[SOLVED] The USB fingerprint reader disconnects and freezes the system for a few seconds + BSODs
Solitario
Argentina.
Hi, I'm having trouble with the USB fingerprint reader. It disconnects itself and freezes the mouse cursor for a few seconds, then reconnects and works properly. I ran FRST to see the errors and I think I found the error (attached in this post). If I attach the wrong error code please tell me. How can I fix this problem? Thank you very much in advance. Best regards.
Mistake: (07/01/2019 12:11:06 PM) (Source: ESENT) (EventID: 544) (User: )
Description: Catalog Database (3872,D,29) Catalog Database: Error when checking the database page read from the "C" file:\WINDOWS\system32\CatRoot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb" at position 48570368 (0x000002e52000) (database page 11857 (0x2E51)) with 4096 (0x00001000) bytes because, persistently, the lost empty detection time stamp does not match. The read operation will close with error -1119 (0xfffffba1).
The empty state on the database page 11857 (0x2E51) was 3, while the empty state on the empty assignments page 0 (0x0) was 1.
If the problem persists, restore the database from a previous backup. This problem may be caused by faulty hardware. Contact your hardware vendor for help diagnosing the problem.
I'm not sure what the error in the code box is referring to.
As far as your fingerprint reader is concerned, the only thing that you really can do to try and fix it is to reinstall the driver.
Go to your system manufacturer's support site; locate the most recent version of the fingerprint device driver; download it and install it.
Keep in mind that it is also possible that the fingerprint device is malfunctioning and MAY need to be replaced. I don't know how old your system is or how often you use the fingerprint device, but hardware failure is a possibility here.
I don't know why it would be disconnecting itself and causing the cursor to freeze -- unless the fingerprint device is malfunctioning as I described or perhaps the driver is corrupted.
Does the fingerprint device work properly? i.e., can you access the system by using it?
Do you actually use it? If not, then it should be disabled.
Check Device Manager and see if the device is reading OK -
Click on WIN key; type devmgmt.msc in the Search box; select same from the list that appears; locate the fingerprint device. If you can't find it, I'll be able to help you once I get the files and reports (see below).
Please run this and attach the output file to your next post in this thread. I know that you don't have BSODs, but I use the jcgriff2/Sysnative app for general troubleshooting as well as for BSODs.
Blue Screen of Death (BSOD) Posting Instructions - Windows 10, 8.1, 8, 7 + Vista
No need to answer the questions.
Regards. . .
jcgriff2
I uninstalled the driver. Now there is only the one that installs windows automatically. I still have the system freezes. The reader is the following : u.are.u 4500 fingerprint reader. Searching the net I didn't find any driver for this fingerprint reader. I bought it and it didn't come with any installation CD or anything, so I don't know how to find the driver to run Windows Hello. It was difficult for me to find the report but I finally found it, a folder was created in Windows.old in my user with all the .txt of the report, then I archived it to .zip. I enclose the requested report. Thank you very much for your help. Best regards.
It seems that it was a problem related to the windows power configuration. If that was the problem I think it's solved. Also, please, leave the issue open for a few more days, so I confirm if it is solved. Thank you very much. Best regards.
Hi. . .
Thank you for the Sysnative folder/files. I found 2 rather bizarre BSOD dumps - both with a 29 May 2019 timestamp.
I do believe that the fingerprint scanner is the least of your problems right now.
You metioned that you had to get it out of windows.old, which tells me that you reinstalled Windows. Is this true? If so, when? Why?
One dump had a bugcheck = 0xc000021a
WINLOGON_FATAL_ERROR (c000021a)
The Winlogon process terminated unexpectedly.
Arguments:
Arg1: ffffb28aa0cfa3a0, String that identifies the problem.
Arg2: ffffffffc0000428, Error Code.
Arg3: 0000000000000000
Arg4: 0000022741970000
0xC000021A STATUS_SYSTEM_PROCESS_TERMINATED{Fatal System Error} The %hs system process terminated unexpectedly with a status of 0x%08x (0x%08x 0x%08x). The system has been shut down.
Error code 0xc0000428 (0xc428) translates to -
0xC0000428 STATUS_INVALID_IMAGE_HASHThe hash for image %hs cannot be found in the system catalogs. The image is likely corrupt or the victim of tampering.
I do not know whether or not the file with the digital signature issue is smss.exe or not (see below)
  • ERROR_CODE: (NTSTATUS) 0xc000021a - {Fatal System Error} The %hs system process terminated unexpectedly with a status of 0x%08x (0x%08x 0x%08x). The system has been shut down.
  • EXCEPTION_CODE: (NTSTATUS) 0xc000021a - {Fatal System Error} The %hs system process terminated unexpectedly with a status of 0x%08x (0x%08x 0x%08x). The system has been shut down.
  • EXCEPTION_CODE_STR: c000021a
  • Bugcheck String -
    BUGCHECK_STR:  0xc000021a_SmpDestroyControlBlock_[h31]smss.exe[/h31]_Terminated_c0000428
  • Process name =
    PROCESS_NAME:  smss.exe
It appears that the 0xc21a termination exception code/bugcheck is referring to smss.exe
smss.exe = Windows Session Manager Subsystem and is responsible for handling sessions on your system. "smss.exe" manages the startup of all user sessions in Windows. It launches processes such as Win32 and WinLogin. In this case of your 0xc21a BSOD, it appears that something unknown caused the sudden and deliberate termination of "smss.exe".
My first guess because of this 0xc21a bugcheck BSOD coupled with your other BSOD with a bugcheck = 0xc0000142 (explained below) is possible hard drive failure. Anytime that I've seen early system start-up executables like smss.exe ad winlogon.exe die suddenly without explanation, the hard drive is usually involved.
The other BSOD had a bugcheck - 0xc0000142. Interpreted, it means - DLL Failure
0xC0000142 STATUS_DLL_INIT_FAILED{DLL Initialization Failed} Initialization of the Dynamic Link Library %hs failed. The process is terminating abnormally.
BSOD Bugcheck NTSTATUS VALUES (EXCEPTION ERROR CODES)
Unknown bugcheck code (c0000142)
Unknown bugcheck description
Arguments:
Arg1: ffff8a8377dfd3d0
Arg2: ffff8a837552c210
Arg4: 0000000000000000
  • BUGCHECK_STR: STATUS_DLL_INIT_FAILED
  • ERROR_CODE: (NTSTATUS) 0xc0000142 - {DLL Initialization Failed} Initialization of the dynamic link library %hs failed. The process is terminating abnormally.
  • EXCEPTION_CODE: (NTSTATUS) 0xc0000142 - {DLL Initialization Failed} Initialization of the dynamic link library %hs failed. The process is terminating abnormally.
  • PROCESS_NAME: csrss.exe
  • FAILURE_BUCKET_ID: STATUS_DLL_INIT_FAILED_nt!PopTransitionSystemPowerStateEx
  • BUCKET_ID: STATUS_DLL_INIT_FAILED_nt!PopTransitionSystemPowerStateEx
  • PRIMARY_PROBLEM_CLASS: STATUS_DLL_INIT_FAILED_nt!PopTransitionSystemPowerStateEx
System Uptimes (the time of BSOD after power turned on for boot-up) -
0xc0000142 - 18.1 seconds
0xc000021a - 10.7 seconds
Any non-Window patches on your system that you know of?
Run SeaTools for DOS, LONG test - Hard Drive (HDD) Diagnostics (Sea Tools for DOS) & SSD Test
I'll try to find the driver for you, but I need the EXACT model number from your system. It is on the label. If a laptop, look on the bottom of the system.
Just run SeaTools for now.
Regards. . .
jcgriff2
BSOD Windbg Logs:
Dump #1
Microsoft (R) Windows Debugger Version 10.0.17763.132 AMD64
Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\Temp3_SysnativeFileCollectionApp.zip\SysnativeFileCollectionApp\052919-8843-01.dmp]
************* Path validation summary **************
Response Time (ms) Location
Deferred SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 18362 MP (8 procs) Free x64
Machine Name:
Kernel base = 0xfffff800`5e600000 PsLoadedModuleList = 0xfffff800`5ea432b0
Debug session time: Wed May 29 18:11:08.999 2019 (UTC - 4:00)
System Uptime: 0 days 0:00:10.690
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck C000021A, {ffffb28aa0cfa3a0, ffffffffc0000428, 0, 22741970000}
ETW minidump data unavailable
Probably caused by : ntkrnlmp.exe ( nt!PopTransitionSystemPowerStateEx+d05e )
Followup:     MachineOwner
Processing initial command '!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck'
2: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck
Arguments:
Debugging Details:
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING:  10.0.18362.145 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER:  System manufacturer
SYSTEM_PRODUCT_NAME:  System Product Name
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  0312
BIOS_DATE:  01/05/2017
BASEBOARD_MANUFACTURER:  ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT:  STRIX B250F GAMING
BASEBOARD_VERSION:  Rev X.0x
EXCEPTION_PARAMETER1:  ffffb28aa0cfa3a0
EXCEPTION_PARAMETER2:  ffffffffc0000428
EXCEPTION_PARAMETER3:  0000000000000000
EXCEPTION_PARAMETER4: 22741970000
