Updater wont work, BITs wont work, help
Kyro
So PC isn't letting me use Windows Update, shows updates but fails to update and gives me error code 80246008. I checked to see if BITs was running and it wasn't. Found COM+ event system wasn't running and ran it. BITs still didn't work and ive received a service-specific error code of -2147023828. Ive attached a SFCfix log View attachment SFCFix.txt. I am lost in how to continue. Any help would be greatly appreciated.
Hi and welcome to Sysnative. Sorry for the delay. Please start with the following so I can gather some info.
SFC Scan
1. Right-click on the Start
Please do the following.
Step#1 - SFCFix Script
Start time: 2016-12-21 11:49:40.224
Microsoft Windows 8.1 - amd64
Using .zip script file at C:\Users\colton\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB
Successfully copied file C:\Users\colton\AppData\Local\niemiro\Archive\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB to C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB.
Successfully restored ownership for C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB
Successfully restored permissions on C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.16384_none_9590ba64d5b91f79\Amd64\CNBJ2530.DPB
Finish time: 2016-12-21 11:49:41.177
Script hash: Vp8fmOaFllKH32OrjAspvOaLBZSyBssPz+9Wam3Uu2Y=
Thanks. Please do the following again.
SFC Scan
Good. That log is now clean. Let's look at the next one.
OK. Please do the following.
Step#1 - FRST Scan
4. Press Scan button.
6. Please copy and paste log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also paste that along with the FRST.txt into your reply.
FRST text
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 21-12-2016
Ran by colton (administrator) on COLTONTABLET (23-12-2016 11:56:28)
Running from C:\Users\colton\Downloads
Loaded Profiles: colton (Available Profiles: colton & kyrow_000)
Platform: Windows 8.1 Pro (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: IE)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: FRST Tutorial - How to use Farbar Recovery Scan Tool - Malware Removal Guides and Tutorials
(Ammyy LLC) C:\Users\colton\Desktop\Security Software\Tech_Support.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\MsMpEng.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\NisSrv.exe
(Cisco) C:\Users\colton\AppData\Local\DIRECTV Player\PCShowServerPMWrapper.exe
(Octoshape ApS) C:\Users\colton\AppData\Roaming\Octoshape\Octoshape Streaming Services\OctoshapeClient.exe
(Google) C:\Program Files (x86)\Google\Drive\googledrivesync.exe
(Oracle Corporation) C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
(Microsoft Corporation) C:\Windows\System32\SkyDrive.exe
(Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ink\InputPersonalization.exe
(Oracle Corporation) C:\Program Files (x86)\Common Files\Java\Java Update\jucheck.exe
() C:\Users\colton\AppData\Local\DIRECTV Player\NDSPCShowServer.exe
(Google Inc.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
(Microsoft Corporation) C:\Program Files\Windows Defender\MpCmdRun.exe
==================== Registry (Whitelisted) ====================
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176440 2016-12-06] (Apple Inc.)
HKLM-x32\...\Run: [APSDaemon] => C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe [67384 2016-11-17] (Apple Inc.)
HKLM-x32\...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [595480 2016-03-20] (Oracle Corporation)
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Run: [Skype] => C:\Program Files (x86)\Skype\Phone\Skype.exe [50378880 2015-12-17] (Skype Technologies S.A.)
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Run: [PCShowServer] => C:\Users\colton\AppData\Local\DIRECTV Player\PCShowServerPMWrapper.exe [1632504 2016-02-14] (Cisco)
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Run: [Octoshape Streaming Services] => C:\Users\colton\AppData\Roaming\Octoshape\Octoshape Streaming Services\OctoshapeClient.exe [500016 2014-08-01] (Octoshape ApS)
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Run: [GoogleDriveSync] => C:\Program Files (x86)\Google\Drive\googledrivesync.exe [23818360 2016-11-30] (Google)
HKU\S-1-5-18\...\RunOnce: [Application Restart #0] => C:\Program Files\Common Files\microsoft shared\ink\TabTip.exe [349176 2013-08-22] (Microsoft Corporation)
ShellIconOverlayIdentifiers: [ GoogleDriveBlacklisted] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D42} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
ShellIconOverlayIdentifiers: [ GoogleDriveSynced] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D40} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
ShellIconOverlayIdentifiers: [ GoogleDriveSyncing] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D41} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
Startup: C:\Users\colton\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Send to OneNote.lnk [2014-09-28]
ShortcutTarget: Send to OneNote.lnk -> C:\Program Files\Microsoft Office 15\root\office15\ONENOTEM.EXE (No File)
Tcpip\Parameters: [DhcpNameServer] 192.168.0.1 192.168.0.1
Tcpip\..\Interfaces\{43C06A76-D774-4169-9C8D-F1E1C71865F3}: [DhcpNameServer] 192.168.0.1 192.168.0.1
Internet Explorer:
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://www.msn.com/?ocid=iehp
BHO: Lync Browser Helper -> {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} -> C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\OCHelper.dll [2016-03-28] (Microsoft Corporation)
BHO: Microsoft OneDrive for Business Browser Helper -> {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} -> C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\GROOVEEX.DLL [2016-03-28] (Microsoft Corporation)
BHO-x32: Lync Browser Helper -> {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} -> C:\Program Files (x86)\Microsoft Office\root\Office16\OCHelper.dll [2016-03-28] (Microsoft Corporation)
BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_77\bin\ssv.dll [2016-04-04] (Oracle Corporation)
BHO-x32: Microsoft OneDrive for Business Browser Helper -> {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} -> C:\Program Files (x86)\Microsoft Office\root\Office16\GROOVEEX.DLL [2016-03-28] (Microsoft Corporation)
BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_77\bin\jp2ssv.dll [2016-04-04] (Oracle Corporation)
Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-03-28] (Microsoft Corporation)
Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-03-28] (Microsoft Corporation)
Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-03-28] (Microsoft Corporation)
Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files (x86)\Microsoft Office\root\Office16\MSOSB.DLL [2016-03-28] (Microsoft Corporation)
FireFox:
FF ProfilePath: C:\Users\colton\AppData\Roaming\Mozilla\Firefox\Profiles\nhwjbju7.default [2016-12-19]
FF DefaultSearchEngine: Mozilla\Firefox\Profiles\nhwjbju7.default -> Google
FF DefaultSearchEngine.US: Mozilla\Firefox\Profiles\nhwjbju7.default -> Google
FF Extension: (Skype) - C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{82AF8DCA-6DE9-405D-BD5E-43525BDAD38A}.xpi [2016-04-29]
FF Plugin: @adobe.com/FlashPlayer -> C:\windows\system32\Macromed\Flash\NPSWF64_24_0_0_186.dll [2016-12-13] ()
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\windows\SysWOW64\Macromed\Flash\NPSWF32_24_0_0_186.dll [2016-12-13] ()
FF Plugin-x32: @java.com/DTPlugin,version=11.77.2 -> C:\Program Files (x86)\Java\jre1.8.0_77\bin\dtplugin\npDeployJava1.dll [2016-04-04] (Oracle Corporation)
FF Plugin-x32: @java.com/JavaPlugin,version=11.77.2 -> C:\Program Files (x86)\Java\jre1.8.0_77\bin\plugin2\npjp2.dll [2016-04-04] (Oracle Corporation)
FF Plugin-x32: @microsoft.com/Lync,version=15.0 -> C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX86\Mozilla Firefox\plugins\npmeetingjoinpluginoc.dll [2016-03-28] (Microsoft Corporation)
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> c:\Program Files (x86)\Microsoft Silverlight\5.1.30214.0\npctrl.dll [2014-02-13] ( Microsoft Corporation)
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files (x86)\Microsoft Office\root\Office16\NPSPWRAP.DLL [2016-03-28] (Microsoft Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-16] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-16] (Google Inc.)
