System Configuration not sufficient privileges issue
DLOKE
Hello,
I am having system config insufficient privileges admin issue where I am the only Admin using this PC (see attached screenshot for detail). SFCFix unable to detect any issue either.
Looking forward to your help. Thanks.
CBS.zip
Hi! 🖖
In the search box you find in windows start orb, copy/paste this (unique) command:
cmd /c (dir %systemroot%\system32\msconfig.exe /q & attrib %systemroot%\system32\msconfig.exe & icacls %systemroot%\system32\msconfig.exe) > "%userprofile%\desktop\MsconfigINFO.txt"
You'll find a file named MsconfigINFO.txt on your desktop: post its content here.
Using windows 10, I get this output (yours could be different, because we don't have the same OS):
Volume in drive C is
Volume Serial Number is 1C79-6CBB
Directory of C:\Windows\system32
11/20/2010 06:24 AM 300,032 BUILTIN\Administrators msconfig.exe
1 File(s) 300,032 bytes
0 Dir(s) 28,240,986,112 bytes free
A C:\Windows\system32\msconfig.exe
C:\Windows\system32\msconfig.exe NT AUTHORITY\SYSTEM:(RX)
BUILTIN\Administrators:(F)
BUILTIN\Users:(F)
NT SERVICE\TrustedInstaller:(F)
Successfully processed 1 files; Failed processing 0 files
Hi!
GSmartControl
