SFCFix Help
dripfedempire7
Hi all!
I've been trying to fix some corrupted files on my computer and I finished
a scan with SFCfix and it still can't fix 5 errors.
I was advised by the softwear to join this forum, ask for further assistance
and post the log of the scan on here for people to advise me.
This is the scan log bellow...
Start time: 2018-07-11 15:01:26.438
Microsoft Windows 7 - amd64
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7600.16385_none_f9cfc5e1446cdbd4\NlsData0416.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7600.16385_none_f9cfc5e1446cdbd4\NlsData001d.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7600.16385_none_f9cfc5e1446cdbd4\NlsData0010.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7600.16385_none_f9cfc5e1446cdbd4\NlsLexicons001d.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7600.16385_none_f9cfc5e1446cdbd4\NlsLexicons0010.dll
CBS & SFC total detected corruption count: 5
Hello and welcome to Sysnative!
SFC Scan
