[SOLVED] SURT Corruption Issue. Need Help
joe_rockstar
First time posting like this,
I am on my HP Laptop which is running Windows 7 Home Premium SP1, No Hardware Issues, Windows Update Current, Running Microsoft Security Essentials. I recently tried to create a back up image and got an error so I decided to further investigate.To Date I have Run the following:
- System File Checker Scan: No Issues or Corruptions detected.
- Windows6.1-KB947821-v34-x64_SURT.msu: Installed no Issues
- SFCFix 3.0.2.1: Detected (1) SURT Corruption Count.
SFXFix Log below:
Start time: 2020-06-06 19:58:36.323
SURT total detected corruption count: 1
Attached is my CBS Log Folder from Windows in .Zip Format for Review.
Thanking you in advance for your expertise trouble shooting and help,
joe_rockstar
,|m|
UPDATE...
I did some digging into the CBS Folder @ the CheckSUR Log and it shows which Windows Update Package - Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 SP1 x86 (KB2894844) is Corrupted. (See below) Further digging and the Update is not even for my Windows Product. I tried to Uninstall the Update with the Control Panel and got the Error, "An Error has Occurred. Not all of the Updates were successfully Uninstalled."
joe_rockstar
,|m|
Binary Version 6.1.7601.22471
Package Version 26.0
2020-06-06 16:35
(f) CBS MUM Corrupt 0x80070026 servicing\Packages\Package_2_for_KB2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum Line 1: X¯
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 1959
Found 1 errors
CBS MUM Corrupt Total count: 1
Unavailable repair files:
servicing\packages\Package_2_for_KB2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum
servicing\packages\Package_2_for_KB2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat
PeterJ,
TY for the Prompt Response. Copied SFCFix.txt below. Is there anything else I need to do? Please Advise.
joe_rockstar
,|m|
________________________________________________________________________________
Start time: 2020-06-07 15:27:11.581
Using .zip script file at C:\Users\LaPuglia\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat
Successfully took permissions for file or folder C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum
Successfully copied file C:\Users\LaPuglia\AppData\Local\niemiro\Archive\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\LaPuglia\AppData\Local\niemiro\Archive\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully restored ownership for C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat
Successfully restored permissions on C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.cat
Successfully restored ownership for C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum
Successfully restored permissions on C:\Windows\servicing\packages\package_2_for_kb2894844~31bf3856ad364e35~amd64~~6.1.1.1.mum
Finish time: 2020-06-07 15:27:14.951
Script hash: 5y5ikQKl0d7AVKCGJ2uRZTVaf6xOYq+FfVsUaxO+T8s=
Restart the computer.
If it fails, attach the zipped cbs log folder to your next reply.
Hey,
This time the Uninstall started and looked like it was going to work, but same error as before. The CBS Log Folder was too big to Upload so I shared it on my Google Drive. See the link below to download.
CBS.zip
joe_rockstar
,|m|
Remove Update Manually
    wusa /uninstall /KB:4054998
After running the Commands you instructed above, the dialogue returned says the the Update is not Installed on this Computer.... Shouldn't I be Uninstalling kb2894844? I am thinking you made a typo. I entered wusa /uninstall /KB:2894844 and got the follow error.
Installer encountered an error 0x800070490. Element not found.
joe_rockstar
,|m|
No typo, I really ment 4054998.
FRST Registry Search
  3. Select the Programs group.
  5. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Right-click on the file FRST64.exe and choose Run as administrator.
  7. Copy and paste KB4054998 into the Search box and click the Search Registry button.
  8. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
As Instructed I Opened the Control Panel made my way to the Turn Windows Features On or Off link. It brought up the Dialog Box but it is blank. It dos not show the Components Hive. Should I continue with running FBRT64? Please Advise.
joe_rockstar
,|m|
Open a elevated command prompt.
Copy and paste the following command into it, then press enter.
REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
Leave the command prompt open and perform the instructions in message #9 again.
As Instructed I OpenED a elevated command prompt, copy and pasted REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS. The Operation was completed sucessfully. I Opened the Control Panel, Clicked the Turn Windows Features On or Off link and the Dialog Box remains Blank. Again it does not show the Components Hive. Should I continue with running FBRT64? Please Advise.
joe_rockstar
,|m|
Good, then you can start with step 5 in message #9.
Peter3,
I ran everything as instructed. See attched SearchReg.txt for your Review.
joe_rockstar
,|m|
  3. Press the Fix button.
PeterJ,
And there you have it. I was successfully able to remove Windows Security Update KB2894844! TY for your assistance in this matter. Now that the issue was resolved should I Re-Run SFCFix? Also, I am still having an issue viewing my Components Hive as I mentioned previously. Can you further assist me with this matter through this Thread or should I start a New One? Please let me know.
Thank you,
joe_rockstar
,|m|
Great, one issue solved.
Attach the zipped cbs.log to your next reply so we can have a look at the other issue.
PeterJ,
See attached Fix.log.txt as requested. Was this Fixlist.txt for my Previous KB2894844 Error or my New Components Hive Error? I am asking because even though I was able to remove Windows Update KB2894844 my New CheckSUR.log shows additional errors because the KB2894844 Update was removed and is now missing... See link below to my Complete CBS Folder.
Logs.zip
Thanks,
joe_rockstar
,|m|
