Unsuccessful attempt to repair corrupt system files using SFCFix
cleanwake
I have Windows 8.1 x64 and noticed recently that Copy-Paste is not working reliably. When I searched online for solutions, I found the possible explanation of corrupt system files so followed the instructions to run SFC as Admin. Indeed, I found three corrupt files on my system but SFC was unable to repair them. I then tried running SFCFix (by niemiro) found on eightforums. Another SFC scan revealed the corrupted files were not able to be repaired. I still have the Copy-Paste problem.
The names of the three corrupt files are: utc.app.json, telemetry.ASM-WindowsDefault.json, and Amd64\CNBJ2530.DPB. Note, I have an Intel processor.
Now I must make a confession and this is totally embarrassing - I realized I had run the Windows7 version of SFCFix by accident! My system is still seems to be working normally, but I feel that was a very dangerous thing I did. Drat! So having realized my mistake, I downloaded the Windows8 version of SFCFix and ran it. Unfortunately, SFC scan still shows the files are corrupt - in other words it was unable to repair them.
Here is the SFCFix.txt from the first run - when I stupidly ran the Windows7 version:
SFCFix version 2.4.5.0 by niemiro.​
Start time: 2015-07-15 17:55:19.509​
Microsoft Windows 8.1 Update 3 - amd64​
Using .zip script file at C:\Users\Anne\Desktop\SFCFix.zip [0]​
PowerCopy::​
Successfully took permissions for file or folder C:\windows\winsxs​
Successfully created directory tree \\?\C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.1.7601.18839_none_fe0845bb1d97efda.​
Successfully copied file C:\Users\Anne\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.1.7601.18839_none_fe0845bb1d97efda\telemetry.ASM-WindowsDefault.json to C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.1.7601.18839_none_fe0845bb1d97efda\telemetry.ASM-WindowsDefault.json.​
Successfully copied file C:\Users\Anne\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.1.7601.18839_none_fe0845bb1d97efda\utc.app.json to C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.1.7601.18839_none_fe0845bb1d97efda\utc.app.json.​
Successfully restored ownership for C:\windows\winsxs​
Successfully restored permissions on C:\windows\winsxs​
PowerCopy:: directive completed successfully.​
Successfully processed all directives.​
SFCFix version 2.4.5.0 by niemiro has completed.​
Currently storing 1 datablocks.​
Finish time: 2015-07-15 17:55:39.717​
Script hash: Sz20Fv8jfGapU+nUI9JBWuyv8aCnEq2LnhycxfNs7JU=​
----------------------EOF-----------------------​
And here is the SFCFix.txt from the second time, when I ran the Windows 8 version:
Start time: 2015-07-16 07:40:31.884​
PowerCopy::​
Successfully created directory tree \\?\C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0.​
Successfully copied file C:\Users\Anne\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\telemetry.ASM-WindowsDefault.json to C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\telemetry.ASM-WindowsDefault.json.​
Successfully copied file C:\Users\Anne\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\utc.app.json to C:\windows\winsxs\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\utc.app.json.​
Finish time: 2015-07-16 07:40:42.312​
Script hash: u/XcPQ2yAlCsHh/kkBZ3OSvSBpcxnCEFqjpE0eFPDGU=​
When I tried to attach a zip of my CBS folder but it would not upload because it exceeded the allowable file size. I had to remove several of the older CbsPersist files in order to reduce the size of the zipped folder, but all of those were dated prior to the events discussed above. The file "CBS 07 15 16 08" is one I created myself by renaming CBS after the scan following the first run of SFCFix (the mistaken Window7 run) - I did this because I wasn't sure if it would be overwritten later. The file "CBS" was created by the scan following the second run of SFCFix (the Windows8 version).
Any suggestions would be greatly appreciated! Thanks!
Hi and welcome to Sysnative. We'll fix the following corruption.
2015-07-15 18:15:05, Info                  CSI    000008ea [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-07-15 18:15:05, Info                  CSI    000008eb Hashes for file member \SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
  Found: {l:32 b:hXmExHkfTwxbzbUy21hYVwdDP67rvJ5gt8pucnuNJX8=} Expected: {l:32 b:n520k714Uu3utHa5JGQ6HQYbZphKhlMWq5pEmfnCDuw=}
However, the other two that reference telemetry are a known issue and can safely be ignored. They don't impact the function of your machine. More info is below.
https://support.microsoft.com/en-us/kb/3022345
Originally Posted by Microsoft
This update enables the Diagnostics Tracking Service in Windows 8.1, Windows Server 2012 R2, Windows 7 Service Pack 1 (SP1), and Windows Server 2008 R2 SP1. This tracking service collects data about functional issues in Windows.
This update contains the following two manifests that are occasionally updated by the Diagnostic Tracking Service:
utc.app.json
The two files are marked as static files in the update. When an advanced user runs the System File Checker Tool (sfc.exe), the files are unintentionally flagged as corrupted. There is no impact or corruption on a device that is running this update, and this issue will be fixed in a later service update.
Please do the following to correct the one corruption.
Step#1 - SFCFix Script
Step#2 - Verify Corruption is fixed
1. Right-click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
Brian,
Thank you! It appears I have successfully repaired the one corrupt file. I am still having the issue with Cut and Paste, so there must be a different cause for that. I'll have to investigate further. Here is the text created by SFCFix, and the CBS.txt is attached. Thanks again.
Start time: 2015-07-18 07:56:18.126​
PowerCopy::​
Successfully took permissions for file or folder C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB​
Successfully copied file C:\Users\Anne\AppData\Local\niemiro\Archive\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB to C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB.​
Successfully restored ownership for C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB​
Successfully restored permissions on C:\windows\Winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB​
Currently storing 2 datablocks.​
Finish time: 2015-07-18 07:56:19.704​
Script hash: FmACULyIMQvynlAegNO67P07Uy9aa/lmDPE5ZawSGlo=​
Verified. Corruption is fixed. Let's do one more scan to ensure there is nothing else that needs fixed from a Windows Update/Servicing perspective.