FF Plugin-x32: @videolan.org/vlc,version=2.1.5 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
FF Plugin-x32: @videolan.org/vlc,version=2.2.4 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AIR\nppdf32.dll [2016-10-01] (Adobe Systems Inc.)
FF Plugin HKU\S-1-5-21-4150806952-2691248085-3505555448-1001: @octoshape.com/Octoshape Streaming Services,version=1.0 -> C:\Users\colton\AppData\Roaming\Octoshape\Octoshape Streaming Services\sua-1411300-0-npoctoshape.dll [2014-11-30] (Octoshape ApS)
FF Plugin ProgramFiles/Appdata: C:\Users\colton\AppData\Roaming\mozilla\plugins\npoctoshape.dll [2016-05-03] (Octoshape ApS)
Chrome:
CHR DefaultProfile: Default
CHR Profile: C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default [2016-12-23]
CHR Extension: (Google Drive) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2016-10-06]
CHR Extension: (Google Docs Offline) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2016-10-06]
CHR Extension: (AdBlock) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\gighmmpiobklfepjocnamgkkbiglidom [2016-12-21]
CHR Extension: (Skype) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\lifbcibllhkdhoafpjfnlhfpfgnpldfl [2016-10-20]
CHR Extension: (Application Launcher for Drive (by Google)) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\lmjegmlicamnimmfhcmpkclmigmmcbeh [2016-10-06]
CHR Extension: (Chrome Web Store Payments) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2016-04-01]
CHR Extension: (Chrome Media Router) - C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2016-12-16]
CHR HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [apdfllckaahabafndbhieahigkjlhalf] - C:\Users\colton\AppData\Local\Google\Drive\user_default\apdfllckaahabafndbhieahigkjlhalf_live.crx [2016-10-05]
CHR HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [lmjegmlicamnimmfhcmpkclmigmmcbeh] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [lifbcibllhkdhoafpjfnlhfpfgnpldfl] - hxxps://clients2.google.com/service/update2/crx
==================== Services (Whitelisted) ====================
R2 AmmyyAdmin; C:\Users\colton\Desktop\Security Software\Tech_Support.exe [743704 2014-01-20] (Ammyy LLC)
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-09-22] (Apple Inc.)
R2 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [2912496 2016-02-27] (Microsoft Corporation)
S3 OverwolfUpdater; C:\Program Files (x86)\Overwolf\OverwolfUpdater.exe [1316080 2016-12-07] (Overwolf LTD)
R3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [346872 2013-08-22] (Microsoft Corporation)
R2 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [23840 2013-08-22] (Microsoft Corporation)
===================== Drivers (Whitelisted) ======================
S3 AX88772; C:\windows\system32\DRIVERS\ax88772.sys [113864 2013-07-18] (ASIX Electronics Corp.)
R3 LcUvcUpper; C:\windows\system32\DRIVERS\LcUvcUpper.sys [34408 2013-09-27] (Microsoft Corporation)
R3 MEIx64; C:\windows\System32\drivers\TeeDriverx64.sys [99288 2013-08-12] (Intel Corporation)
R3 mwlu97w8; C:\windows\system32\DRIVERS\mwlu97w8x64.sys [1591296 2013-09-23] (Marvell Semiconductors, Inc.)
R3 SensorsServiceDriver; C:\windows\system32\DRIVERS\WUDFRd.sys [230912 2013-08-22] (Microsoft Corporation)
R3 SurfaceAccessoryDevice; C:\windows\System32\drivers\SurfaceAccessoryDevice.sys [46744 2013-08-13] (Microsoft Corporation)
R3 SurfaceIntegrationDriver; C:\windows\System32\drivers\SurfaceIntegrationDriver.sys [29752 2013-08-06] (Microsoft Corporation)
S3 SurfaceTouchCover; C:\windows\System32\drivers\SurfaceTouchCover.sys [37992 2013-08-08] (Microsoft Corporation)
R3 SurfaceTypeCover; C:\windows\System32\drivers\SurfaceTypeCover.sys [37944 2013-08-06] (Microsoft Corporation)
S0 WdBoot; C:\windows\System32\drivers\WdBoot.sys [34760 2013-08-22] (Microsoft Corporation)
R0 WdFilter; C:\windows\System32\drivers\WdFilter.sys [265056 2013-08-22] (Microsoft Corporation)
R3 WdNisDrv; C:\windows\System32\Drivers\WdNisDrv.sys [124256 2013-08-22] (Microsoft Corporation)
S3 xb1usb; C:\windows\System32\drivers\xb1usb.sys [34016 2014-05-27] (Microsoft Corporation)
==================== One Month Created files and folders ========
2016-12-23 11:56 - 2016-12-23 11:56 - 00014918 _____ C:\Users\colton\Downloads\FRST.txt
2016-12-23 11:55 - 2016-12-23 11:56 - 00000000 ____D C:\FRST
2016-12-23 11:53 - 2016-12-23 11:53 - 02420736 _____ (Farbar) C:\Users\colton\Downloads\FRST64.exe
2016-12-22 22:51 - 2016-12-22 22:51 - 00124659 _____ C:\Users\colton\Desktop\cbs.zip
2016-12-21 11:49 - 2016-12-21 11:49 - 00002520 _____ C:\Users\colton\Desktop\SFCFix.txt
2016-12-21 11:37 - 2016-12-21 11:37 - 01359197 _____ C:\Users\colton\Desktop\SFCFix.zip
2016-12-21 11:26 - 2016-12-21 11:26 - 02884096 _____ (niemiro) C:\Users\colton\Downloads\SFCFix (1).exe
2016-12-20 11:29 - 2016-12-20 11:29 - 00001772 _____ C:\Users\Public\Desktop\iTunes.lnk
2016-12-20 11:29 - 2016-12-20 11:29 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2016-12-20 11:28 - 2016-12-20 11:29 - 00000000 ____D C:\Program Files\iTunes
2016-12-20 11:28 - 2016-12-20 11:28 - 00000000 ____D C:\Program Files\iPod
2016-12-19 20:00 - 2016-12-19 20:03 - 00000000 ____D C:\Users\colton\AppData\LocalLow\Mozilla
