I use Windows 7 Professional
This is really annoying because I can't use windows update thanks to this corruption, and therefore can't install software that needs this windows update.
This was the log file that was created afterwards:
Start time: 2020-04-09 13:43:25.554
Finish time: 2020-04-09 13:47:21.286
Download SFCFix.exe (by niemiro) and save this to your Desktop.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
SFC Scan
Click on the Start button and in the search box, type Command Prompt
When you see Command Prompt on the list, right-click on it and select Run as administrator
When command prompt opens, copy and paste the following commands into it, press enter after each
Start time: 2020-04-10 02:23:42.840
Using .zip script file at C:\Users\Hamza\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\w32uires.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\w32uires.dll to C:\Windows\WinSxS\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\w32uires.dll.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll to C:\Windows\WinSxS\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll.
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\w32uires.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7601.17514_none_905283bdc3e1d2d8\w32uires.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7601.17514_none_1478eaa56818c3c0\spwizimg.dll
Finish time: 2020-04-10 02:23:43.308
Script hash: Ndc03SrtX2ytc12avZzZWC3xfTmMlfWiuKTZdiiOwLs=
I put the cbs.txt file in a zip because it was too large to upload here
SFC Scan
Start time: 2020-04-10 03:14:27.321
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1dbc2e35304db501\notepad.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\actionqueue.dll.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\audit.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\oobeldr.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setup.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setupugc.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\W32UIRes.dll.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\windeploy.exe.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\WinLGDep.dll.mui
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\winsetup.dll.mui
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1dbc2e35304db501\notepad.exe.mui to C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1dbc2e35304db501\notepad.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\actionqueue.dll.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\actionqueue.dll.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\audit.exe.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\audit.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\oobeldr.exe.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\oobeldr.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setup.exe.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setup.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setupugc.exe.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setupugc.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\W32UIRes.dll.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\W32UIRes.dll.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\windeploy.exe.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\windeploy.exe.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\WinLGDep.dll.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\WinLGDep.dll.mui.
Successfully copied file C:\Users\Hamza\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\winsetup.dll.mui to C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\winsetup.dll.mui.
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1dbc2e35304db501\notepad.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.1.7600.16385_en-us_1dbc2e35304db501\notepad.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\actionqueue.dll.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\actionqueue.dll.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\audit.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\audit.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\oobeldr.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\oobeldr.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setup.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setup.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setupugc.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\setupugc.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\W32UIRes.dll.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\W32UIRes.dll.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\windeploy.exe.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\windeploy.exe.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\WinLGDep.dll.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\WinLGDep.dll.mui
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\winsetup.dll.mui
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-s..component.resources_31bf3856ad364e35_6.1.7600.16385_en-us_dd7048d7d357ea1b\winsetup.dll.mui
Currently storing 12 datablocks.
Finish time: 2020-04-10 03:14:27.773
Script hash: 4QGzGpNaxj9MxsH+PXZiZ7hjeXJDtL8iWqov1DJXEaA=
My laptop doesn't have drivers for Windows 10 so when I installed it everything was incredibly slow.. Then I downgraded to Windows 7 again as it's the easiest to work with. Is it possible for me to fix this without upgrading?
GSmartControl
Download the portable version of GSmartControl and save it on your Desktop;
Extract the zip file to your Desktop. Open the folder gsmartcontrol-1.1.3-win64 which should be located on your Desktop and double-click gsmartcontrol.exe to launch the program.
Identify your drive in the list (if recognized by the tool), and hover your mouse over it.
You should see something called: SMART status. It will either read: Enabled, in which case you should do the following:
Double-click on it to bring up its window (usually you'll find your drive by its size or its brand name);
Go to the Self-Tests tab, then select Extended Self-test in the Test type drop-down list and click on Execute (this test can take a few hours to complete);
Once the test is over, the results will be displayed at the bottom of the window. Please copy and paste these results in your next reply or take a screenshot;
Also, go in the Attributes tab and if you have any entries highlighted in red or pink, take a screenshot of the GSmartControl window and attach it in your next reply;
Please note: If the SMART Status reads: Unsupported, stop and let me know.
Unfortunately, your drive has begun to fail and needs to be replaced with a new one. You can't clone this installation of Windows onto a new drive as this one has been damaged by the bad drive.
