System Freeze results in DPC_WATCHDOG_VIOLATION
blackviking
European Union
Hello Guys,
I'm new to this forum, but I need help finding the cause of my computer problem.
This happens without load, e.g. during web browsing. The system freezes completely (if there was sound running, it hangs with a weird tone) and after a minute or so, the STOP message is shown.
What I already did:
  • Updated NVIDIA drivers (with the reinstall option enabled and GForce Experience disabled)
  • Uninstalled ASUS GPU Tweak II
  • Checked for memory errors (four runs in MemTest86, no errors)
  • Checked the system disk (CHKDSK %systemdrive% /F /R /X)
  • Checked system files (sfc /scannow; in the first run I had some errors, but after rebooting and running again, they were gone)
I suspect this is a driver problem, but I couldn't isolate it :confused2:
The operating system is Windows 10 Pro 1803 (x64), updated from older Windows 10 versions.
Specs:
own-built Desktop PC, Intel i7-6700, 16GB RAM, ASUS H170 Pro Gaming, ASUS GTX 1060, Hauppauge TV Tuner (WinTV-quadHD), 400W BeQuiet Pure Power PSU.
The SysnativeBSODCollectionApp showed nothing but "Waiting for SystemInfo" for about 15 minutes after the SystemInfo window was already gone, so I think it hung up and I manually zipped the Collection folder. I hope you can help me - and maybe I can learn something about BSOD analysis :r1:
Hi blackviking,
What is the age of your hardware?
Thanks for replying!
It's about two years old, with the hard drives being older. The newest component is the TV tuner card, which I bought only short before the World Cup (this is my suspect #1 atm because I haven't had BSODs for a long time).
Could you try and reseat or seat the GPU in a different slot.
Referring to my mother board's manual:
"In single VGA card mode, use the PCIe 3.0 x16_1 slot (gray) for a PCI Express x16 graphics card to get better performance." I understand that the second x16 slot can only use four lanes, that doesn't sound too good to me?
Edit: But I'll reseat it in an hour, when I shut the computer down. In the meantime, I enabled Driver Verifier for all non-MS drivers as described in the forum.
quick update: I just reseated the graphics card and the TV tuner (did both as I had the case open).
I noticed that the TV tuner didn't fit perfectly (when inserting it, the slot cover's screw hole didn't exactly match the case's). So I bent the slot cover just a little bit and re-inserted the card.
Time will tell whether this was the cause - thanks for your assistance so far! I'll update this when (if) my Kernel panics again :D
Hey,
It's me again. I just had another system crash, still error 0x133. Apparently, reseating the PCIe cards did not resolve the issue.
I attached the new minidump file. Does someone have an idea? :confused2:
Please seat the GPU in the second x16 anyways.
4 runs as in 4 tests, or 4 passes? In either way, please make sure MemTest86 reached at least 8 passes.
Hey there,
I'm sorry I didn't update you more quickly, but I have some result now. To be precise, I meant 4 complete passes in MemTest86. This version stops after 4 passes (I think MemTest86+ runs indefinetly, but doesn't support UEFI boot :r1:).
Trying to put the card in the second PCIe bay, I realized that the slot is blocked by a hard drive cage, so I just removed the GPU (two days ago). Since then, I haven't had a bluescreen.
Now, the question is: Is it the hardware? Is it the driver? Or is it perhaps just coincidence?
Thanks again for your help, I really appreciate it!
You can test whether or not the drivers are the issue by installing different driver versions.
If you happen to know someone with whom you can test the GPU, that would be a huge help.
Hm, okay. I think instead of using the newest version, I'll go with the Microsoft ones (via Windows Update) as a first step. If I experience another BSOD, I'll ask my roomie if we can switch GPUs for testing :D
PS: Out of interest, how did you locate the problem at the GPU? Because the stack trace is full of nvidia-related stuff?
DPC watchdog violation is very often from the GPU drivers, the dump agrees with me.
Here's output from the dump, some useless chunk removed, nvlddmkm.sys is the nvidia driver.
BugCheck 133, {1, 1e00, fffff800820fb378, 0}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that   ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
Probably caused by : nvlddmkm.sys ( nvlddmkm+1cb141 )
Followup:     MachineOwner
Processing initial command '!load cmkd; !load procdumpext; !load niemiro; !analyze -v; lmtsmn; !rawstack; !dpx; !sysinfo smbios; !sysinfo machineid; !sysinfo cpuspeed; !thread; .bugcheck; .time;'
0: kd> !load cmkd; !load procdumpext; !load niemiro; !analyze -v; lmtsmn; !rawstack; !dpx; !sysinfo smbios; !sysinfo machineid; !sysinfo cpuspeed; !thread; .bugcheck; .time;
 ProcDumpExt v6.4 - Copyright 2013 Andrew Richards
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
	DISPATCH_LEVEL or above. The offending component can usually be
	identified with a stack trace.
Arg2: 0000000000001e00, The watchdog period.
Arg3: fffff800820fb378
Arg4: 0000000000000000
Debugging Details:
***    work.                                                          ***
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING:  10.0.17134.137 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER:  System manufacturer
SYSTEM_PRODUCT_NAME:  System Product Name
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  3805
BIOS_DATE:  05/16/2018
BASEBOARD_MANUFACTURER:  ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT:  H170 PRO GAMING
BASEBOARD_VERSION:  Rev X.0x
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_TYPE:  2
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff800820fb378
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE:  DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
CPU_COUNT: 8
CPU_MHZ: d50
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R)  SIG: C2'00000000 (cache) C2'00000000 (init)
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  0x133
PROCESS_NAME:  System
CURRENT_IRQL:  d
ANALYSIS_SESSION_HOST:  DESKTOP-NPASAR7
ANALYSIS_SESSION_TIME:  07-10-2018 20:08:57.0321
ANALYSIS_VERSION: 10.0.14321.1024 x86fre
LAST_CONTROL_TRANSFER:  from fffff80081e87947 to fffff80081e39430
STACK_TEXT:
fffff800`819b12a8 fffff800`81e87947 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff800`820fb378 : nt!KeBugCheckEx
fffff800`819b12b0 fffff800`81d3cedd : 000002a2`48047751 fffff800`8127e180 00000000`00000246 00000000`001d6a03 : nt!KeAccumulateTicks+0x146f57
fffff800`819b1310 fffff800`81d3dfc3 : fffff780`00000340 00000000`00000000 00000000`001d6a03 00000000`00000000 : nt!KiUpdateRunTime+0x5d
fffff800`819b1360 fffff800`81c16883 : 000002a2`480427ff fffff800`819b1b31 00000000`00000000 fffff800`819b1730 : nt!KeClockInterruptNotify+0x8f3
fffff800`819b1670 fffff800`81d8bde5 : fffff800`81c77cb0 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalpTimerClockInterrupt+0x63
fffff800`819b16a0 fffff800`81e3acea : fffff800`819b17b0 fffff800`81c77cb0 fffff800`819b1b50 ffff8406`07648930 : nt!KiCallInterruptServiceRoutine+0xa5
fffff800`819b16e0 fffff800`81e3b1d7 : fffff800`819b1b00 00000000`00000000 fffff800`819b1850 fffff809`620e8c17 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
fffff800`819b1730 fffff809`6224b141 : fffff809`6226d234 ffff8406`0a43b000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff800`819b18c8 fffff809`6226d234 : ffff8406`0a43b000 00000000`00000000 00000000`00000000 00000000`00000000 : nvlddmkm+0x1cb141
fffff800`819b18d0 ffff8406`0a43b000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000020 : nvlddmkm+0x1ed234
fffff800`819b18d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000020 fffff800`819b1910 : 0xffff8406`0a43b000
STACK_COMMAND:  kb
THREAD_SHA1_HASH_MOD_FUNC:  238d969c53135466a71c09bbdb5331be9a4735a5
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  5194644e9ffb948c6b3c783f7afb1164cc7ede92
THREAD_SHA1_HASH_MOD:  76bfd36c86c27be87b3f0a089e53fde2b1df96d3
FOLLOWUP_IP:
nvlddmkm+1cb141
fffff809`6224b141 c3              ret
FAULT_INSTR_CODE:  8accccc3
SYMBOL_STACK_INDEX:  8
SYMBOL_NAME:  nvlddmkm+1cb141
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  5b2fbada
BUCKET_ID_FUNC_OFFSET:  1cb141
FAILURE_BUCKET_ID:  0x133_ISR_nvlddmkm!unknown_function
PRIMARY_PROBLEM_CLASS:  0x133_ISR_nvlddmkm!unknown_function
TARGET_TIME:  2018-07-07T10:02:55.000Z
OSBUILD:  17134
OSSERVICEPACK:  137
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  272
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  2018-06-15 06:42:27
BUILDDATESTAMP_STR:  160101.0800
BUILDLAB_STR:  WinBuild
BUILDOSVER_STR:  10.0.17134.137
ANALYSIS_SESSION_ELAPSED_TIME: 961
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x133_isr_nvlddmkm!unknown_function
FAILURE_ID_HASH:  {f97493a5-ea2b-23ca-a808-8602773c2a86}
fffff809`5e600000 fffff809`5e6a5000   ACPI     ACPI.sys     ***** Invalid (A0D961E5)
fffff809`5e450000 fffff809`5e473000   acpiex   acpiex.sys   ***** Invalid (A0DBA1E7)
fffff809`5fc00000 fffff809`5fc9e000   afd      afd.sys      ***** Invalid (E5C2C597)
fffff809`5fbe0000 fffff809`5fbf3000   afunix   afunix.sys   Tue Apr 18 16:12:59 2017 (58F61EEB)
fffff800`80430000 fffff800`80457000   AgileVpn AgileVpn.sys ***** Invalid (B96F50A5)