2016-12-19 19:30 - 2016-12-19 19:30 - 00831176 _____ C:\Users\colton\Downloads\cbs (1) (1).zip
2016-12-19 19:30 - 2016-12-19 19:30 - 00831176 _____ C:\Users\colton\Downloads\cbs (1) (1) (1).zip
2016-12-19 19:25 - 2016-12-19 19:25 - 00831176 _____ C:\Users\colton\Downloads\cbs (1).zip
2016-12-19 19:24 - 2016-12-19 19:24 - 00831176 _____ C:\Users\colton\Downloads\cbs.zip
2016-12-19 19:23 - 2016-12-22 17:51 - 00122704 _____ C:\Users\colton\Desktop\cbsnew.zip
2016-12-19 19:22 - 2016-12-22 22:50 - 02362545 _____ C:\Users\colton\Desktop\cbs.txt
2016-12-18 14:11 - 2016-12-20 11:34 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
2016-12-18 13:25 - 2016-12-18 13:26 - 31081486 _____ C:\Users\colton\Downloads\Flathead Lake Tom Bansak.pptx
2016-12-18 13:23 - 2016-12-18 13:23 - 04561299 _____ C:\Users\colton\Downloads\Cepaea nemoralis instructions for final test.pptx
2016-12-18 12:46 - 2016-12-18 12:46 - 00000718 _____ C:\Users\colton\Downloads\ClamData.csv
2016-12-18 11:46 - 2016-12-18 11:47 - 00041125 _____ C:\Users\colton\Downloads\ynp_willow_height.csv
2016-12-18 11:32 - 2016-12-18 11:32 - 02542443 _____ C:\Users\colton\Downloads\PRSB_Marshall_WolfxBeaverYellowstone_2013.pdf
2016-12-17 11:39 - 2016-12-17 11:39 - 00070478 _____ C:\Users\colton\Downloads\wolfmcp.csv
2016-12-17 11:39 - 2016-12-17 11:39 - 00036340 _____ C:\Users\colton\Downloads\tent equipment logistics.xlsx
2016-12-16 10:57 - 2016-12-16 10:58 - 08528896 _____ C:\Users\colton\Downloads\WILD240_Lecture_21_AIC_II.ppt
2016-12-16 10:57 - 2016-12-16 10:57 - 08443407 _____ C:\Users\colton\Downloads\WILD240_lecture_20_MLR II.pptx
2016-12-14 00:47 - 2016-12-14 00:47 - 00000942 _____ C:\Users\colton\Downloads\SFCFix (1).txt
2016-12-14 00:46 - 2016-12-14 00:46 - 00000942 _____ C:\Users\colton\Downloads\SFCFix.txt
2016-12-13 23:46 - 2016-12-13 23:46 - 00000000 ____D C:\SFCFix
2016-12-13 23:35 - 2016-12-21 11:49 - 00000000 ____D C:\Users\colton\AppData\Local\niemiro
2016-12-13 23:35 - 2016-12-13 23:35 - 02884096 _____ (niemiro) C:\Users\colton\Desktop\SFCFix.exe
2016-12-13 22:38 - 2016-12-13 22:38 - 00000222 _____ C:\Users\colton\Desktop\Age of Empires II HD Edition.url
2016-12-13 22:24 - 2016-12-13 22:24 - 00000000 ____D C:\Users\colton\AppData\Local\ElevatedDiagnostics
2016-12-13 22:21 - 2016-12-13 22:21 - 00313366 _____ C:\Users\colton\Downloads\WindowsUpdateDiagnostic.diagcab
2016-12-13 13:40 - 2016-12-13 13:40 - 00012664 ____H C:\Users\colton\Desktop\~WRL3977.tmp
2016-12-13 12:30 - 2016-12-13 12:30 - 00382103 _____ C:\Users\colton\Downloads\BAI_explained (2).pdf
2016-12-12 20:48 - 2016-12-12 20:48 - 00003182 _____ C:\windows\System32\Tasks\OneDrive Standalone Update Task v2
2016-12-12 16:26 - 2016-12-12 16:26 - 00000000 ____D C:\Users\colton\AppData\Local\Chromium
2016-12-12 15:42 - 2016-12-12 15:42 - 00010374 _____ C:\Users\colton\Downloads\FORS330_Peer Evaluation Form.xlsx
2016-12-12 13:09 - 2016-12-12 13:09 - 00004088 _____ C:\Users\colton\Downloads\WILD240_logistic_regression.R
2016-12-12 13:07 - 2016-12-12 13:07 - 00014463 _____ C:\Users\colton\Downloads\D9_deer_data.csv
2016-12-12 11:08 - 2016-12-12 11:08 - 00181963 _____ C:\Users\colton\Downloads\HowToScanCores.pdf
2016-12-12 09:45 - 2016-12-12 09:45 - 00382103 _____ C:\Users\colton\Downloads\BAI_explained (1).pdf
2016-12-12 09:16 - 2016-12-12 16:31 - 00060498 _____ C:\Users\colton\Downloads\ptarm_oct20_95%CIsmanual (2).xlsx
2016-12-11 12:20 - 2016-12-13 21:42 - 00056320 _____ C:\Users\colton\Downloads\AICTable.xls
2016-12-11 12:17 - 2016-12-11 12:17 - 00009636 _____ C:\Users\colton\Downloads\Ants_rsquared.R
2016-12-08 14:23 - 2016-12-10 11:27 - 00023403 ____H C:\Users\colton\Desktop\~WRL1665.tmp
2016-12-07 12:10 - 2016-12-07 12:10 - 00056939 _____ C:\Users\colton\Downloads\TermsforFORS330FinalExam.pdf
2016-12-07 11:49 - 2016-12-07 11:49 - 00889509 _____ C:\Users\colton\Downloads\HRV_TuesNov22.pptx
2016-12-07 11:16 - 2016-12-07 11:16 - 00000165 ____H C:\Users\colton\Downloads\~$Matrix Modeling Assignment Spreadsheet 2016 moodle.xlsx
2016-12-07 11:15 - 2016-12-07 11:15 - 00043538 _____ C:\Users\colton\Downloads\Matrix Modeling Assignment Spreadsheet 2016 moodle.xlsx
2016-12-06 16:57 - 2016-12-06 16:57 - 00165342 _____ C:\Users\colton\Downloads\Savings Rate and Fee Schedule.pdf
2016-12-05 12:30 - 2016-12-05 12:30 - 00056793 _____ C:\Users\colton\Downloads\MLR_Ants.xlsx
2016-12-04 14:34 - 2016-12-04 14:34 - 00000364 _____ C:\Users\colton\Downloads\AntSpeciesDensity.csv
2016-12-04 14:29 - 2016-12-04 15:59 - 00096380 ____H C:\Users\colton\Desktop\~WRL3502.tmp
2016-11-28 11:19 - 2016-11-28 11:19 - 00146030 _____ C:\Users\colton\Downloads\Millar, Stephenson, Stephens - 2007 - Climate Change and Forests of the Future Managing in the Face of Uncertainty.pdf
==================== One Month Modified files and folders ========
2016-12-23 11:07 - 2015-09-03 13:03 - 00000830 _____ C:\windows\Tasks\Adobe Flash Player Updater.job
2016-12-22 23:59 - 2013-09-18 16:43 - 00005388 _____ C:\windows\system32\PerfStringBackup.INI
2016-12-22 22:50 - 2013-08-22 07:20 - 00000000 ____D C:\windows\CbsTemp
2016-12-22 14:23 - 2013-12-25 12:29 - 00000000 __RDO C:\Users\colton\SkyDrive
