serpinu
- Oct 23, 2019
- 1
Hello everyone, I write here hoping not to make mistakes, I have assembled a PC with these components:
Asus prime x470 pro
AMD Ryzen 7 2700x
RX580 8GB
Corsair Vegance 16GB 3200MHz
750w 80plus gold power supply.
Sabrent nvme 1tb.
Assembled the PC everything ok, however, as soon as it is known I hear an annoying noise coming from the processor heatsink I link you the video I made hoping it feels. IMG_0970.MOV
The other problem instead arose from some time, I realized it because during listening to music or watching movies, the PC had freeze that I didn't understand.
This happened with the old one so by doing various tests I decided to postpone seeing the warranty some components or the old amd ryzen 5 1600 processor
the gigabyte k3 gaming motherboard, 2133 mhz rams and even the power supply. but the problem occurs the same having reinstalled the clean system.
Doing various tests with Latencymon you notice a problem with two storport.sys and sornvme.sys drivers.
I have 3 SATA hard disks and the new Sabrent where I installed the operating system.
I can't find a solution I've already searched around a bit but nothing I asked for in another forum, I'm getting crazy ahaha.
I hope someone can help me thanks a lot in the attached I also put screen and latency report.
Annotazione-2019-10-23-010139
_
CONCLUSION
_
LatencyMon has been analyzing your system for 0:04:49 (h
ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-M604PTK
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: ASUSTeK COMPUTER INC., PRIME X470-PRO
CPU: AuthenticAMD AMD Ryzen 7 2700X Eight-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 16300 MB total
_
CPU SPEED
_
Reported CPU speed: 3693 MHz
_
_
Highest measured interrupt to process latency (µs): 1889,30
Average measured interrupt to process latency (µs): 4,281793
Highest measured interrupt to DPC latency (µs): 1886,10
Average measured interrupt to DPC latency (µs): 1,680574
_
REPORTED ISRs
_
Highest ISR routine execution time (µs): 19,877606
Highest reported total ISR routine time (%): 0,000481
Total time spent in ISRs (%) 0,000481
ISR count (execution time <250 µs): 3107
_
REPORTED DPCs
_
Highest DPC routine execution time (µs): 1893,552396
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 1,040055
Driver with highest DPC total execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 1,381337
DPC count (execution time <250 µs): 25274272
DPC count (execution time 500-999 µs): 0
DPC count (execution time 1000-1999 µs): 3
_
REPORTED HARD PAGEFAULTS
_
Total number of hard pagefaults 88
Hard pagefault count of hardest hit process: 68
Number of processes hit: 4
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 38,925620
CPU 0 ISR highest execution time (µs): 19,877606
CPU 0 ISR total execution time (s): 0,010825
CPU 0 ISR count: 1558
CPU 0 DPC highest execution time (µs): 1893,552396
CPU 0 DPC total execution time (s): 26,563624
CPU 0 DPC count: 7256207
_
CPU 1 Interrupt cycle time (s): 30,436321
CPU 1 ISR highest execution time (µs): 15,839968
CPU 1 ISR total execution time (s): 0,011432
CPU 1 ISR count: 1549
CPU 1 DPC highest execution time (µs): 170,552667
CPU 1 DPC total execution time (s): 13,162771
CPU 1 DPC count: 8956125
_
CPU 2 Interrupt cycle time (s): 13,102202
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 149,793393
CPU 2 DPC total execution time (s): 3,973042
CPU 2 DPC count: 1499600
_
CPU 3 Interrupt cycle time (s): 13,536101
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 54,172488
CPU 3 DPC total execution time (s): 4,006868
CPU 3 DPC count: 1519966
_
CPU 4 Interrupt cycle time (s): 12,961436
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 43,091525
CPU 4 DPC total execution time (s): 4,035090
CPU 4 DPC count: 1485881
_
CPU 5 Interrupt cycle time (s): 13,270214
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 34,655565
CPU 5 DPC total execution time (s): 4,123144
CPU 5 DPC count: 1519391
_
CPU 6 Interrupt cycle time (s): 12,788994
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 45,646358
CPU 6 DPC total execution time (s): 3,966338
CPU 6 DPC count: 1498656
_
CPU 7 Interrupt cycle time (s): 12,920326
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 41,568643
CPU 7 DPC total execution time (s): 4,029491
CPU 7 DPC count: 1535733
_
CPU 8 Interrupt cycle time (s): 2,103683
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 38,362578
CPU 8 DPC total execution time (s): 0,004918
CPU 8 DPC count: 1171
_
CPU 9 Interrupt cycle time (s): 1,857980
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 9,047116
CPU 9 DPC total execution time (s): 0,000009
CPU 9 DPC count: 1
_
CPU 10 Interrupt cycle time (s): 1,740750
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 32,090712
CPU 10 DPC total execution time (s): 0,001910
CPU 10 DPC count: 347
_
CPU 11 Interrupt cycle time (s): 1,785368
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 19,276469
CPU 11 DPC total execution time (s): 0,000124
CPU 11 DPC count: 28
_
CPU 12 Interrupt cycle time (s): 2,311753
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 1667,414568
CPU 12 DPC total execution time (s): 0,006227
CPU 12 DPC count: 802
_
CPU 13 Interrupt cycle time (s): 2,076336
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 1,202275
CPU 13 DPC total execution time (s): 0,000002
CPU 13 DPC count: 2
_
CPU 14 Interrupt cycle time (s): 2,357375
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 46,628216
CPU 14 DPC total execution time (s): 0,002489
CPU 14 DPC count: 324
_
CPU 15 Interrupt cycle time (s): 2,335341
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 40,877335
CPU 15 DPC total execution time (s): 0,000310
CPU 15 DPC count: 41
Asus prime x470 pro
AMD Ryzen 7 2700x
RX580 8GB
Sabrent nvme 1tb.
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
Processor groups: 1
RAM: 16300 MB total
_
CPU SPEED
_
_
_
_
REPORTED ISRs
_
_
REPORTED DPCs
_
_
_
_
PER CPU DATA
_
_
_
CPU 2 ISR count: 0
_
CPU 3 ISR count: 0
_
CPU 4 ISR count: 0
_
CPU 5 ISR count: 0
_
CPU 6 ISR count: 0
_
CPU 7 ISR count: 0
_
CPU 8 ISR count: 0
_
CPU 9 ISR count: 0
CPU 9 DPC count: 1
_
CPU 10 ISR count: 0
_
CPU 11 ISR count: 0
_
CPU 12 ISR count: 0
_
CPU 13 ISR count: 0
CPU 13 DPC count: 2
_
CPU 14 ISR count: 0
_
CPU 15 ISR count: 0