fffff809`5eec0000 fffff809`5ef05000   ahcache  ahcache.sys  ***** Invalid (AAB4C5E7)
fffff809`5f5e0000 fffff809`5f5e6000   AsIO     AsIO.sys     Wed Aug 22 11:54:47 2012 (5034AC67)
fffff809`60380000 fffff809`60394000   bam      bam.sys      ***** Invalid (F0EF718F)
fffff809`5fae0000 fffff809`5faf6000   BasicDisplay BasicDisplay.sys Wed Jul 13 06:57:10 1988 (22DAEDA6)
fffff809`5fb00000 fffff809`5fb10000   BasicRender BasicRender.sys Thu Jun 10 09:53:52 1999 (375F6F10)
fffff809`61130000 fffff809`6113f000   BdaSup   BdaSup.SYS   ***** Invalid (C2034D36)
fffff809`5f7d0000 fffff809`5f7da000   Beep     Beep.SYS     ***** Invalid (E3C311B5)
fffff809`5eb90000 fffff809`5eb9b000   BOOTVID  BOOTVID.dll  ***** Invalid (A81902E1)
fffff800`800b0000 fffff800`800d1000   bowser   bowser.sys   Fri Mar 28 20:00:24 2008 (47ED4048)
ffffe95c`d3480000 ffffe95c`d34bf000   cdd      cdd.dll      unavailable (00000000)
fffff809`5f760000 fffff809`5f78e000   cdrom    cdrom.sys    Mon Jul 31 08:59:18 1978 (1022CDC6)
fffff809`5e850000 fffff809`5e869000   CEA      CEA.sys      Wed Sep 16 07:57:44 1987 (214E2858)
fffff809`5e1a0000 fffff809`5e255000   CI       CI.dll       ***** Invalid (CFB9E6DF)
fffff809`5f610000 fffff809`5f67b000   CLASSPNP CLASSPNP.SYS ***** Invalid (E3348094)
fffff800`7fe00000 fffff800`7fe6e000   cldflt   cldflt.sys   Tue May 17 04:25:49 2005 (4289562D)
fffff809`5ead0000 fffff809`5eb34000   CLFS     CLFS.SYS     ***** Invalid (FF43C502)
fffff809`5e070000 fffff809`5e172000   clipsp   clipsp.sys   Wed Apr 11 06:05:31 2018 (5ACD898B)
fffff809`5e180000 fffff809`5e18e000   cmimcext cmimcext.sys Wed Jul  2 17:10:18 1986 (1F09445A)
fffff809`5e260000 fffff809`5e312000   cng      cng.sys      ***** Invalid (9A741A9D)
fffff809`5f3e0000 fffff809`5f3f1000   CompositeBus CompositeBus.sys ***** Invalid (E21758C8)
fffff800`80610000 fffff800`80622000   condrv   condrv.sys   ***** Invalid (80BAEE40)
fffff809`5f6a0000 fffff809`5f6bb000   crashdmp crashdmp.sys Tue Jul 11 08:42:25 2028 (6E159E51)
fffff809`5fef0000 fffff809`5ff80000   csc      csc.sys      Mon Apr 17 16:17:56 2034 (78EE8014)
fffff809`61440000 fffff809`61456000   dc1_controller dc1-controller.sys Fri Jan 11 19:42:33 2019 (5C38E399)
fffff809`61590000 fffff809`615a3000   DevAuthE DevAuthE.sys Thu Aug 12 10:11:43 1971 (0307A53F)
fffff809`5ffd0000 fffff809`5fff9000   dfsc     dfsc.sys     ***** Invalid (C86C4181)
fffff809`5f5f0000 fffff809`5f60c000   disk     disk.sys     Thu Aug  3 16:40:22 1989 (24D85956)
fffff809`631d0000 fffff809`631f1000   drmk     drmk.sys     Mon Nov  4 06:43:10 2019 (5DBFBA6E)
fffff809`5f720000 fffff809`5f73d000   dump_dumpfve dump_dumpfve.sys Fri Feb 21 04:54:47 1992 (29A47807)
fffff809`61bf0000 fffff809`61bfe000   dump_dumpstorport dump_dumpstorport.sys Fri Aug  8 12:06:57 2025 (6895CC41)
fffff809`5f6e0000 fffff809`5f6ff000   dump_stornvme dump_stornvme.sys Sun May 14 02:35:07 2028 (6DC8D13B)
fffff809`5f7e0000 fffff809`5fa97000   dxgkrnl  dxgkrnl.sys  ***** Invalid (984AD74D)
fffff800`80630000 fffff800`806f6000   dxgmms2  dxgmms2.sys  ***** Invalid (84B4E417)
fffff809`61180000 fffff809`61206000   e1i63x64 e1i63x64.sys Fri Mar  4 22:46:29 2016 (56DA0235)
fffff809`5ec00000 fffff809`5ec1c000   EhStorClass EhStorClass.sys Tue Jan 28 07:15:44 2031 (72E0FC90)
fffff809`5edc0000 fffff809`5ede1000   EhStorTcgDrv EhStorTcgDrv.sys Wed Aug 10 15:51:30 2005 (42FA0662)
fffff809`603a0000 fffff809`60400000   fastfat  fastfat.SYS  Tue May 21 23:53:07 1991 (283996C3)
fffff809`5f790000 fffff809`5f7a4000   filecrypt filecrypt.sys ***** Invalid (BDE52434)
fffff809`5ec20000 fffff809`5ec3a000   fileinfo fileinfo.sys ***** Invalid (D50D6775)
fffff809`5e000000 fffff809`5e069000   FLTMGR   FLTMGR.SYS   ***** Invalid (8801E691)
fffff809`5f280000 fffff809`5f28d000   Fs_Rec   Fs_Rec.sys   Wed Oct 13 21:09:20 1971 (0359FC60)
fffff800`807c0000 fffff800`807d5000   FsDepends FsDepends.sys ***** Invalid (95DA8F49)
fffff809`5f400000 fffff809`5f4bc000   fvevol   fvevol.sys   Sat Mar 30 03:47:16 2030 (715003B4)
fffff809`602b0000 fffff809`60326000   fwpkclnt fwpkclnt.sys Thu Nov  8 10:04:48 1990 (27391FB0)
fffff809`5ffc0000 fffff809`5ffca000   gpuenergydrv gpuenergydrv.sys ***** Invalid (A5E021DD)
fffff800`81c15000 fffff800`81ca1000   hal      hal.dll      Tue Apr  5 23:12:34 2005 (4252FF42)
fffff809`60ee0000 fffff809`61124000   HCW85BDA HCW85BDA.sys Fri Jun 16 18:00:56 2017 (594400B8)
fffff809`63140000 fffff809`6315d000   HDAudBus HDAudBus.sys ***** Invalid (A500E2B9)
fffff809`61b10000 fffff809`61b43000   HIDCLASS HIDCLASS.SYS ***** Invalid (CAEE9942)
fffff809`61b50000 fffff809`61b63000   HIDPARSE HIDPARSE.SYS Sun Sep  4 21:19:34 2033 (77C62546)
fffff809`61af0000 fffff809`61b02000   hidusb   hidusb.sys   Fri Jun 25 07:22:47 2027 (6C1DEEA7)
fffff800`7ffa0000 fffff800`800a2000   HTTP     HTTP.sys     Tue Dec  4 12:28:58 1979 (12AA5D7A)
fffff800`80740000 fffff800`80759000   hvservice hvservice.sys Thu Jun  9 21:15:51 2033 (775371E7)
fffff809`5fe30000 fffff809`5fe41000   hvsifltr hvsifltr.sys ***** Invalid (F4C0611E)
fffff809`5ef50000 fffff809`5ef76000   hvsocket hvsocket.sys ***** Invalid (CE58229D)
fffff800`80720000 fffff800`8072d000   hvsocketcontrol hvsocketcontrol.sys ***** Invalid (A0CC3787)
fffff809`5e780000 fffff809`5e7af000   intelpep intelpep.sys Mon Jan  7 10:28:21 2019 (5C331BB5)
fffff809`61220000 fffff809`6125d000   intelppm intelppm.sys ***** Invalid (E0024307)
fffff809`5f5c0000 fffff809`5f5d1000   iorate   iorate.sys   ***** Invalid (9B6D3859)
fffff809`60e40000 fffff809`60e53000   kbdclass kbdclass.sys Sat May 22 20:26:35 2021 (60A94CDB)
fffff809`61be0000 fffff809`61bf0000   kbdhid   kbdhid.sys   ***** Invalid (D368C0F3)
fffff800`812c5000 fffff800`812d0000   kd       kd.dll       ***** Invalid (FC97B795)
fffff809`60df0000 fffff809`60dfd000   kdnic    kdnic.sys    Thu Sep 21 22:45:00 2028 (6E754FCC)
fffff809`62000000 fffff809`6206b000   ks       ks.sys       ***** Invalid (CEE0FD48)
fffff809`5ea80000 fffff809`5eaaa000   ksecdd   ksecdd.sys   ***** Invalid (DD8EFEF6)
fffff809`5ee90000 fffff809`5eec0000   ksecpkg  ksecpkg.sys  ***** Invalid (F1B128CB)
fffff809`61140000 fffff809`6114f000   ksthunk  ksthunk.sys  ***** Invalid (EFF99365)
fffff800`7ff30000 fffff800`7ff46000   lltdio   lltdio.sys   Tue Oct 19 12:57:28 2010 (4CBD7998)
fffff800`80760000 fffff800`80787000   luafv    luafv.sys    ***** Invalid (8A309BD4)
fffff809`5e500000 fffff809`5e5ff000   LXCORE   LXCORE.SYS   Tue Nov 27 04:05:56 2012 (50B42E14)
fffff809`5e4f0000 fffff809`5e4fa000   lxss     lxss.sys     ***** Invalid (B0BB1927)
fffff800`7ff10000 fffff800`7ff23000   mmcss    mmcss.sys    Thu Feb  9 13:38:08 2017 (589C62B0)
fffff800`80700000 fffff800`80711000   monitor  monitor.sys  ***** Invalid (8CE3B5D7)
fffff809`60eb0000 fffff809`60ec1000   mouclass mouclass.sys ***** Invalid (EC0AC493)
fffff809`60e60000 fffff809`60e6f000   mouhid   mouhid.sys   ***** Invalid (81B3C45F)
fffff809`5e9c0000 fffff809`5e9de000   mountmgr mountmgr.sys Sun Jul 11 07:36:45 2010 (4C39586D)
fffff800`800e0000 fffff800`800f9000   mpsdrv   mpsdrv.sys   Tue Jun 29 21:12:49 1993 (2C309431)
fffff800`80100000 fffff800`80182000   mrxsmb   mrxsmb.sys   Tue Apr 27 21:31:30 2010 (4BD73B92)
fffff800`80190000 fffff800`801cd000   mrxsmb20 mrxsmb20.sys ***** Invalid (EC01DE9F)
fffff809`5fb30000 fffff809`5fb40000   Msfs     Msfs.SYS     ***** Invalid (BD01B948)
fffff809`5e6c0000 fffff809`5e6cb000   msisadrv msisadrv.sys Sun Apr 19 02:48:50 1970 (008E6D72)
fffff800`7fef0000 fffff800`7ff0a000   mslldp   mslldp.sys   Thu Apr  5 13:37:22 1979 (116A02F2)
fffff809`5ea20000 fffff809`5ea80000   msrpc    msrpc.sys    ***** Invalid (D522F4A7)
fffff809`5e480000 fffff809`5e4cf000   mssecflt mssecflt.sys Wed Jun  6 14:24:18 2029 (6FC8FD72)
fffff809`5ffb0000 fffff809`5ffbf000   mssmbios mssmbios.sys ***** Invalid (B89DA2EF)
fffff809`5f590000 fffff809`5f5b4000   mup      mup.sys      ***** Invalid (84DBF4DF)
fffff809`5f290000 fffff809`5f3d1000   ndis     ndis.sys     Sat Jul 29 20:07:48 2034 (79768074)
fffff800`804c0000 fffff800`804cf000   ndistapi ndistapi.sys Mon Apr 13 03:29:09 1970 (00868DE5)
fffff809`612d0000 fffff809`612dd000   NdisVirtualBus NdisVirtualBus.sys ***** Invalid (9BCAE864)
fffff800`804d0000 fffff800`80507000   ndiswan  ndiswan.sys  Tue Aug 11 23:51:57 1987 (211F91FD)
fffff800`80410000 fffff800`80426000   NDProxy  NDProxy.sys  Sat Aug 11 01:19:33 2018 (5B6E1D85)
fffff800`80220000 fffff800`80247000   Ndu      Ndu.sys      ***** Invalid (9D155C46)
fffff809`5fe50000 fffff809`5fe62000   netbios  netbios.sys  ***** Invalid (DBD51B1C)
fffff809`5fb80000 fffff809`5fbd4000   netbt    netbt.sys    ***** Invalid (CA7943CA)
fffff809`5ee00000 fffff809`5ee89000   NETIO    NETIO.SYS    Fri Jul 29 19:31:39 2022 (62E4197B)
fffff809`5fb10000 fffff809`5fb2b000   Npfs     Npfs.SYS     ***** Invalid (927DEFE8)
fffff809`5ffa0000 fffff809`5ffad000   npsvctrig npsvctrig.sys ***** Invalid (E9804B86)
fffff809`5ff80000 fffff809`5ff92000   nsiproxy nsiproxy.sys ***** Invalid (DC8AB40C)
fffff800`81ca1000 fffff800`82602000   nt       ntkrnlmp.exe Fri Jun 15 06:42:27 2018 (5B2343B3)
fffff809`5f020000 fffff809`5f27b000   Ntfs     Ntfs.sys     Mon Feb  3 06:01:31 1986 (1E44462B)
fffff809`5e190000 fffff809`5e19c000   ntosext  ntosext.sys  Wed May 17 19:41:19 1972 (0477FD3F)
fffff809`5f7c0000 fffff809`5f7ca000   Null     Null.SYS     Mon Jun 30 07:17:31 2031 (73AAA46B)