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
DUMP_TYPE:  2
BUGCHECK_P1: ffffb28aa0cfa3a0
BUGCHECK_P2: ffffffffc0000428
BUGCHECK_P3: 0
BUGCHECK_P4: 22741970000
ADDITIONAL_DEBUG_TEXT:  initial session process or
BUGCHECK_STR:  0xc000021a_SmpDestroyControlBlock_smss.exe_Terminated_c0000428
IMAGE_NAME:  ntkrnlmp.exe
MODULE_NAME: nt
CPU_COUNT: 8
CPU_MHZ: e10
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: 9
CPU_MICROCODE: 6,9e,9,0 (F,M,S,R)  SIG: 8E'00000000 (cache) 8E'00000000 (init)
BLACKBOXBSD: 1 (!blackboxbsd)
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
CURRENT_IRQL:  0
ANALYSIS_SESSION_HOST:  SYSNATIVEFORUMS
ANALYSIS_SESSION_TIME:  07-06-2019 17:08:09.0794
ANALYSIS_VERSION: 10.0.17763.132 amd64fre
LAST_CONTROL_TRANSFER:  from fffff8005eba9c7a to fffff8005e7bc8a0
STACK_TEXT:
fffffd85`1496f4a8 fffff800`5eba9c7a : 00000000`0000004c 00000000`c000021a fffffd85`14a2f2f8 ffffdb04`fd4bfdd0 : nt!KeBugCheckEx
fffffd85`1496f4b0 fffff800`5eba0eca : 00000000`00000000 fffffd85`1496f570 00000000`00000000 fffffd85`1496f570 : nt!PopGracefulShutdown+0x29a
fffffd85`1496f4f0 fffff800`5eb9a01c : ffffb28a`9e154d01 fffff800`00000006 00000000`00000004 ffffb28a`9efd1030 : nt!PopTransitionSystemPowerStateEx+0xd05e
fffffd85`1496f5b0 fffff800`5e7cdf95 : 00000000`00000000 fffff800`5e64055b 00000000`00000010 00000000`00040086 : nt!NtSetSystemPowerState+0x4c
fffffd85`1496f790 fffff800`5e7c0660 : fffff800`5ed93935 00000000`c0000004 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
fffffd85`1496f928 fffff800`5ed93935 : 00000000`c0000004 00000000`00000000 00000000`00000000 fffff800`5ea40660 : nt!KiServiceLinkage
fffffd85`1496f930 fffff800`5ed19939 : ffffdb04`fc644080 fffff800`5e6c4d0c fffff800`647b3c70 ffffdb04`00000000 : nt!PopIssueActionRequest+0x79ed9
fffffd85`1496f9d0 fffff800`5e72d88f : 00000000`00000001 00000000`00000002 00000000`00000000 fffff800`5ea40500 : nt!PopPolicyWorkerAction+0x79
fffffd85`1496fa40 fffff800`5e6c4855 : ffffdb04`00000001 ffffdb04`fc644080 fffff800`5e72d800 ffffdb04`f3c95020 : nt!PopPolicyWorkerThread+0x8f
fffffd85`1496fa70 fffff800`5e72f725 : ffffdb04`fc644080 00000000`00000080 ffffdb04`f3c8c380 000024ef`bd9bbfff : nt!ExpWorkerThread+0x105
fffffd85`1496fb10 fffff800`5e7c3dfa : ffff8b00`0fedd180 ffffdb04`fc644080 fffff800`5e72f6d0 00000000`00000000 : nt!PspSystemThreadStartup+0x55
fffffd85`1496fb60 00000000`00000000 : fffffd85`14970000 fffffd85`14969000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
THREAD_SHA1_HASH_MOD_FUNC:  53fc5ecb280b3e5cc6b5dde02f8439c4d5c2f83b
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  80ca9a621965d1a6b9d99af294c40edf3f5ebca9
THREAD_SHA1_HASH_MOD:  dc844b1b94baa204d070855e43bbbd27eee98b94
FOLLOWUP_IP:
fffff800`5eba0eca cc              int     3
FAULT_INSTR_CODE:  685f89cc
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!PopTransitionSystemPowerStateEx+d05e
FOLLOWUP_NAME:  MachineOwner
DEBUG_FLR_IMAGE_TIMESTAMP:  0
IMAGE_VERSION:  10.0.18362.145
STACK_COMMAND:  .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET:  d05e
FAILURE_BUCKET_ID:  0xc000021a_SmpDestroyControlBlock_smss.exe_Terminated_c0000428_nt!PopTransitionSystemPowerStateEx
PRIMARY_PROBLEM_CLASS:  0xc000021a_SmpDestroyControlBlock_smss.exe_Terminated_c0000428_nt!PopTransitionSystemPowerStateEx
TARGET_TIME:  2019-05-29T22:11:08.000Z
OSBUILD:  18362
OSSERVICEPACK:  145
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  272
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  unknown_date
BUILDDATESTAMP_STR:  160101.0800
BUILDLAB_STR:  WinBuild
BUILDOSVER_STR:  10.0.18362.145
ANALYSIS_SESSION_ELAPSED_TIME:  9e3
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0xc000021a_smpdestroycontrolblock_smss.exe_terminated_c0000428_nt!poptransitionsystempowerstateex
FAILURE_ID_HASH:  {11c026a4-042b-4c24-02dc-2da456397475}
rax=ffffdb04fc8738a0 rbx=0000000000000002 rcx=000000000000004c
rdx=00000000c000021a rsi=fffffd851496f628 rdi=fffffd851496f5d0
rip=fffff8005e7bc8a0 rsp=fffffd851496f4a8 rbp=fffffd851496f570
r8=fffffd8514a2f2f8 r9=ffffdb04fd4bfdd0 r10=fffffd8514a2f000
r11=ffff9fcfe7f3f000 r12=fffffd851496f6bc r13=fffffd851496f6b8
r14=fffffd851496f5ec r15=0000000000000002
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00040286
nt!KeBugCheckEx:
fffff800`5e7bc8a0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffffd85`1496f4b0=000000000000004c
# Child-SP RetAddr : Args to Child : Call Site
00 fffffd85`1496f4a8 fffff800`5eba9c7a : 00000000`0000004c 00000000`c000021a fffffd85`14a2f2f8 ffffdb04`fd4bfdd0 : nt!KeBugCheckEx
01 fffffd85`1496f4b0 fffff800`5eba0eca : 00000000`00000000 fffffd85`1496f570 00000000`00000000 fffffd85`1496f570 : nt!PopGracefulShutdown+0x29a
02 fffffd85`1496f4f0 fffff800`5eb9a01c : ffffb28a`9e154d01 fffff800`00000006 00000000`00000004 ffffb28a`9efd1030 : nt!PopTransitionSystemPowerStateEx+0xd05e
03 fffffd85`1496f5b0 fffff800`5e7cdf95 : 00000000`00000000 fffff800`5e64055b 00000000`00000010 00000000`00040086 : nt!NtSetSystemPowerState+0x4c
04 fffffd85`1496f790 fffff800`5e7c0660 : fffff800`5ed93935 00000000`c0000004 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ fffffd85`1496f790)
05 fffffd85`1496f928 fffff800`5ed93935 : 00000000`c0000004 00000000`00000000 00000000`00000000 fffff800`5ea40660 : nt!KiServiceLinkage
06 fffffd85`1496f930 fffff800`5ed19939 : ffffdb04`fc644080 fffff800`5e6c4d0c fffff800`647b3c70 ffffdb04`00000000 : nt!PopIssueActionRequest+0x79ed9
07 fffffd85`1496f9d0 fffff800`5e72d88f : 00000000`00000001 00000000`00000002 00000000`00000000 fffff800`5ea40500 : nt!PopPolicyWorkerAction+0x79
08 fffffd85`1496fa40 fffff800`5e6c4855 : ffffdb04`00000001 ffffdb04`fc644080 fffff800`5e72d800 ffffdb04`f3c95020 : nt!PopPolicyWorkerThread+0x8f
09 fffffd85`1496fa70 fffff800`5e72f725 : ffffdb04`fc644080 00000000`00000080 ffffdb04`f3c8c380 000024ef`bd9bbfff : nt!ExpWorkerThread+0x105
0a fffffd85`1496fb10 fffff800`5e7c3dfa : ffff8b00`0fedd180 ffffdb04`fc644080 fffff800`5e72f6d0 00000000`00000000 : nt!PspSystemThreadStartup+0x55
0b fffffd85`1496fb60 00000000`00000000 : fffffd85`14970000 fffffd85`14969000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
start end module name
fffff800`5e600000 fffff800`5f0b2000 nt ntkrnlmp.exe FECF74B7 (This is a reproducible build file hash, not a timestamp)
fffff800`5f0b2000 fffff800`5f155000 hal hal.dll 63975E9E (This is a reproducible build file hash, not a timestamp)
fffff800`62c00000 fffff800`62c0b000 kdcom kdcom.dll Sat Feb 3 10:28:36 2018 (5A75D524)
fffff800`62c10000 fffff800`62e11000 mcupdate mcupdate.dll Mon Dec 18 04:17:14 1989 (258CAB1A)
fffff800`62e20000 fffff800`62e31000 werkernel werkernel.sys 958E14B2 (This is a reproducible build file hash, not a timestamp)
fffff800`62e40000 fffff800`62e6a000 ksecdd ksecdd.sys A35F28F6 (This is a reproducible build file hash, not a timestamp)
fffff800`62e70000 fffff800`62ed0000 msrpc msrpc.sys 8E1A4F15 (This is a reproducible build file hash, not a timestamp)
fffff800`62ee0000 fffff800`62f07000 tm tm.sys 2ADB549A (This is a reproducible build file hash, not a timestamp)
fffff800`62f10000 fffff800`62f78000 CLFS CLFS.SYS 477FEB27 (This is a reproducible build file hash, not a timestamp)
fffff800`62f80000 fffff800`62f9a000 PSHED PSHED.dll B21F9DDA (This is a reproducible build file hash, not a timestamp)
fffff800`62fa0000 fffff800`62fab000 BOOTVID BOOTVID.dll 0F301604 (This is a reproducible build file hash, not a timestamp)
fffff800`62fb0000 fffff800`630b5000 clipsp clipsp.sys Mon Mar 18 18:11:27 2019 (5C90178F)
fffff800`630c0000 fffff800`63131000 FLTMGR FLTMGR.SYS 2FCE7C68 (This is a reproducible build file hash, not a timestamp)
fffff800`63140000 fffff800`6314e000 cmimcext cmimcext.sys C7F022B4 (This is a reproducible build file hash, not a timestamp)
fffff800`63150000 fffff800`6315c000 ntosext ntosext.sys BAC877D8 (This is a reproducible build file hash, not a timestamp)
fffff800`63160000 fffff800`6323c000 CI CI.dll BFF35B48 (This is a reproducible build file hash, not a timestamp)
fffff800`63240000 fffff800`632fc000 cng cng.sys 65453531 (This is a reproducible build file hash, not a timestamp)
fffff800`63300000 fffff800`633d5000 Wdf01000 Wdf01000.sys 116A658A (This is a reproducible build file hash, not a timestamp)
fffff800`633e0000 fffff800`633f3000 WDFLDR WDFLDR.SYS 3B396780 (This is a reproducible build file hash, not a timestamp)
fffff800`63400000 fffff800`6340f000 SleepStudyHelper SleepStudyHelper.sys BA6E2346 (This is a reproducible build file hash, not a timestamp)
fffff800`63410000 fffff800`63420000 WppRecorder WppRecorder.sys 34A54231 (This is a reproducible build file hash, not a timestamp)
fffff800`63430000 fffff800`63455000 acpiex acpiex.sys 2B91EDB2 (This is a reproducible build file hash, not a timestamp)
fffff800`63460000 fffff800`634a9000 mssecflt mssecflt.sys FA518C4A (This is a reproducible build file hash, not a timestamp)
fffff800`634b0000 fffff800`634ca000 SgrmAgent SgrmAgent.sys F851A195 (This is a reproducible build file hash, not a timestamp)
fffff800`634d0000 fffff800`6359c000 ACPI ACPI.sys 637B6DAD (This is a reproducible build file hash, not a timestamp)
fffff800`635a0000 fffff800`635ac000 WMILIB WMILIB.SYS 59021E3D (This is a reproducible build file hash, not a timestamp)
