Hello,
I am trying to fix a audio problem on my PC for the last few weeks.
I found some very helpful threads on this website but all the fixes that i found so far didnt fix my problem.
-> Problem:
When playing some games (Forza Horizon 5 /Counterstrike) and using Youtube or Spotify at the same time my audio starts crackling really bad.
If i only play those games without any other tasks open they work fine for some time but the crackling starts after 30/40mins -> then i need to restart my PC to fix it.
I downloaded latencymon and i will attach some logs.
Right now im using voicemeeter since a friend of mine tried to help me fix the problem by extending the buffertimes (see picture) without sucess
My Specs:
CPU:I7 6700k
GPU:GTX 1080
Mainboard: Z170-A
RAM: 32GB DDR4
on thing i found with the help of Cystaldiskinfo is that one of my Harddrives has a uncorrectable sector count but i dont know if that could be the fault
Fixes i have tried:
1) Updating ALL my Drivers
2) Disabling CPU throttling in my reg
3) Setting the MSISopported option of my Audiodriver to true
4) Run a test on my RAM
I will be online the next few hours and most likely the hole day tomorrow.
thanks in advance for any tips :)
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:24:58 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-SFOOQSD
OS version: Windows 10, 10.0, version 2009, build: 19044 (x64)
Hardware: System Product Name, System manufacturer
BIOS: BIOS Date: 03/15/18 15:36:09 Ver: 05.0000C
CPU: GenuineIntel Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
Processor group size: 8
RAM: 32706 MB total
CPU SPEED
Reported CPU speed (WMI): 4008 MHz
Reported CPU speed (registry): 4008 MHz
Highest measured interrupt to process latency (µs): 3195,20
Average measured interrupt to process latency (µs): 7,754650
Highest measured interrupt to DPC latency (µs): 3189,10
Average measured interrupt to DPC latency (µs): 4,030545
REPORTED ISRs
Highest ISR routine execution time (µs): 3215,712824
Highest reported total ISR routine time (%): 0,484791
Total time spent in ISRs (%) 0,502604
ISR count (execution time <250 µs): 4812779
ISR count (execution time 500-1000 µs): 139
ISR count (execution time 2000-4000 µs): 14
REPORTED DPCs
Highest DPC routine execution time (µs): 3527,289671
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 512.95 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,443664
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 512.95 , NVIDIA Corporation
Total time spent in DPCs (%) 1,330336
DPC count (execution time <250 µs): 10641577
DPC count (execution time 500-10000 µs): 50763
DPC count (execution time 1000-2000 µs): 133
DPC count (execution time 2000-4000 µs): 375
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: explorer.exe
Total number of hard pagefaults 72913
Hard pagefault count of hardest hit process: 53996
Number of processes hit: 84
PER CPU DATA
CPU 0 Interrupt cycle time (s): 210,773078
CPU 0 ISR highest execution time (µs): 3215,712824
CPU 0 ISR total execution time (s): 58,930699
CPU 0 ISR count: 3995433
CPU 0 DPC highest execution time (µs): 3527,289671
CPU 0 DPC total execution time (s): 116,908988
CPU 0 DPC count: 8216900
CPU 1 Interrupt cycle time (s): 55,089345
CPU 1 ISR highest execution time (µs): 72,031437
CPU 1 ISR total execution time (s): 1,254239
CPU 1 ISR count: 784298
CPU 1 DPC highest execution time (µs): 3211,832834
CPU 1 DPC total execution time (s): 29,004783
CPU 1 DPC count: 1037237
CPU 2 Interrupt cycle time (s): 26,893864
CPU 2 ISR highest execution time (µs): 8,088323
CPU 2 ISR total execution time (s): 0,054088
CPU 2 ISR count: 33201
CPU 2 DPC highest execution time (µs): 3201,293164
CPU 2 DPC total execution time (s): 10,336239
CPU 2 DPC count: 790901
CPU 3 Interrupt cycle time (s): 9,533296
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 2628,013473
CPU 3 DPC total execution time (s): 0,782052
CPU 3 DPC count: 145933
CPU 4 Interrupt cycle time (s): 9,984396
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 3126,702844
CPU 4 DPC total execution time (s): 0,718844
CPU 4 DPC count: 145988
CPU 5 Interrupt cycle time (s): 9,657185
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 2833,312874
CPU 5 DPC total execution time (s): 0,627333
CPU 5 DPC count: 124886
CPU 6 Interrupt cycle time (s): 9,208691
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 174,002994
CPU 6 DPC total execution time (s): 0,606240
CPU 6 DPC count: 131859
CPU 7 Interrupt cycle time (s): 8,408567
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 1731,864022
CPU 7 DPC total execution time (s): 0,461344
CPU 7 DPC count: 99144
-> Problem:
My Specs:
CPU:I7 6700k
GPU:GTX 1080
Mainboard: Z170-A
RAM: 32GB DDR4
Fixes i have tried:
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 32706 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