fffff809`613a0000 fffff809`613d7000   nvhda64v nvhda64v.sys Wed Apr  4 04:01:20 2018 (5AC431F0)
fffff809`62080000 fffff809`6313b000   nvlddmkm nvlddmkm.sys Sun Jun 24 17:38:02 2018 (5B2FBADA)
fffff809`5fe00000 fffff809`5fe29000   pacer    pacer.sys    ***** Invalid (89D4206A)
fffff809`5e870000 fffff809`5e89d000   partmgr  partmgr.sys  Wed Jan 13 21:45:53 2021 (5FFF5C01)
fffff809`5e6d0000 fffff809`5e730000   pci      pci.sys      ***** Invalid (DD60CB9A)
fffff809`5e7e0000 fffff809`5e7f4000   pcw      pcw.sys      Thu Apr 16 15:50:38 2026 (69E0E92E)
fffff809`5e820000 fffff809`5e848000   pdc      pdc.sys      ***** Invalid (E1E24B35)
fffff800`80310000 fffff800`803d0000   peauth   peauth.sys   Fri Sep 12 04:56:58 2036 (7D74B6FA)
fffff809`63160000 fffff809`631c4000   portcls  portcls.sys  Sat Jan 15 04:16:13 1977 (0D3DAE7D)
fffff809`5eb70000 fffff809`5eb87000   PSHED    PSHED.dll    ***** Invalid (FCF5BFC7)
fffff800`80460000 fffff800`80480000   rasl2tp  rasl2tp.sys  ***** Invalid (D79956B1)
fffff800`804a0000 fffff800`804bb000   raspppoe raspppoe.sys ***** Invalid (D6217902)
fffff800`80480000 fffff800`8049f000   raspptp  raspptp.sys  ***** Invalid (DEE494F8)
fffff800`803f0000 fffff800`8040b000   rassstp  rassstp.sys  ***** Invalid (CD5601B9)
fffff809`5fe70000 fffff809`5fee6000   rdbss    rdbss.sys    ***** Invalid (9FD233A8)
fffff809`612f0000 fffff809`612fe000   rdpbus   rdpbus.sys   Fri Aug 15 01:47:33 2031 (73E6FC15)
fffff800`805b0000 fffff800`805bd000   rdpvideominiport rdpvideominiport.sys ***** Invalid (E0ECDD5E)
fffff809`5f540000 fffff809`5f58c000   rdyboost rdyboost.sys Fri Oct 22 03:19:40 1971 (0364DF2C)
fffff800`7ff50000 fffff800`7ff6a000   rspndr   rspndr.sys   ***** Invalid (9EF4AC0E)
fffff809`615b0000 fffff809`61aee000   RTKVHD64 RTKVHD64.sys Tue Aug 16 14:14:34 2016 (57B303AA)
fffff809`61170000 fffff809`6117f000   serenum  serenum.sys  Tue Jan 18 17:54:20 2000 (38849ABC)
fffff809`61150000 fffff809`6116c000   serial   serial.sys   ***** Invalid (BF38AA71)
fffff809`5e4d0000 fffff809`5e4e5000   SgrmAgent SgrmAgent.sys Thu Feb  2 15:30:36 2012 (4F2A9E0C)
fffff809`5e440000 fffff809`5e44f000   SleepStudyHelper SleepStudyHelper.sys Wed Dec 13 17:00:17 2017 (5A314E91)
fffff809`5e8a0000 fffff809`5e939000   spaceport spaceport.sys Mon May 10 13:17:48 2004 (409F64DC)
fffff800`80250000 fffff800`8030c000   srv2     srv2.sys     Thu Dec 15 18:59:17 1977 (0EF6D275)
fffff800`801d0000 fffff800`80218000   srvnet   srvnet.sys   ***** Invalid (F2156005)
fffff809`5e9e0000 fffff809`5ea0a000   storahci storahci.sys ***** Invalid (867FC31B)
fffff809`5eda0000 fffff809`5edbf000   stornvme stornvme.sys Sun May 14 02:35:07 2028 (6DC8D13B)
fffff809`5ed10000 fffff809`5ed9f000   storport storport.sys Sat Oct  5 17:15:35 2024 (67015817)
fffff800`7fec0000 fffff800`7fed9000   storqosflt storqosflt.sys Wed Jan  5 18:54:03 2011 (4D24B03B)
fffff809`612a0000 fffff809`612c6000   storvsp  storvsp.sys  ***** Invalid (CF6757C3)
fffff809`612e0000 fffff809`612ec000   swenum   swenum.sys   Fri Feb  4 03:15:43 1994 (2D51AFCF)
fffff809`5f7b0000 fffff809`5f7bd000   tbs      tbs.sys      ***** Invalid (81533658)
fffff809`60000000 fffff809`602a4000   tcpip    tcpip.sys    Mon Apr  1 04:30:55 2013 (5158F15F)
fffff800`803d0000 fffff800`803e3000   tcpipreg tcpipreg.sys Fri Aug  3 09:02:15 2029 (701528F7)
fffff809`5fb70000 fffff809`5fb80000   TDI      TDI.SYS      ***** Invalid (814E4748)
fffff809`5fb40000 fffff809`5fb63000   tdx      tdx.sys      ***** Invalid (9F3F7265)
fffff809`60e70000 fffff809`60ea4000   TeeDriverW8x64 TeeDriverW8x64.sys Tue Apr  4 09:02:36 2017 (58E3450C)
fffff809`5eb40000 fffff809`5eb64000   tm       tm.sys       ***** Invalid (DA2D5B6C)
fffff809`5e730000 fffff809`5e76d000   tpm      tpm.sys      ***** Invalid (840D39AF)
fffff809`60e00000 fffff809`60e3c000   ucx01000 ucx01000.sys ***** Invalid (F946307A)
fffff809`61260000 fffff809`6126d000   UEFI     UEFI.sys     Tue May 15 14:09:49 2029 (6FABF90D)
fffff809`5ece0000 fffff809`5ecf5000   umbus    umbus.sys    Thu Mar  1 09:22:35 1973 (05F32A4B)
fffff809`61410000 fffff809`6143f000   usbccgp  usbccgp.sys  ***** Invalid (8237B6CE)
fffff809`61390000 fffff809`6139e000   USBD     USBD.SYS     ***** Invalid (A9E461EC)
fffff809`61300000 fffff809`6138e000   UsbHub3  UsbHub3.sys  Fri Dec 10 01:31:51 2004 (41B8EE77)
fffff809`613e0000 fffff809`61405000   USBSTOR  USBSTOR.SYS  Sat Jul  5 01:28:56 1975 (0A5B3138)
fffff809`61b70000 fffff809`61bdf000   USBXHCI  USBXHCI.SYS  Mon Jun 22 16:03:04 1987 (20DD3918)
fffff809`5e800000 fffff809`5e812000   vdrvroot vdrvroot.sys Wed Nov 28 06:36:24 2035 (7BF7DAD8)
fffff809`5fcc0000 fffff809`5fdfd000   vfpext   vfpext.sys   Sun Apr 18 06:36:26 1993 (2BD0DACA)
fffff800`cb2c0000 fffff800`cb376000   vhdmp    vhdmp.sys    ***** Invalid (B147AAB4)
fffff800`80730000 fffff800`80740000   vhdparser vhdparser.sys ***** Invalid (D49D694B)
fffff809`5efa0000 fffff809`5f003000   Vid      Vid.sys      Mon Mar  9 15:57:15 2037 (7E600ACB)
fffff809`5fac0000 fffff809`5fada000   vmbkmclr vmbkmclr.sys ***** Invalid (D822A885)
fffff809`5ef10000 fffff809`5ef43000   vmbusr   vmbusr.sys   ***** Invalid (F30D7B55)
fffff809`60360000 fffff809`6036d000   VmsProxy VmsProxy.sys Wed Jul  3 00:02:40 2030 (71CCFF80)
fffff809`60370000 fffff809`6037e000   VmsProxyHNic VmsProxyHNic.sys ***** Invalid (B8A6C0A3)
fffff809`60ac0000 fffff809`60de9000   vmswitch vmswitch.sys ***** Invalid (9FFB2659)
fffff809`5e940000 fffff809`5e959000   volmgr   volmgr.sys   ***** Invalid (A6ED6AB7)
fffff809`5e960000 fffff809`5e9be000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff809`5f4d0000 fffff809`5f537000   volsnap  volsnap.sys  ***** Invalid (BC6DEACD)
fffff809`5f4c0000 fffff809`5f4cb000   volume   volume.sys   ***** Invalid (BBE7F72B)
fffff809`61270000 fffff809`61293000   vpcivsp  vpcivsp.sys  Sun Sep 17 19:17:49 1989 (2513D1BD)
fffff809`5fca0000 fffff809`5fcba000   vwififlt vwififlt.sys ***** Invalid (E4E7506A)
fffff800`7ff70000 fffff800`7ff8b000   wanarp   wanarp.sys   ***** Invalid (D8D929B9)
fffff809`5faa0000 fffff809`5fab4000   watchdog watchdog.sys Thu Aug 23 10:44:31 2029 (702F9EEF)
fffff800`80790000 fffff800`807b8000   wcifs    wcifs.sys    Tue Dec 17 02:40:30 2024 (6760D68E)
fffff809`5e320000 fffff809`5e404000   Wdf01000 Wdf01000.sys ***** Invalid (BD4591F4)
fffff809`5ec80000 fffff809`5ecd6000   WdFilter WdFilter.sys Sun Jun  4 07:04:34 1972 (048F06E2)
fffff809`5e410000 fffff809`5e423000   WDFLDR   WDFLDR.SYS   Fri Jul 27 04:22:47 2012 (5011FB77)
fffff800`80550000 fffff800`80561000   WdNisDrv WdNisDrv.sys ***** Invalid (E01DC278)
fffff809`5eab0000 fffff809`5eac1000   werkernel werkernel.sys Tue Apr 29 13:25:50 1980 (136C293E)
fffff809`60330000 fffff809`6035d000   wfplwfs  wfplwfs.sys  Sun Feb 10 03:18:15 2030 (7110B4E7)
ffffe95c`d2fe0000 ffffe95c`d305c000   win32k   win32k.sys   unavailable (00000000)
ffffe95c`d3200000 ffffe95c`d3434000   win32kbase win32kbase.sys unavailable (00000000)
ffffe95c`d3d30000 ffffe95c`d40c0000   win32kfull win32kfull.sys unavailable (00000000)
fffff809`5e7b0000 fffff809`5e7c6000   WindowsTrustedRT WindowsTrustedRT.sys ***** Invalid (C5D5EE17)
fffff809`5e7d0000 fffff809`5e7db000   WindowsTrustedRTProxy WindowsTrustedRTProxy.sys Fri Apr 27 12:41:18 2001 (3AE94CCE)
fffff809`5ef80000 fffff809`5ef9c000   winhvr   winhvr.sys   Fri Nov 16 13:19:17 1973 (074A27C5)
fffff800`80510000 fffff800`8054f000   winnat   winnat.sys   Mon Jul 17 20:43:26 2017 (596D054E)
fffff809`61210000 fffff809`6121c000   wmiacpi  wmiacpi.sys  ***** Invalid (953BFBDD)
fffff809`5e6b0000 fffff809`5e6bc000   WMILIB   WMILIB.SYS   Sun Jul 20 21:38:32 2008 (48839438)
fffff809`60a00000 fffff809`60ac0000   wnv      wnv.sys      ***** Invalid (C61223A6)
fffff809`5ec40000 fffff809`5ec7b000   Wof      Wof.sys      Mon Sep 29 15:47:10 2036 (7D8BB8DE)
fffff800`7fee0000 fffff800`7feed000   WpdUpFltr WpdUpFltr.sys Fri Jun  7 18:53:41 2030 (71ABC195)
fffff809`5e430000 fffff809`5e43e000   WppRecorder WppRecorder.sys Mon Jun 29 01:29:10 2009 (4A47FCC6)
fffff800`80570000 fffff800`8057d000   WSDPrint WSDPrint.sys ***** Invalid (DC7DE7CC)
fffff800`80580000 fffff800`8058d000   WSDScan  WSDScan.sys  Fri Apr  5 16:30:11 2024 (66100AF3)
fffff800`7fe70000 fffff800`7feb8000   WUDFRd   WUDFRd.sys   ***** Invalid (873FAAC2)
fffff809`61460000 fffff809`61588000   xboxgip  xboxgip.sys  Thu Mar 21 11:51:40 2030 (714497BC)
fffff800`cb390000 fffff800`cb3a3000   xinputhid xinputhid.sys Wed Sep  2 05:44:29 2009 (4A9DEA1D)
Unloaded modules:
fffff800`cb3c0000 fffff800`cb3c7000   magdrvamd64.
    Checksum:  00000000
    ImageSize:  00007000
fffff800`cb3b0000 fffff800`cb3b7000   magdrvamd64.
    Checksum:  00000000
    ImageSize:  00007000
fffff800`cb380000 fffff800`cb390000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff800`80720000 fffff800`80733000   xinputhid.sy
    Checksum:  00000000
    ImageSize:  00013000
fffff800`805c0000 fffff800`805ce000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000E000
fffff800`805d0000 fffff800`805ef000   hiber_stornv
    Checksum:  00000000
    ImageSize:  0001F000
fffff800`805f0000 fffff800`8060d000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  0001D000
fffff800`805a0000 fffff800`805a7000   magdrvamd64.
    Checksum:  00000000
    ImageSize:  00007000
fffff800`80590000 fffff800`80597000   magdrvamd64.