fffff800`635e0000 fffff800`63629000 intelpep intelpep.sys 8A1B7970 (This is a reproducible build file hash, not a timestamp)
fffff800`63630000 fffff800`63647000 WindowsTrustedRT WindowsTrustedRT.sys CB95CE3D (This is a reproducible build file hash, not a timestamp)
fffff800`63650000 fffff800`6365b000 WindowsTrustedRTProxy WindowsTrustedRTProxy.sys 514E3023 (This is a reproducible build file hash, not a timestamp)
fffff800`63660000 fffff800`63675000 pcw pcw.sys 6B731527 (This is a reproducible build file hash, not a timestamp)
fffff800`63680000 fffff800`63690000 FNETHYRAMAS FNETHYRAMAS.SYS Fri Jul 15 04:22:15 2016 (57889D37)
fffff800`636a0000 fffff800`636ab000 msisadrv msisadrv.sys 5E470A0E (This is a reproducible build file hash, not a timestamp)
fffff800`636b0000 fffff800`6371f000 pci pci.sys AF24B239 (This is a reproducible build file hash, not a timestamp)
fffff800`63720000 fffff800`63733000 vdrvroot vdrvroot.sys 0101BCC6 (This is a reproducible build file hash, not a timestamp)
fffff800`63740000 fffff800`63773000 pdc pdc.sys 9AEEDDCB (This is a reproducible build file hash, not a timestamp)
fffff800`63780000 fffff800`63799000 CEA CEA.sys F3811107 (This is a reproducible build file hash, not a timestamp)
fffff800`637a0000 fffff800`637d0000 partmgr partmgr.sys 89C96AD1 (This is a reproducible build file hash, not a timestamp)
fffff800`637e0000 fffff800`63885000 spaceport spaceport.sys DC82B965 (This is a reproducible build file hash, not a timestamp)
fffff800`63890000 fffff800`638aa000 volmgr volmgr.sys 211CEF76 (This is a reproducible build file hash, not a timestamp)
fffff800`638b0000 fffff800`63913000 volmgrx volmgrx.sys D6F366B7 (This is a reproducible build file hash, not a timestamp)
fffff800`63920000 fffff800`6393f000 mountmgr mountmgr.sys 242DB05F (This is a reproducible build file hash, not a timestamp)
fffff800`63940000 fffff800`639e2000 storport storport.sys A692CE5B (This is a reproducible build file hash, not a timestamp)
fffff800`639f0000 fffff800`63a0b000 EhStorClass EhStorClass.sys 526CC202 (This is a reproducible build file hash, not a timestamp)
fffff800`63a10000 fffff800`63a2a000 fileinfo fileinfo.sys 24BBED20 (This is a reproducible build file hash, not a timestamp)
fffff800`63a30000 fffff800`63a6d000 Wof Wof.sys 3CB75347 (This is a reproducible build file hash, not a timestamp)
fffff800`63a70000 fffff800`63ac6000 WdFilter WdFilter.sys ***** Invalid (ED6139D7)
fffff800`63ad0000 fffff800`63add000 Fs_Rec Fs_Rec.sys 49E932BA (This is a reproducible build file hash, not a timestamp)
fffff800`63ae0000 fffff800`63b74000 NETIO NETIO.SYS E5D63B1E (This is a reproducible build file hash, not a timestamp)
fffff800`63b80000 fffff800`63bb2000 ksecpkg ksecpkg.sys E1E129D5 (This is a reproducible build file hash, not a timestamp)
fffff800`63bc0000 fffff800`63bf0000 wfplwfs wfplwfs.sys ADA837F9 (This is a reproducible build file hash, not a timestamp)
fffff800`63c00000 fffff800`647a4000 iaStorAC iaStorAC.sys Fri Jul 6 08:50:14 2018 (5B3F6586)
fffff800`647b0000 fffff800`64a4e000 Ntfs Ntfs.sys D9A3CE82 (This is a reproducible build file hash, not a timestamp)
fffff800`64a50000 fffff800`64bc2000 ndis ndis.sys A6D0FB1E (This is a reproducible build file hash, not a timestamp)
fffff800`64bd0000 fffff800`64eba000 tcpip tcpip.sys A5F4F7D8 (This is a reproducible build file hash, not a timestamp)
fffff800`64ec0000 fffff800`64f3a000 fwpkclnt fwpkclnt.sys 58C1E6ED (This is a reproducible build file hash, not a timestamp)
fffff800`64f40000 fffff800`65009000 fvevol fvevol.sys 66798154 (This is a reproducible build file hash, not a timestamp)
fffff800`65010000 fffff800`65023000 amdkmpfd amdkmpfd.sys Mon May 25 16:25:23 2015 (55638533)
fffff800`65030000 fffff800`6503b000 volume volume.sys A4E9FDFA (This is a reproducible build file hash, not a timestamp)
fffff800`65040000 fffff800`650ad000 volsnap volsnap.sys 1876F533 (This is a reproducible build file hash, not a timestamp)
fffff800`650b0000 fffff800`650fe000 rdyboost rdyboost.sys F450CEB3 (This is a reproducible build file hash, not a timestamp)
fffff800`65100000 fffff800`65125000 mup mup.sys 565E0311 (This is a reproducible build file hash, not a timestamp)
fffff800`65130000 fffff800`65142000 iorate iorate.sys 18D52DDA (This is a reproducible build file hash, not a timestamp)
fffff800`65160000 fffff800`6517c000 disk disk.sys 384FEFED (This is a reproducible build file hash, not a timestamp)
fffff800`65180000 fffff800`651eb000 CLASSPNP CLASSPNP.SYS 09ED6E49 (This is a reproducible build file hash, not a timestamp)
fffff800`6be00000 fffff800`6be6b000 fastfat fastfat.SYS 5D09ADAA (This is a reproducible build file hash, not a timestamp)
fffff800`6be70000 fffff800`6bebf000 ahcache ahcache.sys A8473BE2 (This is a reproducible build file hash, not a timestamp)
fffff800`6bec0000 fffff800`6bf4c000 Vid Vid.sys B7391632 (This is a reproducible build file hash, not a timestamp)
fffff800`6bf50000 fffff800`6bf65000 umbus umbus.sys 3104A4AD (This is a reproducible build file hash, not a timestamp)
fffff800`6c0d0000 fffff800`6c0ed000 crashdmp crashdmp.sys 2985CB13 (This is a reproducible build file hash, not a timestamp)
fffff800`6c110000 fffff800`6c1a4000 csc csc.sys B2D84C51 (This is a reproducible build file hash, not a timestamp)
fffff800`6c600000 fffff800`6c6a7000 afd afd.sys B88DD13E (This is a reproducible build file hash, not a timestamp)
fffff800`6c6b0000 fffff800`6c6ba000 gpuenergydrv gpuenergydrv.sys 0CC24294 (This is a reproducible build file hash, not a timestamp)
fffff800`6c6c0000 fffff800`6ca33000 dxgkrnl dxgkrnl.sys 8CDD2D26 (This is a reproducible build file hash, not a timestamp)
fffff800`6ca40000 fffff800`6ca56000 watchdog watchdog.sys 21474799 (This is a reproducible build file hash, not a timestamp)
fffff800`6ca60000 fffff800`6ca76000 BasicDisplay BasicDisplay.sys 4E6E05E1 (This is a reproducible build file hash, not a timestamp)
fffff800`6ca80000 fffff800`6ca91000 BasicRender BasicRender.sys 82A93228 (This is a reproducible build file hash, not a timestamp)
fffff800`6caa0000 fffff800`6cabc000 Npfs Npfs.SYS B03ECFD3 (This is a reproducible build file hash, not a timestamp)
fffff800`6cac0000 fffff800`6cad1000 Msfs Msfs.SYS 91FE0FF4 (This is a reproducible build file hash, not a timestamp)
fffff800`6cae0000 fffff800`6cb06000 tdx tdx.sys 0A1F3DC4 (This is a reproducible build file hash, not a timestamp)
fffff800`6cb10000 fffff800`6cb20000 TDI TDI.SYS 894065A0 (This is a reproducible build file hash, not a timestamp)
fffff800`6cb30000 fffff800`6cb46000 netfilter2 netfilter2.sys Sat Sep 17 20:52:38 2016 (57DDE556)
fffff800`6cb50000 fffff800`6cba9000 netbt netbt.sys 113D2A22 (This is a reproducible build file hash, not a timestamp)
fffff800`6cbb0000 fffff800`6cbc3000 afunix afunix.sys 9D6C12C4 (This is a reproducible build file hash, not a timestamp)
fffff800`6cbd0000 fffff800`6cbea000 vwififlt vwififlt.sys 39396289 (This is a reproducible build file hash, not a timestamp)
fffff800`6cbf0000 fffff800`6cbfd000 npsvctrig npsvctrig.sys 0E7AC006 (This is a reproducible build file hash, not a timestamp)
fffff800`6d9f0000 fffff800`6da20000 cdrom cdrom.sys 9F6B0B7B (This is a reproducible build file hash, not a timestamp)
fffff800`6da30000 fffff800`6da45000 filecrypt filecrypt.sys 4EAD73C1 (This is a reproducible build file hash, not a timestamp)
fffff800`6da50000 fffff800`6da5e000 tbs tbs.sys 965BAC31 (This is a reproducible build file hash, not a timestamp)
fffff800`6da60000 fffff800`6da6a000 Null Null.SYS E822087B (This is a reproducible build file hash, not a timestamp)
fffff800`6da70000 fffff800`6da7a000 Beep Beep.SYS 528EC21A (This is a reproducible build file hash, not a timestamp)
fffff800`6da80000 fffff800`6da89000 FNETURPX FNETURPX.SYS Wed May 30 23:00:47 2012 (4FC6DEDF)
fffff800`6da90000 fffff800`6dabb000 pacer pacer.sys E7276BDE (This is a reproducible build file hash, not a timestamp)
fffff800`6dac0000 fffff800`6dad4000 netbios netbios.sys B37FD2E9 (This is a reproducible build file hash, not a timestamp)
fffff800`6dae0000 fffff800`6db5b000 rdbss rdbss.sys BCE0ED0A (This is a reproducible build file hash, not a timestamp)
fffff800`6db60000 fffff800`6db72000 nsiproxy nsiproxy.sys 528DA18A (This is a reproducible build file hash, not a timestamp)
fffff800`6db80000 fffff800`6db90000 mssmbios mssmbios.sys E6DC521D (This is a reproducible build file hash, not a timestamp)
fffff800`6dba0000 fffff800`6dbcc000 dfsc dfsc.sys FABE3F7D (This is a reproducible build file hash, not a timestamp)
fffff800`6dbd0000 fffff800`6e774000 dump_iaStorAC dump_iaStorAC.sys Fri Jul 6 08:50:14 2018 (5B3F6586)
fffff800`6e780000 fffff800`6e791000 CompositeBus CompositeBus.sys F050D616 (This is a reproducible build file hash, not a timestamp)
fffff800`6e7a0000 fffff800`6e7b6000 bam bam.sys 22198778 (This is a reproducible build file hash, not a timestamp)
fffff800`6e7c0000 fffff800`6e7c6000 AsIO AsIO.sys Wed Aug 22 05:54:47 2012 (5034AC67)
fffff800`6e7d0000 fffff800`6e7ef000 winhvr winhvr.sys 5EB9FF62 (This is a reproducible build file hash, not a timestamp)
fffff800`6e7f0000 fffff800`6e7fd000 kdnic kdnic.sys 1FF5F7F5 (This is a reproducible build file hash, not a timestamp)