2016-12-22 14:22 - 2016-10-05 13:46 - 00000000 ___RD C:\Users\colton\Google Drive
2016-12-22 14:22 - 2013-08-22 06:45 - 00000006 ____H C:\windows\Tasks\SA.DAT
2016-12-21 15:08 - 2013-12-25 12:27 - 00000000 ____D C:\Users\colton
2016-12-21 11:34 - 2014-10-26 15:02 - 00000000 ____D C:\Users\colton\Desktop\Science
2016-12-20 11:56 - 2013-12-25 12:33 - 00003600 _____ C:\windows\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-4150806952-2691248085-3505555448-1001
2016-12-20 11:34 - 2014-05-06 16:49 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2016-12-20 11:34 - 2013-08-22 05:25 - 00524288 ___SH C:\windows\system32\config\BBI
2016-12-20 11:33 - 2014-08-23 12:06 - 00000000 ____D C:\Program Files (x86)\Steam
2016-12-20 11:28 - 2013-12-25 13:05 - 00000000 ____D C:\Program Files\Common Files\Apple
2016-12-19 18:59 - 2014-01-14 15:51 - 00412160 ___SH C:\Users\colton\Desktop\Thumbs.db
2016-12-18 13:53 - 2013-12-25 12:27 - 00000000 ____D C:\Users\colton\AppData\Local\Packages
2016-12-16 12:53 - 2014-02-21 16:34 - 00003330 _____ C:\windows\System32\Tasks\GoogleUpdateTaskMachineUA
2016-12-16 12:53 - 2014-02-21 16:34 - 00003202 _____ C:\windows\System32\Tasks\GoogleUpdateTaskMachineCore
2016-12-15 11:54 - 2014-05-06 16:44 - 00002210 _____ C:\Users\Public\Desktop\Google Chrome.lnk
2016-12-15 11:54 - 2014-02-21 16:34 - 00002222 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2016-12-13 22:38 - 2014-08-23 12:17 - 00000000 ____D C:\Users\colton\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Steam
2016-12-13 22:07 - 2015-09-03 13:03 - 00003718 _____ C:\windows\System32\Tasks\Adobe Flash Player Updater
2016-12-13 22:07 - 2013-08-22 07:36 - 00000000 ____D C:\windows\SysWOW64\Macromed
2016-12-13 22:07 - 2013-08-22 07:36 - 00000000 ____D C:\windows\system32\Macromed
2016-12-13 10:53 - 2016-10-05 13:45 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Drive
2016-12-12 20:51 - 2013-08-22 05:36 - 00000000 ____D C:\windows\Inf
2016-12-12 20:48 - 2016-04-23 13:25 - 00002355 _____ C:\Users\colton\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive for Business.lnk
2016-12-12 20:48 - 2016-03-28 08:38 - 00003190 _____ C:\windows\System32\Tasks\Microsoft OneDrive Auto Update Task-S-1-5-21-4150806952-2691248085-3505555448-1001
2016-12-12 17:36 - 2016-02-08 18:45 - 00000000 ____D C:\Users\colton\AppData\Roaming\TS3Client
2016-12-11 12:47 - 2016-02-08 18:47 - 00000000 ____D C:\Program Files (x86)\Overwolf
2016-12-11 12:44 - 2014-10-05 14:40 - 00000002 _____ C:\END
==================== Files in the root of some directories =======
2013-09-18 16:34 - 2013-09-18 16:34 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
Some files in TEMP:
C:\Users\colton\AppData\Local\Temp\jre-8u101-windows-au.exe
C:\Users\colton\AppData\Local\Temp\vlc-2.2.4-win32.exe
==================== Bamital & volsnap ======================
C:\windows\system32\winlogon.exe => File is digitally signed
C:\windows\system32\wininit.exe => File is digitally signed
C:\windows\explorer.exe => File is digitally signed
C:\windows\SysWOW64\explorer.exe => File is digitally signed
C:\windows\system32\svchost.exe => File is digitally signed
C:\windows\SysWOW64\svchost.exe => File is digitally signed
C:\windows\system32\services.exe => File is digitally signed
C:\windows\system32\User32.dll => File is digitally signed
C:\windows\SysWOW64\User32.dll => File is digitally signed
C:\windows\system32\userinit.exe => File is digitally signed
C:\windows\SysWOW64\userinit.exe => File is digitally signed
C:\windows\system32\rpcss.dll => File is digitally signed
C:\windows\system32\dnsapi.dll => File is digitally signed
C:\windows\SysWOW64\dnsapi.dll => File is digitally signed
C:\windows\system32\Drivers\volsnap.sys => File is digitally signed
LastRegBack: 2016-12-14 10:13
==================== End of FRST.txt ============================
addition text
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 21-12-2016
Ran by colton (23-12-2016 11:57:43)
Windows 8.1 Pro (X64) (2013-12-25 20:27:58)
Boot Mode: Normal
Administrator (S-1-5-21-4150806952-2691248085-3505555448-500 - Administrator - Disabled)
colton (S-1-5-21-4150806952-2691248085-3505555448-1001 - Administrator - Enabled) => C:\Users\colton
Guest (S-1-5-21-4150806952-2691248085-3505555448-501 - Limited - Disabled)
HomeGroupUser$ (S-1-5-21-4150806952-2691248085-3505555448-1003 - Limited - Enabled)
kyrow_000 (S-1-5-21-4150806952-2691248085-3505555448-1004 - Limited - Enabled) => C:\Users\kyrow_000
AV: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AS: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.186 - Adobe Systems Incorporated)
Adobe Reader XI (11.0.18) (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AB0000000001}) (Version: 11.0.18 - Adobe Systems Incorporated)
Age of Empires II: HD Edition (HKLM\...\Steam App 221380) (Version: - Skybox Labs)
Apple Application Support (32-bit) (HKLM-x32\...\{D079CAAD-0C31-47A2-9AF5-A82F9CD9B221}) (Version: 5.2 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{64E6007B-1DA9-42CD-BBE4-D5FA67A7C71D}) (Version: 5.2 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
BioTerm (HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\d302bf3f4006560d) (Version: 1.17.1.3 - Biomark, Inc.)
