It's a bit more staggard and shorter when it happens to my PC. Sometimes it will happen in both channels, others in one then the other and then somethimes it wil start in one and end in the other, never lasting more than a second. It doesn't seem to occur when I don't have any audio. That's not to say it's not happening, of course. I have a monitor and two TVs hooked up to my GPU. This issue happens across all of them. I'm not sure if the slowdown happens everytime, either.
I have completed this list of suggestions on the advice of a Microsoft advisor with no luck.
1. Run system file checker from Start > Command prompt > Type and enter: sfc /scannow
2. Run DISM, type and enter in command prompt: DISM.exe /Online /Cleanup-image /Restorehealth
3. Run check disk, type and enter: chkdsk c: /f /r
4. Ensure that your graphics and audio drivers are updated, check the manufacturer's site and do not relay on "search for automatic updates".
5. Re-seat your RAM.
I've just reinstalled Windows 10 (kept personal files) which, of course, didn't work. I have also replaced the RAM and PSU.
I was told that it could be down to my CPU being too hot. I did a test and it is running at about 33 degrees celsius, which I think is ok.
My latest effort has had my uninstall the Nvidia audio from the Device Manager completely on the advice of someone with a similar issue. Even if this doesn't work it doesn't feel like a long term solution. I may be wrong, though. Despite me restarting the PC over a few times the Nvidia audio has not returned to the device manager's list.
I've read some pretty bleak things about this issue like it's a bug that Microsoft aren't prepared to fix and that people have done far more than me and still had no results. Any help would be much appreciated. Trust me when I say I will be donating generoulsy if this is resloved as a result of visiting this website. Cheers.
OS Version: Microsoft Windows 10 Home, 64 bit, Build 18363, Installed 20200128142003.000000+000
Processor: AMD Ryzen 5 3600X 6-Core Processor, AMD64 Family 23 Model 113 Stepping 0, CPU Count: 12
Total Physical RAM: 16 GB
Graphics Card: NVIDIA GeForce RTX 2070 SUPER
Hard Drives: C: 930 GB (829 GB Free); D: 2794 GB (649 GB Free);
Motherboard: ASUSTeK COMPUTER INC. PRIME X470-PRO, ver Rev X.0x, s/n 190144322103977
System: American Megatrends Inc., ver ALASKA - 1072009, s/n System Serial Number
Antivirus: Windows Defender, Enabled and Updated