fffff800`6fe00000 fffff800`6fe88000 USBXHCI USBXHCI.SYS C566CB6A (This is a reproducible build file hash, not a timestamp)
fffff800`6fe90000 fffff800`6fed1000 ucx01000 ucx01000.sys 04268533 (This is a reproducible build file hash, not a timestamp)
fffff800`6fee0000 fffff800`6ff4f000 UcmCxUcsiNvppc UcmCxUcsiNvppc.sys Sun Dec 9 15:39:33 2018 (5C0D7D85)
fffff800`6ff50000 fffff800`6ff7c000 UcmCx UcmCx.sys E8A9CD85 (This is a reproducible build file hash, not a timestamp)
fffff800`6ff80000 fffff800`6ffbb000 TeeDriverW8x64 TeeDriverW8x64.sys Wed Apr 11 10:46:32 2018 (5ACE1FC8)
fffff800`6ffc0000 fffff800`70033000 asmtxhci asmtxhci.sys Wed Aug 16 04:36:59 2017 (5994042B)
fffff800`70040000 fffff800`7005c000 serial serial.sys B6549B39 (This is a reproducible build file hash, not a timestamp)
fffff800`70060000 fffff800`7006f000 serenum serenum.sys 0B8B1DB3 (This is a reproducible build file hash, not a timestamp)
fffff800`70070000 fffff800`700fe000 e1i65x64 e1i65x64.sys Mon Jun 11 14:01:06 2018 (5B1EB8E2)
fffff800`70100000 fffff800`7010c000 wmiacpi wmiacpi.sys AF7EFCE5 (This is a reproducible build file hash, not a timestamp)
fffff800`70110000 fffff800`7014e000 intelppm intelppm.sys DF02127E (This is a reproducible build file hash, not a timestamp)
fffff800`70150000 fffff800`7015b000 acpipagr acpipagr.sys 80AB510E (This is a reproducible build file hash, not a timestamp)
fffff800`70160000 fffff800`7016e000 UEFI UEFI.sys 60BAE916 (This is a reproducible build file hash, not a timestamp)
fffff800`70170000 fffff800`70181000 nvvad64v nvvad64v.sys Thu Mar 14 04:58:48 2019 (5C8A17C8)
fffff800`70190000 fffff800`7019f000 ksthunk ksthunk.sys 15502221 (This is a reproducible build file hash, not a timestamp)
fffff800`701a0000 fffff800`701b0000 nvvhci nvvhci.sys Thu Aug 16 16:01:22 2018 (5B75D812)
fffff800`701c0000 fffff800`701cd000 NdisVirtualBus NdisVirtualBus.sys D217410A (This is a reproducible build file hash, not a timestamp)
fffff800`701d0000 fffff800`701dc000 swenum swenum.sys C4D73525 (This is a reproducible build file hash, not a timestamp)
fffff800`701e0000 fffff800`701ee000 rdpbus rdpbus.sys 4E9899F8 (This is a reproducible build file hash, not a timestamp)
fffff800`701f0000 fffff800`701ff000 clwvd8 clwvd8.sys Mon Jun 11 04:26:37 2018 (5B1E323D)
fffff800`70200000 fffff800`70237000 nvhda64v nvhda64v.sys Tue Mar 19 00:47:57 2019 (5C90747D)
fffff800`70240000 fffff800`702dc000 UsbHub3 UsbHub3.sys D4267D67 (This is a reproducible build file hash, not a timestamp)
fffff800`702e0000 fffff800`702ee000 USBD USBD.SYS CD63CE9D (This is a reproducible build file hash, not a timestamp)
fffff800`702f0000 fffff800`70909000 RTKVHD64 RTKVHD64.sys Mon Feb 26 05:12:31 2018 (5A93DD8F)
fffff800`70910000 fffff800`70943000 usbccgp usbccgp.sys 5D2AF1D1 (This is a reproducible build file hash, not a timestamp)
fffff800`70950000 fffff800`70977000 asmthub3 asmthub3.sys Wed Aug 16 04:37:28 2017 (59940448)
fffff800`70980000 fffff800`70992000 hidusb hidusb.sys 7B9189FE (This is a reproducible build file hash, not a timestamp)
fffff800`709a0000 fffff800`709db000 HIDCLASS HIDCLASS.SYS D4D0DEE6 (This is a reproducible build file hash, not a timestamp)
fffff800`709e0000 fffff800`709f3000 HIDPARSE HIDPARSE.SYS 4105D214 (This is a reproducible build file hash, not a timestamp)
fffff800`70a00000 fffff800`70a11000 kbdhid kbdhid.sys 4CF68CA7 (This is a reproducible build file hash, not a timestamp)
fffff800`70a20000 fffff800`70a34000 kbdclass kbdclass.sys 0B474226 (This is a reproducible build file hash, not a timestamp)
fffff800`70a50000 fffff800`70a5e000 dump_storport dump_storport.sys Fri Apr 26 23:44:32 2019 (5CC3D020)
fffff800`70a80000 fffff800`70a9d000 dump_dumpfve dump_dumpfve.sys C1539D11 (This is a reproducible build file hash, not a timestamp)
fffff800`70aa0000 fffff800`70ab0000 mouhid mouhid.sys A140C187 (This is a reproducible build file hash, not a timestamp)
fffff800`70ac0000 fffff800`70ad3000 mouclass mouclass.sys 4A22FFB8 (This is a reproducible build file hash, not a timestamp)
fffff800`70d10000 fffff800`72246000 nvlddmkm nvlddmkm.sys Wed May 22 17:18:43 2019 (5CE5BCB3)
fffff800`72250000 fffff800`72272000 HDAudBus HDAudBus.sys AECD2958 (This is a reproducible build file hash, not a timestamp)
fffff800`72280000 fffff800`722e7000 portcls portcls.sys D4F15BF0 (This is a reproducible build file hash, not a timestamp)
fffff800`722f0000 fffff800`72311000 drmk drmk.sys ***** Invalid (A3E06FB0)
fffff800`72320000 fffff800`72398000 ks ks.sys D02EDE05 (This is a reproducible build file hash, not a timestamp)
fffff800`723a0000 fffff800`723a1f80   AiCharger AiCharger.sys Thu Mar 22 04:07:51 2012 (4F6ADDD7)
Unloaded modules:
fffff800`70ae0000 fffff800`70b01000 WinUSB.SYS
Checksum: 00000000
ImageSize: 00021000
fffff800`70b10000 fffff800`70b61000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00051000
fffff800`6c100000 fffff800`6c10f000 dump_storpor
Checksum: 00000000
ImageSize: 0000F000
fffff800`6ce00000 fffff800`6d9a5000 dump_iaStorA
Checksum: 00000000
ImageSize: 00BA5000
fffff800`6d9d0000 fffff800`6d9ee000 dump_dumpfve
Checksum: 00000000
ImageSize: 0001E000
fffff800`6e780000 fffff800`6e79e000 dam.sys
Checksum: 00000000
ImageSize: 0001E000
fffff800`635c0000 fffff800`635d1000 WdBoot.sys
Checksum: 00000000
ImageSize: 00011000
fffff800`635b0000 fffff800`635b9000 MbamElam.sys
Checksum: 00000000
ImageSize: 00009000
fffff800`65150000 fffff800`65160000 hwpolicy.sys
Checksum: 00000000
ImageSize: 00010000
Unloaded modules:
Checksum: 00000000
ImageSize: 00021000
Checksum: 00000000
ImageSize: 00051000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00BA5000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00009000
Checksum: 00000000
ImageSize: 00010000
Bugcheck code C000021A
Arguments ffffb28a`a0cfa3a0 ffffffff`c0000428 00000000`00000000 00000227`41970000
2: kd> !blackboxbsd
Version: 168
Product type: 1
Auto advanced boot: FALSE
Advanced boot menu timeout: 30
Last boot succeeded: FALSE
Last boot shutdown: TRUE
Sleep in progrees: FALSE
Power button timestamp: 0
System running: FALSE
Connected standby in progress: FALSE
User shutdown in progress: FALSE
System shutdown in progress: TRUE
Sleep in progress: 0
Connected standby scenario instance id: 0
Connected standby entry reason: 0
Connected standby exit reason: 0
System sleep transitions to on: 0
Last reference time: 0x1d5166b6a7f2749
Last reference time checksum: 0xfd87f49
Last update boot id: 135
Boot attempt count: 2
Last boot checkpoint: FALSE
Checksum: 0xd9
Last boot id: 135
Last successful shutdown boot id: 135
Last reported abnormal shutdown boot id: 132
Error info boot id: 0
Error info repeat count: 0
Error info other error count: 0
Error info code: 0
Power button last press time: 0
Power button cumulative press count: 0
Power button last press boot id: 0
Power button last power watchdog stage: 0
Power button watchdog armed: FALSE
Power button shutdown in progress: FALSE
Power button last release time: 0
Power button cumulative release count: 0
Power button last release boot id: 0
Power button error count: 0
Power button current connected standby phase: 0
Power button transition latest checkpoint id: 0
Power button transition latest checkpoint type: 0
Power button transition latest checkpoint sequence number: 0
BSOD Log #2
Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\Temp3_SysnativeFileCollectionApp.zip\SysnativeFileCollectionApp\052919-9953-01.dmp]
Machine Name:
Kernel base = 0xfffff802`58200000 PsLoadedModuleList = 0xfffff802`586432d0
Debug session time: Wed May 29 17:10:07.459 2019 (UTC - 4:00)
System Uptime: 0 days 0:00:18.151
BugCheck C0000142, {ffff8a8377dfd3d0, ffff8a837552c210, 0, 0}
6: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING:  10.0.18362.116 (WinBuild.160101.0800)
EXCEPTION_CODE_STR:  c0000142
EXCEPTION_PARAMETER1:  ffff8a8377dfd3d0
EXCEPTION_PARAMETER2:  ffff8a837552c210
EXCEPTION_PARAMETER4: 0
DUMP_TYPE:  2
BUGCHECK_P1: ffff8a8377dfd3d0
BUGCHECK_P2: ffff8a837552c210
BUGCHECK_P3: 0
BUGCHECK_P4: 0
CPU_COUNT: 8
CPU_MHZ: e10
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: 9
CURRENT_IRQL:  0
ANALYSIS_SESSION_TIME:  07-06-2019 17:08:11.0143
LAST_CONTROL_TRANSFER:  from fffff802587a9c7a to fffff802583bc8a0
STACK_TEXT:
fffff885`ebca74a8 fffff802`587a9c7a : 00000000`0000004c 00000000`c0000142 fffff885`ec5472f8 ffffd904`692bbbd0 : nt!KeBugCheckEx
fffff885`ebca74b0 fffff802`587a0eca : 00000000`00000000 fffff885`ebca7570 00000000`00000000 fffff885`ebca7570 : nt!PopGracefulShutdown+0x29a
fffff885`ebca74f0 fffff802`5879a01c : ffff8a83`7a6ffe01 fffff802`00000006 00000000`00000004 ffff8a83`77dfd030 : nt!PopTransitionSystemPowerStateEx+0xd05e
fffff885`ebca75b0 fffff802`583cdf95 : 00000000`00000000 fffff802`5824055b 00000000`00000010 00000000`00040086 : nt!NtSetSystemPowerState+0x4c
fffff885`ebca7790 fffff802`583c0660 : fffff802`58993935 00000000`c0000004 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
fffff885`ebca7928 fffff802`58993935 : 00000000`c0000004 00000000`00000000 00000000`00000000 fffff802`586406a0 : nt!KiServiceLinkage
fffff885`ebca7930 fffff802`58919939 : ffffd904`5f1d6140 fffff802`582c4d0c fffff802`5adb3c70 ffffd904`00000000 : nt!PopIssueActionRequest+0x79ed9