Bitcoin Core (64-bit) (HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Bitcoin Core (64-bit)) (Version: 0.12.1 - Bitcoin Core project)
Bonjour (HKLM\...\{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 4.10 - Piriform)
Chivalry: Medieval Warfare (HKLM-x32\...\Steam App 219640) (Version: - Torn Banner Studios)
DIRECTV Player (HKLM-x32\...\{4a5ad61d-1fe9-48b9-87a8-9235f71120f3}) (Version: 12.1 - DIRECTV)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 55.0.2883.87 - Google Inc.)
Google Drive (HKLM-x32\...\{07A12123-B717-496B-B471-48AF6407B433}) (Version: 1.32.4066.7445 - Google, Inc.)
Google Update Helper (x32 Version: 1.3.25.11 - Google Inc.) Hidden
Google Update Helper (x32 Version: 1.3.32.7 - Google Inc.) Hidden
Icy Tower v1.5.1 (HKLM-x32\...\Icy Tower v1.5.1_is1) (Version: - Free Lunch Design)
Infinite HDâ„¢ App (HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\Octoshape Streaming Services) (Version: - Octoshape ApS)
iTunes (HKLM\...\{81C96689-EA5B-4B7D-A04F-16326EC51BC2}) (Version: 12.5.4.42 - Apple Inc.)
Java 8 Update 77 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83218077F0}) (Version: 8.0.770.3 - Oracle Corporation)
Microsoft Office 365 ProPlus - en-us (HKLM\...\O365ProPlusRetail - en-us) (Version: 16.0.6001.1068 - Microsoft Corporation)
Microsoft OneDrive (HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\OneDriveSetup.exe) (Version: 17.3.6720.1207 - Microsoft Corporation)
Microsoft Silverlight (HKLM-x32\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.30214.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 (HKLM-x32\...\{9A25302D-30C0-39D9-BD6F-21E6EC160475}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32\...\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32\...\{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Xbox One Controller for Windows (HKLM\...\{DC2CB48C-FD96-48EB-A36A-7D995BB587EB}) (Version: 1.0.2 - Microsoft Corporation)
Mozilla Firefox 50.1.0 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 50.1.0 (x86 en-US)) (Version: 50.1.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 50.1.0.6186 - Mozilla)
Office 16 Click-to-Run Extensibility Component (x32 Version: 16.0.6001.1068 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (Version: 16.0.6001.1068 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (x32 Version: 16.0.6001.1068 - Microsoft Corporation) Hidden
Overwolf (HKLM-x32\...\Overwolf) (Version: 0.100.227.0 - Overwolf Ltd.)
Patch testing for Chivalry (HKLM-x32\...\Steam App 232210) (Version: - )
Quantum Moves version 1.1.3 (HKLM-x32\...\Quantum Moves_is1) (Version: 1.1.3 - Aarhus University)
R for Windows 3.3.1 (HKLM\...\R for Windows 3.3.1_is1) (Version: 3.3.1 - R Core Team)
Skype Click to Call (HKLM-x32\...\{873F8E7C-10E6-449F-BD7E-5FBA7C8E1C9B}) (Version: 8.5.0.9167 - Microsoft Corporation)
Skypeâ„¢ 7.17 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.17.105 - Skype Technologies S.A.)
Steam (HKLM-x32\...\Steam) (Version: - Valve Corporation)
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.0.18 - TeamSpeak Systems GmbH)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
==================== Custom CLSID (Whitelisted): ==========================
CustomCLSID: HKU\S-1-5-21-4150806952-2691248085-3505555448-1001_Classes\CLSID\{162C6FB5-44D3-435B-903D-E613FA093FB5}\InprocServer32 -> C:\Users\colton\AppData\Local\Microsoft\OneDrive\17.3.6720.1207\amd64\FileCoAuthLib64.dll (Microsoft Corporation)
==================== Scheduled Tasks (Whitelisted) =============
Task: {04E8EB53-D4C1-4633-A02A-574B81E6E086} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-30] (Google Inc.)
Task: {05775DCA-AE16-4442-8C09-0C1D1D5FE24E} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentLogOn2016 => C:\Program Files (x86)\Microsoft Office\root\Office16\msoia.exe [2016-03-28] (Microsoft Corporation)
Task: {0B43CA3D-3BF1-48F4-BBE9-93EF8294EA2E} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
Task: {39119E57-A282-4199-80EC-4002FCE45FFE} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2016-10-21] (Adobe Systems Incorporated)
Task: {50BA3F59-5871-4ECE-A11C-7B5838BC80A4} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2015-08-30] (Google Inc.)
Task: {572F3328-848D-4804-928A-FE51E8A99132} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-02-27] (Microsoft Corporation)
Task: {595092B4-E114-48EA-B2C2-DC5B426C638D} - System32\Tasks\{9A80A375-7C6F-41F5-901F-9A0283143906} => pcalua.exe -a "C:\Users\colton\AppData\Local\Temp\Temp1_mule_windows_1.3.6 (1).zip\mule\mule.exe" <==== ATTENTION
Task: {5CC834AE-8F51-45E3-A983-0FC6218D24D6} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2014-01-21] (Piriform Ltd)
Task: {5DC37E78-931E-49F5-A003-7DF1B6AB907A} - System32\Tasks\PCProtector_Popup => C:\Program Files (x86)\PC Protector\Splash.exe
Task: {6ACE9390-173E-45D6-88E2-60D31918E039} - System32\Tasks\Overwolf Updater Task => C:\Program Files (x86)\Overwolf\OverwolfUpdater.exe [2016-12-07] (Overwolf LTD)
Task: {7EE9B37E-E943-4891-B951-1BDC0FB67AF0} - System32\Tasks\Microsoft\Office\Office Subscription Maintenance => C:\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonx86\Microsoft Shared\Office16\OLicenseHeartbeat.exe [2016-03-28] (Microsoft Corporation)
Task: {AAB6F722-021B-4D0C-979A-0FD6E6602DCA} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentFallBack2016 => C:\Program Files (x86)\Microsoft Office\root\Office16\msoia.exe [2016-03-28] (Microsoft Corporation)
Task: {BBF048AA-92D0-4342-B905-18A1B4B5B293} - System32\Tasks\Adobe Flash Player Updater => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2016-12-13] (Adobe Systems Incorporated)
Task: {CF52819D-8E3B-46AA-844E-353F971E6516} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-02-27] (Microsoft Corporation)
Task: {D2E659E4-78E4-4FA9-B930-D25679C24BB0} - System32\Tasks\PCProtector_Start => C:\Program Files (x86)\PC Protector\PCProtector.exe
Task: C:\windows\Tasks\Adobe Flash Player Updater.job => C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
==================== Shortcuts =============================
(The entries could be listed to be restored or removed.)