    Checksum:  00000000
    ImageSize:  00007000
fffff800`7ff90000 fffff800`7ffa0000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff809`5f6d0000 fffff809`5f6de000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000E000
fffff809`5f700000 fffff809`5f71f000   dump_stornvm
    Checksum:  00000000
    ImageSize:  0001F000
fffff809`5f740000 fffff809`5f75d000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  0001D000
fffff809`60eb0000 fffff809`60ed5000   WudfPf.sys
    Checksum:  00000000
    ImageSize:  00025000
fffff809`60e40000 fffff809`60e65000   WudfPf.sys
    Checksum:  00000000
    ImageSize:  00025000
fffff809`60380000 fffff809`6039b000   dam.sys
    Checksum:  00000000
    ImageSize:  0001B000
fffff809`5e770000 fffff809`5e77f000   WdBoot.sys
    Checksum:  00000000
    ImageSize:  0000F000
fffff809`5f5e0000 fffff809`5f5ef000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  0000F000
dps fffffb08e37de000 fffffb08e37e4d38
fffffb08`e37e2558  00000000`00000000
fffffb08`e37e2560  00000000`00000000
fffffb08`e37e2568  00000000`00000000
fffffb08`e37e2570  00000000`00000000
fffffb08`e37e2578  00000000`00000000
fffffb08`e37e2580  00000000`00000000
fffffb08`e37e2588  00000000`00000000
fffffb08`e37e2590  00000000`00000000
fffffb08`e37e2598  00000000`00000000
fffffb08`e37e25a0  00000000`00000000
fffffb08`e37e25a8  00000000`00000000
fffffb08`e37e25b0  00000000`00000000
fffffb08`e37e25b8  00000000`00000000
fffffb08`e37e25c0  00000000`00000000
fffffb08`e37e25c8  00000000`00000000
fffffb08`e37e25d0  00000000`00000000
fffffb08`e37e25d8  00000000`00000000
fffffb08`e37e25e0  ffffd6f8`15ec14b8
fffffb08`e37e25e8  fffff800`81cb7beb nt!RtlFindClearBitsAndSetEx+0xeb
fffffb08`e37e25f0  00000000`00000245
fffffb08`e37e25f8  00000000`000003fc
fffffb08`e37e2600  00000000`00000000
fffffb08`e37e2608  00000000`00000000
fffffb08`e37e2610  00000000`00000000
fffffb08`e37e2618  00000000`00000000
fffffb08`e37e2620  00000000`00000245
fffffb08`e37e2628  fffff800`81cb7882 nt!MiIncreaseNonPagedPoolUsage+0x42
fffffb08`e37e2630  00000000`00000000
fffffb08`e37e2638  fffffb08`e37e26d0
fffffb08`e37e2640  00000000`00000000
fffffb08`e37e2648  fffffb08`e37e26d0
fffffb08`e37e2650  00000000`00000245
fffffb08`e37e2658  fffff800`81cb74f0 nt!MiScanLeafNonPagedPool+0x250
fffffb08`e37e2660  00000000`00000000
fffffb08`e37e2668  00000000`00000000
fffffb08`e37e2670  00000000`00000000
fffffb08`e37e2678  00000000`00000000
fffffb08`e37e2680  00000000`00000000
fffffb08`e37e2688  00000000`00000000
fffffb08`e37e2690  00000000`00000000
fffffb08`e37e2698  00000000`00000000
fffffb08`e37e26a0  00000000`00000400
fffffb08`e37e26a8  ffffd6f8`15ec1440
fffffb08`e37e26b0  00000000`00000000
fffffb08`e37e26b8  ffffbe00`0000b070
fffffb08`e37e26c0  00000000`00000000
fffffb08`e37e26c8  00000000`00000000
fffffb08`e37e26d0  ffffbe00`0000b090
fffffb08`e37e26d8  fffffb08`e37e2800
fffffb08`e37e26e0  00000000`00003051
fffffb08`e37e26e8  00000000`00000001
fffffb08`e37e26f0  ffff8406`09fb8c63
fffffb08`e37e26f8  fffff800`81c1d8da hal!HalpHvCounterQueryCounter+0x1a
fffffb08`e37e2700  ffff8406`09fb8c60
fffffb08`e37e2708  00000000`12be97cd
fffffb08`e37e2710  00000000`00000000
fffffb08`e37e2718  fffff800`81ca34e2 nt!ExReleaseAutoExpandPushLockShared+0x82
fffffb08`e37e2720  00000000`00000000
fffffb08`e37e2728  fffff800`81e00bd3 nt!EtwpCCSwapTrace+0x1b3
fffffb08`e37e2730  00000000`00000000
fffffb08`e37e2738  fffff800`81d5a61a nt!MmCheckCachedPageStates+0x2ea
fffffb08`e37e2740  00000000`00000000
fffffb08`e37e2748  00000000`00000000
fffffb08`e37e2750  00000000`00000e98
fffffb08`e37e2758  ffff8406`076a9000
fffffb08`e37e2760  00000000`00000000
fffffb08`e37e2768  ffff8406`076a9000
fffffb08`e37e2770  00000000`0ac3c011
fffffb08`e37e2778  ffffc700`90eb9200
fffffb08`e37e2780  00000000`00000501
fffffb08`e37e2788  ffffbb00`031c5720
fffffb08`e37e2790  00000000`00000002
fffffb08`e37e2798  fffff800`81e009b5 nt!EtwpLogContextSwapEvent+0xe5
fffffb08`e37e27a0  ffff8406`00000000
fffffb08`e37e27a8  00000000`00000000
fffffb08`e37e27b0  00000000`00000001
fffffb08`e37e27b8  fffffb08`00000000
fffffb08`e37e27c0  0a000001`09726863
fffffb08`e37e27c8  fffffe54`85df23d8
fffffb08`e37e27d0  00000000`00000000
fffffb08`e37e27d8  00000000`00000000
fffffb08`e37e27e0  0a000001`09726863
fffffb08`e37e27e8  00000000`00000000
fffffb08`e37e27f0  ffff8406`076a9000
fffffb08`e37e27f8  ffff8406`076a9000
fffffb08`e37e2800  00000000`00000000
fffffb08`e37e2808  fffff800`8207c000 nt!MiSystemPartition
fffffb08`e37e2810  ffff8406`0a045ed0
fffffb08`e37e2818  fffffe54`85df23e0
fffffb08`e37e2820  00000000`00000000
fffffb08`e37e2828  00000000`00000000
fffffb08`e37e2830  00000000`00000000
fffffb08`e37e2838  fffffb08`e37e2980
fffffb08`e37e2840  00000000`00000000
fffffb08`e37e2848  ffff8406`076dd040
fffffb08`e37e2850  ffffc700`90eb9200
fffffb08`e37e2858  fffff800`81e407e1 nt!SwapContext+0x411
fffffb08`e37e2860  ffffc700`90ea9180
fffffb08`e37e2868  0000046d`b19bbfff
fffffb08`e37e2870  ffff8406`0ac3c080
fffffb08`e37e2878  ffffc700`90eb9200
fffffb08`e37e2880  00000000`00000000
fffffb08`e37e2888  ffff8406`09fb6100
fffffb08`e37e2890  ffff8406`0ac3c3a0
fffffb08`e37e2898  fffff800`81d2a457 nt!ExAcquirePushLockSharedEx+0xe7
fffffb08`e37e28a0  ffff8406`0ac3c080
fffffb08`e37e28a8  ffff8406`0a038e48
fffffb08`e37e28b0  ffff8406`07738240
fffffb08`e37e28b8  fffff809`5f02d867 Ntfs!NtfsCheckMappingPairs+0xe7
fffffb08`e37e28c0  00000000`18080001
fffffb08`e37e28c8  ffff8406`0a038de0
fffffb08`e37e28d0  ffff9eb2`0df2c356
fffffb08`e37e28d8  fffff800`81d59ee7 nt!CcGetVirtualAddress+0x207
fffffb08`e37e28e0  fffffb08`e37e2a68
fffffb08`e37e28e8  ffff8406`09fb6180
fffffb08`e37e28f0  fffffb08`e37e2c60
fffffb08`e37e28f8  00000000`00000000
fffffb08`e37e2900  ffffa90b`be47bd50
fffffb08`e37e2908  00000000`00000000
fffffb08`e37e2910  00000000`00000018
fffffb08`e37e2918  fffff809`5f0f7a38 Ntfs!NtfsCheckAttributeRecord+0x3a8
fffffb08`e37e2920  ffff8406`09fb6180
fffffb08`e37e2928  ffffa90b`be47bd00
fffffb08`e37e2930  fffffb08`e37e2a68
fffffb08`e37e2938  00000000`00015dbc
fffffb08`e37e2940  ffffd806`0fc14748
fffffb08`e37e2948  fffffb08`e37e2a68
fffffb08`e37e2950  ffffa90b`be47bd00
fffffb08`e37e2958  fffff809`5f0f7631 Ntfs!NtfsCheckFileRecord+0x161
fffffb08`e37e2960  ffffd806`0fc14748
fffffb08`e37e2968  ffff8406`0a3ac3c8
fffffb08`e37e2970  ffffa90b`be47bc00
fffffb08`e37e2978  fffff800`e37e2978
fffffb08`e37e2980  fffffb08`e37e2a68
fffffb08`e37e2988  fffffb08`e37e2a18
fffffb08`e37e2990  fffffb08`e37e2901
fffffb08`e37e2998  fffffb08`00000000
fffffb08`e37e29a0  ffff8406`00000000
fffffb08`e37e29a8  ffffc700`00000000
fffffb08`e37e29b0  ffffc700`90eb9200
fffffb08`e37e29b8  00000000`00000001
fffffb08`e37e29c0  fffffe42`03052228
fffffb08`e37e29c8  fffffe7f`21018290
fffffb08`e37e29d0  ffffd806`0fc14748
fffffb08`e37e29d8  00000000`00000008
fffffb08`e37e29e0  fffffb08`e37e2c68
fffffb08`e37e29e8  fffff809`5f0f74b5 Ntfs!NtfsReadMftRecord+0x465
fffffb08`e37e29f0  ffff8406`0a3ac3c8
fffffb08`e37e29f8  fffffb08`e37e2bc1
fffffb08`e37e2a00  ffff8406`09fb6180
fffffb08`e37e2a08  00000000`180bbc00
fffffb08`e37e2a10  fffffb08`e37e2c01
fffffb08`e37e2a18  fffffb08`e37e2a68
fffffb08`e37e2a20  ffffbe00`0000b070
fffffb08`e37e2a28  fffffe42`03052200
fffffb08`e37e2a30  fffffe7f`21018200
fffffb08`e37e2a38  00000000`00000000
fffffb08`e37e2a40  ffffd806`0fc14748
fffffb08`e37e2a48  00000000`180bbc00
fffffb08`e37e2a50  fffffb08`e37e2c60
fffffb08`e37e2a58  ffff8406`0a3ac3c8
fffffb08`e37e2a60  fffffb08`e37e2d30
fffffb08`e37e2a68  fffff800`00000000
fffffb08`e37e2a70  ffffc700`90f8d580
fffffb08`e37e2a78  fffff800`81f95543 nt!ExAllocatePoolWithTag+0x133
fffffb08`e37e2a80  ffffd806`0fc14748
fffffb08`e37e2a88  ffffd806`0fc14748
fffffb08`e37e2a90  fffffb08`e37e2c68
fffffb08`e37e2a98  fffff800`81d54121 nt!MiAllocateWsle+0x5e1
fffffb08`e37e2aa0  00000000`00000200
fffffb08`e37e2aa8  fffffe7f`21018290
fffffb08`e37e2ab0  00000000`00000ca0
fffffb08`e37e2ab8  00000000`00001001
fffffb08`e37e2ac0  ffffc700`91000000
fffffb08`e37e2ac8  ffff8406`0a3ac3c8
fffffb08`e37e2ad0  fffffb08`e37e2c60
fffffb08`e37e2ad8  ffff8406`09fb6180
fffffb08`e37e2ae0  ffffd806`0fc14748
fffffb08`e37e2ae8  fffff800`81d5a61a nt!MmCheckCachedPageStates+0x2ea
fffffb08`e37e2af0  fffffb08`e37e2c68
fffffb08`e37e2af8  fffff809`5f0f6dbf Ntfs!NtfsReadFileRecord+0xff
fffffb08`e37e2b00  00000000`00000000
fffffb08`e37e2b08  1a000000`c3f2a863
fffffb08`e37e2b10  00000000`00000000
fffffb08`e37e2b18  fffff800`81d6903a nt!KeAbPreAcquire+0xea
fffffb08`e37e2b20  00000000`00000000
fffffb08`e37e2b28  ffffc700`91206088
fffffb08`e37e2b30  00000000`00003618
fffffb08`e37e2b38  00000000`00003618
fffffb08`e37e2b40  00000000`00000000
fffffb08`e37e2b48  ffff8406`0f710cf0
fffffb08`e37e2b50  ffffc700`91200180
fffffb08`e37e2b58  ffff8406`0f710090
fffffb08`e37e2b60  ffff8406`0f710ca8
fffffb08`e37e2b68  fffff800`81cf3310 nt!KiTransitionSchedulingGroupGeneration+0x1a0
fffffb08`e37e2b70  ffff8406`0f710101
fffffb08`e37e2b78  fffff800`81cf3310 nt!KiTransitionSchedulingGroupGeneration+0x1a0
fffffb08`e37e2b80  ffffc700`91200180
fffffb08`e37e2b88  00000000`00000000
fffffb08`e37e2b90  ffffc700`91210200
fffffb08`e37e2b98  fffff800`81d6757a nt!KiStartThreadCycleAccumulation+0x4a
fffffb08`e37e2ba0  00000000`00000001
fffffb08`e37e2ba8  00000000`00000000
fffffb08`e37e2bb0  ffff8406`0ae20540
fffffb08`e37e2bb8  00000000`00000000
fffffb08`e37e2bc0  00000000`00000000
fffffb08`e37e2bc8  fffff800`81cf2fa7 nt!KiGroupSchedulingGenerationEnd+0xaf
fffffb08`e37e2bd0  ffffc700`91200180
fffffb08`e37e2bd8  ffff8406`0ae20540
fffffb08`e37e2be0  fffff800`8127e100
fffffb08`e37e2be8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2bf0  ffffa90b`be47bc00
fffffb08`e37e2bf8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2c00  00000000`00000000
fffffb08`e37e2c08  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2c10  00000000`00131c34