fffff885`ebca79d0 fffff802`5832d88f : 00000000`00000001 00000000`00000002 00000000`00000000 fffff802`58640500 : nt!PopPolicyWorkerAction+0x79
fffff885`ebca7a40 fffff802`582c4855 : ffffd904`00000001 ffffd904`5f1d6140 fffff802`5832d800 ffffd904`5f0749a0 : nt!PopPolicyWorkerThread+0x8f
fffff885`ebca7a70 fffff802`5832f725 : ffffd904`5f1d6140 00000000`00000080 ffffd904`5f079380 00000000`00000000 : nt!ExpWorkerThread+0x105
fffff885`ebca7b10 fffff802`583c3dfa : fffff802`52f46180 ffffd904`5f1d6140 fffff802`5832f6d0 00000000`00000000 : nt!PspSystemThreadStartup+0x55
fffff885`ebca7b60 00000000`00000000 : fffff885`ebca8000 fffff885`ebca1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
FOLLOWUP_IP:
fffff802`587a0eca cc              int     3
MODULE_NAME: nt
IMAGE_VERSION:  10.0.18362.116
TARGET_TIME:  2019-05-29T21:10:07.000Z
OSBUILD:  18362
OSSERVICEPACK:  116
OS_REVISION: 0
SUITE_MASK:  272
PRODUCT_TYPE:  1
OSNAME:  Windows 10
OS_LOCALE:
USER_LCID:  0
BUILDOSVER_STR:  10.0.18362.116
ANALYSIS_SESSION_ELAPSED_TIME:  6a3
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:status_dll_init_failed_nt!poptransitionsystempowerstateex
FAILURE_ID_HASH:  {3062d9f4-6d6b-6e95-3950-c5e344d01b2a}
rax=ffffd90467fd9190 rbx=0000000000000002 rcx=000000000000004c
rdx=00000000c0000142 rsi=fffff885ebca7628 rdi=fffff885ebca75d0
rip=fffff802583bc8a0 rsp=fffff885ebca74a8 rbp=fffff885ebca7570
r8=fffff885ec5472f8 r9=ffffd904692bbbd0 r10=fffff885ec547000
r11=fffff0f87c3e1000 r12=fffff885ebca76bc r13=fffff885ebca76b8
r14=fffff885ebca75ec r15=0000000000000002
nt!KeBugCheckEx:
fffff802`583bc8a0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff885`ebca74b0=000000000000004c
00 fffff885`ebca74a8 fffff802`587a9c7a : 00000000`0000004c 00000000`c0000142 fffff885`ec5472f8 ffffd904`692bbbd0 : nt!KeBugCheckEx
01 fffff885`ebca74b0 fffff802`587a0eca : 00000000`00000000 fffff885`ebca7570 00000000`00000000 fffff885`ebca7570 : nt!PopGracefulShutdown+0x29a
02 fffff885`ebca74f0 fffff802`5879a01c : ffff8a83`7a6ffe01 fffff802`00000006 00000000`00000004 ffff8a83`77dfd030 : nt!PopTransitionSystemPowerStateEx+0xd05e
03 fffff885`ebca75b0 fffff802`583cdf95 : 00000000`00000000 fffff802`5824055b 00000000`00000010 00000000`00040086 : nt!NtSetSystemPowerState+0x4c
04 fffff885`ebca7790 fffff802`583c0660 : fffff802`58993935 00000000`c0000004 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25 (TrapFrame @ fffff885`ebca7790)
05 fffff885`ebca7928 fffff802`58993935 : 00000000`c0000004 00000000`00000000 00000000`00000000 fffff802`586406a0 : nt!KiServiceLinkage
06 fffff885`ebca7930 fffff802`58919939 : ffffd904`5f1d6140 fffff802`582c4d0c fffff802`5adb3c70 ffffd904`00000000 : nt!PopIssueActionRequest+0x79ed9
07 fffff885`ebca79d0 fffff802`5832d88f : 00000000`00000001 00000000`00000002 00000000`00000000 fffff802`58640500 : nt!PopPolicyWorkerAction+0x79
08 fffff885`ebca7a40 fffff802`582c4855 : ffffd904`00000001 ffffd904`5f1d6140 fffff802`5832d800 ffffd904`5f0749a0 : nt!PopPolicyWorkerThread+0x8f
09 fffff885`ebca7a70 fffff802`5832f725 : ffffd904`5f1d6140 00000000`00000080 ffffd904`5f079380 00000000`00000000 : nt!ExpWorkerThread+0x105
0a fffff885`ebca7b10 fffff802`583c3dfa : fffff802`52f46180 ffffd904`5f1d6140 fffff802`5832f6d0 00000000`00000000 : nt!PspSystemThreadStartup+0x55
0b fffff885`ebca7b60 00000000`00000000 : fffff885`ebca8000 fffff885`ebca1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
ffff8664`6e600000 ffff8664`6e9a0000 win32kfull win32kfull.sys 7996D6E0 (This is a reproducible build file hash, not a timestamp)
ffff8664`6e9b0000 ffff8664`6ec58000 win32kbase win32kbase.sys B4BB87F9 (This is a reproducible build file hash, not a timestamp)
ffff8664`6f440000 ffff8664`6f4cc000 win32k win32k.sys 7B83186F (This is a reproducible build file hash, not a timestamp)
fffff802`5815d000 fffff802`58200000 hal hal.dll 18DFC8D0 (This is a reproducible build file hash, not a timestamp)
fffff802`58200000 fffff802`58cb2000 nt ntkrnlmp.exe DD52FF09 (This is a reproducible build file hash, not a timestamp)
fffff802`59200000 fffff802`5920b000 kdcom kdcom.dll Sat Feb 3 10:28:36 2018 (5A75D524)
fffff802`59210000 fffff802`59411000 mcupdate mcupdate.dll Mon Dec 18 04:17:14 1989 (258CAB1A)
fffff802`59420000 fffff802`59431000 werkernel werkernel.sys 958E14B2 (This is a reproducible build file hash, not a timestamp)
fffff802`59440000 fffff802`5946a000 ksecdd ksecdd.sys A35F28F6 (This is a reproducible build file hash, not a timestamp)
fffff802`59470000 fffff802`594d0000 msrpc msrpc.sys 8E1A4F15 (This is a reproducible build file hash, not a timestamp)
fffff802`594e0000 fffff802`59507000 tm tm.sys 2ADB549A (This is a reproducible build file hash, not a timestamp)
fffff802`59510000 fffff802`59578000 CLFS CLFS.SYS 477FEB27 (This is a reproducible build file hash, not a timestamp)
fffff802`59580000 fffff802`5959a000 PSHED PSHED.dll B21F9DDA (This is a reproducible build file hash, not a timestamp)
fffff802`595a0000 fffff802`595ab000 BOOTVID BOOTVID.dll 0F301604 (This is a reproducible build file hash, not a timestamp)
fffff802`595b0000 fffff802`595be000 cmimcext cmimcext.sys C7F022B4 (This is a reproducible build file hash, not a timestamp)
fffff802`595c0000 fffff802`595cc000 ntosext ntosext.sys BAC877D8 (This is a reproducible build file hash, not a timestamp)
fffff802`595d0000 fffff802`595e3000 WDFLDR WDFLDR.SYS 3B396780 (This is a reproducible build file hash, not a timestamp)
fffff802`595f0000 fffff802`595ff000 SleepStudyHelper SleepStudyHelper.sys BA6E2346 (This is a reproducible build file hash, not a timestamp)
fffff802`59600000 fffff802`59705000 clipsp clipsp.sys Mon Mar 18 18:11:27 2019 (5C90178F)
fffff802`59710000 fffff802`59781000 FLTMGR FLTMGR.SYS 2FCE7C68 (This is a reproducible build file hash, not a timestamp)
fffff802`59790000 fffff802`5986c000 CI CI.dll CA73D753 (This is a reproducible build file hash, not a timestamp)
fffff802`59870000 fffff802`5992c000 cng cng.sys 65453531 (This is a reproducible build file hash, not a timestamp)
fffff802`59930000 fffff802`59a05000 Wdf01000 Wdf01000.sys 116A658A (This is a reproducible build file hash, not a timestamp)
fffff802`59a10000 fffff802`59a20000 WppRecorder WppRecorder.sys 34A54231 (This is a reproducible build file hash, not a timestamp)
fffff802`59a30000 fffff802`59a55000 acpiex acpiex.sys 2B91EDB2 (This is a reproducible build file hash, not a timestamp)
fffff802`59a60000 fffff802`59aa9000 mssecflt mssecflt.sys FA518C4A (This is a reproducible build file hash, not a timestamp)
fffff802`59ab0000 fffff802`59aca000 SgrmAgent SgrmAgent.sys F851A195 (This is a reproducible build file hash, not a timestamp)
fffff802`59ad0000 fffff802`59b9c000 ACPI ACPI.sys 637B6DAD (This is a reproducible build file hash, not a timestamp)
fffff802`59ba0000 fffff802`59bac000 WMILIB WMILIB.SYS 59021E3D (This is a reproducible build file hash, not a timestamp)
fffff802`59be0000 fffff802`59c29000 intelpep intelpep.sys 8A1B7970 (This is a reproducible build file hash, not a timestamp)
fffff802`59c30000 fffff802`59c47000 WindowsTrustedRT WindowsTrustedRT.sys CB95CE3D (This is a reproducible build file hash, not a timestamp)
fffff802`59c50000 fffff802`59c5b000 WindowsTrustedRTProxy WindowsTrustedRTProxy.sys 514E3023 (This is a reproducible build file hash, not a timestamp)
fffff802`59c60000 fffff802`59c75000 pcw pcw.sys 6B731527 (This is a reproducible build file hash, not a timestamp)
fffff802`59c80000 fffff802`59c90000 FNETHYRAMAS FNETHYRAMAS.SYS Fri Jul 15 04:22:15 2016 (57889D37)
fffff802`59ca0000 fffff802`59cab000 msisadrv msisadrv.sys 5E470A0E (This is a reproducible build file hash, not a timestamp)
fffff802`59cb0000 fffff802`59d1f000 pci pci.sys AF24B239 (This is a reproducible build file hash, not a timestamp)
fffff802`59d20000 fffff802`59d33000 vdrvroot vdrvroot.sys 0101BCC6 (This is a reproducible build file hash, not a timestamp)
fffff802`59d40000 fffff802`59d73000 pdc pdc.sys 9AEEDDCB (This is a reproducible build file hash, not a timestamp)
fffff802`59d80000 fffff802`59d99000 CEA CEA.sys F3811107 (This is a reproducible build file hash, not a timestamp)
fffff802`59da0000 fffff802`59dd0000 partmgr partmgr.sys 0F8ED6CE (This is a reproducible build file hash, not a timestamp)
fffff802`59de0000 fffff802`59e85000 spaceport spaceport.sys DC82B965 (This is a reproducible build file hash, not a timestamp)
fffff802`59e90000 fffff802`59eaa000 volmgr volmgr.sys 211CEF76 (This is a reproducible build file hash, not a timestamp)
fffff802`59eb0000 fffff802`59f13000 volmgrx volmgrx.sys D6F366B7 (This is a reproducible build file hash, not a timestamp)
fffff802`59f20000 fffff802`59f3f000 mountmgr mountmgr.sys 242DB05F (This is a reproducible build file hash, not a timestamp)
fffff802`59f40000 fffff802`59fe2000 storport storport.sys A692CE5B (This is a reproducible build file hash, not a timestamp)
fffff802`59ff0000 fffff802`5a00b000 EhStorClass EhStorClass.sys 526CC202 (This is a reproducible build file hash, not a timestamp)
fffff802`5a010000 fffff802`5a02a000 fileinfo fileinfo.sys 24BBED20 (This is a reproducible build file hash, not a timestamp)
fffff802`5a030000 fffff802`5a06d000 Wof Wof.sys 3CB75347 (This is a reproducible build file hash, not a timestamp)