Shortcut: C:\Users\colton\AppData\Local\Microsoft\Windows\ConnectedSearch\History\site_2662767491_en-us.lnk -> hxxp://www.windowssearch.com:80/suggestions?q=itu&cc=US&setlang=en-US&inlang=en-US&adlt=moderate
ShortcutWithArgument: C:\Users\colton\AppData\Local\Google\Chrome\User Data\Default\Web Applications\theithelpdesk.co\http_80\Support Assistant.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> --app=hxxp://theithelpdesk.co/support-center-details.html
==================== Loaded Modules (Whitelisted) ==============
2016-11-17 01:28 - 2016-11-17 01:28 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2016-11-17 01:28 - 2016-11-17 01:28 - 01353528 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2016-03-28 08:17 - 2016-02-27 22:41 - 00171720 _____ () C:\Program Files\Common Files\Microsoft Shared\ClickToRun\ApiClient.dll
2016-03-28 08:19 - 2016-03-28 08:19 - 08911048 _____ () C:\Program Files (x86)\Microsoft Office\root\VFS\ProgramFilesX64\Microsoft Office\Office16\1033\GrooveIntlResource.dll
2016-12-12 20:48 - 2016-12-12 20:48 - 01678560 _____ () C:\Users\colton\AppData\Local\Microsoft\OneDrive\17.3.6720.1207\amd64\ClientTelemetry.dll
2016-02-14 07:14 - 2016-02-14 07:14 - 01384168 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\NDSPCShowServer.exe
2016-12-22 14:22 - 2016-12-22 14:22 - 00098816 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32api.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00110080 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\pywintypes27.dll
2016-12-22 14:22 - 2016-12-22 14:22 - 00364544 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\pythoncom27.dll
2016-12-22 14:22 - 2016-12-22 14:22 - 00320512 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32com.shell.shell.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00914432 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_hashlib.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 01176576 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._core_.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00806400 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._gdi_.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00816128 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._windows_.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 01067008 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._controls_.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00733184 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._misc_.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00682496 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\pysqlite2._sqlite.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00088064 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_ctypes.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00686080 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\unicodedata.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00119808 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32file.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00108544 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32security.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00007168 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\hashobjs_ext.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00017920 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\thumbnails_ext.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00088064 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\usb_ext.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00012800 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\common.time34.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00018432 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32event.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00167936 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32gui.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00046080 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_socket.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 01303552 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_ssl.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00128512 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_elementtree.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00127488 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\pyexpat.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00038912 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32inet.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00036864 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_psutil_windows.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00524248 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\windows._lib_cacheinvalidation.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00011264 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32crypt.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00123392 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._wizard.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00077312 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._html2.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00027648 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_multiprocessing.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00020480 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\_yappi.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00035840 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32process.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00078848 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\wx._animate.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00024064 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32pipe.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00010240 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\select.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00025600 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32pdh.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00017408 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32profile.pyd
2016-12-22 14:22 - 2016-12-22 14:22 - 00022528 ____R () C:\Users\colton\AppData\Local\Temp\_MEI38522\win32ts.pyd
2016-02-14 07:14 - 2016-02-14 07:14 - 11423968 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\PCShowServer.dll
2016-02-14 07:15 - 2016-02-14 07:15 - 00340192 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\ndsLogStore.dll
2016-02-14 07:14 - 2016-02-14 07:14 - 03301088 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\DrmSingleton.dll
2016-02-14 07:14 - 2016-02-14 07:14 - 02100968 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\DiscoveryManager.dll
2016-02-14 07:14 - 2016-02-14 07:14 - 08346848 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\gsttspplugin.dll
2016-02-14 07:14 - 2016-02-14 07:14 - 00689904 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\libgstreamer-0.10.dll
2016-02-14 07:15 - 2016-02-14 07:15 - 01404128 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\libxml2-2.dll
2016-02-14 07:15 - 2016-02-14 07:15 - 00092880 _____ () C:\Users\colton\AppData\Local\DIRECTV Player\z.dll
2016-12-15 11:54 - 2016-12-07 23:29 - 01829208 _____ () C:\Program Files (x86)\Google\Chrome\Application\55.0.2883.87\libglesv2.dll
2016-12-15 11:54 - 2016-12-07 23:29 - 00085848 _____ () C:\Program Files (x86)\Google\Chrome\Application\55.0.2883.87\libegl.dll
==================== Alternate Data Streams (Whitelisted) =========
(If an entry is included in the fixlist, only the ADS will be removed.)
==================== Safe Mode (Whitelisted) ===================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\AmmyyAdmin => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SMPCHelper => ""=""
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\tvnserver => ""=""
==================== Association (Whitelisted) ===============
(If an entry is included in the fixlist, the registry item will be restored to default or removed.)
==================== Internet Explorer trusted/restricted ===============
(If an entry is included in the fixlist, it will be removed from the registry.)
==================== Hosts content: ===============================
2013-08-22 05:25 - 2013-08-22 05:25 - 00000824 ____A C:\windows\system32\Drivers\etc\hosts
==================== Other Areas ============================
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\Control Panel\Desktop\\Wallpaper -> C:\Users\colton\Desktop\IMG_3416.JPG
DNS Servers: 192.168.0.1
Windows Firewall is enabled.
