Unrepaired corruptions after running SFCFix
alphapleb
Hi, I'm having an issue on Windows 7 with my Asus laptop where running SFC /scannow does not repair the corrupted file PINTLGB.IMD. I then found out about SFCFix.exe (from a google search which led here https://www.sysnative.com/forums/wi...ow-cannot-repair-member-file-pintlgb-imd.html) and ran the newer version of the program but it was not able to repair the corrupted file and referred me back here. If someone could help me fix this it would be greatly appreciated. A google drive link to my CBS zip is below.
CBS.zip - Google Drive
Hi and :welcome: to Sysnative :wave:
Please run the following fix:
SFCFix Fix
This fix is very specific for alphapleb's computer. Trying this fix on your own computer might damage your computer. If you are after assistance, create a new thread, and you will be assisted shortly.
Download SFCFix.exe (by niemiro) and move the executable on your Desktop.
Download the attached View attachment SFCFix.zip and move the archive to your Desktop
Save any work you have open, and close every programs
Drag the SFCFix.zip file over the SFCFix.exe executable and release it
SFCFix will launch, let it complete
Once done, a file will appear on your Desktop, called SFCFix.txt
Open the file, then copy and paste its content in your next reply
After you have run the fix, could you run SFC again, and if it reports that it found corrupt files, could you attach the C:\Windows\logs\CBS\CBS.log?
-CKing
It worked! Thank you so much you are amazing! I ran sfc /scannow with no issues. Here is the SFCFix log:
Start time: 2017-02-09 14:11:13.597
Using .zip script file at C:\Users\Amy\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.23572_none_767df08977e35328\pintlgb.imd
Successfully copied file C:\Users\Amy\AppData\Local\niemiro\Archive\SFCFix.exe to C:\Windows\WinSxS\SFCFix.exe.
Successfully copied file C:\Users\Amy\AppData\Local\niemiro\Archive\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.23572_none_767df08977e35328\pintlgb.imd to C:\Windows\WinSxS\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.23572_none_767df08977e35328\pintlgb.imd.
Successfully restored ownership for C:\Windows\WinSxS
Successfully restored permissions on C:\Windows\WinSxS
Successfully restored ownership for C:\Windows\WinSxS\amd64_micro
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.23572_none_767df08977e35328\pintlgb.imd
Finish time: 2017-02-09 14:12:42.673
Script hash: /wb2ooPSuDqg9oyI/Usrqq7t/Bq4JLhaDKVzt3PDgwY=
No problem! Glad to help!
Just before I mark this thread as solved, I noticed something strange:
It seemed to have copied SFCFix as well. Let's delete that:
SFCFix Fix
Download the attached View attachment SFCFixScript.txt and move the archive to your Desktop
Note: Make sure that the file is named SFCFixScript.txt, do not rename it.
Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it
-CKing
