[SOLVED] still have DISM issue (Error 0x800f081f) after running SFCFix
Hello,Sirs
i have some BSod and OS stuck these days so i run as it required and got:
Microsoft Windows [Version 10.0.17763.737]
(c) 2018 Microsoft Corporation. All rights reserved.
Verification 100% complete.
Version: 10.0.17763.1
Image Version: 10.0.17763.737
[===========================84.9%================= ]
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see Configure a Windows Repair Source.
this is SFCFix logfile
Start time: 2019-09-29 00:23:40.921
Microsoft Windows 10 Build 17763 - amd64
Finish time: 2019-09-29 00:29:48.501
but I still have Error: 0x800f081f. CBS folder included to this topic
hoping sysnative experts can help
Many thanks
Hello and welcome:
GSmartControl
no red or pink entries in in the Attributes tab. waiting for Extended Self-test to complete
Thanks.
Retrieve Components Hive
Thanks.
endSpace
this is one as required COMPONENTS.zip
maybe it can help. i have this errors in windows log since 25-Sep-19 after latest windows update
Start time: 2019-09-29 21:03:44.480
Using .zip script file at C:\Users\homepc\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5
Successfully copied file C:\Users\homepc\AppData\Local\niemiro\Archive\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normidna.nlp to C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normidna.nlp.
Successfully copied file C:\Users\homepc\AppData\Local\niemiro\Archive\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfc.nlp to C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfc.nlp.
Successfully copied file C:\Users\homepc\AppData\Local\niemiro\Archive\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfd.nlp to C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfd.nlp.
Successfully copied file C:\Users\homepc\AppData\Local\niemiro\Archive\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfkd.nlp to C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5\normnfkd.nlp.
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_mscorlib_b77a5c561934e089_4.0.15744.328_none_5f3d4dfe66ffe8d5
Finish time: 2019-09-29 21:03:44.766
Script hash: 36KpkjXYP3v9qKKRAe+M/ibSX2nlHkxK/yutqAgauBc=
and finally we have now
C:\WINDOWS\system32>DISM /Online /Cleanup-Image /RestoreHealth
[==========================100.0%==========================] The restore operation completed successfully.
THANK YOU VERY MACH,SIR(y):-)