fffffb08`e37e2c18  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2c20  ffff8406`0a43b000
fffffb08`e37e2c28  ffff8406`0a43b000
fffffb08`e37e2c30  00000000`00000000
fffffb08`e37e2c38  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2c40  ffff8406`0a43bdf8
fffffb08`e37e2c48  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e2c50  ffff8406`0a43b000
fffffb08`e37e2c58  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2c60  ffff8406`0a43bdf8
fffffb08`e37e2c68  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e2c70  ffff8406`0a43b000
fffffb08`e37e2c78  fffff809`622b5ebf nvlddmkm+0x235ebf
fffffb08`e37e2c80  ffff8406`0a849000
fffffb08`e37e2c88  ffff8406`07648930
fffffb08`e37e2c90  00000000`00063801
fffffb08`e37e2c98  fffffb08`e37e3200
fffffb08`e37e2ca0  ffff8406`07648930
fffffb08`e37e2ca8  fffff809`623efbc2 nvlddmkm+0x36fbc2
fffffb08`e37e2cb0  ffff8406`0a43b000
fffffb08`e37e2cb8  00000000`00000000
fffffb08`e37e2cc0  00000000`00131c34
fffffb08`e37e2cc8  fffff809`6226d257 nvlddmkm+0x1ed257
fffffb08`e37e2cd0  ffff8406`00000020
fffffb08`e37e2cd8  fffffb08`e37e2cf0
fffffb08`e37e2ce0  00000000`00000000
fffffb08`e37e2ce8  fffff809`6226a87c nvlddmkm+0x1ea87c
fffffb08`e37e2cf0  00000000`00000000
fffffb08`e37e2cf8  ffff8406`0a43b000
fffffb08`e37e2d00  ffff8406`0a43b000
fffffb08`e37e2d08  00000000`00000000
fffffb08`e37e2d10  00000000`00000000
fffffb08`e37e2d18  fffff809`6226d149 nvlddmkm+0x1ed149
fffffb08`e37e2d20  00000000`08b51000
fffffb08`e37e2d28  00000000`00131c34
fffffb08`e37e2d30  ffff8406`0a43b000
fffffb08`e37e2d38  fffff809`6226d149 nvlddmkm+0x1ed149
fffffb08`e37e2d40  ffff8406`0a43bdf8
fffffb08`e37e2d48  00000000`00000000
fffffb08`e37e2d50  00000000`00000300
fffffb08`e37e2d58  fffff809`6226d358 nvlddmkm+0x1ed358
fffffb08`e37e2d60  00000000`00000002
fffffb08`e37e2d68  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2d70  00000000`10001009
fffffb08`e37e2d78  fffff809`6226d358 nvlddmkm+0x1ed358
fffffb08`e37e2d80  fffff1f4`f29236cf
fffffb08`e37e2d88  fffffb08`e37e2df0
fffffb08`e37e2d90  ffff8406`0a43b000
fffffb08`e37e2d98  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2da0  ffff8406`0a43b000
fffffb08`e37e2da8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2db0  00000000`0010a1c0
fffffb08`e37e2db8  fffff809`623f440e nvlddmkm+0x37440e
fffffb08`e37e2dc0  ffff8406`0a43b000
fffffb08`e37e2dc8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2dd0  00000000`0010a1c0
fffffb08`e37e2dd8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2de0  00000000`0010a1c0
fffffb08`e37e2de8  ffff8406`0a43b000
fffffb08`e37e2df0  ffff8406`0a43bdf8
fffffb08`e37e2df8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2e00  00000000`0010a1c0
fffffb08`e37e2e08  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2e10  ffff8406`0a43b000
fffffb08`e37e2e18  ffff8406`0a43b000
fffffb08`e37e2e20  00000000`00000000
fffffb08`e37e2e28  fffff809`62274f2b nvlddmkm+0x1f4f2b
fffffb08`e37e2e30  ffff8406`0a43bdf8
fffffb08`e37e2e38  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e2e40  ffff8406`0a43b000
fffffb08`e37e2e48  ffff8406`0a43b000
fffffb08`e37e2e50  00000000`00000000
fffffb08`e37e2e58  fffff809`622752d6 nvlddmkm+0x1f52d6
fffffb08`e37e2e60  ffff8406`0a43bdf8
fffffb08`e37e2e68  fffff809`622b5ebf nvlddmkm+0x235ebf
fffffb08`e37e2e70  00000000`00005a01
fffffb08`e37e2e78  ffff8406`07648930
fffffb08`e37e2e80  00000000`00000001
fffffb08`e37e2e88  00000000`00000002
fffffb08`e37e2e90  ffff8406`07648930
fffffb08`e37e2e98  fffff809`6226d257 nvlddmkm+0x1ed257
fffffb08`e37e2ea0  ffff8406`0a43b000
fffffb08`e37e2ea8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2eb0  00000000`0010a1c0
fffffb08`e37e2eb8  00000000`00000002
fffffb08`e37e2ec0  ffff8406`00000020
fffffb08`e37e2ec8  fffffb08`e37e2ee0
fffffb08`e37e2ed0  ffff8406`0a43b000
fffffb08`e37e2ed8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2ee0  00000000`00000000
fffffb08`e37e2ee8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2ef0  00000000`0010a1c0
fffffb08`e37e2ef8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2f00  ffff8406`0a43b000
fffffb08`e37e2f08  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2f10  00000000`0010a1c0
fffffb08`e37e2f18  ffff8406`0a43b000
fffffb08`e37e2f20  00000000`00625008
fffffb08`e37e2f28  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e2f30  ffff8406`0a43bdf8
fffffb08`e37e2f38  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2f40  00000000`00000000
fffffb08`e37e2f48  ffff8406`0a43b000
fffffb08`e37e2f50  00000000`0010a4cc
fffffb08`e37e2f58  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e2f60  fffffb08`e37e2ff0
fffffb08`e37e2f68  ffff8406`0a43b000
fffffb08`e37e2f70  00000000`00000000
fffffb08`e37e2f78  00000000`00000000
fffffb08`e37e2f80  ffff8406`0a43bdf8
fffffb08`e37e2f88  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e2f90  ffff8406`0a43b000
fffffb08`e37e2f98  fffff809`622752d6 nvlddmkm+0x1f52d6
fffffb08`e37e2fa0  00000000`00000000
fffffb08`e37e2fa8  ffff8406`0a43b000
fffffb08`e37e2fb0  00000000`00625008
fffffb08`e37e2fb8  fffff809`622b5ebf nvlddmkm+0x235ebf
fffffb08`e37e2fc0  ffff8406`0a476e80
fffffb08`e37e2fc8  ffff8406`07648930
fffffb08`e37e2fd0  ffff8406`0a4eaa10
fffffb08`e37e2fd8  ffff8406`0a43b000
fffffb08`e37e2fe0  ffff8406`07648930
fffffb08`e37e2fe8  fffff809`6226d257 nvlddmkm+0x1ed257
fffffb08`e37e2ff0  ffff8406`0a43b000
fffffb08`e37e2ff8  00000000`00000000
fffffb08`e37e3000  00000000`0010a4cc
fffffb08`e37e3008  fffff809`6226ff36 nvlddmkm+0x1eff36
fffffb08`e37e3010  ffff8406`00000020
fffffb08`e37e3018  fffffb08`e37e3030
fffffb08`e37e3020  00000000`00000000
fffffb08`e37e3028  fffff809`6226a87c nvlddmkm+0x1ea87c
fffffb08`e37e3030  fffff809`00000000
fffffb08`e37e3038  ffff8406`0a43b000
fffffb08`e37e3040  ffff8406`0a4eaa10
fffffb08`e37e3048  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3050  00000000`00000000
fffffb08`e37e3058  fffff809`6226d149 nvlddmkm+0x1ed149
fffffb08`e37e3060  00000000`00005a58
fffffb08`e37e3068  00000000`0010a4cc
fffffb08`e37e3070  00000000`0010a4cc
fffffb08`e37e3078  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e3080  ffff8406`0a43bdf8
fffffb08`e37e3088  ffff8406`0a43b000
fffffb08`e37e3090  00000000`00000000
fffffb08`e37e3098  fffff809`6226d358 nvlddmkm+0x1ed358
fffffb08`e37e30a0  ffff8406`0a43bdf8
fffffb08`e37e30a8  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e30b0  ffff8406`0a43b000
fffffb08`e37e30b8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e30c0  00000000`00000000
fffffb08`e37e30c8  fffff809`6236d6a2 nvlddmkm+0x2ed6a2
fffffb08`e37e30d0  ffff8406`0ef6fe20
fffffb08`e37e30d8  fffff809`622b5ebf nvlddmkm+0x235ebf
fffffb08`e37e30e0  ffff8406`0a43b001
fffffb08`e37e30e8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e30f0  00000000`ffffffff
fffffb08`e37e30f8  00000000`00000000
fffffb08`e37e3100  ffff8406`07648930
fffffb08`e37e3108  fffff809`6226d257 nvlddmkm+0x1ed257
fffffb08`e37e3110  00000000`0010a008
fffffb08`e37e3118  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e3120  00000000`0010a4cc
fffffb08`e37e3128  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3130  00000000`00000000
fffffb08`e37e3138  fffffb08`e37e3150
fffffb08`e37e3140  ffff8406`0a43bdf8
fffffb08`e37e3148  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e3150  ffff8406`0a43b000
fffffb08`e37e3158  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3160  ffff8406`0a476e80
fffffb08`e37e3168  ffff8406`0a43b000
fffffb08`e37e3170  00000000`00000160
fffffb08`e37e3178  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3180  ffff8406`0a43b000
fffffb08`e37e3188  fffff809`6226a87c nvlddmkm+0x1ea87c
fffffb08`e37e3190  00000000`00000554
fffffb08`e37e3198  fffff809`6225ae23 nvlddmkm+0x1dae23
fffffb08`e37e31a0  00000000`00000002
fffffb08`e37e31a8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e31b0  ffff8406`0a43bdf8
fffffb08`e37e31b8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e31c0  00000000`00000000
fffffb08`e37e31c8  fffff809`6225b418 nvlddmkm+0x1db418
fffffb08`e37e31d0  00000000`00000000
fffffb08`e37e31d8  fffffb08`e37e32d0
fffffb08`e37e31e0  00000000`00087345
fffffb08`e37e31e8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e31f0  00000000`00000000
fffffb08`e37e31f8  000000ec`0a43b000
fffffb08`e37e3200  00000000`0000000e
fffffb08`e37e3208  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3210  ffff8406`0a43bdf8
fffffb08`e37e3218  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e3220  ffff8406`0a43b000
fffffb08`e37e3228  00000000`00000004
fffffb08`e37e3230  ffff8406`0a43b000
fffffb08`e37e3238  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e3240  ffff8406`0a43b000
fffffb08`e37e3248  ffff8406`0a43b000
fffffb08`e37e3250  00000000`00001548
fffffb08`e37e3258  fffff800`81c17f45 hal!HalpApicRequestInterrupt+0x135
fffffb08`e37e3260  ffff8406`0a43bdf8
fffffb08`e37e3268  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e3270  00000000`00000102
fffffb08`e37e3278  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3280  00000000`00000000
fffffb08`e37e3288  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3290  fffffb08`e37e3498
fffffb08`e37e3298  fffff809`62509456 nvlddmkm+0x489456
fffffb08`e37e32a0  00000000`0000ffff
fffffb08`e37e32a8  ffff8406`0ad0e660
fffffb08`e37e32b0  00000000`00000001
fffffb08`e37e32b8  ffffc700`918f48c0
fffffb08`e37e32c0  fffffb08`e37e35b0
fffffb08`e37e32c8  fffff800`81c178bd hal!HalRequestSoftwareInterrupt+0xcd
fffffb08`e37e32d0  fffff7bc`80001908
fffffb08`e37e32d8  00000000`0000002f
fffffb08`e37e32e0  00000000`00000000
fffffb08`e37e32e8  00000000`00000007
fffffb08`e37e32f0  fffffb08`e37e3320
fffffb08`e37e32f8  fffff809`622661f7 nvlddmkm+0x1e61f7
fffffb08`e37e3300  ffffc700`91116de0
fffffb08`e37e3308  fffff800`81f95706 nt!ExAllocatePoolWithTag+0x2f6
fffffb08`e37e3310  00000000`00000000