MSCONFIG\Services: EventLog => 2
MSCONFIG\Services: EventSystem => 2
HKLM\...\StartupApproved\Run: => "iTunesHelper"
HKLM\...\StartupApproved\Run: => "XboxStat"
HKLM\...\StartupApproved\Run32: => "APSDaemon"
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\StartupApproved\StartupFolder: => "Send to OneNote.lnk"
HKU\S-1-5-21-4150806952-2691248085-3505555448-1001\...\StartupApproved\Run: => "Skype"
==================== FirewallRules (Whitelisted) ===============
FirewallRules: [vm-monitoring-nb-session] => LPort=139
FirewallRules: [{4118CA82-10A1-437B-B7D0-855B2BC85E34}] => C:\Program Files\Bonjour\mDNSResponder.exe
FirewallRules: [{85CAB626-6168-4188-800D-D7CB8B7BB775}] => C:\Program Files\Bonjour\mDNSResponder.exe
FirewallRules: [{123333CF-A4BF-410E-A297-1D6F11CC5779}] => C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [{0AAC087F-C231-4ECB-AE7B-CBAFF9E3B5EE}] => C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [TCP Query User{D0B63CE6-2912-4C20-96F6-E8C6710E48E9}C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe] => C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe
FirewallRules: [UDP Query User{56F423C1-9956-4185-8236-FFFB2C68F945}C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe] => C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe
FirewallRules: [{509D96EB-86FE-4C88-B010-544FB8D9E289}] => C:\Program Files\Microsoft Office 15\root\Office15\Lync.exe
FirewallRules: [{C1855497-30CC-4963-A51D-43F176FBB7DD}] => C:\Program Files\Microsoft Office 15\root\Office15\UcMapi.exe
FirewallRules: [TCP Query User{633B2374-673B-46BC-BE20-1DBF31239343}C:\users\colton\downloads\mule_windows_1.3.6 (1)\mule\data\lib\jre\bin\java.exe] => C:\users\colton\downloads\mule_windows_1.3.6 (1)\mule\data\lib\jre\bin\java.exe
FirewallRules: [UDP Query User{B7EC6956-4F07-42AA-B0CA-C13B56AEAEE4}C:\users\colton\downloads\mule_windows_1.3.6 (1)\mule\data\lib\jre\bin\java.exe] => C:\users\colton\downloads\mule_windows_1.3.6 (1)\mule\data\lib\jre\bin\java.exe
FirewallRules: [{BBB98D8C-5676-494C-83B8-7BC636793EA7}] => C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{DCD86DBF-B433-44A2-8090-2CC374CDD836}] => C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{06F2ABF2-8687-41F5-B340-9F627F637ADA}] => C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{FC761108-DBEA-4B83-A8B8-DE616126FFD9}] => C:\Program Files (x86)\Steam\bin\steamwebhelper.exe
FirewallRules: [{D633C508-9AAC-4967-BA0E-33B1825DF202}] => C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{77BC1B3D-8FEB-4DB3-8E44-33FDA8285EDB}] => C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [TCP Query User{9AD1F3E8-AFBC-4B7B-A209-4DC5C8E0303C}C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe] => C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe
FirewallRules: [UDP Query User{82F19FE1-CE93-4D28-836B-EF5B6F9F6BC0}C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe] => C:\users\colton\appdata\local\temp\showmypc\smpc3152\smpcph.exe
FirewallRules: [TCP Query User{63F44865-E06E-4533-9C41-37A008356F89}C:\program files (x86)\mozilla firefox\firefox.exe] => C:\program files (x86)\mozilla firefox\firefox.exe
FirewallRules: [UDP Query User{91068389-04C8-4446-A75B-3C255F77BC98}C:\program files (x86)\mozilla firefox\firefox.exe] => C:\program files (x86)\mozilla firefox\firefox.exe
FirewallRules: [TCP Query User{19755B2B-E722-4BC8-989F-761C1F2E04D0}C:\program files (x86)\skype\phone\skype.exe] => C:\program files (x86)\skype\phone\skype.exe
FirewallRules: [UDP Query User{AA746E89-426E-49B8-8452-1954B3BD5553}C:\program files (x86)\skype\phone\skype.exe] => C:\program files (x86)\skype\phone\skype.exe
FirewallRules: [{F6F7EFF2-A204-4200-8EF0-9C7E9E2D4A42}] => C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{1820B488-2DFD-4B2C-9373-AF1E098B5713}] => C:\Program Files (x86)\Mozilla Firefox\firefox.exe
FirewallRules: [{BA575797-A48E-4AC0-9BF0-CFE440103754}] => C:\Program Files\Bonjour\mDNSResponder.exe
FirewallRules: [{9B0EE8BF-A530-4C48-B5A3-1DB22D50CB29}] => C:\Program Files\Bonjour\mDNSResponder.exe
FirewallRules: [{BAFC2AD4-BE66-4818-8483-FEF05F2794EB}] => C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [{1EC211F2-9D5B-4B00-B099-5C82E3A8F6D3}] => C:\Program Files (x86)\Bonjour\mDNSResponder.exe
FirewallRules: [{7A33C216-D412-4C08-A9E7-691A55883FB7}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\Binaries\Win64\CMW.exe
FirewallRules: [{1B2AF27C-3B5E-435B-B128-34CA1FD8572A}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\Binaries\Win64\CMW.exe
FirewallRules: [{D6DB617B-A5A6-409C-940D-40DCB1D20966}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\CDW\Binaries\Win64\CDW.exe
FirewallRules: [{7AC6A250-50B9-4B9A-B515-3507D1D1E0DB}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\CDW\Binaries\Win64\CDW.exe
FirewallRules: [{88C9E466-FC95-4529-9C99-DCA0ED45EEFA}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\Binaries\Win32\CMW.exe
FirewallRules: [{A23307F8-9556-49FC-9922-D757E4B5099F}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\Binaries\Win32\CMW.exe
FirewallRules: [{D69A01B6-DDF9-4729-AC07-DAE8AE53F38D}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\CDW\Binaries\Win32\CDW.exe
FirewallRules: [{09FD90EF-B3DE-4D24-98F4-237CBC589803}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\CDW\Binaries\Win32\CDW.exe
FirewallRules: [{0AECFCBF-BE09-4DA6-8D01-A49AEE7867EA}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\ChivLauncher.exe
FirewallRules: [{0E873E74-853C-482C-9CD5-46B1A447DED7}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfarebeta\ChivLauncher.exe
FirewallRules: [{7CA2E425-EF97-44AF-9658-4670C4CF708E}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\Binaries\Win64\CMW.exe
FirewallRules: [{3EE11B16-CFAD-4E57-B332-9D84DA5C1D10}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\Binaries\Win64\CMW.exe
FirewallRules: [{CE950563-6B95-4573-97DD-F466DEBF219E}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\CDW\Binaries\Win64\CDW.exe
FirewallRules: [{B1D91F01-953F-47DA-A8F9-36897AF55570}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\CDW\Binaries\Win64\CDW.exe
FirewallRules: [{D24764F6-C041-47D1-AD5A-0E833BEC4753}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\Binaries\Win32\CMW.exe
FirewallRules: [{84DF6D12-2879-4AFE-9092-F3263F84C8DF}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\Binaries\Win32\CMW.exe
FirewallRules: [{39058B79-2884-4481-9E43-D14A66ABB7D8}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\CDW\Binaries\Win32\CDW.exe
