Stupid high CPU usage, SFX fix encountering issues...
awesomewizard
Aug 7, 2019
2
Hope this thread is in the correct place (I'm new here).
My laptop has been running some crazy high numbers the last 3 days. Task manager lists everything below 10%, yet ROG center states that CPU memory is almost 4000 MHz for all 6 of my cores. GPU memory fluctuates from 405MHz to almost 90%. Temperature stays a steady 50-70 Celsius, yet the fans kick on high whenever I have anything more than chrome or edge open.
Ran 2 different malware programs repeatedly to no avail. CMD prompt gave me this; "Windows Resource Protection found corrupt files but was unable to fix some of them." while SFX game me this: "SFCFix version 3.0.2.1 by niemiro has encountered an unhandled exception".
The laptop just crashes if there is a video game being run, even at the menu screen. It'll make portions of the image neon green, flicker sometimes, then go to a black screen (not shut down).
I'll link some image and the CBS file.
Please help. If I have to do a factory reset I will. I have 2 YT channels that I'm trying to upkeep, and this stops everything. All advice is appreciated, THANK YOU! :-)
  • CBS.log
    CBS.log
Write your reply...