fffffb08`e37e3318  00000000`00000000
fffffb08`e37e3320  00000001`ffffffff
fffffb08`e37e3328  fffffff6`00000002
fffffb08`e37e3330  ffff8406`0a43b000
fffffb08`e37e3338  fffff809`622661f7 nvlddmkm+0x1e61f7
fffffb08`e37e3340  00000000`00000000
fffffb08`e37e3348  00000000`00001001
fffffb08`e37e3350  ffffc700`91180000
fffffb08`e37e3358  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e3360  fffff800`82090948 nt!NonPagedPoolDescriptor+0x8
fffffb08`e37e3368  fffff809`62266d00 nvlddmkm+0x1e6d00
fffffb08`e37e3370  ffff8406`0a43b000
fffffb08`e37e3378  fffff809`00000003
fffffb08`e37e3380  ffff8406`0a43b000
fffffb08`e37e3388  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e3390  ffff8406`0a44a000
fffffb08`e37e3398  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e33a0  00000000`0010a1c4
fffffb08`e37e33a8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e33b0  ffff8406`0a43bdf8
fffffb08`e37e33b8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e33c0  00000000`0010a1c0
fffffb08`e37e33c8  fffff809`6225a568 nvlddmkm+0x1da568
fffffb08`e37e33d0  ffff8406`0a43bdf8
fffffb08`e37e33d8  fffff800`81c17f45 hal!HalpApicRequestInterrupt+0x135
fffffb08`e37e33e0  00000000`00000000
fffffb08`e37e33e8  fffff809`62274f2b nvlddmkm+0x1f4f2b
fffffb08`e37e33f0  ffff8406`0a43bdf8
fffffb08`e37e33f8  fffff809`6226b35f nvlddmkm+0x1eb35f
fffffb08`e37e3400  ffff8406`0a43b000
fffffb08`e37e3408  fffff800`81c17f45 hal!HalpApicRequestInterrupt+0x135
fffffb08`e37e3410  fffffb08`e37e3470
fffffb08`e37e3418  fffff809`622752d6 nvlddmkm+0x1f52d6
fffffb08`e37e3420  00000000`00000028
fffffb08`e37e3428  00000000`00005c00
fffffb08`e37e3430  ffff8406`07648930
fffffb08`e37e3438  ffffc700`918f48c0
fffffb08`e37e3440  fffffb08`e37e3730
fffffb08`e37e3448  fffff800`81c178bd hal!HalRequestSoftwareInterrupt+0xcd
fffffb08`e37e3450  fffff7bc`80001908
fffffb08`e37e3458  00000000`0000002f
fffffb08`e37e3460  00000000`0010a1c0
fffffb08`e37e3468  ffffc700`918f48c0
fffffb08`e37e3470  fffffb08`e37e34a0
fffffb08`e37e3478  fffff800`81c178bd hal!HalRequestSoftwareInterrupt+0xcd
fffffb08`e37e3480  fffff7bc`80001908
fffffb08`e37e3488  00000000`0000002f
fffffb08`e37e3490  00000000`0010a1c0
fffffb08`e37e3498  fffff800`81e4017f nt!KiDispatchInterrupt+0xf
fffffb08`e37e34a0  00000240`00000000
fffffb08`e37e34a8  fffff800`81e4017f nt!KiDispatchInterrupt+0xf
fffffb08`e37e34b0  ffffc700`918f48c0
fffffb08`e37e34b8  fffff800`81c184e6 hal!HalPerformEndOfInterrupt+0x16
fffffb08`e37e34c0  00000000`00000000
fffffb08`e37e34c8  fffff800`81e3fae5 nt!KiDpcInterruptBypass+0x25
fffffb08`e37e34d0  00000000`00000000
fffffb08`e37e34d8  fffff800`81e3fae5 nt!KiDpcInterruptBypass+0x25
fffffb08`e37e34e0  00000000`00000056
fffffb08`e37e34e8  fffff800`81e3a611 nt!KiChainedDispatch+0xb1
fffffb08`e37e34f0  00000000`00000000
fffffb08`e37e34f8  ffffc700`918f48c0
fffffb08`e37e3500  ffff8406`0a582730
fffffb08`e37e3508  fffff800`81e3fae5 nt!KiDpcInterruptBypass+0x25
fffffb08`e37e3510  00000000`00000000
fffffb08`e37e3518  00001f80`00e30011
fffffb08`e37e3520  ffff8406`0a849000
fffffb08`e37e3528  ffff8406`0a43b000
fffffb08`e37e3530  ffff8406`0a849000
fffffb08`e37e3538  ffff8406`0a582730
fffffb08`e37e3540  00000000`00000ed5
fffffb08`e37e3548  fffffb08`e37e36e0
fffffb08`e37e3550  fffffb08`e37e36f8
fffffb08`e37e3558  00000000`00000010
fffffb08`e37e3560  ffff8400`0008adae
fffffb08`e37e3568  fffff800`000970fe
fffffb08`e37e3570  00000240`00000000
fffffb08`e37e3578  fffff800`81e4017f nt!KiDispatchInterrupt+0xf
fffffb08`e37e3580  ffffc700`918f48c0
fffffb08`e37e3588  fffff800`81c184e6 hal!HalPerformEndOfInterrupt+0x16
fffffb08`e37e3590  00000000`00000000
fffffb08`e37e3598  00000000`00000000
fffffb08`e37e35a0  00000000`00000000
fffffb08`e37e35a8  fffff800`81e3fae5 nt!KiDpcInterruptBypass+0x25
fffffb08`e37e35b0  00000000`0000001f
fffffb08`e37e35b8  fffff800`81e3a611 nt!KiChainedDispatch+0xb1
fffffb08`e37e35c0  00000000`00000000
fffffb08`e37e35c8  ffffc700`918f48c0
fffffb08`e37e35d0  00000240`00000000
fffffb08`e37e35d8  fffff800`81e4017f nt!KiDispatchInterrupt+0xf
fffffb08`e37e35e0  ffffc700`00000000
fffffb08`e37e35e8  00001f80`00c100e6
fffffb08`e37e35f0  00000000`00000eee
fffffb08`e37e35f8  ffff8406`0a43b000
fffffb08`e37e3600  ffff8406`0ad0e660
fffffb08`e37e3608  ffff8406`0a586e50
fffffb08`e37e3610  ffff8406`0a582730
fffffb08`e37e3618  fffff809`625b6b2b nvlddmkm+0x536b2b
fffffb08`e37e3620  ffff8406`0a582730
fffffb08`e37e3628  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e3630  ffff8400`0008adae
fffffb08`e37e3638  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e3640  fffffb08`e37e3650
fffffb08`e37e3648  00000003`00000000
fffffb08`e37e3650  ffff8406`00000097
fffffb08`e37e3658  fffffb08`e37e37fc
fffffb08`e37e3660  00000000`00000056
fffffb08`e37e3668  fffff809`625b73ec nvlddmkm+0x5373ec
fffffb08`e37e3670  ffff8406`0a582730
fffffb08`e37e3678  fffff800`81c17f45 hal!HalpApicRequestInterrupt+0x135
fffffb08`e37e3680  ffff8406`0a849000
fffffb08`e37e3688  ffff8406`0a586e50
fffffb08`e37e3690  fffffb08`e37e37fc
fffffb08`e37e3698  fffff800`00097000
fffffb08`e37e36a0  ffff8406`0a582730
fffffb08`e37e36a8  fffff809`625b6b2b nvlddmkm+0x536b2b
fffffb08`e37e36b0  fffffb08`e37e37f8
fffffb08`e37e36b8  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e36c0  ffff8406`0a849000
fffffb08`e37e36c8  00000000`00000000
fffffb08`e37e36d0  ffff8406`0a586e50
fffffb08`e37e36d8  ffffc700`918f48c0
fffffb08`e37e36e0  fffffb08`e37e39d0
fffffb08`e37e36e8  fffff800`81c178bd hal!HalRequestSoftwareInterrupt+0xcd
fffffb08`e37e36f0  fffff7bc`80001908
fffffb08`e37e36f8  00000000`0000002f
fffffb08`e37e3700  00000000`000000ff
fffffb08`e37e3708  ffff8406`0a586e50
fffffb08`e37e3710  fffffb08`e37e3740
fffffb08`e37e3718  fffff809`6273039b nvlddmkm+0x6b039b
fffffb08`e37e3720  fffffb08`e37e388c
fffffb08`e37e3728  fffffb08`e37e3700
fffffb08`e37e3730  ffff8406`0a849000
fffffb08`e37e3738  ffff8406`0a43b000
fffffb08`e37e3740  00000001`ffffffff
fffffb08`e37e3748  fffffff6`00000002
fffffb08`e37e3750  00000000`00000000
fffffb08`e37e3758  fffff809`625b6b00 nvlddmkm+0x536b00
fffffb08`e37e3760  ffff8406`0a586e00
fffffb08`e37e3768  ffff8406`0ad0e660
fffffb08`e37e3770  fffffb08`e37e3a00
fffffb08`e37e3778  fffff809`626a2704 nvlddmkm+0x622704
fffffb08`e37e3780  ffff8406`0a43b000
fffffb08`e37e3788  ffff8406`0ad0e600
fffffb08`e37e3790  fffffb08`e37e3890
fffffb08`e37e3798  fffffb08`00000003
fffffb08`e37e37a0  00000000`0000001f
fffffb08`e37e37a8  fffff809`6273039b nvlddmkm+0x6b039b
fffffb08`e37e37b0  ffff8406`0a580eee
fffffb08`e37e37b8  fffffb08`e37e3888
fffffb08`e37e37c0  ffff8406`0a586e50
fffffb08`e37e37c8  ffff8406`0a43b00c
fffffb08`e37e37d0  fffffb08`e37e3888
fffffb08`e37e37d8  ffff8406`0ad0e600
fffffb08`e37e37e0  ffff8406`00000eee
fffffb08`e37e37e8  ffff8406`0a43b000
fffffb08`e37e37f0  ffff8406`0a43b000
fffffb08`e37e37f8  ffff8406`0ad0e600
fffffb08`e37e3800  fffffb08`e37e3a01
fffffb08`e37e3808  fffff809`626a2704 nvlddmkm+0x622704
fffffb08`e37e3810  ffff8406`0a582730
fffffb08`e37e3818  fffff809`625b6b2b nvlddmkm+0x536b2b
fffffb08`e37e3820  fffffb08`e37e3a10
fffffb08`e37e3828  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e3830  00000243`00000000
fffffb08`e37e3838  fffff800`81e35870 nt!HvlEndSystemInterrupt
fffffb08`e37e3840  fffffb08`e37e3850
fffffb08`e37e3848  fffff800`81c18400 hal!HalpCalculateScatterGatherListSize+0x150
fffffb08`e37e3850  ffff8406`00000097
fffffb08`e37e3858  fffffb08`e37e39fc
fffffb08`e37e3860  00000000`00000056
fffffb08`e37e3868  fffff809`625b73ec nvlddmkm+0x5373ec
fffffb08`e37e3870  ffff8406`0a582730
fffffb08`e37e3878  ffff8406`0a586e50
fffffb08`e37e3880  ffff8406`0a849000
fffffb08`e37e3888  fffff800`81c77bb0 hal!HalpKInterruptHeap+0x700
fffffb08`e37e3890  fffffb08`e37e39fc
fffffb08`e37e3898  fffff800`81f95700 nt!ExAllocatePoolWithTag+0x2f0
fffffb08`e37e38a0  ffff8406`0a849000
fffffb08`e37e38a8  ffff8406`0a43b000
fffffb08`e37e38b0  fffffb08`e37e39f8
fffffb08`e37e38b8  fffff809`626e9a9c nvlddmkm+0x669a9c
fffffb08`e37e38c0  00000000`00000000
fffffb08`e37e38c8  00000000`00000e00
fffffb08`e37e38d0  ffff8406`0a586e00
fffffb08`e37e38d8  ffff8406`0ad0e660
fffffb08`e37e38e0  fffffb08`e37e3b00
fffffb08`e37e38e8  fffff809`6226a1f4 nvlddmkm+0x1ea1f4
fffffb08`e37e38f0  ffff8406`0a43b000
fffffb08`e37e38f8  ffff8406`0ad0e600
fffffb08`e37e3900  000002a2`00000000
fffffb08`e37e3908  fffff800`81e35870 nt!HvlEndSystemInterrupt
fffffb08`e37e3910  ffffc700`918f48c0
fffffb08`e37e3918  fffff800`81c184e6 hal!HalPerformEndOfInterrupt+0x16
fffffb08`e37e3920  ffffeca9`90023beb
fffffb08`e37e3928  fffffb08`e37e39f8
fffffb08`e37e3930  00000000`000000ff
fffffb08`e37e3938  fffff800`8127e180
fffffb08`e37e3940  00000000`000000ff
fffffb08`e37e3948  fffff800`81e3c391 nt!KiIsrLinkage+0x2c0
fffffb08`e37e3950  fffff800`8127e180
fffffb08`e37e3958  ffffc700`918f48c0
fffffb08`e37e3960  ffff8406`0a43b000
fffffb08`e37e3968  ffff8406`0ad0e600
fffffb08`e37e3970  fffffb08`00000000
fffffb08`e37e3978  00001f80`006a0204
fffffb08`e37e3980  00000000`00000001
fffffb08`e37e3988  65baee8c`e4160000
fffffb08`e37e3990  fffff800`81283dc0
fffffb08`e37e3998  00000000`00000248
fffffb08`e37e39a0  00000000`00000000
fffffb08`e37e39a8  fffff780`00000014
fffffb08`e37e39b0  fffff800`819aaf80
fffffb08`e37e39b8  ffff8406`0a586e00
fffffb08`e37e39c0  00000000`00000000
fffffb08`e37e39c8  00000000`00000000
fffffb08`e37e39d0  ffff8406`00000000
fffffb08`e37e39d8  fffff809`00000000
fffffb08`e37e39e0  00000000`00000000
fffffb08`e37e39e8  00000000`00000000
fffffb08`e37e39f0  00000000`00000000
fffffb08`e37e39f8  00000000`00000000
fffffb08`e37e3a00  00000000`00000000
fffffb08`e37e3a08  00000000`00000000
fffffb08`e37e3a10  00000000`00000000
fffffb08`e37e3a18  00000000`00000000
fffffb08`e37e3a20  ffff8406`0a582730
fffffb08`e37e3a28  fffff809`625b6b2b nvlddmkm+0x536b2b
fffffb08`e37e3a30  00000000`00000000
fffffb08`e37e3a38  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e3a40  fffffb08`e37e3b80