fffff802`5a070000 fffff802`5a0c6000 WdFilter WdFilter.sys ***** Invalid (ED6139D7)
fffff802`5a0d0000 fffff802`5a0dd000 Fs_Rec Fs_Rec.sys 49E932BA (This is a reproducible build file hash, not a timestamp)
fffff802`5a0e0000 fffff802`5a174000 NETIO NETIO.SYS E5D63B1E (This is a reproducible build file hash, not a timestamp)
fffff802`5a180000 fffff802`5a1b2000 ksecpkg ksecpkg.sys E1E129D5 (This is a reproducible build file hash, not a timestamp)
fffff802`5a1c0000 fffff802`5a1f0000 wfplwfs wfplwfs.sys ADA837F9 (This is a reproducible build file hash, not a timestamp)
fffff802`5a200000 fffff802`5ada4000 iaStorAC iaStorAC.sys Fri Jul 6 08:50:14 2018 (5B3F6586)
fffff802`5adb0000 fffff802`5b04e000 Ntfs Ntfs.sys 32E481C0 (This is a reproducible build file hash, not a timestamp)
fffff802`5b050000 fffff802`5b1c2000 ndis ndis.sys A6D0FB1E (This is a reproducible build file hash, not a timestamp)
fffff802`5b1d0000 fffff802`5b4ba000 tcpip tcpip.sys A5F4F7D8 (This is a reproducible build file hash, not a timestamp)
fffff802`5b4c0000 fffff802`5b53a000 fwpkclnt fwpkclnt.sys 58C1E6ED (This is a reproducible build file hash, not a timestamp)
fffff802`5b540000 fffff802`5b609000 fvevol fvevol.sys 66798154 (This is a reproducible build file hash, not a timestamp)
fffff802`5b610000 fffff802`5b623000 amdkmpfd amdkmpfd.sys Mon May 25 16:25:23 2015 (55638533)
fffff802`5b630000 fffff802`5b63b000 volume volume.sys A4E9FDFA (This is a reproducible build file hash, not a timestamp)
fffff802`5b640000 fffff802`5b6ad000 volsnap volsnap.sys 1876F533 (This is a reproducible build file hash, not a timestamp)
fffff802`5b6b0000 fffff802`5b6fe000 rdyboost rdyboost.sys F450CEB3 (This is a reproducible build file hash, not a timestamp)
fffff802`5b700000 fffff802`5b725000 mup mup.sys 565E0311 (This is a reproducible build file hash, not a timestamp)
fffff802`5b730000 fffff802`5b742000 iorate iorate.sys 18D52DDA (This is a reproducible build file hash, not a timestamp)
fffff802`5b760000 fffff802`5b77c000 disk disk.sys 384FEFED (This is a reproducible build file hash, not a timestamp)
fffff802`5b780000 fffff802`5b7eb000 CLASSPNP CLASSPNP.SYS 09ED6E49 (This is a reproducible build file hash, not a timestamp)
fffff802`62400000 fffff802`62773000 dxgkrnl dxgkrnl.sys 75520BEF (This is a reproducible build file hash, not a timestamp)
fffff802`62780000 fffff802`62827000 afd afd.sys B88DD13E (This is a reproducible build file hash, not a timestamp)
fffff802`62830000 fffff802`6285b000 pacer pacer.sys E7276BDE (This is a reproducible build file hash, not a timestamp)
fffff802`62860000 fffff802`62874000 netbios netbios.sys B37FD2E9 (This is a reproducible build file hash, not a timestamp)
fffff802`62880000 fffff802`628fb000 rdbss rdbss.sys 83FA6372 (This is a reproducible build file hash, not a timestamp)
fffff802`62900000 fffff802`62994000 csc csc.sys B2D84C51 (This is a reproducible build file hash, not a timestamp)
fffff802`629a0000 fffff802`629b2000 nsiproxy nsiproxy.sys 528DA18A (This is a reproducible build file hash, not a timestamp)
fffff802`629c0000 fffff802`629d0000 mssmbios mssmbios.sys E6DC521D (This is a reproducible build file hash, not a timestamp)
fffff802`629e0000 fffff802`629ea000 gpuenergydrv gpuenergydrv.sys 0CC24294 (This is a reproducible build file hash, not a timestamp)
fffff802`629f0000 fffff802`62a1c000 dfsc dfsc.sys FABE3F7D (This is a reproducible build file hash, not a timestamp)
fffff802`62a40000 fffff802`62aab000 fastfat fastfat.SYS 5D09ADAA (This is a reproducible build file hash, not a timestamp)
fffff802`62ab0000 fffff802`62ac6000 bam bam.sys 22198778 (This is a reproducible build file hash, not a timestamp)
fffff802`62ad0000 fffff802`62ad6000 AsIO AsIO.sys Wed Aug 22 05:54:47 2012 (5034AC67)
fffff802`62ae0000 fffff802`62b2f000 ahcache ahcache.sys A8473BE2 (This is a reproducible build file hash, not a timestamp)
fffff802`62b30000 fffff802`62bbc000 Vid Vid.sys B7391632 (This is a reproducible build file hash, not a timestamp)
fffff802`62bc0000 fffff802`62bdf000 winhvr winhvr.sys 5EB9FF62 (This is a reproducible build file hash, not a timestamp)
fffff802`62be0000 fffff802`62bf1000 CompositeBus CompositeBus.sys F050D616 (This is a reproducible build file hash, not a timestamp)
fffff802`62c00000 fffff802`62c0d000 kdnic kdnic.sys 1FF5F7F5 (This is a reproducible build file hash, not a timestamp)
fffff802`62c10000 fffff802`62c25000 umbus umbus.sys 3104A4AD (This is a reproducible build file hash, not a timestamp)
fffff802`62cd0000 fffff802`62ced000 crashdmp crashdmp.sys 2985CB13 (This is a reproducible build file hash, not a timestamp)
fffff802`645f0000 fffff802`64620000 cdrom cdrom.sys 9F6B0B7B (This is a reproducible build file hash, not a timestamp)
fffff802`64630000 fffff802`64645000 filecrypt filecrypt.sys 4EAD73C1 (This is a reproducible build file hash, not a timestamp)
fffff802`64650000 fffff802`6465e000 tbs tbs.sys 965BAC31 (This is a reproducible build file hash, not a timestamp)
fffff802`64660000 fffff802`6466a000 Null Null.SYS E822087B (This is a reproducible build file hash, not a timestamp)
fffff802`64670000 fffff802`6467a000 Beep Beep.SYS 528EC21A (This is a reproducible build file hash, not a timestamp)
fffff802`64680000 fffff802`64689000 FNETURPX FNETURPX.SYS Wed May 30 23:00:47 2012 (4FC6DEDF)
fffff802`64690000 fffff802`646a6000 watchdog watchdog.sys 21474799 (This is a reproducible build file hash, not a timestamp)
fffff802`646b0000 fffff802`646c6000 BasicDisplay BasicDisplay.sys 4E6E05E1 (This is a reproducible build file hash, not a timestamp)
fffff802`646d0000 fffff802`65274000 dump_iaStorAC dump_iaStorAC.sys Fri Jul 6 08:50:14 2018 (5B3F6586)
fffff802`65280000 fffff802`65291000 BasicRender BasicRender.sys 82A93228 (This is a reproducible build file hash, not a timestamp)
fffff802`652a0000 fffff802`652bc000 Npfs Npfs.SYS B03ECFD3 (This is a reproducible build file hash, not a timestamp)
fffff802`652c0000 fffff802`652d1000 Msfs Msfs.SYS 91FE0FF4 (This is a reproducible build file hash, not a timestamp)
fffff802`652e0000 fffff802`65306000 tdx tdx.sys 0A1F3DC4 (This is a reproducible build file hash, not a timestamp)
fffff802`65310000 fffff802`65320000 TDI TDI.SYS 894065A0 (This is a reproducible build file hash, not a timestamp)
fffff802`65330000 fffff802`65346000 netfilter2 netfilter2.sys Sat Sep 17 20:52:38 2016 (57DDE556)
fffff802`65350000 fffff802`653a9000 netbt netbt.sys 41625C01 (This is a reproducible build file hash, not a timestamp)
fffff802`653b0000 fffff802`653c3000 afunix afunix.sys 9D6C12C4 (This is a reproducible build file hash, not a timestamp)
fffff802`653d0000 fffff802`653ea000 vwififlt vwififlt.sys 39396289 (This is a reproducible build file hash, not a timestamp)
fffff802`653f0000 fffff802`653fd000 npsvctrig npsvctrig.sys 0E7AC006 (This is a reproducible build file hash, not a timestamp)
fffff802`657b0000 fffff802`657c3000 HIDPARSE HIDPARSE.SYS 4105D214 (This is a reproducible build file hash, not a timestamp)
fffff802`657e0000 fffff802`657ee000 dump_storport dump_storport.sys Fri Apr 26 23:44:32 2019 (5CC3D020)
fffff802`65810000 fffff802`6582d000 dump_dumpfve dump_dumpfve.sys C1539D11 (This is a reproducible build file hash, not a timestamp)
fffff802`65830000 fffff802`65842000 hidusb hidusb.sys 7B9189FE (This is a reproducible build file hash, not a timestamp)
fffff802`65850000 fffff802`6588b000 HIDCLASS HIDCLASS.SYS D4D0DEE6 (This is a reproducible build file hash, not a timestamp)
fffff802`658a0000 fffff802`65eb9000 RTKVHD64 RTKVHD64.sys Mon Feb 26 05:12:31 2018 (5A93DD8F)
fffff802`65ec0000 fffff802`65ed0000 mouhid mouhid.sys A140C187 (This is a reproducible build file hash, not a timestamp)
fffff802`65ee0000 fffff802`65ef3000 mouclass mouclass.sys 4A22FFB8 (This is a reproducible build file hash, not a timestamp)
fffff802`65f50000 fffff802`65f77000 asmthub3 asmthub3.sys Wed Aug 16 04:37:28 2017 (59940448)
fffff802`66a00000 fffff802`66a67000 portcls portcls.sys D4F15BF0 (This is a reproducible build file hash, not a timestamp)
fffff802`66a70000 fffff802`66a91000 drmk drmk.sys ***** Invalid (A3E06FB0)
fffff802`66aa0000 fffff802`66b18000 ks ks.sys D02EDE05 (This is a reproducible build file hash, not a timestamp)
fffff802`66b20000 fffff802`66b21f80 AiCharger AiCharger.sys Thu Mar 22 04:07:51 2012 (4F6ADDD7)
fffff802`66b30000 fffff802`66bb8000 USBXHCI USBXHCI.SYS C566CB6A (This is a reproducible build file hash, not a timestamp)
fffff802`66bc0000 fffff802`66c01000 ucx01000 ucx01000.sys 04268533 (This is a reproducible build file hash, not a timestamp)
fffff802`66c10000 fffff802`66c7f000 UcmCxUcsiNvppc UcmCxUcsiNvppc.sys Sun Dec 9 15:39:33 2018 (5C0D7D85)
fffff802`66c80000 fffff802`66cac000 UcmCx UcmCx.sys E8A9CD85 (This is a reproducible build file hash, not a timestamp)
fffff802`66cb0000 fffff802`66ceb000 TeeDriverW8x64 TeeDriverW8x64.sys Wed Apr 11 10:46:32 2018 (5ACE1FC8)
fffff802`66cf0000 fffff802`66d63000 asmtxhci asmtxhci.sys Wed Aug 16 04:36:59 2017 (5994042B)
fffff802`66d70000 fffff802`66d8c000 serial serial.sys B6549B39 (This is a reproducible build file hash, not a timestamp)
fffff802`66d90000 fffff802`66d9f000 serenum serenum.sys 0B8B1DB3 (This is a reproducible build file hash, not a timestamp)
