[SOLVED] SFCFix isn't able to solve a corruption problem
Andrea71
this is my first time I write a thread....I tent to read instead to write, but I' not able to solve the issue even if I read many explanations.
I've a laptop Asus N53S with W7 64 and the error 800703F1 happens when I try to update to W10.
I wasn't aware about a corruption problem until I did a scan with SFC, as stated on many threads...,and the file PINTLGB.IMD is the one with problem!
The SFCFix results is:
Start time: 2015-11-01 22:31:36.733
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.1.7601.17514_none_763763505e93084b\PINTLGB.IMD
Finish time: 2015-11-01 22:46:44.489
I also tried CheckSur but everything was correct, below the outcome:
Binary Version 6.1.7601.22471
Package Version 26.0
2015-11-01 20:45
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 1065
No errors detected
Customer Experience report successfully uploaded. Thank you for participating. For more information, see the Microsoft Customer Experience Improvement Program on the Microsoft web site.
Annex the CBS log compressed with rar
I bought this laptop 4 years ago and I still have another problem, hope this can be also solved together with the file corruption explained above.
If I restart the pc by reopening the tilted screen than sooner or later a blue screen will arrived. At the following Windows restart the mistake is described like a power management issue.
Hope that this 2 thing are connected, and to solve both with your help.
Thank You in advance
Kind regards
Andrea
Hi and welcome to Sysnative. Let's see what we can do. Please start with the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
  1. Click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
Hi BrianDrab,
thank You for your fast reply.
I followed the steps and the SFC finished the analysis stating No corruption found! Seems You did right .....Thank You.
Annex the 2 txt files generated.
I will wait for your check before trying to update to W10.
Thank You again
Kind regards
Andrea
Excellent. When you attempt your next upgrade to Windows 10 I suggest you do the following. It gives you the best chance of success.
1. Ensure that everything is unplugged from your computer except keyboard/mouse. No printers, scanners, etc.
2. Reboot your computer into a Clean Boot state by following the information at the following link.
https://support.microsoft.com/en-us/kb/929135
3. Download the Media Creation Tool and save to your desk. Run this Media Creation Tool and begin the upgrade.
Let me know how it goes.
