SURT Issues - Repair Issues
StrangeBrew
Hello!
I've been having issues going about repairing corrupt mum and cat files via the following routes:
1. Have tried placing MSUs in %systemroot%\checksur\packages AND trying via %systemroot%\temp\checksur\servicing\packages, but the same files come up running SURT each time.
2. Tried grabbing the .cat and .mum files myself and placing them in %systemroot%\temp\checksur\servicing\packages, but logs still bring up the same thing.
Have run sfc /scannow, among other things, and I'm still unable to install Monthly rollups.
Any help would be greatly appreciated.
Thank you!
Below is the checksur.log:
Binary Version 6.1.7601.24499
2020-02-21 15:53
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\PA2E43~1.MUM Line 1:
(f) CBS Catalog Missing 0x00000002 servicing\Packages\PA2E43~1.cat
(f) CBS MUM Corrupt 0x00000000 servicing\Packages\PA6B16~1.MUM Expected file name Package_2_for_KB2965788~31bf3856ad364e35~amd64~~6.1.1.1.mum does not match the actual file name
(f) CBS Catalog Missing 0x00000002 servicing\Packages\PA6B16~1.cat
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\PA82E1~1.MUM Line 1:
(f) CBS Catalog Missing 0x00000002 servicing\Packages\PA82E1~1.cat
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\PAD62B~1.MUM Line 1:
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 264
Found 7 errors
CBS MUM Corrupt Total count: 4
CBS Catalog Missing Total count: 3
Unavailable repair files:
servicing\packages\PA2E43~1.mum
servicing\packages\PA6B16~1.mum
servicing\packages\PA82E1~1.mum
servicing\packages\PAD62B~1.mum
servicing\packages\PA2E43~1.cat
servicing\packages\PA6B16~1.cat
servicing\packages\PA82E1~1.cat
servicing\packages\PAD62B~1.cat
Hello and welcome!
GSmartControl