fffff802`66da0000 fffff802`66e2e000 e1i65x64 e1i65x64.sys Mon Jun 11 14:01:06 2018 (5B1EB8E2)
fffff802`66e30000 fffff802`66e3c000 wmiacpi wmiacpi.sys AF7EFCE5 (This is a reproducible build file hash, not a timestamp)
fffff802`66e40000 fffff802`66e7e000 intelppm intelppm.sys DF02127E (This is a reproducible build file hash, not a timestamp)
fffff802`66e80000 fffff802`66e8b000 acpipagr acpipagr.sys 80AB510E (This is a reproducible build file hash, not a timestamp)
fffff802`66e90000 fffff802`66e9e000 UEFI UEFI.sys 60BAE916 (This is a reproducible build file hash, not a timestamp)
fffff802`66ea0000 fffff802`66eb1000 nvvad64v nvvad64v.sys Thu Mar 14 04:58:48 2019 (5C8A17C8)
fffff802`66ec0000 fffff802`66ecf000 ksthunk ksthunk.sys 15502221 (This is a reproducible build file hash, not a timestamp)
fffff802`66ed0000 fffff802`66ee0000 nvvhci nvvhci.sys Thu Aug 16 16:01:22 2018 (5B75D812)
fffff802`66ef0000 fffff802`66efd000 NdisVirtualBus NdisVirtualBus.sys D217410A (This is a reproducible build file hash, not a timestamp)
fffff802`66f00000 fffff802`66f0c000 swenum swenum.sys C4D73525 (This is a reproducible build file hash, not a timestamp)
fffff802`66f10000 fffff802`66f1e000 rdpbus rdpbus.sys 4E9899F8 (This is a reproducible build file hash, not a timestamp)
fffff802`66f20000 fffff802`66f2f000 clwvd8 clwvd8.sys Mon Jun 11 04:26:37 2018 (5B1E323D)
fffff802`66f30000 fffff802`66f67000 nvhda64v nvhda64v.sys Tue Mar 19 00:47:57 2019 (5C90747D)
fffff802`66f70000 fffff802`6700c000 UsbHub3 UsbHub3.sys D4267D67 (This is a reproducible build file hash, not a timestamp)
fffff802`67010000 fffff802`6701e000 USBD USBD.SYS CD63CE9D (This is a reproducible build file hash, not a timestamp)
fffff802`67470000 fffff802`689a6000 nvlddmkm nvlddmkm.sys Wed May 22 17:18:43 2019 (5CE5BCB3)
fffff802`689b0000 fffff802`689d2000   HDAudBus HDAudBus.sys AECD2958 (This is a reproducible build file hash, not a timestamp)
Unloaded modules:
fffff802`62d00000 fffff802`62d0f000 dump_storpor
Checksum: 00000000
ImageSize: 0000F000
fffff802`63a00000 fffff802`645a5000 dump_iaStorA
Checksum: 00000000
ImageSize: 00BA5000
fffff802`645d0000 fffff802`645ee000 dump_dumpfve
Checksum: 00000000
ImageSize: 0001E000
fffff802`65ec0000 fffff802`65ee1000 WinUSB.SYS
Checksum: 00000000
ImageSize: 00021000
fffff802`65ef0000 fffff802`65f41000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00051000
fffff802`62a20000 fffff802`62a3e000 dam.sys
Checksum: 00000000
ImageSize: 0001E000
fffff802`59bc0000 fffff802`59bd1000 WdBoot.sys
Checksum: 00000000
ImageSize: 00011000
fffff802`59bb0000 fffff802`59bb9000 MbamElam.sys
Checksum: 00000000
ImageSize: 00009000
fffff802`5b750000 fffff802`5b760000 hwpolicy.sys
Checksum: 00000000
ImageSize: 00010000
Unloaded modules:
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00BA5000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00021000
Checksum: 00000000
ImageSize: 00051000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00009000
Checksum: 00000000
ImageSize: 00010000
Bugcheck code C0000142
Arguments ffff8a83`77dfd3d0 ffff8a83`7552c210 00000000`00000000 00000000`00000000
Hi, thank you very much. As far as I can remember I didn't reinstall Windows for the second time, I think that folder must be from some Windows version update. As for the disk verification tool, when the start does not recognize me any disk, ie the window comes out if I accept the terms and conditions of Seatools but then comes another screen that only gives me the option of exit. It should be noted that I have an ssd as a win disk. Thank you very much for your help. I am waiting for your instructions. Best regards.
Translated with www.DeepL.com/Translator
Is there still issues with the fingerprint reader?
Freezing?
Apparently the fingerprint reader problem is solved. I haven't had any more system freezes.
I need the system model number, please.
I don't know how to find that information. It is an assembled pc, that is to say I did not buy it as it is now but I was buying components until I assembled it. Thank you very much. Best regards.
l informe del sistema se escribió en: 07/07/19 14:22:54
Nombre del sistema: DESKTOP-QGCBUE3
[Resumen del sistema]
Elemento    Valor
Nombre del SO    Microsoft Windows 10 Pro
Versión    10.0.18362 compilación 18362
Descripción adicional del SO     No disponible
Fabricante del SO    Microsoft Corporation
Nombre del sistema    DESKTOP-QGCBUE3
Fabricante del sistema    System manufacturer
Modelo del sistema    System Product Name
Tipo de sistema    x64-based PC
SKU del sistema    SKU
Procesador    Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 procesadores principales, 8 procesadores lógicos
Versión y fecha de BIOS    American Megatrends Inc. 1207, 4/9/2018
Versión de SMBIOS    3.0
Versión de controladora integrada    255.255
Modo de BIOS    UEFI
Fabricante de la placa base    ASUSTeK COMPUTER INC.
Producto placa base    STRIX B250F GAMING
Versión de la placa base    Rev X.0x
Rol de plataforma    Escritorio
Estado de arranque seguro    Desactivado
Configuración de PCR7    Enlace no posible
Directorio de Windows    C:\WINDOWS
Directorio del sistema    C:\WINDOWS\system32
Dispositivo de arranque    \Device\HarddiskVolume5
Configuración regional    México
Capa de abstracción de hardware    Versión = "10.0.18362.145"
Nombre de usuario    DESKTOP-QGCBUE3\User
Zona horaria    Hora estándar de Argentina
Memoria física instalada (RAM)    20,0 GB
Memoria física total    19,9 GB
Memoria física disponible    12,0 GB
Memoria virtual total    21,2 GB
Memoria virtual disponible    10,6 GB
Espacio de archivo de paginación    1,25 GB
Archivo de paginación    C:\pagefile.sys
Protección de DMA de kernel    Desactivado
Seguridad basada en la virtualización    No habilitado
Compatibilidad con cifrado de dispositivo    Razones del error de cifrado automático de dispositivo: No se puede usar TPM, No se admite un enlace PCR7, Error en la interfaz de prueba de seguridad de hardware y el dispositivo no está en modo de espera moderno, Se detectaron dispositivos o un bus compatible con DMA no permitidos, No se puede usar TPM
Hyper-V - Extensiones de modo de monitor VM    Sí
Hyper-V - Extensiones de traducción de dirección de segundo nivel    Sí
Hyper-V - Virtualización habilitada en Firmware    Sí
Hyper-V -Protección de ejecución de datos    Sí
Hi. . .
Glad to hear that the fingerprint reader is working again and that the freezing has stopped.
You've done 2 tests now on your SSD and both have passed it, so it looks like my theory was just plain wrong this time. Thanks for taking the time to run the tests.
As far as the drivers are concerned, in the future, you'll have to go through Device Manager (type devmgmt.msc into the Search box or into a CMD prompt/screen) and try to find the driver that you want to update (like th fingerprint driver for example).
I believe that I found the Asus support page containing drivers for your system based on the little system information found in the many system reports generated by the jcgriff2/Sysnative app that you ran.
Your Asus Desktop Model Number -
From msinfo32
Asus STRIX B250F GAMING DESKTOP
Asus Support Driver Downloads - ROG STRIX B250F GAMING Driver & Tools | Motherboards | ASUS USA
Click on the spoiler button below (same info as the link contains) -
VGA
Version 23.20.16.4849 2017/12/28307.62 MBytes
Intel Graphics Accelerator Driver
Improve system stability & Support Windows 10 latest version (Build 16299)
Downloaded DOWNLOAD
Version 22.20.16.4691 2017/07/19297.82 MBytes
Improve system stability & Support Windows 10 latest version.
Downloaded DOWNLOAD
Version 21.20.16.4565 2017/02/20241.69 MBytes
-Kabylake - Intel Graphics Accelerator Driver V21.20.16.4565 for Windows Win10 64bit.
-Skylake - Intel Graphics Accelerator Driver V21.20.16.4565
for Windows Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 21.20.16.4551 2017/01/22365.96 MBytes
VGA_2120164551_20170120_Win10_64
Downloaded DOWNLOAD
Version 21.20.16.4528 2017/01/05366.32 MBytes
-VGA
-Kabylake - Intel Graphics Accelerator Driver V21.20.16.4528 for Windows Win10 64bit---(WHQL).
-Skylake - Intel Graphics Accelerator Driver V21.20.16.4528 for Windows Win7 64bit & Win8.1 64bit.
- Intel Graphics Accelerator Driver V21.20.16.4528 for Windows Win7 32bit.
Downloaded DOWNLOAD
See All DownloadsBIOS
Version 1207 2018/09/287.83 MBytes
STRIX B250F GAMING BIOS 1207
release BIOS 1207 to fix PCIEX16_2 can not use after G3 to S0 with customer pcie card
Downloaded DOWNLOAD
Version 1205 2018/05/257.83 MBytes
STRIX B250F GAMING BIOS 1205
Intel New ME Update, Improve Stability.
Downloaded DOWNLOAD
Version 1010 2018/04/167.87 MBytes
STRIX B250F GAMING BIOS 1010
1. Improve memory compatibility.
Downloaded DOWNLOAD
Version 1006 2018/03/277.87 MBytes
STRIX B250F GAMING BIOS 1006
1. Improve system stability
Downloaded DOWNLOAD
Version 1002 2018/01/047.87 MBytes
STRIX B250F GAMING BIOS 1002
"1. Update CPU Microcode
2. Improve system compatibility and stability"
Downloaded DOWNLOAD
Version - 2017/11/223.65 MBytes
MEUpdateTool
Intel has identified security issue that could potentially place impacted platform at risk.
Use ME Update tool to update your ME.
*We suggest you update ME Driver to the latest Version 11.7.0.1040 simultaneously.
