[SOLVED] Unfixed Errors in sfcfix..Need help..!
OutLaw
hello guys....i need help...
i found Some corruptions could not be fixed automatically in sfcfix..
SFCFIX log details are below...
Start time: 2016-06-07 12:24:10.229
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-m..onwizardapplication_31bf3856ad364e35_6.1.7601.17514_none_bc8280d4f2975f56\PostMig.exe
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-p..nfiguration-cmdline_31bf3856ad364e35_6.1.7600.16385_none_09320e5ae212b9d9\powercfg.exe
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-powershell-exe_31bf3856ad364e35_6.1.7600.16385_none_68ec54d7638638f5\powershell.exe
CBS & SFC total detected corruption count: 3
Finish time: 2016-06-07 12:24:29.104
thank u very much..!
Hi and welcome to Sysnative. This should get you fixed up.
Step#1 - SFCFix Script
Step#2 - SFC Scan
  1. Click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
More to fix. Please do the following.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
thanks ..now there is no error in sfcscan.
but the main reason i started sfcscan bcoz "aero" theme in my pc sometimes go off and on and in this process the whole screen flickers.this affect my game experiance and sometimes games get freeze due to this problem.
but sadly even after solving sfcscan errors this problem is still happening.
i searched about this problem , and services related to aero theme is fine in my pc..
now i dont know what am i suppose to do..?
can anyone please suggest me a solution..!!
thanks..
Let's do one more scan please.
now no errors deected in checksur log and there is no error in sfcscan..
thanks for the help..!! :)
but aero theme problem is still happening.i understand that this is not the topic in this site...
but still i'm attaching aero problem log too... the problem in the log happenning again n again..maybe u can help me with that too.!
