SFCFix stuck after at running DISM
J_Newman
Jan 26, 2021
3
I am trying to use SFCFix to fix some corruption that is preventing upgrading to a new build of Windows 10. However, SFCFix just stops with the following:
"Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see Configure a Windows Repair Source.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log"
SFCFix never creates a log due to this.
Background of the computer: The computer had a failing HDD, but the OS was imaged to a new replacement HDD. I manually deleted 3 or so corrupt files/folders in the WinSxS dir that were causing DISM to crash (based on the logged errors in CBS.log), which allowed it to get to 100%, but DISM then couldn't automatically download the new files. I found SFCFix and was hoping that it would automatically resolve the issue, but alas, I haven't been able to get it to successfully complete without stopping here. Help would be very much appreciated!
On a whim, I used cleanmgr to delete old Windows Update/installation files, and oddly enough, DISM was able to complete successfully. SFC still gave an error, but after going through CBS.log and deleting the two files it was hung up on, SFC was also able to successfully complete. I now have an upgrade to the latest windows build in progress, things are looking good thus far. I'm still not sure why SFCFix is not progressing normally, but thankfully I stumbled upon a fix that allowed DISM to work. :)
I'll post back here if the upgrade was successful.
Looks like it went through! Still not sure why SFCFix got stuck but at least things worked out. :)