Please download the file and check the MD5 code first.
MD5: 478dca5db24254d3a40824cc6b91ccf6
Downloaded DOWNLOAD
Version 0810 2017/09/297.86 MBytes
STRIX B250F GAMING BIOS 0810
Improve memory stability & compatibility
Downloaded DOWNLOAD
Version 0608 2017/06/097.76 MBytes
STRIX B250F GAMING BIOS 0608
Improved DRAM compatibility
Downloaded DOWNLOAD
Version 0606 2017/03/257.76 MBytes
STRIX B250F GAMING BIOS 0606
Complete support for Intel® Optane Memory
Downloaded DOWNLOAD
Version 0312 2017/01/207.76 MBytes
STRIX B250F GAMING BIOS 0312
Downloaded DOWNLOAD
Version 0310 2017/01/107.75 MBytes
STRIX B250F GAMING BIOS 0310
First release BIOS
Downloaded DOWNLOAD
See All DownloadsAUDIO
Version 6.0.1.8382 2018/04/12645.24 MBytes
Realtek_Audio_Driver
Downloaded DOWNLOAD
Version 6.0.1.8273 2017/12/28750.3 MBytes
Realtek Audio Driver
Downloaded DOWNLOAD
Version 6.0.1.8158 2017/07/19466.17 MBytes
Downloaded DOWNLOAD
Version 8090 2017/04/27459.48 MBytes
Audio Driver
Add RS2 support for Sonic Studio 3 and Sonic Radar 3.
Downloaded DOWNLOAD
Version 6.0.1.7997 2017/02/08520.97 MBytes
Realtek Audio driver 6.0.1.7997
Downloaded DOWNLOAD
Version 6.0.1.7962 2017/01/05493.25 MBytes
-Audio
- Realtek Audio Driver V6.0.1.7962 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit---(WHQL).
- Sonic Radar3 3.0.0.35752 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
                         - Sonic Studio3 3.0.0.35752 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
See All DownloadsLAN
Version 22.9.16.0 2017/12/28149.06 MBytes
Intel LAN driver
Downloaded DOWNLOAD
Version 22.4.16.0 2017/07/19317.32 MBytes
Intel LAN Driver
Downloaded DOWNLOAD
Version 21.1.30.0 2017/02/08147.24 MBytes
Intel LAN driver 21.1.30.0
Downloaded DOWNLOAD
Version 21.1.27.0 2017/01/05257.2 MBytes
-LAN
-Intel
- Intel LAN Driver V21.1.27.0 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit---(WHQL).
                         - Intel LAN Driver V21.1.27.0 for Windows Win10 64bit---(WHQL)
Downloaded DOWNLOAD
See All DownloadsUtilities
Version 10.10.0.0779 2019/04/0430.45 MBytes
DAEMON Tools
DAEMON Tools V10.10.0.0779 for Windows 10 64-bit.
Downloaded DOWNLOAD
Version 5.70.0 2019/04/0436.24 MBytes
WinRAR
WinRAR V5.70.0 for Windows 10 64-bit.
Downloaded DOWNLOAD
Version 10.9.0.0644 2018/11/2137.34 MBytes
DAEMON Tools Lite for ASUS
The most personal application for disc imaging yet.
Downloaded DOWNLOAD
Version 1.05.14 2018/02/01146.47 MBytes
Performance and Power Saving Utilities
Fix compatibility issue with the latest Windows updates. Performance and Power Saving Utilities update v1.05.14 patches an issue that resulted in the Windows power plan being forced to “balanced". Note that this patched build only includes the PPSU utility, it does not include other utilities in AI Suite 3.
- AI Suite 3 v3.00.13
- Performance and Power Saving Utilities v1.05.14
Downloaded DOWNLOAD
Version 10.7.0.0336 2018/01/1832 MBytes
DAEMON Tools
Install DAEMON Tools. Note:Internet connection is required for successful DAEMON Tools activation.
Downloaded DOWNLOAD
Version 3.00.13 2018/01/16146.47 MBytes
ASUS AI Suite 3
Fix compatibility issue between the latest Windows 10 update KB4056892.
- Performance and Power Saving Utilities v1.05.13
Downloaded DOWNLOAD
Version 1.7.2.0 2018/01/1015.68 MBytes
GameFirst_IV_1.7.2.0 for Windows Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.6.6.0 2017/09/0513.62 MBytes
ROGGameFirst_IV
ROGGameFirst_IV_V1.6.6.0
Downloaded DOWNLOAD
Version 1.6.4.0 2017/08/1715.38 MBytes
ROGGameFirst_IV_V1.6.4.0
Downloaded DOWNLOAD
Version 1.05.12 2017/07/2633.18 MBytes
AURA_1.05.12
Downloaded DOWNLOAD
Version 1.04.65 2017/07/26140.57 MBytes
AisuiteIII_2.00.10 &PPSU_1.04.65&EZUpdate_2.03.17&System Information_1.01.17
Downloaded DOWNLOAD
Version 1.6.3.0 2017/07/2015.38 MBytes
ROGGameFirst_IV_V1.6.3.0
Downloaded DOWNLOAD
Version 1.6.2.0 2017/07/0615.53 MBytes
ROGGameFirst_IV_1.6.2.0
Downloaded DOWNLOAD
Version 1.04.29 2017/04/0132.92 MBytes
-AURA for STRIX B250F GAMING
- AURA V1.04.29 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version - 2017/03/292.74 MBytes
-Overwolf
-Overwolf online version for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 10.4.0.0195 2017/02/1625.22 MBytes
-DAEMON
- DAEMON Tools V10.4.0.0195 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.04.26 2017/02/1032.87 MBytes
Lighting_Control_10426
Downloaded DOWNLOAD
Version 6.1.0.0486 2017/01/0528.22 MBytes
-DAEMON
- DAEMON Tools Pro V6.1.0.0486 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.5.31 2017/01/0514.8 MBytes
-GameFirst IV
- GameFirst IV 1.5.31 for Windows Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.00.35 2017/01/0513.45 MBytes
-ROG Connect Plus
-ASUS ROG Connect Plus 1.00.35 for Windows Win7 32bit & Win7 64bit& Win8.1 64bit & Win10 64bit.
-ROG Connect Plus
Downloaded DOWNLOAD
Version 1.00.07 2017/01/058.27 MBytes
-Clone Driver
- Clone Driver 1.00.07 for Windows Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.01.04 2017/01/056.61 MBytes
-RamCacheII            - ASUSRAMCACHEII V1.01.04 for Windows Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 2.2.9.564 2017/01/0530.19 MBytes
-ASUS_WebStorage
                         - ASUS WebStorage V2.2.9.564 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.77 2017/01/053.31 MBytes
-ROG-CPUZ
- ROG CPU-Z V1.77 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 0.85.199.0 2017/01/0561.38 MBytes
-Overwolf
-Overwolf 0.85.199.0 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.05.02 2017/01/054.29 MBytes
-Ai Charger
                         - ASUS Ai Charger V1.05.02 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
Version 1.01.57 2017/01/05157.33 MBytes
-AI_SuiteIII
-ASUS AI Suite 3 V1.01.57 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
-EZUpdate - EZ Update V2.03.01 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
-PPSU - Performance and Power Saving Utilities V1.03.84 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
    -System Information  - System Information V1.01.04 for Windows Win7 32bit & Win7 64bit & Win8.1 64bit & Win10 64bit.
Downloaded DOWNLOAD
See All DownloadsUSB
Version 1.16.49.1 2017/10/1287.51 MBytes
ASMedia USB3.1/USB3.0 Driver V1.16.49.1
Downloaded DOWNLOAD
Version 1.16.47.2 2017/07/1913.14 MBytes
Asmedia USB Driver
Downloaded DOWNLOAD
See All DownloadsChipset
Version 11.7.0.1057 2019/04/0366.21 MBytes
MEI_Intel
Support KBL series project.
Downloaded DOWNLOAD
Version 10.1.1.45 2017/12/285.52 MBytes
Intel Chipset Driver
Downloaded DOWNLOAD
Version 11.7.0.1045 2017/12/2874.26 MBytes
Management Engine Interface
Downloaded DOWNLOAD
Version 11.7.0.1040 2017/11/0186.56 MBytes
Downloaded DOWNLOAD
Version 11.7.0.1014 2017/07/1989.73 MBytes
Downloaded DOWNLOAD
Version 10.1.1.44 2017/07/194.96 MBytes
Downloaded DOWNLOAD
Version 11.6.0.1032 2017/03/0984.17 MBytes
-MEI
- Management Engine Interface V11.6.0.1032 for Windows Win7 32bit & Win7 64bit---(WHQL) .
- Management Engine Interface V11.6.0.1032 for Windows Win8.1 64bit(WHQL).
- Management Engine Interface V11.6.0.1032 for Windows Win10 64bit---(WHQL).
Downloaded DOWNLOAD
Version 11.6.0.1026 2017/02/08104.12 MBytes
ME driver 11.6.0.1026
Downloaded DOWNLOAD
Version 10.1.1.38 2017/02/084.49 MBytes
Chipset 10.1.1.38
Downloaded DOWNLOAD
See All DownloadsSATA
Version 15.9.0.1015 2017/12/2827.34 MBytes
Intel Rapid Storage Technology Driver software
Downloaded DOWNLOAD
Version 15.7.1.1015 2017/07/1925.02 MBytes
Downloaded DOWNLOAD
Version 15.5.0.1051 2017/04/2424.67 MBytes
Intel Rapid Storage Technology Driver software V15.5.0.1051 for Windows Win7 32bit & Win7 64bit---(WHQL).
Intel Rapid Storage Technology Driver software V15.5.0.1051 for Windows Win8.1 64bit ---(WHQL).
Intel Rapid Storage Technology Driver software V15.5.0.1051 for Windows Win10 64bit---(WHQL).
Downloaded DOWNLOAD
SHOW MORE DESCRIPTION
Version 15.5.0.1047 Beta Version2017/03/2424.59 MBytes
Intel RST driver 15.5.0.1047 beta
RST driver 15.5.0.1047(Beta) is updated for Intel® Optane™ memory support.  If you are not using Intel® Optane™ memory, we recommend that you do not proceed with this update.
Downloaded DOWNLOAD
Version 15.2.7.1042 2017/02/0814.57 MBytes
IRST_15.2.7.1042
Downloaded DOWNLOAD
Version 15.2.0.1020 2017/02/0223 MBytes
Intel(R) Rapid Storage Technology Driver
Intel(R) Rapid Storage Technology Driver for Windows 7 32-bit & 64-bit,
Windows 8.1 64-bit, Windows 10 64-bit
Downloaded DOWNLOAD
See All DownloadsQualified Vendor List
Version - 2018/01/12525.14 KBytes
STRIX B250F GAMING Memory QVL
Downloaded DOWNLOAD
Version - 2017/11/11315.95 KBytes
STRIX_B250F_GAMING_Devices_report
Be sure that if you ever do update a driver to create a Windows System Restore point first - Windows System Restore - Create a Restore Point (Windows 10, 8.1, 8, 7 & Vista)
That way, if something goes wrong with the driver installation, you can run Windows System Restore and use that newly created restore point to restore your system - Windows System Restore - Restore your System (Windows 10, 8.1, 8, 7 & Vista)
Is there anything else that you need help with now?
Regards. . .
jcgriff2
