX, CPU: AMD Athlon 5050e).
When installing the updates, the following patches can not be installed:
Updates KB4462927, KB2592687 and KB4457144.
And one more - probably irrelevant - apparently an update for keyboard or mouse drivers.
I run SFC /SCANNOW - no issues found
I run SURT
SFCFIX
->SFCFix version 3.0.0.0 by niemiro.
Start time: 2018-10-26 21:05:12.350
SURT total detected corruption count: 1
Finish time: 2018-10-26 21:25:17.356
I also run FRST64 with KB4025341
-> Farbar Recovery Scan Tool (x64) Version: 24.10.2018
durchgeführt von Vento A8 (26-10-2018 21:33:02)
Gestartet von C:\Users\Vento A8\Desktop
Start-Modus: Normal
================== Registry-Suche: "KB4025341" ===========
====== Ende von Suche ======
That was user specific.
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
  9. Afterwards, run SURT again and attach CheckSUR.log.
SFCFix.txt:
Start time: 2018-10-27 15:38:11.059
Using .zip script file at C:\Users\Vento A8\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully copied file C:\Users\Vento A8\AppData\Local\niemiro\Archive\Packages\package_235_for_kb4457144~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\package_235_for_kb4457144~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Vento A8\AppData\Local\niemiro\Archive\Packages\package_235_for_kb4457144~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\package_235_for_kb4457144~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
Finish time: 2018-10-27 15:38:14.241
Script hash: HC+XtQ8pDkKBTtDGqE2pU83iyLShYUfdHgGNFvGt6lY=
I have problems with the attachements again.
Here' the contents of the checkSUR.log:
Binary Version 6.1.7601.22471
Package Version 26.0
2018-10-27 15:49
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_235_for_KB4457144~31bf3856ad364e35~amd64~~6.1.1.6.cat
(fix) CBS Catalog Corrupt CBS File Replaced Package_235_for_KB4457144~31bf3856ad364e35~amd64~~6.1.1.6.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix) CBS Paired File CBS File also Replaced Package_235_for_KB4457144~31bf3856ad364e35~amd64~~6.1.1.6.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 952
Found 1 errors
Fixed 1 errors
CBS Catalog Corrupt Total count: 1
Fixed: CBS Catalog Corrupt. Total count: 1
Fixed: CBS Paired File. Total count: 1