fffffb08`e37e3a48  fffffb08`e37e3b80
fffffb08`e37e3a50  fffffb08`e37e3a60
fffffb08`e37e3a58  ffff8406`0a43b001
fffffb08`e37e3a60  ffff8406`000000a0
fffffb08`e37e3a68  fffffb08`e37e3b20
fffffb08`e37e3a70  ffff8406`0a582730
fffffb08`e37e3a78  fffff809`625b6b2b nvlddmkm+0x536b2b
fffffb08`e37e3a80  ffff8406`0a582730
fffffb08`e37e3a88  fffff809`62337564 nvlddmkm+0x2b7564
fffffb08`e37e3a90  ffff8406`0a849000
fffffb08`e37e3a98  ffff8406`0a849000
fffffb08`e37e3aa0  ffffc700`918f48c0
fffffb08`e37e3aa8  fffffb08`e37e3ba0
fffffb08`e37e3ab0  00000000`00000072
fffffb08`e37e3ab8  fffff800`81e401b8 nt!KiDispatchInterruptContinue+0x8
fffffb08`e37e3ac0  00000000`00000010
fffffb08`e37e3ac8  00000000`00000246
fffffb08`e37e3ad0  fffffb08`e37e3ae0
fffffb08`e37e3ad8  00000000`00000000
fffffb08`e37e3ae0  ffffc700`918f48c0
fffffb08`e37e3ae8  fffff800`81c184e6 hal!HalPerformEndOfInterrupt+0x16
fffffb08`e37e3af0  fffffb08`e37e3c5c
fffffb08`e37e3af8  fffff809`625b6b01 nvlddmkm+0x536b01
fffffb08`e37e3b00  00000000`00000000
fffffb08`e37e3b08  fffff800`81e3fae5 nt!KiDpcInterruptBypass+0x25
fffffb08`e37e3b10  00000000`000000ff
fffffb08`e37e3b18  fffff800`81e3a611 nt!KiChainedDispatch+0xb1
fffffb08`e37e3b20  00000000`00000000
fffffb08`e37e3b28  ffffc700`918f48c0
fffffb08`e37e3b30  ffff8406`0a586e01
fffffb08`e37e3b38  ffff8406`0ad0e660
fffffb08`e37e3b40  00000000`00000000
fffffb08`e37e3b48  00001f80`005b00ec
fffffb08`e37e3b50  0006ddd0`e37e01fa
fffffb08`e37e3b58  fffffb08`e37e3de8
fffffb08`e37e3b60  00000000`00000004
fffffb08`e37e3b68  00000000`00000195
fffffb08`e37e3b70  00000000`000001fa
fffffb08`e37e3b78  fffffb08`e37e3ab0
fffffb08`e37e3b80  fffffb08`e37e3bc0
fffffb08`e37e3b88  fffffb08`e37e3c58
fffffb08`e37e3b90  00000000`00000000
fffffb08`e37e3b98  00000000`00000000
fffffb08`e37e3ba0  000000ff`00000000
fffffb08`e37e3ba8  00000003`00000000
fffffb08`e37e3bb0  00000000`00000000
fffffb08`e37e3bb8  00000000`00000000
fffffb08`e37e3bc0  00000000`00000000
fffffb08`e37e3bc8  00000000`00000000
fffffb08`e37e3bd0  00000000`00000000
fffffb08`e37e3bd8  00000000`00000000
fffffb08`e37e3be0  00000000`00000000
fffffb08`e37e3be8  00000000`00000000
fffffb08`e37e3bf0  ffff8406`0a849000
fffffb08`e37e3bf8  00000000`00000000
fffffb08`e37e3c00  fffffb08`e37e3c20
fffffb08`e37e3c08  ffff8406`0a43b000
fffffb08`e37e3c10  fffffb08`e37e3d01
fffffb08`e37e3c18  fffff809`62730601 nvlddmkm+0x6b0601
fffffb08`e37e3c20  ffff8406`0a43b000
fffffb08`e37e3c28  00000000`00000000
fffffb08`e37e3c30  ffff8406`0a849001
fffffb08`e37e3c38  ffff8406`0a586e50
fffffb08`e37e3c40  ffff8406`0a849000
fffffb08`e37e3c48  fffff809`626d8a34 nvlddmkm+0x658a34
fffffb08`e37e3c50  00000000`00000000
fffffb08`e37e3c58  000001fa`000001fa
fffffb08`e37e3c60  000001fa`e37e3d00
fffffb08`e37e3c68  fffffb08`e37e3d20
fffffb08`e37e3c70  ffff8406`0a43b000
fffffb08`e37e3c78  ffff8406`0ad0e660
fffffb08`e37e3c80  00000000`00000072
fffffb08`e37e3c88  fffff809`62739146 nvlddmkm+0x6b9146
fffffb08`e37e3c90  00000000`00000010
fffffb08`e37e3c98  00000000`00000246
fffffb08`e37e3ca0  fffffb08`e37e3cb0
fffffb08`e37e3ca8  00000000`00000000
fffffb08`e37e3cb0  00000000`00000000
fffffb08`e37e3cb8  ffff8406`0ad0e660
fffffb08`e37e3cc0  ffff8406`0a43b000
fffffb08`e37e3cc8  fffff809`623613be nvlddmkm+0x2e13be
fffffb08`e37e3cd0  fffffb08`e37e3d00
fffffb08`e37e3cd8  fffffb08`e37e0116
fffffb08`e37e3ce0  ffff8406`0a43b000
fffffb08`e37e3ce8  fffffb08`e37e3de8
fffffb08`e37e3cf0  ffff8406`0ad0e660
fffffb08`e37e3cf8  00000000`00000000
fffffb08`e37e3d00  00000000`00000000
fffffb08`e37e3d08  fffffb08`e37e3df8
fffffb08`e37e3d10  fffffb08`e37e3e00
fffffb08`e37e3d18  fffff809`62738d2e nvlddmkm+0x6b8d2e
fffffb08`e37e3d20  0006ddd0`e37e01fa
fffffb08`e37e3d28  00000000`00000001
fffffb08`e37e3d30  fffffb08`e37e3d40
fffffb08`e37e3d38  ffff8406`0a4ca000
fffffb08`e37e3d40  ffff8406`000000ff
fffffb08`e37e3d48  fffffb08`e37e3e00
fffffb08`e37e3d50  00000000`00000000
fffffb08`e37e3d58  fffff809`625b7300 nvlddmkm+0x537300
fffffb08`e37e3d60  fffffb08`e37e3de8
fffffb08`e37e3d68  ffff8406`0a586e50
fffffb08`e37e3d70  ffff8406`0a43b000
fffffb08`e37e3d78  00000000`000000ff
fffffb08`e37e3d80  ffff8406`0a4ca000
fffffb08`e37e3d88  ffff8406`08a7d501
fffffb08`e37e3d90  ffff8406`0a586e50
fffffb08`e37e3d98  ffff8406`0a849000
fffffb08`e37e3da0  fffffb08`e37e3e18
fffffb08`e37e3da8  fffff809`626d93ca nvlddmkm+0x6593ca
fffffb08`e37e3db0  ffff8406`0a849000
fffffb08`e37e3db8  00000000`0000000c
fffffb08`e37e3dc0  ffff8406`0a586e50
fffffb08`e37e3dc8  ffff8406`0a43b0ff
fffffb08`e37e3dd0  fffffb08`e37e3df8
fffffb08`e37e3dd8  fffffb08`e37e3de8
fffffb08`e37e3de0  00000000`00000003
fffffb08`e37e3de8  0012fa66`e37e0fd2
fffffb08`e37e3df0  fffffb08`e37e3e90
fffffb08`e37e3df8  00000000`00000000
fffffb08`e37e3e00  ffffffff`00000000
fffffb08`e37e3e08  fffff1f4`f29227cf
fffffb08`e37e3e10  00043df0`0007b890
fffffb08`e37e3e18  ffff8406`0a586e50
fffffb08`e37e3e20  ffff8406`0a849000
fffffb08`e37e3e28  ffff8406`0a43b000
fffffb08`e37e3e30  ffff8406`08a7d5f4
fffffb08`e37e3e38  ffff8406`0a586e50
fffffb08`e37e3e40  fffffb08`e37e3f60
fffffb08`e37e3e48  ffff8406`0a43b000
fffffb08`e37e3e50  00000000`00000000
fffffb08`e37e3e58  fffff809`6263d4d3 nvlddmkm+0x5bd4d3
fffffb08`e37e3e60  00000000`00000001
fffffb08`e37e3e68  ffff8406`0a43b000
fffffb08`e37e3e70  ffff8406`08a7d5f4
fffffb08`e37e3e78  fffffb08`e37e3f60
fffffb08`e37e3e80  ffff8406`0a43b001
fffffb08`e37e3e88  fffffb08`e37e3e90
fffffb08`e37e3e90  000001fa`00000000
fffffb08`e37e3e98  00000000`00000000
fffffb08`e37e3ea0  fffff1f4`f292241f
fffffb08`e37e3ea8  fffff809`6263b1fd nvlddmkm+0x5bb1fd
fffffb08`e37e3eb0  00000000`00000001
fffffb08`e37e3eb8  ffff8406`0a55ecb0
fffffb08`e37e3ec0  ffff8406`0a55ef4c
fffffb08`e37e3ec8  00000000`00000000
fffffb08`e37e3ed0  ffff8406`08a7d2f0
fffffb08`e37e3ed8  fffff809`6263d0af nvlddmkm+0x5bd0af
fffffb08`e37e3ee0  ffff8406`08a7d2f0
fffffb08`e37e3ee8  00000000`00000000
fffffb08`e37e3ef0  ffff8406`0a55ef4c
fffffb08`e37e3ef8  ffff8406`0a55ecb0
fffffb08`e37e3f00  ffff8406`0a4cdf00
fffffb08`e37e3f08  fffff809`626a2704 nvlddmkm+0x622704
fffffb08`e37e3f10  ffff8406`0a4cdf30
fffffb08`e37e3f18  00043df0`00000000
fffffb08`e37e3f20  ffff8406`0a43b000
fffffb08`e37e3f28  ffff8406`0a55ef4c
fffffb08`e37e3f30  00000000`00000000
fffffb08`e37e3f38  ffff8406`0a55efec
fffffb08`e37e3f40  ffff8406`0a4ca000
fffffb08`e37e3f48  ffff8406`08a7d5f4
fffffb08`e37e3f50  ffff8406`0a55ecb0
fffffb08`e37e3f58  fffff809`6263dad3 nvlddmkm+0x5bdad3
fffffb08`e37e3f60  003dcc50`00043df0
fffffb08`e37e3f68  ffff8406`0a4ca000
fffffb08`e37e3f70  ffff8406`08a7d2c0
fffffb08`e37e3f78  ffff8406`0a4ca000
fffffb08`e37e3f80  ffff8406`0a55ef4c
fffffb08`e37e3f88  ffff8406`08a7d5f4
fffffb08`e37e3f90  ffff8406`0a55efec
fffffb08`e37e3f98  00000000`00000000
fffffb08`e37e3fa0  ffff8406`0a43b000
fffffb08`e37e3fa8  ffff8406`0a4ca000
fffffb08`e37e3fb0  ffff8406`0a43b000
fffffb08`e37e3fb8  ffff8406`0a503000
fffffb08`e37e3fc0  00000000`00000000
fffffb08`e37e3fc8  fffffb08`e37e40f8
fffffb08`e37e3fd0  ffff8406`0a503000
fffffb08`e37e3fd8  fffff809`62647ce2 nvlddmkm+0x5c7ce2
fffffb08`e37e3fe0  ffff8406`08a7d2c0
fffffb08`e37e3fe8  ffff8406`00000000
fffffb08`e37e46d0  00000000`00000000
fffffb08`e37e46d8  fffff800`81e3fa00 nt!KiDpcInterrupt+0x370
fffffb08`e37e46e0  00000000`00000001
fffffb08`e37e46e8  fffff800`81e40106 nt!KiSwapContext+0x76
fffffb08`e37e46f0  ffff8406`0aff8000
fffffb08`e37e46f8  ffffc700`918f48c0
fffffb08`e37e4700  00000000`00000000
fffffb08`e37e4708  fffff800`81e3b225 nt!KiInterruptDispatchNoLockNoEtw+0x85
fffffb08`e37e4710  00000000`00000000
fffffb08`e37e4718  fffff800`81d36d2f nt!EtwWriteEx+0xdf
fffffb08`e37e4720  00000000`00000000
Stack pointer ($csp: fffff800819b12a8) not within StackBase (fffffb08e37e5000) and StackLimit (fffffb08e37de000)
- Try changing the effective machine (.effmach x86 or .effmach amd64)
- Or just try the entire stack (!dpx fffffb08e37de000 fffffb08e37e5000 -u)
[SMBIOS Data Tables v3.0]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 4505 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
  Vendor                        American Megatrends Inc.
  BIOS Version                  3805
  BIOS Starting Address Segment f000
  BIOS Release Date             05/16/2018
  BIOS ROM Size                 1000000
  BIOS Characteristics
       07: - PCI Supported
       10: - APM Supported
       11: - Upgradeable FLASH BIOS
       12: - BIOS Shadowing Supported
       15: - CD-Boot Supported
       16: - Selectable Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       26: - Print Screen Device Supported
       27: - Keyboard Services Supported
       28: - Serial Services Supported
       29: - Printer Services Supported
       32: - BIOS Vendor Reserved
  BIOS Characteristic Extensions
       00: - ACPI Supported
       01: - USB Legacy Supported
       08: - BIOS Boot Specification Supported
       10: - Specification Reserved
       11: - Specification Reserved
  BIOS Major Revision           5
  BIOS Minor Revision           12
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
[System Information (Type 1) - Length 27 - Handle 0001h]
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
  Version                       System Version
  Serial Number                 System Serial Number
  UUID                          00000000-0000-0000-0000-000000000000
  Wakeup Type                   Power Switch
  SKUNumber                     SKU
  Family                        To be filled by O.E.M.
[BaseBoard Information (Type 2) - Length 15 - Handle 0002h]
  Manufacturer                  ASUSTeK COMPUTER INC.
  Product                       H170 PRO GAMING
  Version                       Rev X.0x
  Serial Number                 151261904700209
  Asset Tag
  Feature Flags                 09h
       167780872: - ‹ÿU‹ìƒì¡H.