FirewallRules: [{9D51DAEE-01BF-4850-8AC6-839475CDC52A}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\CDW\Binaries\Win32\CDW.exe
FirewallRules: [{5D9A604E-688E-4D05-99CE-0F3C30CFB588}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\ChivLauncher.exe
FirewallRules: [{F4493367-6A9A-493E-B94E-2C5469F70B75}] => C:\Program Files (x86)\Steam\SteamApps\common\chivalrymedievalwarfare\ChivLauncher.exe
FirewallRules: [{831EB29A-300E-44AA-8159-BD9A783EC72D}] => C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe
FirewallRules: [{A6D1137B-234D-456C-900E-47A205DDF615}] => C:\Program Files (x86)\Microsoft Office\root\Office16\Lync.exe
FirewallRules: [{911608D6-9A97-48D9-96F9-D0ED9C38D2C5}] => C:\Program Files (x86)\Microsoft Office\root\Office16\Lync.exe
FirewallRules: [{4CACF8CA-B533-4508-A6F2-5B576276EBF3}] => C:\Program Files (x86)\Microsoft Office\root\Office16\UcMapi.exe
FirewallRules: [{B908D77A-511F-45E3-BA54-3123A582870E}] => C:\Program Files (x86)\Microsoft Office\root\Office16\UcMapi.exe
FirewallRules: [TCP Query User{562FAE31-8C86-49D1-A0A4-447725028F18}C:\users\colton\appdata\local\directv player\ndspcshowserver.exe] => C:\users\colton\appdata\local\directv player\ndspcshowserver.exe
FirewallRules: [UDP Query User{871F670F-A883-4BA0-A30B-097C6EEC536A}C:\users\colton\appdata\local\directv player\ndspcshowserver.exe] => C:\users\colton\appdata\local\directv player\ndspcshowserver.exe
FirewallRules: [TCP Query User{D070A938-26EE-48C8-9048-C052E4FAEE74}C:\program files\bitcoin\bitcoin-qt.exe] => C:\program files\bitcoin\bitcoin-qt.exe
FirewallRules: [UDP Query User{F17D073B-98B7-406A-9948-C3A83247C721}C:\program files\bitcoin\bitcoin-qt.exe] => C:\program files\bitcoin\bitcoin-qt.exe
FirewallRules: [{96C091C7-13BC-4AFA-997A-C6967D544644}] => C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
FirewallRules: [{10F69145-CE98-4AD3-9F47-8A321FFECC6D}] => C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
FirewallRules: [{2A133C9E-8C2E-4E12-9261-4815687D136C}] => C:\Program Files (x86)\Steam\SteamApps\common\Age2HD\Launcher.exe
FirewallRules: [{2089DB6A-6E83-4EBD-A342-B86580733A82}] => C:\Program Files (x86)\Steam\SteamApps\common\Age2HD\Launcher.exe
FirewallRules: [{EE06A799-60C5-4F85-8E74-01ADBE4A368C}] => C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
FirewallRules: [{9D9CC074-4E7B-4F7E-8B5A-C2341159E8A9}] => C:\Program Files\iTunes\iTunes.exe
16-12-2016 03:01:29 Scheduled Checkpoint
==================== Faulty Device Manager Devices =============
==================== Event log errors: =========================
Application errors:
Error: (12/22/2016 11:59:42 PM) (Source: Microsoft-Windows-LoadPerf) (EventID: 3011) (User: NT AUTHORITY)
Description: Unloading the performance counter strings for service WmiApRpl (WmiApRpl) failed. The first DWORD in the Data section contains the error code.
Error: (12/22/2016 11:59:42 PM) (Source: Microsoft-Windows-LoadPerf) (EventID: 3012) (User: NT AUTHORITY)
Description: The performance strings in the Performance registry value is corrupted when process Performance extension counter provider. The BaseIndex value from the Performance registry is the first DWORD in the Data section, LastCounter value is the second DWORD in the Data section, and LastHelp value is the third DWORD in the Data section.
Error: (12/22/2016 10:45:52 PM) (Source: Microsoft-Windows-LocationProvider) (EventID: 2002) (User: NT AUTHORITY)
Description: There was an error starting the Windows Location Provider
Error: (12/22/2016 05:50:36 PM) (Source: Microsoft-Windows-LocationProvider) (EventID: 2002) (User: NT AUTHORITY)
Error: (12/22/2016 02:28:16 PM) (Source: Microsoft-Windows-LoadPerf) (EventID: 3011) (User: NT AUTHORITY)
Error: (12/22/2016 02:28:16 PM) (Source: Microsoft-Windows-LoadPerf) (EventID: 3012) (User: NT AUTHORITY)
Error: (12/22/2016 02:23:31 PM) (Source: Microsoft-Windows-LocationProvider) (EventID: 2002) (User: NT AUTHORITY)
Error: (02/23/2014 02:23:48 PM) (Source: Bonjour Service) (EventID: 100) (User: )
Description: Task Scheduling Error: m->NextScheduledSPRetry 91492610
Description: Task Scheduling Error: m->NextScheduledEvent 91492610
Description: Task Scheduling Error: Continuously busy for more than a second
System errors:
Error: (12/22/2016 04:05:32 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Windows Search service terminated unexpectedly. It has done this 112 time(s).
Error: (12/22/2016 04:05:32 PM) (Source: Service Control Manager) (EventID: 7024) (User: )
Description: The Windows Search service terminated with the following service-specific error:
%%2147749126
Error: (12/22/2016 04:04:40 PM) (Source: Service Control Manager) (EventID: 7024) (User: )
Description: The Background Intelligent Transfer Service service terminated with the following service-specific error:
%%2147943468 = The dependency service or group failed to start.
Error: (12/22/2016 04:04:40 PM) (Source: Microsoft-Windows-Bits-Client) (EventID: 16392) (User: NT AUTHORITY)
Description: The BITS service failed to start. Error 2147943468.
Error: (12/22/2016 04:04:40 PM) (Source: DCOM) (EventID: 10005) (User: NT AUTHORITY)
Description: DCOM got error "1068" attempting to start the service netprofm with arguments "Unavailable" in order to run the server:
{A47979D2-C419-11D9-A5B4-001185AD2B89}
Error: (12/22/2016 04:04:40 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Description: The Network List Service service depends on the Network Location Awareness service which failed to start because of the following error:
Description: The Network Location Awareness service depends on the Windows Event Log service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
Percentage of memory in use: 58%
Total physical RAM: 4016.1 MB
Available physical RAM: 1674.35 MB
Total Virtual: 5104.1 MB
Available Virtual: 2399.97 MB
Drive c: (Windows) (Fixed) (Total:112.92 GB) (Free:28.03 GB) NTFS
==================== MBR & Partition Table ==================
Disk: 0 (Size: 119.2 GB) (Disk ID: 7F2F56B3)
Partition: GPT.
==================== End of Addition.txt ============================
OK, please do the following.
1. Right-click your Start button and choose Run.
2. Type msconfig and click OK.
3. Ensure Normal Startup is selected in the first tab.
4. Click the Services tab and then click Enable all.
5. Click OK and the reboot when prompted.
Please let me know when complete.