3ʼnEü3ÀW‹‰Eô‰Eø…ÿu
       167780912: - ‹ÿU‹ìƒì¡H.
3ʼnEü3ÀW‹‰Eô‰Eø…ÿu
  Location                      Default string
  Chassis Handle                0003h
  Board Type                    0ah - Processor/Memory Module
  Number of Child Handles       0
[System Enclosure (Type 3) - Length 22 - Handle 0003h]
  Manufacturer                  Default string
  Chassis Type                  Desktop
  Version                       Default string
  Serial Number
  Asset Tag Number
  Bootup State                  Safe
  Power Supply State            Safe
  Thermal State                 Safe
  Security Status               None
  OEM Defined                   0
  Height                        0U
  Number of Power Cords         1
  Number of Contained Elements  0
  Contained Element Size        3
[Onboard Devices Information (Type 10) - Length 6 - Handle 0029h]
  Number of Devices             1
  01: Type                      Video [enabled]
  01: Description                  To Be Filled By O.E.M.
[OEM Strings (Type 11) - Length 5 - Handle 002ah]
  Number of Strings             8
   1                            Default string
   2                            02AI010F7EF100000000000000000000
   3                            MUCHA
   4                            Default string
   5                            FFFFFFFFFFFFF
   6                            FFFFFFFFFFFFF
   7                            FFFFFFFFFFFFF
   8                            y O.E.M.
[System Configuration Options (Type 12) - Length 5 - Handle 002bh]
[Physical Memory Array (Type 16) - Length 23 - Handle 0046h]
  Location                      03h - SystemBoard/Motherboard
  Use                           03h - System Memory
  Memory Error Correction       03h - None
  Maximum Capacity              67108864KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      4
[Memory Device (Type 17) - Length 40 - Handle 0047h]
  Physical Memory Array Handle  0046h
  Memory Error Info Handle      [Not Provided]
  Total Width                   0 bits
  Data Width                    0 bits
  Size                          [Not Populated]
  Form Factor                   02h - Unknown
  Device Set                    [None]
  Device Locator                DIMM_A1
  Bank Locator                  BANK 0
  Memory Type                   02h - Unknown
  Type Detail                   0000h -
  Speed                         0MHz
  Manufacturer                  [String Not Specified]
  Serial Number                 [String Not Specified]
  Asset Tag Number              [String Not Specified]
  Part Number                   [String Not Specified]
[Memory Device (Type 17) - Length 40 - Handle 0048h]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          8192MB
  Form Factor                   09h - DIMM
  Device Set                    [None]
  Device Locator                DIMM_A2
  Bank Locator                  BANK 1
  Memory Type                   1ah - Specification Reserved
  Type Detail                   0080h - Synchronous
  Speed                         2133MHz
  Manufacturer                  Kingston
  Serial Number
  Asset Tag Number
  Part Number                   KHX2133C14D4/8G
[Memory Device (Type 17) - Length 40 - Handle 0049h]
  Total Width                   0 bits
  Data Width                    0 bits
  Device Set                    [None]
  Device Locator                DIMM_B1
  Bank Locator                  BANK 2
  Type Detail                   0000h -
  Speed                         0MHz
[Memory Device (Type 17) - Length 40 - Handle 004ah]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          8192MB
  Device Set                    [None]
  Device Locator                DIMM_B2
  Bank Locator                  BANK 3
  Speed                         2133MHz
  Serial Number
  Asset Tag Number
[Memory Array Mapped Address (Type 19) - Length 31 - Handle 004bh]
  Starting Address              00000000h
  Ending Address                00ffffffh
  Partition Width               02
[Cache Information (Type 7) - Length 19 - Handle 004ch]
  Socket Designation            L1 Cache
  Cache Configuration           0180h - WB Enabled Int NonSocketed L1
  Maximum Cache Size            0100h - 256K
  Installed Size                0100h - 256K
  Supported SRAM Type           0020h - Synchronous
  Current SRAM Type             0020h - Synchronous
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Unified
  Associativity                 8-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 004dh]
  Socket Designation            L2 Cache
  Cache Configuration           0181h - WB Enabled Int NonSocketed L2
  Maximum Cache Size            0400h - 1024K
  Installed Size                0400h - 1024K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  Associativity                 4-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 004eh]
  Socket Designation            L3 Cache
  Cache Configuration           0182h - WB Enabled Int NonSocketed L3
  Maximum Cache Size            2000h - 8192K
  Installed Size                2000h - 8192K
  Cache Speed                   0ns
  Error Correction Type         Specification Reserved
  Associativity                 16-way Set-Associative
[Processor Information (Type 4) - Length 48 - Handle 004fh]
  Socket Designation            LGA1151
  Processor Type                Central Processor
  Processor Family              c6h - Specification Reserved
  Processor Manufacturer        Intel(R) Corporation
  Processor ID                  e3060500fffbebbf
  Processor Version             Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
  Processor Voltage             8bh - 1.1V
  External Clock                100MHz
  Max Speed                     8300MHz
  Current Speed                 3400MHz
  Status                        Enabled Populated
  Processor Upgrade             Other
  L1 Cache Handle               004ch
  L2 Cache Handle               004dh
  L3 Cache Handle               004eh
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0050h]
  Ending Address                007fffffh
  Memory Device Handle          0048h
  Mem Array Mapped Adr Handle   004bh
  Partition Row Position        [Unknown]
  Interleave Position           01
  Interleave Data Depth         02
[Memory Device Mapped Address (Type 20) - Length 35 - Handle 0051h]
  Starting Address              00800000h
  Memory Device Handle          004ah
  Interleave Position           02
Machine ID Information [From Smbios 3.0, DMIVersion 0, Size=4505]
BiosMajorRelease = 5
BiosMinorRelease = 12
BiosVendor = American Megatrends Inc.
BiosVersion = 3805
BiosReleaseDate = 05/16/2018
SystemManufacturer = System manufacturer
SystemProductName = System Product Name
SystemFamily = To be filled by O.E.M.
SystemVersion = System Version
SystemSKU = SKU
BaseBoardManufacturer = ASUSTeK COMPUTER INC.
BaseBoardProduct = H170 PRO GAMING
BaseBoardVersion = Rev X.0x
CPUID:        "Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz"
MaxSpeed:     3400
CurrentSpeed: 3408
THREAD ffff84060ae20540  Cid 0004.0358  Teb: 0000000000000000 Win32Thread: 0000000000000000 RUNNING on processor 0
Not impersonating
GetUlongFromAddress: unable to read from fffff8008204a094
Owning Process            ffff8406076c9440       Image:         System
Attached Process          N/A            Image:         N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount      1920003        Ticks: 7680
Context Switch Count      13699          IdealProcessor: 0
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime                  00:00:00.000
KernelTime                00:00:00.000
Win32 Start Address nvlddmkm (0xfffff80962196e9c)
Stack Init fffffb08e37e4c10 Current fffffb08e37e46b0
Base fffffb08e37e5000 Limit fffffb08e37de000 Call 0000000000000000
Priority 16 BasePriority 8 PriorityDecrement 0 IoPriority 2 PagePriority 5
Child-SP          RetAddr           : Args to Child                                                           : Call Site
fffff800`819b12a8 fffff800`81e87947 : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff800`820fb378 : nt!KeBugCheckEx
fffff800`819b12b0 fffff800`81d3cedd : 000002a2`48047751 fffff800`8127e180 00000000`00000246 00000000`001d6a03 : nt!KeAccumulateTicks+0x146f57
fffff800`819b1310 fffff800`81d3dfc3 : fffff780`00000340 00000000`00000000 00000000`001d6a03 00000000`00000000 : nt!KiUpdateRunTime+0x5d
fffff800`819b1360 fffff800`81c16883 : 000002a2`480427ff fffff800`819b1b31 00000000`00000000 fffff800`819b1730 : nt!KeClockInterruptNotify+0x8f3
fffff800`819b1670 fffff800`81d8bde5 : fffff800`81c77cb0 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalpTimerClockInterrupt+0x63
fffff800`819b16a0 fffff800`81e3acea : fffff800`819b17b0 fffff800`81c77cb0 fffff800`819b1b50 ffff8406`07648930 : nt!KiCallInterruptServiceRoutine+0xa5
fffff800`819b16e0 fffff800`81e3b1d7 : fffff800`819b1b00 00000000`00000000 fffff800`819b1850 fffff809`620e8c17 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea (TrapFrame @ fffff800`819b15a0)
fffff800`819b1730 fffff809`6224b141 : fffff809`6226d234 ffff8406`0a43b000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37 (TrapFrame @ fffff800`819b1730)
fffff800`819b18c8 fffff809`6226d234 : ffff8406`0a43b000 00000000`00000000 00000000`00000000 00000000`00000000 : nvlddmkm+0x1cb141
fffff800`819b18d0 ffff8406`0a43b000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000020 : nvlddmkm+0x1ed234
fffff800`819b18d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000020 fffff800`819b1910 : 0xffff8406`0a43b000
Bugcheck code 00000133
Arguments 00000000`00000001 00000000`00001e00 fffff800`820fb378 00000000`00000000
Debug session time: Sat Jul  7 12:02:55.063 2018 (UTC + 2:00)
System Uptime: 0 days 8:22:00.062
Hey Guys,
I know it's been a long time since my last post, but I wasn't in town during my semester break and now I can provide more information on my problem.
Firstly, the driver thing did not help. I tried the versions automatically installed by the Device Manager and Windows Update and I also went with an older version from NVIDIA. None of them solved the problem.
Secondly, I removed the GPU and ran the computer with just the integrated graphics for about two weeks - no BSOD. So I contacted my dealer to exchange the card. Well, I inserted the new one (it was sealed new, no second hand stuff) and a few hours later I got the next Bluescreen. I'd say we can officially strike the GPU off the list.
I tested the RAM again, but this time, I let it run overnight. 16 passes, no errors.
Now, after removing the HDD cage and puzzling a bit, I've been running the GPU in the second PCIe x16 slot (as axe0 recommended) for two days. It just crashed (memory dump View attachment 092918-18421-01.zip).
So, my question is: What is the issue here? :huh:
My only suspect left for now is the mainboard, but I'd like to know your opinion on this before I exchange a part that's totally fine again. :r1:
I appreciate your help!
Hi blackviking,
Please check the Event Trace Sessions node in Computer Management to make sure the Circular Kernel Context Logger is Running. It should look like this. If it is, there should be trace information in C:\Windows\MEMORY.DMP which could allow us to see what the kernel was doing shortly before and up to the time of the crash. We might be able to see what caused DPC processing to timeout.
MEMORY.DMP can get quite large so I'd suggest creating a zip of the file and making the zip available via a cloud drive or file sharing service and making a download link available here.
Hi cwsink,
yes, the context logger is running. Thanks for your advice, I'll upload the file to some cloud service.
In the meantime, I can provide you with this output I extracted from the dump using Windows Debugger (maybe this is what you meant?):
0: kd> !dpcs
CPU Type      KDPC       Function
 0: Normal  : 0xffff9b86634dc0e0 0xfffff807aa5c7fbc nvlddmkm
 0: Normal  : 0xffff9b86606a03f8 0xfffff807a6e42450 tcpip!TcpPeriodicTimeoutHandler
 0: Normal  : 0xffff9b86634fd660 0xfffff807a8259810 dxgkrnl!DpiFdoDpcForIsr
 0: Normal  : 0xfffff80344950f90 0xfffff803452e2840 nt!PpmPerfAction
 0: Normal  : 0xffff9b86636ac2f8 0xfffff807a6ad3d80 ndis!ndisInterruptDpc
 0: Normal  : 0xffff9b866067e1a8 0xfffff807a6d317d0 stornvme!NVMeCompletionDpcRoutine
 0: Normal  : 0xfffff80344951568 0xfffff803452a3a50 nt!KiEntropyDpcRoutine
 0: Normal  : 0xffff9b8664527010 0xfffff807a81368b0 Ndu!NduQueryStatisticsDpc
 0: Normal  : 0xffff83050a597080 0xfffff80345232420 nt!PopExecuteProcessorCallback
 0: Normal  : 0xffff9b86631f36b0 0xfffff807a6011f10 Wdf01000!FxInterrupt::_InterruptDpcThunk
 0: Normal  : 0xffff9b86637f3c38 0xfffff807ab522ea0 HDAudBus!HdaController::CodecDpc
 0: Threaded: 0xfffff803449510d8 0xfffff80345289280 nt!KiDpcWatchdog
I got the MEMORY.DMP file and I'll have a look. This blog post is what I'm basing the analysis on starting at the heading How to troubleshoot a 0x133 (1, …
I'm trying to extract ETL data from the dump file and hopefully find something useful with Windows Performance Analyzer. This episode of Defrag Tools goes into some detail about it, also.
Hmmm... unfortunately I'm not able to extract a good etl file from that MEMORY.DMP. There is something that suggests a file named:
[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]C:\Windows\system32\WDI\LogFiles\ShutdownCKCL.etl
m[/FONT][FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]ay have been created. Does that file exist on your computer?[/FONT]
Hi cwsink,
I used your link and tried to follow the instructions, extracted a 2.31 MB ETL file, but Windows Performance Analyzer complains about "Time Inversion". Overriding with /tti made WPA load the file, but there was no "Computation" field in the Graph Explorer to the left - I guess this is also what you did? Anyway, thanks for your time!
